- which shocks/struts to use??
- INSTALLED EIBACH PRO KIT w pics
- Anybody winter drive Lowering Springs?
- The Pedders look
- Weight limit
- Torque steer
- Suspension Squeak In Cold Weather Fix?
- Inspect my brakes please....
- Reuse of bumpstops with Cobalt SS coils
- Also looking to replace brakes..
- Stance coilovers
- Proline Eibach and Turbo Tech Racing bar: is lower control bushing preloading needed?
- Brake line fitting question
- We Now Carry Pedders @ Turbo Tech Racing!
- Goldlines will be here today!!!
- Leveling SS
- Firestone Lifetime Alignment
- lowering springs
- another spring ?
- GM HHR Factory Suspension Parts Question - experts?
- Lowering the SS
- Koni Struts! great, but lota work!
- Wheel Bearings preload
- Need Some Quick info on Camber
- Snow Traction
- Goldline springs
- Slotted or smooth rotors
- shocks
- Brake update
- Braking
- ES or Prothane bushing sets?
- HHR SS aftermarket springs...
- Lowering my HHR what do I need?
- Rear Brake Calibers
- Wheels 20 inch
- soltice/skye wheels
- Putting in a straight axle and tri4link
- Factory alignment OFF SPEC?
- Sway bars on my 2009 HHR Panel
- ST lowering springs
- Cold weather sqeaking is back...
- New Product @ TTR - Turbo Tech Racing Steering Rack Spacers!
- Stabilizer links
- Can't find it.....Strut GM Part Numbers
- Steering and acceleration
- rear shocks
- Identifying 08/09 Cobalt SS/TC springs ?
- SS springs question
- SS Front suspension on a 2LT
- Lowering Springs
- Base versus 2LT struts - Firsthand experience comparison??
- Front Brake Noise
- TTR Rear Sway Bar Installation 101
- will H&R Sport springs for saab 9.3 fit on my 06 hhr
- Question about gen 1 goldlines
- Springs from a HHR SS
- Lowering on stock struts???
- Snow tire/wheel setup question-
- Shock brand names
- Help with springs!!!
- front brake pads
- alignment & Eibach's ?
- your choices for suspension work
- Wheel Studs
- Anti sway bars
- Monroe Brake Pads
- eibach pro plus kit
- Sport Tuned means what exactly?
- Cobalt SS Springs - '08-'09 versus '06-'07
- Just got one 09 HHR LT
- Wheel bearing replacement
- duralast rotors
- how low can i drop on 20" rims
- Cobalt SS Springs on HHR? Worth it?
- Performance Brakes for Ls & LT HHR
- Monroe Shocks?
- Front brake help
- Brake Rotor replacement
- new for hhr?
- Will improved suspension help raise tongue weight?
- How low can you go?
- Trim bump stop> goldline springs?
- Eibach vs. Goldline Need Pics!!!
- Ground Force Rear Leveling Springs
- Need help
- Fe5 front struts?
- Emergency Brake Didn't Release
- Need help with ............
- Making Shocks
- front brakes 07' HHR
- gold-line? Wheels?
- help with pedders rear springs.
- Missing Bolt
- Progress Technology Sway-Bar
- Front Goldline
- front end noise
- Aftermarket brakes
- New shocks installed
- Front struts on the way.......Finally
- weird sound from passenger suspension..pics included
- springs
- lowering spring
- Goldlines
- Cobalt rear brakes on HHR
- raising the rear.
- Gold Line spring install question-
- finally,nice coilovers
- ok one more sway bar question...
- sway bar link
- do you need a rear shim to drop on gold lines???
- KYB Struts
- Time Attack rear anti-roll bars!!!!
- Lowering hhr
- Gold Line Gen 2
- Rear Discs?
- can i drop on stock struts?
- sway bar question for those who have eibach or goldlines springs
- struts
- hey guys i want to drop my hhr?
- Real rotor problems
- Suspension Techniques Anti Sway Bar Part Numbers
- Coil spring lowering kit?
- Question Eibach Pro kit
- Looking 4 HHR SS part #'s
- Torque Specs? (Wheel bearing bolt, spindle nut)
- I got my useage out of my stock brakes
- 20" Wheels
- Lower or just Level?
- Cobalt rims
- Struts
- Brake conversion.
- Aftermarket Brake Rotor Recommendations Wanted
- air ride done... almost
- HHR SS Susupension & Brakes
- thinking about heating the springs???
- Gold-line Leveling
- Gold-Line ride quality
- struts and anny other prob
- Eibach Pro kit
- Tire Pressures
- Goldline springs question-origin/weight
- getting lower front bags almost done
- 06 cobalt ss front caliper
- 08 Panel with eibach kit And 18's = GTG
- suspension noise
- Suggestion on lowering
- Struts with eibach lowing springs
- update on airbags
- Lowering Springs/Kits for the SS
- Cold weather brings cool noises!
- Cooked HHR SS Brakes?
- Non dusty pads?
- Progress Technology Rear Anti-Sway Bar
- airbags on back finally finshed
- New rotors not rotoring
- Before / after pics with Cobalt SS Springs installed
- Wheel Spacers
- Help! Eibach or Cobat SS springs
- Ordered Goldlines - how much lower on an SS?
- 83K mi New Struts and Shocks
- Cobalt SS springs?
- TCE Plus-2 Brake Package for the SS! (56K WARNING!)
- coil springs boom (noisy reverb)
- Rears breaks locked up
- Cobalt SS Struts and springs
- Allignment
- Eibach Sportline for HHR??
- Alignment kit with Lowering
- goldline Gen 2 springs
- Just out of curiousity...
- Just want to level my Panel
- Cons of Lowering???
- Alignment situation
- Difference in Suspension packages?
- Gold Line ride height?
- Which Springs?
- Shorter rear shocks
- disc brakes for the rear
- Torque Specs for Brake Caliper Bolts
- springs on the hhr ss
- Wheel Studs
- Has any body installed a Eibach rear swaybar ?
- Lowering with GM parts
- Warped Rotors
- 07 Panel leveled
- 2 questions - springs and brakes?
- is the cobalt front rotors the same as the hhr and if so why are they cheaper to buy?
- Factory Warrenty after lowering?
- bagged hhr?
- Rattling noise with GoldLine Leveling Springs?
- where to get goldlines
- Opinion Needed
- my official post
- Brake Rotor Upgrade How to (56k beware)
- where do I put these?
- rear helpers
- Ummmmmmm
- Yeah! EBC brakes ordered!
- gettin' slammed in SWFL
- Can't find EBC Rotors GD7375
- progressive or suspension techniques
- Lift it!
- Heavy Jobs With A Lowered HHR?
- Aftermarket Brakes
- Coilovers?
- Rides better with Koni's
- brake pedal too soft
- goldline leveling springs...
- Low-SKOOL
- I'm Lowered!!!
- How to install lowering springs!!!
- regarding brake issues on the HHR
- Another SoCal HHR to Praise The Lowered
- Looking for Brake replacement help
- Aftermarket rear shock?
- Springs
- Warning for people with leveling springs
- Bump Stops!
- Goldline squeekin remedies?
- Replacement brake rotors.
- Lowering the cars tomorrow!
- rear disc brake kits?
- Lowered using Eibach Pro Kit
- question
- Leveling question?
- Aftermarket Struts
- Lowering Kits - what's best?
- ground force leveling springs
- Camber Plates for the HHR
- Finally got it lowered
- For those with 'bag setups--
- $45 lowering springs?
- Touring vs Sport Ride
- HHR SS Suspension
- Ride Quality With Eibach Sports
- lowering...
- 08 HHR - Right Front Suspension Pics
- Camber Kit Needed ??
- Lowering coils means alignment after?
- lowering...
- Not For The Weekend Tweakers
- HHR Springs Group Buy!
- Guess who is getting a Anti Sway bar for Xmas?!
- Brakes? (again)
- hhrboutique group buy on springs
- gold lines, eibach, or ?
- Noise in front end on Panel??
- Drilled/slotted brakes???
- Sway Bar install?
