- 2008 HHR Brake N Shake
- Front End Knock that goes away in 15-20 min.
- Lower Control Arm - Vertical mount bushing replacement
- Sway Bar Bushing Confusion
- Independent Rear Suspension
- Brake pulsating
- Ss fe5 struts and springs
- Brake pad material
- Can ABS Wheel Hub Replace Non-ABS?
- Eibach pro kit
- KYB Struts/Eibach Springs Installed, Veritcal Play in Passenger Side Strut Shaft
- How to Replace the Master Brake Cylinder on 2006 HHR
- Front rotor dimensions
- clicking sound when brake pedal depressed after brake job?
- Need help with shorter struts.
- Advice
- Brake fix tsb 09-05-22-001a
- Intermediate Steering Column Shaft Issue.
- Need Advice buying new control arms.
- HHR Lift
- Do I already have a rear sway bar?
- Struts for my 2008 hhr
- Help- 2010 rear brake shoe replacement
- Brake shake fix
- Repainting Repainting Brembo's and installing on SS. PICTURES!
- Installing 2008 Cobalt SS Brembo kit on my 09 HHR SS
- ABS module reprograming
- Suspension Questions
- Upgrading Sad Brakes and Suspension on '07 LT
- Removing EBCM harness from EBCM
- ABS light and Skid control Light
- Need Help. Dreaded "Clunk" Already Replaced bushings AND links...
- Brake Lights: Only 3rd Brake Light Lighting Up
- Sway bar end links review
- Sway bar lateral lock
- new cross drilled rotor install
- ESC Light after Changing Brake pads and Rotor
- Soft brake pedal when car is on
- Can I use Eibach Sportline lowering springs on my HHR LS?
- Rear Hub assembly w/abs
- Recommend Springs? 18" Solstice wheels + tow
- trying to upgrade to SS brakes
- ABS & Traction Light warning lights
- Air bag suspension
- When did you replace sway bar bushings and links
- Upgrade to SS brake rotors
- Dreaded clunk is back
- Warped OEM rotors after 6k miles
- Just when do these brake shoes wear out?
- Caliper rebuild kit
- Steering Column noise
- Rear suspension question
- Suspension work
- Pedders USA
- Steering and suspension
- SR4057 kyb
- Bad strut
- Which are OEM Lower Control Arms
- Shock Check ???
- unstable when taking angled road
- front sway bar size
- front end noise
- Power Steering doesn't work
- Grinding rear drum
- Any tips for squeezing e-brake cable barrel back into cantilever?
- Front end rehab 2009 HHR Panel
- HHR SS lowering springs still available in 2015
- Brake Shimmy
- Lower control arm busuings
- Aftermarket Sway Bar Links
- shudder on high speed braking
- Front brake caliper bolts on 2010 1LT
- 2010 SS Whistle at startup and after braking
- suspension
- Brake pedal soft and differs
- HHR SS Front Rotors warped. Need Help!
- Suspension difference question
- drums opinion
- Lowered HHR with Pictures
- Drum to Disc replacement
- Cryogenically treated rotors
- Upgrading lower control arms!!!
- Rear Coil Springs from Moog Replacement for CobaltSS
- non brembo SS brake upgrade
- new to forum
- hhr ss brembo swap
- 97K Miles on original rear drum brakes
- HHR Rotor Problems
- front rotors and brakes
- Cobalt springs both front and rear
- Brake Rotor Run Out Spec
- Smooth Suspension Suggestions (Cakes on Board)
- Centric 127.62095 VS EBC GD7275 Rotor
- Intermittent vibration while driving and braking
- Suspension interchangeability!!
- Brake upgrade to SS brakes ....
- Shudder front end after 10 mins driving
- Front control arm bushing?
- Caliper pins
- 2010 HHR, just lowered and now a clunking sound.
- Quick Strut question
- Full Contact Camber Shim
- Lower just the rear of your HHR
- Upgrading Suspension
- Sway/track bar link length?
- Timken front hubs. Best price
- Another cause of suspension clunk??
- ABS & Brake Light On
- Adding brembo brakes and using 16" stock wheels
- tire/wheels not right after A arms
- Bushings
- Rear hub attachment torque
- Rock Auto??
- Popping Noise
- Cruze coilovers
- Fabricating Rear Air Suspension
- Creaking like an old door!
- What a pain.....
- rear suspension upgrade
- Raise an HHR for ground clearance
- Energy Suspension sway bar bushing question
- Hub Assemblies Available On Ebay
- servicing rear drum brake
- well struts are shot
- Suspension, brakes, and hubs question.
- Rattle in Rear - Can't pinpoint it
- a arms
- HHR SS coil springs from O'Reilly's
- Grinding noise from brakes?
- rusty brakes
- warped rotors again
- tired of clunking and rattleing
- What brand spring to lower rear of an SS
- Safe to remove Power Steering Motor and drive?
- Adjusting Brakes
- control arm question
- Anyone with coilovers and 16" wheels?
- jack it up
- Free at last
- Goldline springs
- MAX rotors and pads
- Anyone purchase these brakes for their SS?
- Suspension Upgrade and Towing question
- Lower control arms
- Sway bar hits lower control arm?
- Lower control arm frame bolt says no
- Need help with brakes
- Brembo caliper pins
- Installing some BC Coilovers on my HHR SS
- Rear shocks don't fint
- sway bar connecting rod bolts
- Sway bar question...
- zz performance big brake kit
- air bags
- Anyone have experience with the electronic steering?
- hhr/cobalt lowering springs
- Needing new hub bearing assembly for 2008 HHR LS
- need new rotors
- 09 clunking noise
- Wheel Hub Assemblies
- "inner tie rod" how to replace help?
- hub replacement 09
- Ride Height Of HHR and Panel LS
- hhr front strut replacement
- Sway bar bushings
- Self Adjuster Repair Kit?
- New grinding
- Clanking noise from front wheel area
- 172179 Quick Struts not mounting.
- lower control arm FRONT bushing
- hey I need help
- Sway bar rubbing on lower control arm
- Questions on Suspension, ride and height
- Bleeding ABS brakes. Just need to verify something.
- coil spring replacement
- Rough ride with Gold-Line springs and TTR swaybar; need advice
- Lowering Question
- Vibration front passenger side
- Ksport Coilovers
- Seriously considering buying Sway Bar, need thoughts
- Installed Ksport Coilovers...One Week Review
- Question for the Brembo upgrade guys.
- Panel on airbags
- Replacement struts
- Brake question
- Brake Question - Wear Indicators?
- LCA suggestions and sway bushings
- Service Traction light on
- performance struts and springs
- HHR Electic steering wiring diagram
- SS Struts & shocks???
- Part numbers for Cobalt SS rear springs
- air ride for an HHR
- cobalt spring validation
- Need new power steering motor
- FE1 to FE5
- Softer ride for SS
- throwing out alignments
- Famous Clunk.. Suspesion question.
- strut mounts
- eibach on SS
- LS/LT brakes upgraded to SS 11.65 inch brakes was it worth it?
- how can i raise front end
- Improving 2LT brakes?
- Severe inside tire wear
- Lowest springs I can get without damaging anything
- For the guys repainting their Brembos.
- goldline springs
- Need Help Replacing SS FE5 suspension
- Pedders eXtreme XA coilovers review
- mounting rear discs...help!
- Sway bar links
- Will all 4 SS/SC Springs level me out
- HHR LT Brake System Type
- Pedders springs and coil binding
- brake warning light
- Brembo up-grade, easy as 1,2,3
- Brake upgrade
- Time to make the donuts.
- HHR SS calipers
- Lower Control Arm Bolt Spins!!
- Best Suspension Upgrade EVER
- Cobalt SS TC/SC springs on a hhr SS?
- Pics of HHRs with Wheel Spacers!
- Upgrade suspension
- Whistling Noise When Braking
- Airbag suspension systems
- Wearever Platinum Ceramic Brake Pads
- Replacing rack and pinion
- Alignment after struts?
- Rear Drum Noises (Please HELP!)
- Self Check Alignment Article
- B&G vs. H&R Lowering Springs
- Suggestions for Strut Replacement HHR SS
- Cutting rear springs to lower??
- replacing tie rod end links
- FYI on the Brembo's for the upgrade guys
- KYB Gas-a-Just Shocks?
- quick strut noise
- replacing lower control arms/bushings
- HHR electric power steering
- Drum to disc rear
- Suspension
- Suspension rattle??
- HHR brake and warning light issues
- What else do I need? (Parts # included)
- Spring settling timeframe
- Does the HHR have FE2 or FE3 suspension?
- e-brake
