- Abs Braking
- Need a GOOD Ground under the hood...
- GM Protection Plan
- Front lower control arm
- Shifter problems
- Almost 1 Year and no problems...
- No Door Ajar warning
- State of Michigan and the Lemon Law
- Check Engine Light
- Dont let this happen to you....
- Clink
- My Car Died Friday
- Radio and Engine problem
- Has anyone else seen this?
- Shift Light Question...
- Air conditioner problem of a different color
- HHR Rattling sound when driving over uneven surfaces
- Steering Wheel Rubbing Sound?
- gauges stuck
- HHR Wanders to the left
- Pressurized Gas Tank
- Update: Outside air temp read problem
- pulls to right on acceleration
- paint chip
- 1 speed fan
- Air bag warning light
- How to get Crayon out of the back seat??
- The window buttons...
- Ignition Jamming
- 40lb Rock vs My Oil Pan
- Sunroof squeaks
- Gas sloshing around!
- whistling noise
- Keyless Remote FOB
- Interior Air Filter
- Noise in shifter?
- Accessory Power Outlets and Aux Audio
- Delayed start after having battery unhooked
- Remote Start Battery
- Key Sticks
- Driver seat !
- Exterior black rubber window trim..looks old already?
- "Alarm"-ing problem
- Maybe fuses......
- Radio with XM, but no XM
- Engine Noise
- Alarm goes off with Remote Start
- Recirculating system is loud!
- Starting Problem
- Squeeky/Groaning Sunroof?
- Getting New Carpet!
- At The Dealer for 2 weeks
- A/C Recirculation & Wiper Blades...
- Most Recalled Vehicles: 2006
- A/C problem or not?
- Factory wiper blades
- slight whistle noise
- 5 speed rolls away............
- Oil change?
- Engine Compartment "Heat" Really "Hot"
- Scary..Car died while driving 65mph!!
- No Power Steering. Read Before You Jump Start
- Cylinder Head Replacement?
- Tire Pressure Warning!!!
- popping noise?
- Roof Side Rails/Cross Bars
- Brake Shudder Update
- I'm Sad
- Speed Control Volume
- Overheating and Liquid Slush Sound
- Overheating - 2nd time
- temp. gauge stops working
- Displaying Date on Radio
- engine mis-fire when starting
- Fuses Keep Blowing
- Engine light keep's coming on.
- After shutdown Click and Liquid sounds
- New Owners Nightmare
- Check the retainer that holds the cargo cover in place.
- No sound from radio!?!!?
- WHERE'S The COLD FILL line
- New HHR Owner- I have a few ?'s!!
- Wheel Blemish
- Won't start after amp installed
- Outside Thermometer
- Interm. Hard Starting
- Drivers door seal
- Window Seals
- Warranty & Magnuson Moss Warranty Act
- Squeeky steering wheel
- Front licence plate bracket
- MY Rant !!!!!
- A/C Went Out...Completely.
- Lighting / Control Issues
- New Section: "Problems/Service Issues" ...help us
- hvac blower noise
- how long for decals!?!!?!
- Downhill (bad)brakes
- Oil Life
- Turn Signal Clicker Malfunction...
- Turn Signal lever malfunction
- front bumper removal
- Overheating
- engine mis-fire
- Brake Dust ??
- Paint Issues Spring Edition Only !
- Air Condition Compressor
- Strange sound
- How do you fix a squeeky drivers seat?
- Found a minor issue
- Mods Can Void Warranty
- Old Recall and TSB Number post
- Tsb # 06-06-03-003
- Roof Rack
- New HHR, and problems a-plenty
- sunroof leak
- Wheel Hop
- Pop goes the radio ? ? ?
- Etching of paint on rocker panel and rear door rock guard
- Water leaks?
- Fuse Blows When Jumpstarting?
- Rattle
- GM Service site
- Rear Hatch TSB - Info For Your Dealer
- 1st Oil Change
- Underhood Fuses Tip
