- Normal oil loss?? How much??
- New member, just a few quick questions
- another clunk noise for my fellow members to help me with!
- Shifter Knob Problems.
- How to remove interior rear dome light/switch
- Shifter button is not pressed
- Code PO300 & PO171....?
- Check engine light issue
- AC intermittant
- Driver's Door Center Hinge (Link)
- Scratches on my Window Tint
- help power steering problem
- Airbag service light
- security horn disable
- Has anyone ever had trouble after Seafoam?
- Broken driver side door handle
- Burning Hair!?
- Sunroof
- Traction Control
- Need some help w/the ac not working properly!
- Help!!
- no brake lights
- transmission lines
- 2.4L Fuel Injectors by Borg Warner
- Fuse for warning chime?
- radio dead tpms sensors dead
- HHR suspesion fix on Saturn
- Sunroof control panel
- Need help regarding AC and temp. gage.
- Rear Bumper Removal....Interesting...
- Tire noise?
- Window Washers Out
- How do you get the trouble codes?
- pretty fed up
- TPMS problems.
- Breaking News! One of my HHR's actually broke.
- AC Fan is clicking
- Automatic transmission issue
- Problems With Rear Windows..Is it the Switch??
- need wiring diagram for 08 power steering. thanx
- Power Steeering fuse under hood keeps blowing
- strange steering noise
- Strange problems
- Engine Light and T/C Light...
- Alignment performed, car still pulls left.
- 2008-2009 Special Coverage for Ignition Cylinder
- 2009 & 2010 Models with Ignition Lock Cylinder Issue!!!
- Lost my brake fluid
- New Buzzing Sound with Acceleration
- Rear wiper switch
- Something strange
- cel 2006 lt
- "service airbag" after jump start
- door thing
- Power Steering Issue.....
- Which heater hose is the inlet hose?
- key fob programming
- Service Traction light???
- Brake judder & swaybar looseness> an ah ha moment
- Brakes and clunking noise
- Engine light & T/C light on, why?
- P0300 was hell to fix
- A New One On Me!
- Heater Blower/Fan
- Broken Plastic clips
- engine or trany problem
- Braking at 60+ mph
- Oil Pan Stuck
- Back Up Lights
- Remote Start
- Coolant resevoir
- Speed sensor wiring ABS
- Interior water leak/no a/c
- Transmission HELP !!!
- P1174
- Hard shifting/staying in lower gears when cold?
- Air Intake Hose GM #15865168
- March HHR of the month
- Camshaft "Parking" Info
- Drivers door seems to have slid forward
- Gas in the oil?
- flex pipe
- Popping noise out of exhaust
- At gm dealer having alignment done and confused
- Shifter Repair
- Key stuck and SS still running.
- Transmission problems...
- Gurgle gurgle?
- Something missing ?
- Great, a new problem. TC light, hard shifting, torque converter stays locked.
- Dead electrical and stuck key
- Temp gauge not registering
- Pennzoil platinum full synthetic?
- Electricial Problem
- Crank sensor
- Another Ignition Switch Bad 5 Speed
- Changed transmission
- CMP solenoids for 2009 with 2.2L
- Strange Beeping or Chirping at Start Up
- Radio Issues - Need Input
- Unexpected ESC SVRC Messages
- cadolitic converter
- Radiator replacement
- HELP! Key Out Battery Disconnected Engine Still Running
- check engine light coming on
- Seat Height Adjustment
- racked lower rocker panel
- Clear Coat Issues
- HHR rattle at start up fixed
- Service ESC ?
- Hub / Bearing Assembly Cost Difference (abs vs. non-abs)
- Panel lights won't dim
- Wind noise from a closed moon roof..
- Engine continues running when key switched off
- Doors lock and unlock sitting there
- Dash clicking
- 2007 hhr P0496 and P0171
- Dielectric Grease
- Mystery Wire
- Mystery Rattle
- Flywheel port cover?
- Has anyone fixed their front end squeek?
- Remote Mirror switch is not working
- Weird idling problems
- Woke up battery dead completely?
- Ignition switch
- Help key stuck in ignition 09 SS manual
- horn issues
- Dtc p0700 & u0073
- Fueling issue
- Key not opening door lock
- Thong noise when turning steering wheel...help
- Vibration
- ABS and Trac control light
- Dex-Cool
- 2008 Base (LS) Consuming/Loosing Coolant
- Hoping new info on lowering driver seat.
- rear door panel
- Windshield washer sprayer question
- Couldn't Get Out Of Park
- Power Door Lock Failure/Clicking Sound In Center Console
- NEW battery; NO PS!
- code P0451
- Can't unlock 2006 HHR with a dead battery
- Adding remote start
- Look what I found loose under the hood..
- Check Engine Light On
- Keyless entry not working and dashes on TPMS
- Mystery Code: B2AAA
- 2011 AC/Heat fan question
- parking brake alarm disconnect
- Door locks
- O2 Sensor Locations
- 2006 Chevrolet HHR AC- Heater problems
- Sticking Transmission?
- Clarification Needed/Desired on a P0011 Code
- P0806
- Steering column rattle when breaking
- Steering pulls left
- I thought it could never happen to me.?.!
- What all does the BCM control? What are the symptoms of a bad one?
- Passenger door not opening from inside
- head light replacement
- TPS Question
- Disappearing coolant
- rear wiper cap
- Circle Bubbles or rust under pait on roof
- air flow sensor
- No visual or audible warnings on dashboard?
- new here engine removal
- Remote start only works with one key fob
- 06 Speakers
- Radio loses station memory
- Reduced Engine Power, now will not run.
- Annoying check engine light
- Died On Interstate
- Bad radio reception
- 2010 HHR 1LT service esc message
- 2010 HHR, Fuel Air Meter or code P013A
- Thump sound when turning right
- Thermostat
- 2010 Chevy hhr airbag light on
- low speed clunk;steering shakes on braking
- Traffic light prism?
- Digital gauge not as responsive
- Transmission stuck
- Replace Front Power Outlet?
- Odometer not working in new cluster
- Check engine light & cold weather
- Strange noise
- Rear Window Washer Leak
- P0102 and P2138 codes...?
- Brake pedal relay click??
- Check Engine, idling at low RPM, low power.
- Constant DIC Message
- SPANISH...Help wanted!!! t/c & checck engine light
- Transmission Slow to engage
- Help No Hi-Beams
- Knock sensor?
- Another P0449 Issue Needing Assistance
- rear doors
- I finally found rattle in the dash.....help
- How do you remove the A/C vents?
- $600 Control Arm replacement?!
- Need Help with a rattle
- 08 Transmission Problems
- Wheel bearing issue?
- engine help
- Front-end whine
- Need help 3rd brakelight LEDS
- 2010 water leak
- Clutch warranty?
- 2011 HHR drivers airbag replacement question
- half shaft removal
- New shifter problem?
- HHR Imobilized...HELP HELP HELP
- Well that's one way to fix it!
- Dome light reinstall?
- Burning Through Headlights
- Reocurring HHR Issues - Cam Sensor, Rough Idle, Shifting/Power Issues, Burning Smell
- Call Chevrolet and report your sticking ignition key
- theres a loose bracket jiggling around under my hood.
- Has anyone replaced ball joints
- List of Common Problems/Questions and related links
- How do you get to the Master Cylinder
- Engine Mount Bracket - Removal?
- dic, radio display
- Water leak on right side
- Full engine replacement
- Radio loses reception when very cold
- Article on Check Engine Light
- fire job
- Cost of new sun visor
- Tell us about your Front End Noise
- Cold Start - Gas Smell
- Clicking noise
- Driver's Seat Mounting Bolt
- HHR Won't Start - Will Crank
- power steering issue starting
- Windshield wipers 2006 chevy HHR
- Ignition cylinder
- Clicking noise
- Service SEC
- Foam Piece Blocking VIN Number
- Anyone replaced their own oil pan?
- Need help
- PO843-tranny press sel- powertrain coverage ?
- exhaust cam sensor plug
- Remote start triggers panic horn
