- Blue tooth problems
- P-0300 code
- Overheating issue
- Esc inactive
- 2L engine blown
- MAF question
- esc/traction/abs messages,stuck key.
- can anyone identify this fluid
- David S
- lower control arms
- When it rains it pours
- P2176 Engine Power Reduced
- front window
- hard cranking after gassing up
- My engine replacement
- Overheating, not your usual culprit...
- Do I need a fuel sending unit?
- Hard to shift ?
- funny noise
- T/C light and hard shifting, mechanic says broken engine mount??
- How do you know if your tie rods are going
- Nosies in front end while driving on a bummpy road
- Car won't start and lean fuel
- Remote won't respond, any last ideas?
- P0017 Camshaft position sensor
- BTB Warranty Ends Soon~What should I check?
- Any way?
- I just replaced the front right wheel bearing and
- Cylinders in 2008 HHR
- 2nd water leak solved after butyl patch.
- HELP After a Throttle Body cleaning I have now high RPM.
- The infamous puddle of water on the passenger side floorboard
- Hard shift?
- Car problems
- Trac light on dash stays lit?
- Headlights went out
- And now it's Engine Power Reduced - Oh Joy!
- Passanger windshiled wiper quit working?
- Power Steering and tie rod problem
- Weird tranny behavior.
- Power Steering cutting out but fuses OK - still the motor?
- AC not that cold
- AC smell
- Evaporator Drain Location
- Won't start this morning
- Clunking/rattling
- 2006 HHR rear hub relacement
- Locked...
- Power steering out
- ext. warranty ?'s
- Sun/Moon roof Wind Deflector removal
- Liquid under rear axle.
- Broke radiator fan blade, waiting on part to come in ... In the mean while -
- Key fob change?
- Theft, broken slide rear glass, how to install replacement?
- How do i get it in neutral
- Key fob repair
- Fuel Pressure Test Procedure
- P0446
- Startup noise 2011 HHR 2.2
- Electrical Charging System
- Sway bar links
- New Battery Needed.....
- Uneven Tire Wear
- Does HHR Emissions Warranty Include Flex Pipe
- Question reguarding standard brake vibration
- Gasoline overflow/vent tube
- How to Turn Off With Stuck Key?
- Scan tool not reading 2007 LT Help!
- 2nd key fob
- sunroof won't close
- Odd brake/reverse light issue
- Taking her into the dealer tomorrow morning..
- tranny problem
- Transmission issues...
- The butyl patch water funnel...
- T/C & Alarm Light
- Air bag sterring wheel
- codes p0016, p0171 and p0131
- Pop on Cold Start and Other Engine Issues
- Cracked rear water squirter hose...
- exhaust gets noisy when passing
- factory fog lights
- Shifter Replacement
- Warm A/C no readout on temperature gauge
- Esc Light
- P2138 help me please
- Mutiple problems. 2010 hhr LT 2.2
- Burned valve at 79,000 miles
- Torque Converter Replacement
- Sometimes power window won't open
- Got that notorious clunking
- Popping/loud tick from front under power.
- Spider cracking on rear bumper.
- Door bubble
- battery drain ???
- Click/pop noise from front end
- Front end clunk
- slow acceleration
- Cruise problems
- Rattling sound in the front
- P0455 Evaporative Emission (EVAP) System Large Leak
- Fuse - ign & stoplight - eh?
- Warning Beeper
- Problem with my USB/Thumb Drive/Flash Drive
- suspension "noise"
- Remove the door cap?
- Camshaft Sensor Problem
- How do you install an alternator
- Alternator problems?
- Chirping/Squealing noise when A/C is on
- Lost my remaining bumper reflector
- Automatic Trans Problems
- Frightening discovery... parking brake cable hanging, rubbing on wheel
- Can't find this part- 2009 2.2L knock sensor
- arrrg
- Beyond the Blower Motor & Resistor...
- Squeaking rear suspension
- Has anyone successfully fixed bumping problems
- anti theft lockup
- Storage bin fix $5.00
- 2006 HHR Died on interstate Stuck in gear oil in engine
- DDM HID bi-xenon kit - no high beams
- Brakes - Rotors
- Got key problems again.
- timing chain replacement
- growl in lower gears with ac on..
- Dome Light Dimmer Switch
- P258b
- Electrical schematic
- Mass Air Flow Sensor problems.....
- Changing oil and Seems low
- Clutch Pedal on Floor
- Paint Issues
- Problem with lights on instrument panel .
- Stalled while driving
- Dreaded Key Stuck
- how do you get to the temp sensor..??
- Went to have the tires rotated and...
- Still having issues with T/C light on!
- 2008 HHR LT dead in driveway
- Overheating problem
- coding replacement ignition cylinder
- Suspension clunk.....give up?
- Door weatherstrip
- transmission shifting
- Outside thermometer possibly broken
- 2009 HHR Outside Air Temp Sensor bad?
- 06 2.4 auto trans issue
- Timing Belt
- Interior driver side door handle
- Radio draining battery
- Please Help.... Again. 07' HHR LS
- Gauges on and off while driving.
- 2008 2.2 starting hard, runs bad, surges
- HELP! 07' HHR wont drive!
- A/C Pressure Specs
- codes on 2006 hhr with psteering error code
- New member with HHR power steering question...
- Gas overflows at station...
- Time to replace starter 07 HHR 2.4L?
- Problem with aux input on stock radio
- Intermittent Hard Starting When Warm
- Key fob issues
- internal computer module
- 2008 ignition problem
- Squeeky hatch
- Fuse question
- Battery
- 08 HHR Acceleration/Cut-Off Problems??
- Tsb ??
- T/C CElight DIC Power steering problems
- 09 2.4L eps failing, heat sensitive
- 06 LT won't learn new keys
- Missing inside emergency hatch opener cover piece
- Rustproofing HHR Doors
- squeeky hatch
- Faint squeaking noise when engine is running
- P0303 Cylinder 3 Misfire
- Went in for an oil change...came out with a list
- Cause of low fuel pressure?
- Fuel smell in Engine Oil...
- wheel bearings
- Driver Side Sun Visor Mirror Flap
- ABS sensor question for ChevyMgr , or anyone that knows LOL
- Horn Problem
- 06 HHR Electrical Problems - Code P0742
- control arm
- Dashboard compartment lid not correct
- Lunging at stop light
- Cooling Fan
- P0135 code with no CEL?
- Is my water pump bad???
- Code P0014- cam position performance
- Looks like I may tear down the engine......
- water in blower motor?
- creak or grinding noise
- Question regarding control arms...
- air bag light
- power steering issues...
- Key stuck in ignition- which issue do I have?
- Key fob not working
- Radio switches between Aux and radio:
- air conditioning and vent controls
- P0013
- engine light on, no remote control
- Temp. of digital coolant
- Pulling to the left ?
- Remote lock/unlock receiver "asleep"?
- 2 questions
- HHR air conditioning problems
- Service Manual
- int switch stuck in on position with key
- Problems in front end
- P0171 (System too Lean Bank 1)
- 225/35/r20 Rubbing
- Hazard Button/Switch
- Radio only plays thru tweeter until it gets HOT
- Power Mirrors Blow Fuses
- Service air-bag light on at 45k.
- A/C Drain
- Overheating
- Seat belt warning chime...
- Just bought my first HHR!...need help with the AC
- sunroof snap bracket left side..fail..
- Help! Horn & Key Fob - What's going on?
- Code P0087 fuel rail/sys pres too low.
- 2006 front power door regulator died
- Whistle sound after Hahn Charge Pipe Install?
- No tail lights or radio lights at night
- 09 hhr overheating
- Using a temporary shorter serpentine belt
- TC Light Issue
- Rattle rattle thunder clatter.......
- Door won't unlock with key
- $7E8 and/or $7EA Trouble Codes
- First Major Problem Code p0016
- Key fob not working...
- Engine Code P0011
- Letter from GM for ignition lock cylinder
- Newbie with the dreaded shifter/key problem - what's my best move?
- Battery Discharge Display Error
- Engine light / No Remote Start
- Too rich bank 1 PO174 code
- Transmission mounts?
- Replacement Parts
- Power Mirror Issue
- Driver Side Leak
- Clock Spring Part Number
- airbag light
