PDA
View Full Version : Problems/Service/Repairs
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. Does this BM resistor really need to be replaced?
  2. HELP!! little all in one in here!!
  3. Rear hatch leak
  4. 2009 hhr electrical problems
  5. Hello from Upstate NY
  6. Reduced engine power code/engine light
  7. I had another oddity ESC & ABS
  8. bad gas milage
  9. Rear axle bushings. Anyone have to replace them?
  10. Airbag Light on?
  11. A/C Clutch replacement
  12. sun visor
  13. Tail Light/Side Marker Lights wont turn on
  14. Dead Battery
  15. HHR SS Steering sensor
  16. Front End Shake
  17. Front End Vibration
  18. Rear Inner Fender Well
  19. power steering
  20. Code P0326 and oil change
  21. Strut Issue
  22. camshaft sensor
  23. Coolant loss and mysterious picture
  24. 2006 2.2 Hard Shifting (no cam sensors on my engine)
  25. shifter release button sticking
  26. code P0016
  27. 2007 a/c compressor identification for serpentine belt
  28. Rotor Warp
  29. Car won't start after brake master cylinder replacement
  30. engine light
  31. New guy from Tex. Having Power Steering Problems
  32. OEM and Dorman handles interchangeable?
  33. Steering
  34. Electrical Gremlin, 2006 model, 135K miles
  35. Tire Sensor Service light / message
  36. bucking and surging while stopped
  37. Need a recall on 2010 hhr
  38. Service ESC 2010 HHR
  39. Need a recall for the dashboard lights
  40. BCM replacement?
  41. Front End Shake
  42. Mysterious oil loss
  43. Turn Signals will not turn off automatically
  44. Motor and trans swap. Now no start.
  45. Troubleshooting time
  46. HHR randomly flashes brights on and off while not touching control arm
  47. '09 HHR P0010 Code
  48. sticking doors
  49. Air vent chrome rings
  50. Codes P0014 & P0326
  51. Problems stemming from aftermarket deck installation HELP!
  52. Side view cam
  53. Flex Pipe and Emissions Warranty
  54. Firestone and lifetime balancing/alignment
  55. Dash Compartment Latch
  56. Noise from front when steering wheel is turned
  57. Haunted LT Panel/Uncommanded Door Opening
  58. Check Engine Code P0014?
  59. 2010 HHR - Shut down going down the freeway
  60. Video of my car noise
  61. front speakers sometimes work-sometimes don't
  62. Radio problems after dead battery
  63. Need help with leak diagnosis
  64. Engine Light & Codes P0449 P0455
  65. Braided Flex Pipe
  66. Timing Chain Replacement Cost
  67. Key Stuck ?
  68. Engine Surge
  69. Brakes making a grinding noise
  70. So My Chk Engine light went on :)
  71. 08 HHR Thermostat guage reading intermittent
  72. performance chip
  73. hit a bad bump and .......
  74. blower motor stops and starts intermittently
  75. Head Gasket/Engine
  76. Help!!! RPM's at 65 M.P.H. ???
  77. water leak passenger side
  78. Looking for permanent fix for HHR suspension issues
  79. 2010 HHR engine noise help
  80. Cam Solenoids Installed!
  81. Going through coolant
  82. SS fan motor not working.
  83. 2011 HHR Rumble noise when accelerating HELP!
  84. camshaft actuator solenoid problem
  85. Some good news for a change
  86. 2011 HHR heated seat problem
  87. repair recommendation
  88. Suitable replacement engines
  89. Radio Problems
  90. GM Recall? 2007
  91. Help...smoking while idling
  92. heater/blower problems
  93. Door lock and alarm system
  94. rear doors on panel
  95. Both lights are out now
  96. Code Scanner Recommendation
  97. Cruise fixed itself?
  98. Replaced actuator still have code p0010
  99. Gas leak toward back tire
  100. 2007 HHR 2.2L trouble code 604
  101. New Tire Presure Monitors?
  102. Ticking sound when HVAC is on
  103. rattle over rough surfaces and during braking
  104. power steering motor.
  105. Ranting, Stuck in ignition
  106. tcm
  107. 2009 sputtering, rough idle. runs fine off-idle
  108. 02 senser
  109. heated seat problem
  110. Electrical problems
  111. Engine noise
  112. HHR Third Brake Light Problems
  113. power steering failure
  114. Failed inspection
  115. CEL Purgatory
  116. Oil in spark plug well
  117. Persistent Vibration
  118. Coolant temp question
  119. Returning '06 HHR Owner
  120. Newcomer to Forum(Key Problem)
  121. my piece of junk
  122. Engine troubles
  123. PVC. Question
  124. Hazard lights switch
  125. flopping sound upon starting
  126. Engine Power Reduced: codes P2135 & P2119
  127. Thunk Thunk sound gone.
  128. Coolant
  129. Possibly an Electrical Problem 2006 HHR
  130. p0010
  131. knock senser code p0325
  132. HVAC blend door
  133. Hoses are changed, ac recharged, still a darn growl, howl or whatever
  134. trans issues
  135. problem in winter
  136. Mass air flow sensor
  137. Suspension? Weird feeling in front end.
  138. Key stuck 2006 HHR
  139. Rear Motor Mount Problems?
  140. Peeling hubcaps
  141. Help with HHR 06 ls
  142. Fluttering Locks - Slips into Neutral
  143. Chevy HHR - How to "reground" ECU
  144. rack and pinion
  145. Power Steering fainted
  146. Running Lights Scorching Headlight Lenses
  147. Couple strange electical issues
  148. A/C and Thermostat
  149. Bypass CEL for remote start?
  150. What fuse
  151. 2006 Problem Child
  152. 2 year problem
  153. Oil pan removal (Rod knock problem?)
  154. Sway Arm Bushings Size
  155. Possible ECM Damage from OBD II Port?
  156. 2006 HHR LT suddenly stalls intermittently
  157. Traction control light/ check engine P0301
  158. spark plug blown out of cylinder?
  159. The Mystery Clunk!
  160. Power Steering/Service Air Bag Message
  161. HHR OBD2 codes B0100 B0140 airbag and speed sensor
  162. engine shutdown after coming to a stop
  163. Power Window Question
  164. Service ESC traction control
  165. cruise don't work pain in the a$$ driving with out cruise control
  166. Battery-Speaker-Auto Lights
  167. P2135 TPS sensor fault
  168. whistling noise - heater
  169. Frost/Moisture on the inside of windshield
  170. HHR Rack & Pinion Replacement
  171. Issues with remote start
  172. 06-Under dash leak
  173. HHR dead again
  174. High RPM after Throttle Cleaning
  175. A slightly more complex Key Fob Question
  176. Clearing dummy lights ABS and TCS
  177. feeling held back
  178. Sticky shift button
  179. Codes
  180. passenger airbag indicator flashing occasionally
  181. DIC personalization
  182. Drum Wheel Stud replacement
  183. Transaxle leaking
  184. 2011 HHR LT poor gas mileage
  185. Catalytic / Electrical issue in just purchased HHR
  186. 2008 LT 2.2 Overheating and Unable to Start
  187. Well I "did a dumb"....
  188. power steering motor
  189. P2A01 Code After New Cat Installed for P0420 Code
  190. Surges around the 40mph mark
  191. Parking Light Problem
  192. Security Issue
  193. Code P1516
  194. Key stuck in '08 HHR w/ manual transmission
  195. losing air in tires
  196. 06 LT Power-steering and throttle/transmission issue - intermitant
  197. New Catalytic Converter Time! P0420 Code. New Bolt Size?
  198. yet another radio question
  199. Throttle position sensor
  200. 2007 HHR won't shift out of park
  201. Overheating-Not Thermostat Related
  202. Heated seats switch blinking
  203. Fuel Trim Issue?
  204. New control arms
  205. trouble code
  206. 2006 HHR - Auto Shift Button Depressed & Key Stuck
  207. New Flex Pipe Design?
  208. Rear windshield washer fluid is leaking.
  209. Exhaust gasket blowout
  210. Grinding/squealing when hhr 06 is placed in reverse?
  211. vibration
  212. Engine Noise Question.....
  213. Check engine light
  214. service esc,abs,and traction control messages during cold snap
  215. FOB crank, BUT NO START???
  216. tugging my car and off in the morning
  217. I did a stupid thing today!
  218. Key Fob Low Battery Alert?
  219. 2006 HHR gages
  220. Engine temp indications after inadvertent engine shut-off while driving
  221. Speakers not working after servicing at dealership.
  222. Electric latch & sunroof
  223. Oil leak on back side, rear, of motor
  224. Rear passenger door won't open
  225. Replaced cam sensors check engine still on
  226. Steering wheel harness wiring question
  227. mysterious noise
  228. Disappearing Coolant
  229. Fuel door not opening like it use to
  230. ENG PWR REDUCED - when it's COLD Redux
  231. Brake Master Cylinder
  232. Codes p0030, p0033, and p0135
  233. ENG PWR REDUCED - when it's COLD
  234. rear main seal leaking
  235. HHR Key stuck in the ignition
  236. No crank, no start
  237. radio light allways on
  238. Air Bag light is on (needs attention)
  239. Power steering problem
  240. Misfire code p0304
  241. throttle position sensor
  242. Car wont start after remote starting
  243. check engine light went on...
  244. where is the alarm module locate on hhr2008
  245. p0700, p0740, p0742, u800 code combos
  246. code P0010
  247. starting problems
  248. 06 HHR CEL not working
  249. '08 2.4 Water Pump R&R
  250. engine/throttle surge
