PDA
View Full Version : Problems/Service/Repairs
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35
  1. chevy warrenty is a joke
  2. Doors wont auto lock when pulled from park..
  3. Tail Light issue : Think its a fuse?
  4. Interior Leak!!
  5. Leak? or just condensation?
  6. Auto shifting
  7. Engine Governor
  8. front bumper repair
  9. Cover under Fender near Front Tires - Mounting Problems!
  10. Battery
  11. Paint Damage due to Road Debris
  12. Remote start
  13. Multitude of Problems (Gotta find a new mechanic)
  14. Searched but Did not Find...
  15. remote starter quit working
  16. E brake sticking after sitting for 2 or 3 days
  17. Won't fire after sitting in the cold
  18. Sagging Sunvisor
  19. Car won't start if sitting for more than 3 days.
  20. clunk noise
  21. Ignition Key Removeal
  22. Clicking in brakes
  23. Another weird one
  24. Clicking from Shifter
  25. Oil leak....
  26. Road Debris!!!
  27. T/C "idiot light" question
  28. Inadequate Battery?
  29. Flickering Dash Lights
  30. Slow Tire Pressure Leak and Fix
  31. Rattling Headliner....Fixed
  32. bad brake rotors?
  33. New Owner, now afraid
  34. Engine light with new wheels?
  35. Aux Input Issue on my first Vehicle/HHR
  36. Driver door seal coming up
  37. Dent in Fender - How to fix it?
  38. check engine light-corroded wire
  39. Dome light and rear hatch
  40. Power Steering 06 HHR
  41. Transmission Troubles?
  42. New Problems!!!
  43. Talk About a Bad Day
  44. i have got a few problems
  45. Black Chrome not black anymore
  46. Runs ruff after long trips
  47. Added radio controls & cruise Quit
  48. HEEEEEELP!@?!?!?!? left signal out
  49. Is the key fob remote covered under warranty?
  50. Service manual for HHR?
  51. Laundry list of issues
  52. Sunroof shatters!!!
  53. FOB programming
  54. Heater fan and rear wiper
  55. Wet seat belts
  56. steering problem
  57. Automatic Shift Handle Position Indicator
  58. Slow parts department
  59. Squealing Blower Fan??
  60. Todays Dealership Visit
  61. Winshield replacement problems
  62. Doors no longer lock when shifting from park
  63. Got a plug in seat heater for the rear seat......
  64. frozen window
  65. Sunroof Hiss
  66. Inside windows
  67. Dome light
  68. a better ground under hood?
  69. won't start
  70. Nellie's sick - rough start w/check engine light
  71. bumper rattles
  72. Engine Check Light Comes On??
  73. Miss or sputter?
  74. rotor and brake problems
  75. Horn won't work
  76. Ticking
  77. Dealer Couldn't Fix,gave Me A New One
  78. 5-speed issues
  79. surging
  80. Block heater temperature mod?
  81. Low speed front end noise
  82. Heater fan control problem!
  83. LS Radio problems??
  84. Snow-packed wheels
  85. Thermostat
  86. No Water
  87. Noise and Heat
  88. Wierd Noises
  89. oil filter wrench
  90. Keys Stuck in Ignition
  91. Tire pressure sensor wigging out.
  92. IMCO-T924 and ABS Line
  93. Two issues
  94. Automatic Headlights / IPC Lights Dont Work!!
  95. High Beam Headache
  96. Grinding noise while turning right....
  97. Hatch Struts groaning
  98. Transmission Control Module code errors
  99. Sun Roof Goes Pop
  100. Whats that noise???????
  101. Any new answers ?
  102. Dead Battery
  103. eng shut off
  104. Squeaky Steering Column
  105. Water Leak!
  106. Ice on running boards
  107. Engine Noise When Cold - Maybe Not A Problem
  108. Water Leak/ Contacting GM
  109. Rattles from the center glove box
  110. Malfunctioning Alarm
  111. Window Switches
  112. Window controls
  113. 06 hhr key fob programing
  114. Reinstalling shifter
  115. SMOKE In The Shop
  116. Wheelie's embarrasing moment
  117. outside temp display
  118. another broken sun/moonroof
  119. Banging under my feet?
  120. !Q@%^!$# Coolant leak is BACK
  121. Rattle in the headliner...
  122. Site to search for recalls, problems etc
  123. Warranty Issue on antifreeze?
  124. Eng PWR Reduced for the 3rd time
  125. Wheelie has a problem
  126. Pioneer Premium Stereo "Whoomp"
  127. Temp gauges flat lined
  128. Car sputters and dies
  129. Rear Window Blow Out
  130. Outside air temperature problem
  131. She's going in
  132. Resetting check engine light?
  133. rear view mirror
  134. Windshield Glass Imperfection
  135. Check Engine? P1682
  136. Black Paint - Will it match?
  137. A/C problem
  138. Paint Chips on Roof
  139. Stereo backlight going out, any advice?
  140. Interior Lighting Glitch
  141. 16" Michelin HydroEdge
  142. Bad Tires Or Wheel Bearings ???
  143. Key stuck
  144. gas pedal\regime needs adjustment??
  145. Going in at 1145 mi :(
  146. Poor Service
  147. Clutch Chatter in Reverse (Manual Trans)
  148. Leather seats bunching?
  149. Vibrations in the gas pedal?
  150. Towing with a motorhome
  151. Grease fittings?
  152. Does anyones a/c leak on the passenger side?
  153. Reduced Engine Power
  154. Service Question
  155. Windshield Cracks
  156. dash went blank
  157. Clock Radio Loosing Time
  158. GM finally gave me a decent resolution to my problems..
  159. Running Boards/Sand Blasting
  160. Breaks Wearing?
  161. Brake Pedal Shutter....Check this !!
  162. Wear/OpenBubbles above the radio unit! (With Pictures)
  163. Mobil 1 Oil Filter
  164. AC Stops Working
  165. Just got the car back.......
  166. Dead battery
  167. Rear hatch won't open
  168. Radio Problem
  169. Power window motor
  170. Warped rotor..
  171. Musical car horn delay
  172. #!$&**!@ seat parts
  173. Need tech help, crash damage, no start
  174. new owners biggest complaint.
  175. 2006: Steering Column Rattle
  176. Sort of funny noise from engine?
  177. Starting Problem
  178. 4T45E automatic transaxle clank/lurch upon engine start
  179. Anyone suffer a creaking Driver's seat?
  180. Scraped curb with painted aluminum rims.
  181. Trim around rearview mirror
  182. Remote Key - Locking Door Lock & Remote starting
  183. Water leaking in 2007
  184. A/C and Heat Air Flow **VERY WEAK**
  185. Wheel Hop On Wet Pavement
  186. Stone chips
  187. MAP question
  188. Whistling noise from rear door
  189. GMs answer to my problems.....
  190. New owner has a few questions!!
  191. Transmission Torque specs
  192. Long Trip Problems... Any ideas?
  193. bad day and good day for Frosty....
  194. MAP bad?
  195. Idle drops slightly at stoplight
  196. i think my hhr finally gave up lol
  197. GM Zone Manager
  198. Replacement stubby antena
  199. HHR overheating
  200. I hate rattles
  201. Rear View Mirror point too low
  202. Just picked up our new HHR LS...
  203. Whrrrrrring noise when A/C compressor running
  204. it may sound stupid
  205. Where is the knock sensor on the Ecotec engine?
  206. Alarm system goes off ?
  207. I'm pissed off!
  208. Whistling noise
  209. grill bowtie
  210. AC Question.
  211. Serpentine Belt
  212. warped cargo panel
  213. Touch Up paint problem
  214. Oil Change Guidelines
  215. Smashed Windshield
  216. Possible new owner with a ? about moonroof leaks
  217. keyless entry/remote start
  218. my RIKSHA HHR(made in Nafta)was fixed on 7/11
  219. The Beautiful One shut down...?
  220. Brake Headache
  221. I'm an idiot
  222. paint drip
  223. sqeaky dash
  224. Power steering problem
  225. Should paint be chipping/splitting here???
  226. Scratch Mark repair?
  227. Strange Radio Noise
  228. What with the Sheet Metal on these HHR's?
  229. Hail Damage on Hood
  230. Towing HHR
  231. Dash Rattle?
  232. Ticking/rumbling noise in new HHR 2.4
  233. Coolent leak
  234. leaky a/c condensor
  235. Anti Freeze smell after sitting overnight.
  236. drivers power seat
  237. No problem HHR
  238. Cant' shift out of Park.
  239. My HHR is hazard to road safety!
  240. [photos] Possible oil flow restriction?
  241. Headlights go on when put in gear?
  242. Worn Carpet Under Clutch Pedal
  243. Ecotec oil filters observation part II
  244. Whacky Gas Gauge
  245. low tires?
  246. Observation about Ecotec oil filters
  247. Was this limp mode?
  248. door handles
  249. Free stuff (after rebate) @ O'Reilly Auto Parts
  250. Castrol GTX has failed GM's most recent GM6094M testing
