- Clunk at hard low speed acceleration, again when hard braking afterward.
- O2 sensor bad again
- New Battery Installed Lost Radio and Sounds
- Trans fluid leaking out of top of coolant reservoir
- P0455 cel 2008 ls 2.2
- Radio reception: how to access wires?
- smell coolant no visable leaks
- moderate speed "clunk"
- Fuel Gauge Problem
- Thermostat stuck open (I think)
- Fixing the 3.5mm aux port
- flooded passenger floor
- Horn problems with my 2011 HHR
- Oil leak
- Something wrong?
- Rims
- Rough Idling
- Wireless entry keyfob
- No high beams
- What temp for cooling fan to come on
- ODB-2 Plug Had a jumper wire
- Dorman programmable key fob
- Pulsating hum from front end at highway speeds
- Temp/Perma Fix LH Inerior Door Handle
- Back to the grind!
- Latest spark plug info
- Flex pipe questions
- 2009 HHR LT2 check engine light
- Suspension problems again...
- FUSE for power mirrors
- 2009, with wet carpet, help!
- Timing Chain gears
- Warning lights on
- Can't install air cleaner housing / help
- Spare tire rim no fully on???
- T/C light on hard shift
- P0010 cel..fixed!!
- 3 Codes at once: P0016, P0299, P0087
- Po107, Co561-71...have scan-tool, should I use it to clear codes?
- Airbag light and seat swap
- HHR not wanting to start after engine replacement
- Battery Reserve Capacity Test
- Clutch
- P0016 error code
- Tool Thread
- Shift Cable Removal
- What is it? HHR 06' 2.4L
- Plunger For Column Lock Release
- Engine swapp 2.4l 2011 with 2.4l 2009
- Questions about CEL O2 Sensor Codes
- coolant or oil sludge in air intake?
- Another speakers don't work, but tweeters do
- Strange noise on cold start
- Am I being overcharged
- A/C broken
- Engine R & R
- Bent transmission oil pan
- Carbon buildup on catalytic converter
- Wheel hub and bearing assembly
- Dash Storage Bin Repair
- Coolant level dropped in the reservoir
- Shoddy Paint Job?
- Replacement Engine Mileage
- no power,key stuck:compounding the original problems
- A/C Accumulator/Receiver Drier on 2006 HHR
- Thermostat issues
- Replaced Timing chain tensioner - now big problem
- Check engine and t/c lights
- Oil Leak
- AC stopped blowing cold air, smoke from under hood, battery good, won't start.
- Spark plugs change
- 2006 HHR LT Gremlins - Speedometer/Powersteering/check engine/bad shifts 2nd and 3rd
- Cluster info
- Fuel Pump
- Help.2007 HHR LT ....shifter is very sloppy and will not go into any gears
- Where in the hell is the Ignition Control Module
- thermostat
- 2010 hhr no start no crank for several minutes
- A/C just stopped working
- Rough Idle Stalling 2006 HHR 2.2L NEED HELP!
- Roaring sound help
- Torque spec for motor mounts
- HHR 8 Way Power Seat Issue
- 2008 HHR LT 2.2L p0016
- PSI reading different or is TPMS failing
- Not an HHR but still a Chevrolet
- Service Airbag - I put dielectric grease on the connectors I could find
- Another No Start issue, with a twist
- Clutch slowly going, what to do
- Higher Coolant Temperature
- Dome light
- Could running E85 cause the check engine light to come on?
- bad BCM or ?
- transmission not engaging
- car stalls at stop
- Key fob
- Steering knuckle replacement.
- HELP Error codes I cant seem to find!
- How to repair - Accidentally removed the drain plug on the a/c compressor
- P0013
- Please Help! Headlight Problems
- no crank , fuel primes
- Engine Swap issue
- My Car shakes and makes a noise and feels like it is not getting gas
- Windshield washer not spraying
- mysterious switch
- car slips into nuetral while driving
- Vibrations in the front end while braking
- No Start: no steering wheel lock, key turns & pulls out, can shift gears, no turnover
- Starting issue
- puzzling noise
- Remote start isnt working on my 2007 Chevy HHR
- How bad is my rear shock?
- Slight fluctuations during constant speed
- Need a little help
- steering wheel question
- 2007 HHR LT Fuel Pressure Issues
- Passenger Windows Won't Work
- Bcm/LED
- 06 HHR won't go into third gear.
- CV axles going bad?
- Valve issue
- oil change/should i change at 50% or 3000 miles ?
- Engine cooling system drain, flush, and refill
- New wheel bearing noise
- P2199 what 2 sensors
- Does the 2.2L have just one camshaft position sensor or two?
- Intermittent No Crank/No Start, No Module Communication, MIL, Warning Lights, Vehicle
- Rough start/then dies
- Long start up after several hours in the garage.
- A/c clutch replacement
- Battery light, not charging, no volts under hood.
- Clunking noise
- P0690 ecm power relay curciut high
- Service Air Bag Light when weight in back
- Light problem?
- VUE V6 P0010
- 007 Fall edit. hood stripe
- A/C blows hot while parked or at a stop
- '11 2.4 code P0106, P0108, P0641
- New ECM troubles...
- Exhaust Trouble
- Four long beeps?
- Check Charge System woes ... Again
- Interior door handle cable help
- DTC code c0050 Rear Hub Replaced code on
- All 4 doors lock/unlock/ randomly.
- theft alarm system problem
- 2006 HHR Intermittent Starting Problems
- front end clunks
- Starter stays engaged
- Tire pressure not reading on rear tires
- Traction control
- Car dead. battery ok. security light blinked
- Electrical Problem?
- A/C Stopped working and Lots of codes
- no power to these fuses
- Question about coolant recovery tank
- poo17 after cams replacement
- Research Topic: Airbox replacement mounting grommets
- How to replace door lock
- Proportioning Valve
- Door lock
- Charging system problems?
- Traction Control Light
- Blower fan blew smoke and stopped working
- A/C Sporadically Cools
- Fixed my engine temperature fluctuations...
- More traction and ABS
- P1400
- 07 HHR Electrical- A/C cycles on/off, left lo beam & left parking light won't turn on
- 2006 LT AC Controls And Instrument Pannel Not Working
- Windshield wipers stall engine
- Esc and traction
- A/C stopped working and no reading on coolant temperature guage.
- Code P0700
- 06 aluminum shavings in oil
- Hey Wait... it's DRY!
- Check engine light on what does this code translate to?
- Sun roof functions got stupid
- HHR Alternator
- 08 HHR electrical
- Noisy tranny
- A/C problem
- Weekend Disappointment
- Seat Belt Malfunction During Crash
- tail lights stay on
- a/c vent temps
- steering locks while turning
- Dash lights go crazy
- MPG going downhill
- Slow to start
- Overheating and electrical schematics
- How I cured my wind noise issue.
- Low power around 2000 rpm
- bluetooth/onstar audio poor
- No start/no crank
- Coolant temp issue
- Drivability issues - 2011 hhr
- vibration when between 60 and 70 mph
- Code P0010 solved somewhat
- jerking randomly
- Steering Column Rattle
- P0107 causing ESC/TC problem?
- Cannot Open Storage Bin on Dash
- Power windows not functioning properly!
- seat heater question
- Check charging system
- P1682 No crank issue - starter clicks
- Jacking points
- 2006 Front wheel bearing / half shafts making noise
- Factory radio problem
- HO2S Oxygen Sensor
- 2011 HHR Rear drivers door will not latch
- P0621 Code
- Confused about test data, low compression and normal leakdown?
- Low beam rt hand side not working
- Need help with supposedly broken timing chain.
- engine noise when warm
- Excessive Oil Consumption-quart per 60 miles
- Interior lights turning on by themselves
- Dead Gauges
- Chevy HHR Major Steering Problem
- Steering "dead zone" or loose steering
- First time code
- rich to lean and lean to rich
- P0300 p0301 p0302
- Need Fuse/relay Box help,no start after trans swap
- Sounded like a Timing Chain Tensioner.
- P0300 on 2006 HHR
- 2008 HHR SS outside air ambient temp sensor
- soft brake pedal
- Window switches
- 2009 Dash Lights Issue
- told that the ball joints both lower-front need to be replaced
- Remote Start Intermittant.
- Transmission whining...
- po171 and po303
- Firestone
- Gotta Whopper Electric Problem
- Wish to add pillar post gauge to 2010 SS
- Electric cooling fan
- 2006 Electrical Problems
- engine noise
- replaced battery and tire pressure indicator stopped working had to have serviced
- p0016 and check engine light not working Need help in Cleveland
- Bolt stuck into vaccum tubing?
- Fuel Door Problem
- Finally, an "on-the-road" breakdown
- Car won't start after changing ECM
