- wont start
- 2011 hhr problem..
- Howling Buzzing Noise (Sounds like a dirtbike)
- cargo light switch not making contact
- Front End Noise
- 2009 HHR with 0420 and trims looking lean
- Turbo pressure disappears
- P0420
- P0054 code o2 sensor 2
- Tire Pressure Sensor
- P2122
- Front End Wobble
- Tire Pressure Sensor and svc tire monitor
- Engine power reduced
- P2A01 issue
- Good Grease or Not
- Cluster of problems
- Drives only in reverse
- No compression 2008 hhr
- No tail light, no radio button, no heater control light
- Sunroof
- Raw gas oder
- Service traction light.
- Numerous OBD codes
- Battery light keeps coming on. Help
- Wiring
- Rod Bearings/Oil Clearances
- Torque for Motor Mount and Rear Transmission Mount
- P0121 problem
- Window Regulator
- Speedo
- Fuel odour.
- engine stalls when cold
- Engine Rattle on Cold Startup
- 06 HHR LT really stumped
- Front end accident, bent radiator! Help!
- How To Re-Program Old Car Key/2006 HHR
- Heat and air doesn't work unless I hit a bump
- 08 HHR Steering swaying left and right?
- Help.......
- car loading up. wont even stay running
- bolt on rear SS disc brakes ? should work
- Strange Oil Leak
- Rear lamps only work when braking
- Clunk
- TC light comes on if car sits idling
- Power window problem
- battery won't start when really cold
- Replacing the thermostat tomorrow, how annoying is it to locate and access?
- Timing Chain Replacement
- Charging battery
- P0017 Cam Position has ne stumped
- 2010 2.2L P0700 P0974 codes, no overdrive, rpms show higher on tach than thru Torque
- Cylinder Head Bolts
- 20-35 Acceleration problem?
- 2010 hhr 2.4 turned off on the highway while driving 65
- Leakage past exhaust valve
- 2006 hhr tranny
- Vacuum gauge help
- No crank
- Blower Fan "Review"
- 07 HHR 2.2 swap exhaust question
- Camphaser spring mix up.
- Evap problems
- Smog check failed
- Another Cat Con Question
- P0014
- climate control panel lamp flickers
- Catalytic converter life cycle?
- Car stalls
- Differences between LS, LT and SS front wheel hub assemblies?
- Heater core valve/hose, fluid loss
- HHR poor handling/goes left and right. No problems found
- 2011 hhr panel ls
- Rear Stereo speakers
- Rear door poppers on dash
- Doors locks act up and trans slips
- Cam Reluctor Ring
- Passenger Rear Water Leak
- Front end rattling noise
- HHR Panel Rear Door Popper problem...HELP!!
- Alignment needed after LCA bushings replacement?
- Front suspension components replacement
- Replacing wheel bearing - what parts do I need?
- Control Arm Bushing Orientation
- Help my HHR won't crank
- Auto door lock inop
- Could this be the battery at last?
- Lots of issues please help
- brake shudder
- Rear hub leak
- Need help new tires ( size consideration)
- 2007 Cranks, Sparks, Fuel But No Start After Valve Job (Video)
- 2010 LS Remote Start?
- Vaseline door hinge
- BCM replacement
- Noise muffler or latch?
- Air bag light.
- Need help with electrical problems
- blinkers
- Too much oil
- Help needed, catastrophic electrical failure!
- Rear hatch won’t open
- problem after ignition recall
- Glove Box Damper
- Need Help
- Left front speaker doesn't work and chime is very quiet
- 2009 Service ESC message and scan tool question
- Engine Removal step by step
- Ignition lock problem
- Please help!!!!! If anyone can.
- service ESC code
- Key fob cleaning
- Code P1400
- Intermittent starting issues.
- Loose Wire Identification Question
- Locks and cruise control issues
- damn dinging
- CEL on (LPG)
- Fuel line disconnect tool
- Hard time filling gas tank/ code p0446
- Front bumper reinforcement question
- Recirculation actuator
- ABS and Tc light on
- Transmission Slipping
- Keyless entry module
- Possible battery trouble
- ESC, Airbag Lights
- No coolant temp reading and the thermostat was changed
- No crank over most of the time?!
- Heater core
- Accident Repair
- Codes and leaky fuel lines
- ESC light
- advice on new ( used ) engine install?
- Over heating Problem?
- 2008 SS starter spins with ket in run pos
- HHR 2006 won't start
- P0042 2006 code problem
- Oil level drops after sitting over night
- Check Engine Light
- P0172 code
- No AC, Power Steering, Wipers, etc.
- Where is the High Pressure AC Switch located on the 2006 HHR 2.2L
- 2006 HHR auction buy
- No Bright Headlights
- Interior blower inop
- P0700 code issue
- Knock Sensor?
- Coolant Temperatures
- Int. Starting issues, ground related, I think!
- Got flat tire,outside temp on DIC displays dashes
- Power Steering Issue
- ESC Active flashing
- dash gages going to zero and radio turning off
- My exhaust suddenly sounds like a lawn mower
- Axle issue after accident.
- Camshaft position sensor changed,CEL won't clear
- clutch pedal not returning to top.
- misses under full throtle
- Weird Steering Pump Going Out Noise, Now Battery Light On
- 2006 chevy hhr 2.2 ecotec
- Head gasket fouled?
- ECM Issues
- Lights on steering wheel
- did the hub bearings....
- Key Fob
- Location of Camshaft sensor?
- ABS brake code
- TPMS : 2 sensors quit reporting at same time
- Code p0172
- Thanks guy's and girls
- Transmission Will not go into reverse after fluid change
- Help with replacing vent
- Rear Hatch
- 2008 HHR SS Gas Cap
- Service esc service traction
- Traction control light
- Brake lights don't work unless brake is pushed down hard
- No AC
- Car shuts off when I press the brake
- Hatch strut mounts
- Plastic Running Board Clips
- Butyl Patch Revisited
- RPM limit safety
- New Key not Working after being Programmed
- Spark Plugs Too Far Gone - Am I Getting Ripped Off?
- Lazy Idle-down at city speeds
- Service airbag warning
- Black Tail Pipe
- In mirror compass
- Hewbie
- Interior heat ?
- Steering Column Rattle - Chasing Ghosts
- Power Driver Seat
- Steering Component Replacement
- Lug nuts wont come off???
- Intermediate steering shaft idea
- Drivers side turn signal / brake light
- HHR won't start
- Installing aftermarket Remote Keyless Entry
- 2010 front end shudder
- power steering fails
- 2011 Chevy HHR LT Humming Under the hood
- No power steering above 10MPH only
- ac clutch problems, codes, rear hatch won't open
- P0315
- remote mirror switch problem
- vibration in accel. pedal
- P0011, P0014, P0016, P0017 Set
- HHR overheating
- Crank seal
- Drain plug next to crank pulley?
- Bad ECM?
- Battery Test Results Difference
- ONE Headlight 'stuck' in DRL mode
- Car will not stay running
- code u0073
- hhr blower fan
- No Voltage at Starter
- Stabilizer Bar Bearing Nut Dilemma
- Ac problem
- rhythmic rubbing sound from front end
- Power brake and dashboard lights
- Car wont open, alarm always screams! Help
- Chip key workaround
- Liftgate lock bar seal
- BCM problem(s)?
- Remote engine start ?!
- A traverse issue in my Traverse
- Another possible bearing issue (noise)
- intermittent starting problems
- Intake cam position actuator
- Lens restore for headlamps
- Stealership tried to rip me off on repairs to my SS
- Speaker Change Out - not recommended by chevyhhr.net
- Does this sound like a bearing issue ( NOISE )
- Busting out the timing gun!
- Driver power window not working
- rattle noise
- An ECM question
- Compression numbers - HELP
- Steering rack and pinion failure
- Winding Passenger Side Front tire
- Coolant tank weep hole
- Oh boy, did I buy a lemon!
- hvac not draining water
- Intake Camshaft repair
- camshaft position sensor
- Ac blower motor not blowing
