- Accident! Hood Alignment
- Lower Control Arm
- more CEL! p0172
- Ran low on oil..PLEASE HELP!
- Whining noise possibly wheel bearing..?
- I killed my HHR
- Can't remove key
- Speedometer not working and transmission not shifting
- Low battery on key FOB
- Just bought 2009! But has loud roar from rear end area...
- Presence de glace dans collecteur d admission
- Plastic piece that rolls when gears moved
- 2008 ls - bcm
- Need help finding a part
- P0014
- 2006 HHR fan not turning off...
- Belt Tool on Sale at HF
- Unexplained oil leak...HELP!
- Body work advice sought
- Odd noise
- Power Window problems
- Air Dam ?
- tire bobbing between 90 and 100 km speed
- Key ignition issue
- 2007 hhr is dead
- Odd sound from rear of car
- will not start
- Power Drivers Seat Fuse
- rough idle after changing head
- Check Engine Light, OBII Port not reading and a partridge in a pear tree!!
- Evaporative Emissions purge valve
- Fresh air button will not shut off.
- Both Cam sensors changed, still throwing P0010 code?
- Rough shifting then no auto lock
- Window and Windshield wiper not working
- Bad smell
- Strange seat belt issue
- hello
- 07 HHR won't start after changing clutch
- 2008 5 spd reverse engagement
- 2006 cold weather suspension noise
- No mids or lows
- Feels like a 5 speed auto
- intermittent traction control
- Check engine light
- Complete Timing Replacement @55k miles.
- Interior lights won't go off
- Power Mirror Problems
- Problems with my remote
- Trans problem again
- Serpentine belt
- HHR clunking and bumping
- Turn signal won't turn off
- Engine bucking
- Headlight/ Key chimes
- 2 payments to go..
- any recalls on 2006 HHR's ignition switch
- CHILTON (new release) paperback Repair Manual
- Temp. gauge not working
- rear wiper
- Power steering message
- Brand new programmed key fobs just stopped working.
- rear doors
- Headlights stay on when car off
- Brake clicking noise near console inside
- Fearing the worst for my 07 HHR LT 2.2l - Bad timing chain?
- tranny in trouble
- Heater Blower Motor Issue
- dry start
- Remote Start for 2008??
- SHOCKED when I removed the valve (camshaft) cover!
- Door relocks itself when trying to open
- cold start rough running
- 100,000 mile service
- Radiator Replacement Questions
- 12 volt power outlets
- 2006 fuel preasure regulator
- Ignition Key Stuck - Now Fixed
- Problems with repaired clutch
- Injector removal / installation
- Water in floor pass side ???
- Smell of fuel/fumes inside the cabin
- rear hatch
- Crunching sound in front suspension on hard bumps. Common problem?
- Very hard start in the morning...runs and cranks fine after
- driver side rear door leaking
- New Battery
- Not again....
- Front end shacking
- What happened??
- Keyfob issues
- p1174 -Fuel Trim Cylinder Balance
- 2008 2lt - sun roof access
- No Heat To The Floor
- Remote Keyless programming
- Changing headlights
- My front end clunks and rattles
- headlight issue
- Wet Floor
- Battery Life
- Steering wheel replaced but now blinkers don't work
- 2009 HHR with Pioneer stereo issues
- New key fob
- P0449 and leak
- hhr ss 18" rear wheel
- Dash Lights Dimmer Switch
- Fram Oil Filter O-ring sucks!
- Aftermarket Warranty Question
- Problems with Accessories working on "Accessory" position on ignition
- 2008 HHR SS Oil leak
- key not turning
- recommendations for a scan tool ?
- Auto Shifter removal
- Radio Problem
- Help: Dive in fuel economy
- Color HHR
- front end alignment specs
- Battery jumping
- Help!!! I need more info ENGINE AND TC LIGHT ON
- Power Steering Loss
- Starter solenoid voltage
- A/c
- 2009 HHR SS smokes after accidental grounding of batt cable.
- Rich and Lean
- Sticking door locks
- Replacing dual catalitic converter with single catalitic converter
- coolant(water) pump starting to leak
- Guys what is this part
- Creaking from brakes
- tpms wont sync
- Where The Coolant is Going
- Draggin'
- Rust problem with rear door/fenders
- Seatbelt
- Check Enigne Light on Steady (help)
- 2009 chevy hhr
- Dead battery ( symptom )
- tansmission service
- so much rattling
- crank position sensor
- Engine power reduced
- 07heater core leak so soon?
- Messed up TPMS
- No Power Whatsoever - key stuck in ignition
- HELP PLEASE! 2011 HHR LT Stalled...:-(
- Lemon?
- Broken wires in steering wheel harness
- r&r hhr hvac vent 2011
- P0128 & c0460
- sun roof repair
- Service ESC Service Traction after panic stop.
- 2006 hhr problems
- Help - engine, airbag, ESC, temp
- My paint is peeling, HELP!!!
- Disc error and ejecting
- intermittene parking lights stay on & fast beep when leaving car
- K&N Intake causing check engine light to come on...
- Motor surging
- Help!!! Wont start!!!!
- Can I get warrenty work at any GM dealer?
- Temperature and blower direction will not change?
- Water leak
- 2006 hhr ignition problem
- Key Fob Kaput?
- Car does not want to start...
- hatch not sealing when I close it - sunlight visible. huge gap :(
- Remote Start Button Honks the Horn
- Body control module
- No bi-level or defrost
- Block heater installation
- A little squeek when I turn the wheel right
- Black stuff in gas tank
- cruise control/left rear window control hard to push
- Air Bag Light On
- P2122/P2127 code
- Temp guage not working
- Fuel door not closing properly.
- Electrical system
- P0601 Internal Control module Memory Check Sum Error
- How do you take off the front door panel to replace speaker?
- Idleing hard, bogging out, almost shutting off
- Reduced Engine Power
- Suspension and electrical
- Video: Steering column
- DIY head gasket
- High pitched sound
- Speakers cutting out
- Water dripping inside from AC
- Air Bag Question
- Thumping sound/vibration
- No power to DLC
- turn signal cancel dosent work
- Gauges going crazy and shifting hard
- Door latch cable un hooked or broken?
- Elec Window Stopped Working
- Sensor Problem
- wet drivers side floor
- Knocking in Front End
- Alarm just keeps going off
- Hub/Bearing Time Again
- random stalling
- No tail lights
- Factory Radio Issues
- T/C issue.....still....
- Sulfur Smell
- Headlights
- water inside
- Drivers side front door
- Weird message
- Lighting Problem
- remote door opener
- Engine won't run
- What the fashizzle?
- It Keeps getting BETTER!
- clunking sound front end
- how do I replace the turn signal lamp?
- The Key Won't Turn Problem
- Damaged Chevy Bowtie
- P2128 Code: Help
- remote start not starting anymore
- Solution -- Default AC Vent Issue
- Whats the difference in Lower Control Arms
- Light Wiring Diagrams
- 06 HHR Storage Bin Latch Broken
- Tranny??? or something
- 2009 Ignition Stuck In ON
- Service Air Bags Light
- GM's Un Kept Promise
- 2010 Chevrolet HHR Panel LS Rear Speaker Wire Colors
- P0014 and P0016 - Timing Chain / Tensioner Issues
- Question about TSB and Recalls
- p2261
- Security lighting low or highbeam?
- HHR Parts Including SS Parts.
- Our NEW (USED) Blue HHR LS
- how do i change fuel injector?
- Computer Issues
- Engine stalling
- Esc inactive + voided warranty
- Break problem
- P0700 and P0751, wont shift into high gear, shifts hard into lower ones
- Well crap, flashing CEL
- Radio and chimes don't work
- Hello everyone! Need help with headlights.
- Gauges on dash go to zero while driving
- engine or clutch issue or both standered tran
- Seat belt issue
- Valve Body (transmission)
- PO446 Error Code
