PDA
View Full Version : Problems/Service/Repairs
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35
  1. Remote mirrors don't work
  2. ignition will not turn
  3. Fusebox and power steering issue
  4. curb idle rpm
  5. Couple ?'s about some stuff that irks me...
  6. Rear driver side door lock malfunction
  7. wheel loks&key missing
  8. Wooly Worm Hose?
  9. 09 HHR Radio and Blinker Chime not working
  10. dtc codes
  11. AC trouble
  12. Serpentine Belt Slipping
  13. No power
  14. Cracked Radiator
  15. Loud Humming Noise?
  16. water dripping onto floor
  17. Defective Ignition Lock Cylinder
  18. New member with a problem
  19. Drivers Side Leak...again
  20. Seat Belt Latch Loose
  21. non-limp mode check engine light
  22. ESC code
  23. One More Down .....
  24. Fuel Pump install....soon
  25. AC problem
  26. HARD 1-2-3-od shift
  27. What is this part?
  28. Rattle
  29. Warning Bell
  30. A New Clue to a front end Clunk/Noise ...
  31. Confused
  32. air bag?
  33. Rear door lock sticking
  34. Spare Key
  35. Junk
  36. Cam Actuator Solenoid
  37. exhaust
  38. Tire psi sensors
  39. Humming noise
  40. Check Engine Light
  41. DTCs / fault codes
  42. 2 Blown Headlights.... Help!
  43. Frontend Noise/Brakes
  44. Tighten Sunroof Glass
  45. Transmission Cooler Lines
  46. Radio and flasher sound is not working
  47. Are these fender liners any good?
  48. Remotes
  49. Esc traction
  50. Canadian Special Coverage of steering parts
  51. 2011 Rear noise fix found ......
  52. My experience at the dealership today.
  53. Fan Running after Engine Shut Off
  54. P0300 error 2008 SS
  55. Opening Rear Door
  56. 2011 a c problem
  57. 2.0 cracked
  58. Right side brake squeal and chirp??
  59. Interior Fan Not Working.
  60. Check gas cap
  61. Bad fan motor AND Module???
  62. Brakes noise issue
  63. I thought i had a good one
  64. Hewbie
  65. Need Transmision help
  66. alernator removal
  67. Cylinder 1 misfire
  68. New Problem - slow gasoline refill
  69. LE8 2.2L VVT CPS issue
  70. New transmission @ 145,000 miles
  71. how do i keep the dash from rattling
  72. What's that noise?
  73. Removal of Leather Wrap on 1LT Steering Wheel ???
  74. Front Wheel bearing Inquiry
  75. Computer Shut Down
  76. wiper
  77. Only Starts When engine is cold...
  78. Rattle in the steering wheel. Still a problem with 2011 models?
  79. Help needed for Vibrations
  80. Tire pressure light
  81. Yes, another question on the "Rattle"
  82. Fuel Pump Noise
  83. TPMS, something happened
  84. 2010 HHr - electrical issue? (First post.)
  85. ABS Light - C0045 code
  86. Bypass valve messing up? Video inside
  87. Dead Red Toad
  88. how hot is too hot?
  89. Another water leak, please help.
  90. Cat. Converter
  91. rear window switch broken?
  92. rear suspension
  93. silverstar bulbs
  94. HHR SS Brake Problem Continues
  95. 2006 injector replacement
  96. sunroof windscreen needs fixing!
  97. Coolant Temp Display on DIC
  98. 2006 HHR problems over and over and over
  99. Noise in front end, may not be noise from the front end!!
  100. What fell off my HHR this morning?!?
  101. Coolant temp sensor
  102. Suspension Noise
  103. engine harness electrical connector
  104. Final Easy Care Service Appointment(s)
  105. Outside temp gage stuck at 54.
  106. turn signal not working
  107. 2007 HHR Electrical Issue with Tail Lights
  108. To those with the traction control issue
  109. sticking storage compartment on dash
  110. Problems calibrating TPMS
  111. Brake/Front End Shake
  112. Brakes on my HHR while Towing
  113. Engine temps.
  114. Downshifting 3rd to 2nd getting "iffy"
  115. Sunroof Sticking
  116. Intake duct question
  117. TPM problem
  118. Manual 5 speed getting harder to shift.
  119. Struts Leaking
  120. thermostat
  121. HVAC Blower wiring diagram
  122. Locked ignition.... please help
  123. New Ignition Key RIP-OFFS
  124. boost to 25psi and then knocking and CEL
  125. 2006 hhr axles keep wearing out
  126. Air Vents
  127. Car dead
  128. Two trifling issues - noise in front and tire pressure monitor
  129. anti rust
  130. Whining Alternator Area
  131. Key wont come out
  132. disengaged engine/need car guys help!
  133. Fuel guage doesn't work
  134. ABS Light On
  135. Peeling Black Chrome Wheels...
  136. motor mounts
  137. Never give up...
  138. wheel alignment
  139. Vibrations in Steering wheel, front floor boards, and Driver Seat
  140. Remote not working anymore....
  141. Eng Pwr Reduced - Once again
  142. Check Engine Light
  143. wiper failure
  144. rust on pos
  145. drivers side floor soaked
  146. Squealing noise on 2006 HHR
  147. CEL problem solved (I hope)
  148. "check charge system" On DIC
  149. side skirts or running boards
  150. Rear Window Noise
  151. Ignition switch cylinder went ka-put!
  152. Sunroof busted
  153. USB Port Problems
  154. SS Overheating?
  155. Headlight aim help needed!
  156. warped rotors?
  157. missing coolant
  158. Multiple issues repaired, here's the lowdown
  159. Service damaged my bumper, half ass fixed it, didn't tell me
  160. Ongoing Brake Issues
  161. Transmission noise 2007 2LT
  162. Side skirts
  163. seat belt won't release
  164. Brake lights
  165. Storage
  166. Turn Signal Issues
  167. Help With Silly Battery Cable Ends
  168. steering
  169. Gotta HHR so i'm here
  170. led turn signal replacements fast flash
  171. Auto-Lock non-functional, Shifter Solenoid Noise on Braking
  172. Power Steering Loss and Service Airbag Indicator
  173. High Idle
  174. HHR giving code P0604 will not crank
  175. Brake TSB Done- No difference
  176. Finally - A problem with my HHR
  177. heated seat temp
  178. Rusty Brakes
  179. Sporadic idle issue when coming to a complete stop!!!!
  180. First dealing with service dept.
  181. Headlight Etching
  182. Loose axle in transmission
  183. Air bag light
  184. A Stupid Question
  185. Compass not displaying
  186. Ignition ring
  187. drivers side wiper arm
  188. 2006 HHR LT intermittent starting problems
  189. Automatic Un-Locking of doors in Park
  190. cracked clear piece over gauge cluster
  191. thermostat
  192. Windshield
  193. Power Steering Bulletin-ChevyMgr?
  194. Trip A/Trip B reset?
  195. Pass. side water leak
  196. front-end clunk/rattle
  197. 248 degrees, is this normal?
  198. Catalytic Converter!!
  199. HHR SS in the shop again
  200. crank position sensor
  201. Time to get the hands dirty....
  202. My power steering hates me!
  203. Grinding noise AC related
  204. Something Draining Battery On My SS
  205. Possessed Headlights
  206. Liquid rushing sound on start and accel
  207. Ratteling noise in my dash
  208. VCIM connector C3 Location?
  209. Brakes roaring noise
  210. Drivers door won't open.
  211. Just a fair warning!
  212. A Question
  213. paint
  214. Help With O2 Sensor Please
  215. Loose steering Column
  216. dead gauges
  217. Power Steering cutting out
  218. 08 SS leaking boost bad and no power
  219. Fuel Pump Part #???
  220. Chevyland Shreveport, LA - HORROR DAY!
  221. Rear Window
  222. My car was stolen!
  223. car rev's up on it's own???? Help
  224. fog lights
  225. Heated Seats - Blinking Lights
  226. Cuts out - Misses DEEP DIVE problem
  227. P0449 & P0496 Codes
  228. can not find parts
  229. High pitch electronic whining sound coming from dash
  230. Help needed - Scanner code, locate camshaft position sensor
  231. Ignition Coil
  232. Service ESC = Malfunctioning Yaw Rate Sensor
  233. Can't seem to get rid of front end clunk
  234. rpo codes
  235. 2008 SS key won't turn
  236. Stuck Key at 328miles 2010 HHR Panel
  237. Seizure=Totally Dead
  238. throttle actuator control
  239. Shifter Broken - Removed, Disassembled, and Fixed
  240. rear window washer
  241. lowering kit 2010 SS
  242. Rear wiper
  243. interior water leak '06 HHR?
  244. 2008 2LT 2.4L Front Wheel Bearing
  245. Airbag malfunction light
  246. Sunroof issue
  247. Yep Plastic just blowing up!
  248. any Gm part guys can help?
  249. GM Notice
  250. Maybe another mystery solved.....can you identify this part??
