PDA
View Full Version : Problems/Service/Repairs
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 [34] 35
  1. Thoughts on changing filters with synthetic oil
  2. New HHR's 1st oil change: Done
  3. What size is the hex nut on oil filter cap?
  4. Mobil Clean 5000, Mobil Clean 7500 motor oils
  5. Mileage @ first oil change (poll)
  6. Rust on inside of door
  7. Stalling motor. Larger than we know ?
  8. shifter stuck, but not stuck??
  9. 2 new problems
  10. Any issue getting an alignmnet after installing rear sway bar?
  11. Right Rear Door
  12. Rear Fender Pads Adhesion
  13. Key Stuck in Ignition Problem
  14. A/C Odor
  15. Rotors ( Funny Sound)
  16. Arming other HHR's alarm!
  17. Brake issues . .
  18. Upper Storage Compartment Issues
  19. i think my hhr is junk....anyone else tired of theirs
  20. A/C growl
  21. Odd pinging noise under accelaration.
  22. Steering clunk fixed...new problem!!
  23. My heater/AC fan wont shut off
  24. waiting for the tow truck
  25. Traction Control problem
  26. My leaky HHR saga: Back to coolant
  27. no throttle body left in the usa.
  28. New owner
  29. newbie with poor MPG
  30. Its raining transmission fluid under my new HHR
  31. Automatic transmission dipstick on 2.2?
  32. Best place to by online for touchup paint
  33. Dealership Service and Customer Satisfaction
  34. passenger side water (front)
  35. Running Board Problem
  36. Engine Air filter
  37. 2007 fuel injector problems w/ 2.4
  38. Coolant leak @ rear of engine, new HHR
  39. Steering wheel question
  40. Hello, and keyless entry issue
  41. Oil Filter Debris 2.2L/2.4L engines; metal shavings
  42. Handy reference: List of oils that meet GM6094M spec
  43. HHR factory wheel alignment specs, anyone?
  44. Trip Odometer B resets at 1000 miles
  45. Odd noise
  46. Anyone Buy These Seat Covers?
  47. the clear bowtie on the rear beauty bar
  48. Magnetic oil plug for HHR?
  49. Took 'em all day but they turned my rotors
  50. temp guage
  51. How long for oil change at your dealer?
  52. Drivers wiper arm rubs on hood when arm is lifted?
  53. Owners Manual
  54. hmmmm noticed door isn't lined up...
  55. Sharp clunk when putting transmission into reverse
  56. TC shutting down
  57. Transportation damage
  58. Thunking sound in rear area
  59. Wood Dash Kit
  60. Difficult to replace front bowtie?
  61. TSB's and alldata
  62. Slow start
  63. Roof rail chrome discoloration
  64. Was your HHR overfilled with oil when you got it?
  65. Wind noise drivers door
  66. Check Engine Light came on after Coolant Guage stop working!
  67. A/C Compressor
  68. Brake noise
  69. update to no dash/tail lights
  70. Engine Surge While Ideling+sunroof ?
  71. Cruise Control won't set
  72. Brand New Dead
  73. dealer story
  74. I want A/C on when I start the engine
  75. Fog Light bulb #
  76. Windows down - noise
  77. Brand New Dead
  78. All Gauges Flatlined!!!!
  79. I NEED HELP......3 times in service.....clunk knocking noise front drivers side
  80. Newbie--
  81. Windshield Leak
  82. TSB 06-01-39-007 Air Conditioning - Contaminated R134a Refrigerant
  83. Paint / design problem with HHR
  84. Locking Gas Cap ?
  85. running board
  86. Confused..
  87. Newbie - '06 HHR LS
  88. ac condenser
  89. Chrome Trim Corrosion
  90. Full Size Spare
  91. Glove Box Sticks
  92. EQ button
  93. Power Seat Problems
  94. Price change for positive battery cable
  95. Smoke Going Back To Dealer
  96. Crap Brakes!??
  97. My new awesome LT!
  98. Headlights and Dash Lights
  99. radio
  100. Disc brake pads
  101. Hello from Texas and small issues
  102. Mobile Syntec
  103. Broken Moon Roof
  104. New TSB applies to Deer breaking the HHR..
  105. Rear hatch question
  106. "Smoke" Going In For Service Issues
  107. Problem with Purlator oil filters
  108. Black portion of running boards bubbling up?
  109. New service bulletin for uncomfortable armrests
  110. Battery/start problems-now dash is melting
  111. How to remove salt stains from the carpets
  112. Vibration in brake pedal
  113. Issues
  114. I'm so mad right now.....
  115. no dash lights?
  116. liquid noise
  117. my 2007 in for service today
  118. A word from a fellow Technician!
  119. GM warrenty
  120. Outside temp gauge sticks
  121. car won't shift out of park please help
  122. Gas odor strong when idling
  123. Window issue in cold weather
  124. Front End Noises
  125. Sun Visor
  126. Door Lock Actuator Help
  127. Battery woes
  128. Tailgate Groaning
  129. Door Component Diagram?
  130. Turn Signal "Tick Tock" Problem
  131. removing badging and emblems
  132. Bad Fuel Injector Already
  133. Key won't turn all the way off
  134. Bad Clock?
  135. Tire Air Pressure Problems?
  136. Front brakes sticking
  137. Rear Bowtie Paint Failture Seal Failture?
  138. Water draining from rear spoiler
  139. Best placement of spare?
  140. My Air vents are breaking !
  141. Burning MP3 cds for 07 LS
  142. auto trans gear lock
  143. help
  144. Remote Starting_Lighting?
  145. Belt noise.
  146. "Turning On" Rear View Mirror
  147. Possible Water in Gas Tank. Please advise...
  148. Advice -Front end noise over bumps/thump noise
  149. Check engine light came on today
  150. My first problem - loud rattle in rear - fixed
  151. Brake Fluid Warning
  152. Remote starting in cold weather
  153. "I" gear RPM shift range
  154. brake warning / low brake fluid / ABS fault
  155. Leaking Shock
  156. Key Fob Problems
  157. TSB link troubles
  158. Intermediate Steering Shaft!
  159. Ecm Problems
  160. Arm Rest issue
  161. T/C shut off
  162. Just bought my used HHR yesterday...
  163. Tranny Jump ater car wash
  164. 16" Firestone Tires
  165. Headlights
  166. How low do you let the oil life get?
  167. Clicking - anyone else had this issue?
  168. car stalling when hitting bumps?
  169. Oil life monitor - how fast does your percentage drop
  170. Knocking
  171. Trans Fluid Change
  172. Rear wiper freeze!!!
  173. Optima battery...what size?
  174. Shaking in the steering wheel
  175. electronic door locks
  176. Assistance needed in a major way!
  177. Im New and need help..
  178. No sound coming from anything
  179. Tire Pressure
  180. Big Problems--please Read!!!
  181. PCM Issues?
  182. car wont start or stay running.
  183. UPDATE on the stereo poppin crackin noise!!!
  184. This could be the end...
  185. 1st Problem W/the Toy
  186. Car won't start
  187. electric steering
  188. coolant level in tank
  189. Scratched aluminum rim - how to fix
  190. remote start dies after unlock
  191. Poor Paint
  192. Poor gas mileage
  193. Occasional brief LOUD exhaust note on startup
  194. uncomfortable door panel arm rest cracks?
  195. what happens when you open your door?
  196. Window Defrost
  197. Heated Seats (Light Blinks)
  198. Suspension Problems/noise?
  199. Reseting Oil Life...
  200. Transmission Problem ?
  201. Hhr Problems Again Bulletin Issued
  202. crappy side mirrors
  203. Noisy rear window washer
  204. Heads up about the radio pop/crackleing noise!!
  205. remote start question
  206. Low fuel warning
  207. Mobil 1 or other synthetic?
  208. How many miles untill you needed new break pads?
  209. Front Rotors warped
  210. Anemic heater (cold tootsies)
  211. Windshield looks like it was sand plasted
  212. Broken Sunroof...no replacement available
  213. Brake light
  214. What to do....
  215. Shifting Into to Low Without My Help
  216. Blower Fan Stays On
  217. Rear Wiper- It does not go down all the way
  218. passenger side dash rattle?
  219. Dome/Rear reading lights
  220. FM Reception problem - did the TSB fix the problem?
  221. Warning lights after tire rotation
  222. Fuel pump problem
  223. The steering rattle saga continued....
  224. Had enough...
  225. Extended Warranty?
  226. This is why i don't trust dealerships
  227. Exposed insulation between front fender and doors?
  228. Encounters of the strainge kind
  229. Fuel Filter
  230. Front strut leaks
  231. holding RPMs when clutch is depressed
  232. "Engine Disabled" & "Eng Pwr Reduced"
  233. Blown Speaker
  234. Trim Issue (interior)
  235. Busted door handle
  236. Factory Mismatched Paint!
  237. Noisy roof (headliner)
  238. Trouble with my HHR
  239. My Baby is Going in Today!
  240. Vibration, roughness on new '07
  241. car wont start need help ASAP
  242. Front Rotors Needed To Be Cut at 6000 miles
  243. Damaged pan, Run without oil
  244. Interesting ... paint chip on hood and windshield wiper arm
  245. temp guage
  246. Mirror Whistling
  247. Radiator Seam Burst - 4000 miles
  248. Air condition trouble
  249. Stupid question on Fuses
  250. Passenger Airbag Cover
