- Front brakes
- 60MPH Shimmy or Vibration
- Intermittent Power Steering & have already replaced Power Steering Motor
- stubbyjs - Keyfob Questions?
- p0700 and c0700
- 2006 Chevy HHR Transmission wont shift into overdrive
- Loud Noise Under Idle And Acceleration
- Shaking while braking
- AC power button
- Intermittent temp gauge and A/C problem
- No remotes to car
- Blowing ac fuses often
- Door chime
- Sounds like there is a hole in floor board?
- Is Customer Service Dead?
- Catalytic converter noise and buzzing noise
- please help !
- ESC Light On & Shuttering (No Codes)
- Emergency flashers
- Key Fobs not working suddenly
- A/C Compressor Won't Kick In
- Fixing a snapped sunroof bracket, and avoiding those cheap stick on wind deflectors
- CMP sensor cause rough idle?
- Flex Pipe Broken AGAIN!!!!
- Installed new cat today
- hhr transmission code p0757
- how long 'til you 1st changed your plugs?
- Engine power reduced & then engine disengaged
- Info on airbag service light
- Fan Shaking Badly 08 HHR
- XM Radio will not activate
- actron scan tool not working
- Locks are opened automatically
- Error Code P1516 and P2176
- Key stuck in the ignition
- noise while driving
- 2008 HHR Exhaust
- Weird rubbing noise in the steering column
- traction control lite on 07 hhr 2.4 litre
- Ignition Problems
- 2.2L Transmission up shifting hard
- Thermo-siphon
- Clear CEL code
- cooling system?
- Radiator replacement issues?
- TC light and hard shifting problem
- climate control
- Problem with suspention
- Noise from left front under braking and minor bumps
- Check Engine Light/no problem seen yet
- 09 2.2 NO FAN- Overheating
- 2006 & 2007 2.2 engine swapping ??
- Kind of an emergency
- electrical problem? help!
- Jump starting
- Won't Crank
- Airbag sevice message
- No coolant temperature and air blowing warm
- No longer able to accelerate after checking wheel hub.
- radiator replcement how-to
- Leaking wiper fluid
- Grease on the lower passenger door
- Odd smell occasionally while accelerating, and randomly on the highway
- Dimmer switch doesn't work on 2007 HHR
- Dome Lights - turn off?
- Windows stuck down!
- How to test Brake Transaxle Shift Solenoid before re-installing old one
- Passenger side under dash airbag connector
- 2009 HHR shimmies going down road
- Clunking noise when braking
- Clunks in the front end
- Rattle taking right turn
- Leaky HHR Sunroof
- hhr quarter panel skin
- 2008 HHR, motor won't turn over. Good battery.
- Horn Issues
- noise at 48,000 miles
- DIY ignition cylinder lock replacement?
- Failed State Inspection/Diagnostics Connector Not Found/Not Communicating
- Reduced engine power engine shutdown error code P0340 and P0601
- Problems already....
- #3 misfire & compression test....
- Mass Air Flow part
- Valve noise?
- "Sweating" gaskets???
- is this bad?
- Funky new sound
- CEL light and diagnosis
- Wooly Worm?/New member
- Running board pads
- 2008 HHR SS overheating
- Difficulty Starting
- Power steering problem 2008 HHR
- Check Engine Light Help Please
- high beams cut out
- steering collum noise
- No electrical power!
- Service esc
- Snap sound when going to reverse
- Engine idle rough/ check engine light
- 2006 2.4l overheating
- possible oil leak?
- interior door handle
- Alternator Died
- Does FOB Not Working Also Disable Key Working
- Headlights
- 2009 hhr
- Parking lights come on with brake pedal depressed?
- Reduced Power, Electrical Issues?
- Nothing But Trouble
- My electrical sensors are possessed...
- New info on Service Traction Control Light
- P00010 Code
- 2006 HHR Ignition Lock
- Key wouldnt turn off alternate problem
- 3rd brake light sockets burned
- HELP ME, Connected battery wrong tried to start
- Power steering motor or module??? Which one has failed this time?
- Fuel Pump failing?
- Engine cleaning/water
- hhr issues
- power steering issue
- HHR lights Flash and horn beeps without reason
- Code P0013
- 2.2 liter engine overheating please help
- Ac
- Eng Pwr Reduced, check engine light, will not move
- Front end noise
- no OBDII connect,no crank on 2007 panel
- Rear wiper arm R/R
- wiper control arm repair
- HELP!!!!!!! Ignition/Key issue
- Helicopter noise
- Remote fob problem
- Starting problem
- replacing center window console
- Transmission Control Module
- Rear Passenger Window Problem
- BCM3 fuse
- Weird issue with turn signals
- engine "chirp" with A/C engaged
- Condensation on windshield at night.
- passenger fuse panel incorrect 2006 HHR
- Air Filter Casing - Does not just "lift off"
- BCM3 & Blower Fan
- Rear wheels
- Engine noise
- Loud humming noise...
- TPMS error
- engine reduce power
- Random vibration when applying the brakes
- Minor problem with my new used HHR- rear wiper not working
- HHR headlight problum?
- Ran Over A Log In The Rain
- Power steering stops while I'M driving
- Fuse #45 is blowing
- HELP!!! Dealer wants to drop gas tank
- 12 error codes...damn
- Acclerating Problems! Help?!
- Intermittent starting/stalling 06 HHR LT
- Radio/Clock display flickering
- Possible short?
- haywire
- gear shifter switch problem..please help!
- Gravity brake bleeding
- General up keep
- transmision
- Searching Code P0171
- Wheel chirp
- Outside Temp
- white smoke
- 2009 HHR Ignition Repair
- 2009 cruise control problem
- Jumped HHR the wrong way...
- P0010
- Inboard front brake pads worn out
- HHR cooling problems. water inside vehicle.
- power steering failure
- Remote entry issue, and water in drivers side
- hi im new here and i have a question about my 2011 hhr
- Shifter issue - 2006 hhr lt
- A/C Issue
- $27 valve stem?
- macgyver6046
- Occasional long start
- Check Engine Light & Message...
- Driver's Door Unlocks but Will Not Open from Inside
- 2.2 crankshaft seal leaking
- Rust On Inner Door
- 2007 HHR Starting problems
- 08 2LT peeing on the floor
- Starting Issues
- Beware chrome inside door handle
- A/C problem
- Water leaking passenger side
- Sensor warnings come on after oil change
- 2008 panel door popper harness missing
- transmission fluid
- oh boy flex pipe time...
- Can'tTurn Key
- 2008 hhr
- a/c compressor bypass
- car horn beeping when opening driver door with key?
- P0010 CEL Issue
- 2.2 engine removal
- AC problem
- Reduced engine power and temp gage problem
- HHR back hatch hits me on my head
- Car won't start, no lights
- Fuel Pump Replacment
- Excessive Oil Consumption
- Issues...
- Interior fans only work on high and theres a burning smell
- tranny vibration
- 2006 Audio issues
- Hi I'm new here. From Pittsburgh Area, need a little help.
- A/C Problem
- AC problems
- Water leak
- shifter won't lock in "Park"
- I cannot keep HID lights working.
- Best way to remove back of rear seats
- Am I missing something
- radio lighting flashes
- DIC Not Working
- Fan only works on high
- ABS and Traction control light on ?
- Brake lights
- Key interlock problem
- Engine light still on after replacing sensors
- More whining noise in front
- Water in the Driverside Front
- help: Rough shifting, Limp Mode
- 2008 HHR "SS" Turbo Issue
- p1174 code and misfire code
- P0090:Fuel Pressure Regulator Control Circuit (HELP PLEASE)
- Electric Problem ?!?!
- Water passenger front. I have searched this forum, please help
- HHR Misc Problems
- Leaking Tranny pan
- Fender removal question
- Clutch rattle
- Replacement Part CP471 2009 HHR
- Help- HHR Won't Crank but turns on
- clunking sound when shifting
- AC Condensate leak in car
- P0446 and hard time filling at gas pump
- losing brake fluid
- trans/brake problems
- a/c problems
