PDA
View Full Version : Problems/Service/Repairs
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 [30] 31 32 33 34 35
  1. Windshield Wipers Acting Goofy
  2. Two Small Problems
  3. Glitches
  4. Gettin Horny..need to add some noise!
  5. Took it in for a few warranty things.....
  6. Sunroof Pop, Clunk, Thunk, Type Noise
  7. Normal or not?
  8. Headliner keeps falling down
  9. blower motor issue
  10. Fluid on trans. pan
  11. New Windshield Wiper Problem
  12. HHR SS Stage 1 Problem
  13. HHR Quality ?
  14. Temp gauge
  15. HELP! w/Fender & Running board adjustments
  16. Took my ss in for the first time
  17. Headlights
  18. I have a new problem in my HHR now
  19. Tire Pressure Monitor crapped out...
  20. Sway Bar Link
  21. Stagnant odour from A/C and no horn
  22. A/C take a while to come on
  23. Chilton Library | Automotive Repair Information for Do-It-Yourself
  24. Synthetic over Conventional Oil????
  25. front end clunk
  26. HHR woes
  27. Air Conditioning Fan
  28. Onstar diagnostic
  29. Pull to the left
  30. Burned Out Blinker
  31. Driver side windshield wiper when lifted hits hood edge and wore the paint off.
  32. Grease fittings
  33. Bluetooth- Problem Pairing
  34. Oil Fill Tube, how to remove?
  35. Hard Shifting, Traction Control Light and P0010 P0011
  36. Roof Rail Install $$$?
  37. Strange cruise control behavior
  38. wants to cut out
  39. In need of some HELP!
  40. right front wheel area thumping under hard braking
  41. Anyone have the radio with the MP3/USB port option....
  42. Tell me more about Map Sensors on Turboed cars
  43. Car alarm keeps going off by itself!
  44. hate to bring this up again but autodimming compass maplite mirror
  45. Slight clunk in steering column when turning
  46. remote entrance not working all the time
  47. Fan Trouble
  48. Failures after Jump Start
  49. Sound and shaking during driving.
  50. Floorboard "pops" during braking
  51. Creaking Sound Heard After Starting To Drive
  52. Thrum/Roar fom Front Drivetrain
  53. Cooling Fan won't run
  54. Cranking issue?
  55. Accelerator Doesn't Step Up
  56. Time for new brakes. Ideas on cost?
  57. Popping noise front end braking and turning
  58. front end shimmy
  59. Cruise control
  60. Replacing Sensors
  61. shifter is broke i guess. help
  62. Onstar Recall Reminder
  63. Key Fob problem
  64. front wheel bearings
  65. Dead Short on Radio Circuit
  66. Steering Wheel Lock
  67. Shifter sticks in park
  68. Exhaust Cam, Timing Tensioner, Door Module issues
  69. Disable alarm system
  70. Same issue different problem
  71. Blower motor issues?
  72. Removing plastic running board cover piece
  73. turn signals (bulbs)
  74. Wind noise with sunroof open
  75. Clutch Wearing Through Carpet
  76. Revving in Park
  77. Where to buy battery?
  78. AC Fan Speed
  79. Quick thought
  80. Anyone reported brake issue to Feds?
  81. Bluetooth question
  82. Motor noise
  83. Door Ajar Alarms 2008 HHR
  84. Ugh....here we go....
  85. Is my car a lemon?
  86. Ignition won't turn
  87. Can't Link with ECM
  88. Electric power steering
  89. starting problem
  90. Brakes
  91. dash lights
  92. Rear Door Speakers Not working
  93. DIC Warning "Service Esc"
  94. Where is a Ground connection for a cooling fan?
  95. HVAC cutting in and out
  96. Need help with the brake and rear turn signal
  97. CEL = No Onstar, no remote start?
  98. TPMS Problem
  99. Spare tire for the HHR
  100. 2006 2.4 hesitation
  101. Transmission service?
  102. Turn off content theft system?
  103. A/C On and Off???
  104. Decided to take the hhr on one last road trip.. Huge mistake
  105. 2006 HHR won't start after sitting in heat.
  106. Warped
  107. Clutch Pedal Bracket
  108. Parts Availability......
  109. Had an ESC malfunction the other day
  110. Passenger windshield wiper arm
  111. Shifter Assembly Question
  112. Shifter Knob
  113. Air Cleaner
  114. Clicking on Turns
  115. PCM/TCM Upgrade Help
  116. Coolant Temperature Low
  117. Sunroof Maintenance?
  118. Sunroof question
  119. Onstar antenna mast
  120. Programing New 2 Way Remote...How?
  121. rear tailgate bending
  122. Gauges acting strange
  123. Rear hatch supports
  124. Fog Light Bulb
  125. Low Speed Surge
  126. Horn works some of the time
  127. Power steering just went off!
  128. Turn right and the car wont go
  129. Spiral Drilled Rotors
  130. Brake issues.
  131. Dome Light?
  132. Abs: Brake problem
  133. best way to replace the glass ina door
  134. Service Airbag
  135. Problem Pls Help, Clicking noise near Dvr frt
  136. Turn signal fuse location
  137. brakes 2.4 07 hhr
  138. A/C and Heater not working
  139. Cheap Rims
  140. solenoid on shifter failing?
  141. Fuel pressure sensor
  142. wrong spare tire
  143. Rod knock on startup.
  144. Rear Brake problem
  145. Cylinder head repair at Dealer- ChevyMgr?
  146. Thermostat recommendations?
  147. body shop problems
  148. Climate control temperature
  149. the chassis number
  150. Has anyone ever noticed this?
  151. Check Engine Light for a busted fuel cap? Rip Off?
  152. Fuel rail question?
  153. Dome Light Bulb Replacement
  154. Starting after a failed start
  155. Cooling fan
  156. Radiator damage, Check yours
  157. Cracked end piece on Windshield Cowling
  158. Hit bump...car shut off!
  159. CEL came on today P0335 :o(
  160. Air Condition Running Intermittently
  161. Oil Life Indicator Reset Itself...
  162. Battery issue and secret compartments
  163. Broken Sunroof
  164. Annual Brake Warping Tour
  165. Any one else have this problem...
  166. Gurgling From Heater Core on 2008 HHR SS
  167. 5 Speed Shifter Height Issue
  168. 36,000 Mile Warranty
  169. Eng mount thunk
  170. my remote start issues
  171. AC Delco Oil Filter?
  172. Transmission issue?
  173. Cooling system flush procedure
  174. Engine Misses and Dies Over 1250 RPM
  175. Auto-Dimming Mirror
  176. SS Help!
  177. Serious water leak in the 09......
  178. Service advisor called... blown headgasket :(
  179. Rotors
  180. general quality stuff
  181. Front end noise
  182. DIC message:Service Traction Control
  183. 08 HHR won't start?
  184. P0107
  185. can you change the 24 hour clock setting?
  186. Engine Light/ Traction Control
  187. Check Engine Light
  188. Seafoam ?
  189. Front Seat Doesn't Fold Flat
  190. need help now with brakes.
  191. Wobble in front end
  192. Steering rattle, brakes or steering column?
  193. URGHH!!! It happened again
  194. Electrical problem or my car is haunted.
  195. Leaking transaxle seal?
  196. Headlight
  197. Help!! Dim Headlight Problem
  198. Interior Rattle Question
  199. Engine "stumbling", now Check Engine Light on
  200. evap vent valve solenoid malfunction
  201. Rear drum brake repair tutorial
  202. Won't start with remote!
  203. Sticky Door Locks
  204. Creaking from rear upon stop
  205. GM Employee Discount problems
  206. Need Help Car Won't start..Think its in security lockdown.
  207. Steering Wheel Lock
  208. won't move.....
  209. The perfect tire
  210. rough idle then no start.
  211. Problems with HHR
  212. SS jack points - can't find markings
  213. DRL problem
  214. Chirpping from Engine
  215. Aid for technical data
  216. Steering Play at Stop
  217. Where is Splice J323?
  218. Cruise Accelerating by itself
  219. Battery died again, WTF!
  220. DIC says "SVC TIRE MONITOR"
  221. 09' LT2 60 to 80 drifts on the road
  222. Need help from Chevy parts factory
  223. Recall 2009 HHRs with Auto Transmission
  224. what is this green goo?
  225. new problem/issue rear door / hatch
  226. Temperature Display
  227. steering column noise
  228. Turn Signal Chime – not loud enough!
  229. That First HHR Recall....
  230. Exhaust cool down noise
  231. Stronger Lifts for tailgate?
  232. Any 5 VDC available in Vehicle?
  233. Problems after jumping my HHR
  234. '07-'09 & '10-'11 Powertrain Parts Coverage List
  235. Water leaking into back seat compartement
  236. Transmission Problems
  237. Condensation on the inside
  238. Key fob problem?
  239. *Service Airbag* light keeps coming on
  240. Blob-O-Grease
  241. Rattles
  242. Frozen Gauge Cluster
  243. Driver's door doesn't lock from remote
  244. Manual Transmission Noise
  245. no obd 2 meters will work on my car???
  246. warranty?
  247. Extended Warranty If GM Goes Bankrupt:
  248. Traction control and fog light buttons get hot
  249. Three times to the dealer
  250. Radio Buttons not working? I need help!
