PDA
View Full Version : Problems/Service/Repairs
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35
  1. mirrors
  2. Rear tire has uneven tread wear
  3. Dome Light Troubles
  4. Why does my boost keep decreasing and increasing?
  5. Lola Back From Shop
  6. TWM Short Shifter - Problem after install
  7. Issues with Dalight running lights
  8. GRR!!! stupid tire monitor system!
  9. Fin.
  10. Plastic Shield to Stop Stone/Debris Impingement TSB #08-06-02-001
  11. Where Does This Plug Go??
  12. Oil Leak from Somewhere
  13. Help Needed - Hesitation, No Boost (P0101, P0556 Codes)
  14. auto lock sensor
  15. Water leak front passenger floor
  16. Repair or part out?
  17. Hesitation, No Boost P0101 and P0556 Codes
  18. 08 engine light
  19. HHR power steering help!!!
  20. 5 Times For Clunk - Lemon Law
  21. A/C drain?
  22. Onstar going crazy
  23. Service Airbag Light
  24. Clunk in the steering.
  25. AC water drain in cowl?
  26. Rear Vibration
  27. 06 Lt no start
  28. new owner--dash storage & sunroof rattle
  29. front spring noise
  30. 2008 SS No Start
  31. Check engine light on and thermostat replaced 3 times in 36,000 miles
  32. Wiper adjuster cap
  33. Clunking Sound....
  34. Hood Struts
  35. Steering Question.
  36. HHR Check engine light and remote prob
  37. 06 failed emmissions
  38. struts replaced still front end noise
  39. Part Number Help - HHR Storage Tray Wing Nut
  40. Speedometer Calibration, Didn't Work
  41. A/C Low Pressure Switch
  42. HHR Shop Manuals
  43. Sudden Unintended Acceleration
  44. Back Hatch not Locking
  45. Oil leak
  46. Traction Control Off
  47. Door Open Chime does not sound
  48. Buyback.
  49. Daytime running lights
  50. New Water Leak Location
  51. Red Circle Covering Opening Inside Drivers Door
  52. Ummm wheres the SS's battery?
  53. launch control problems?
  54. Trouble Starting
  55. Removing bumper protector
  56. passenger seat belt stuck not operable
  57. 2010 HHR SS 700 Miles Shifting Issue
  58. Problem w/seat belt latch?
  59. Floppy driverside sun visor.....
  60. Rear Door Adjustment
  61. Bow Tie Falling Apart
  62. Need help with diagnosing problems on a 2006 LT auto
  63. Wheel Wobble?
  64. Stuck in the Driveway!
  65. What could it be?
  66. Rear windows
  67. Black Chrome Wheels?!?
  68. 2008 SS dies
  69. Sunroof rattle
  70. I'm sick of finding bad things about this car...
  71. Happened Again.
  72. Electric Power Steering EZ fix no recall
  73. AIR BAG SRS COMPUTER MODULE - Replacement
  74. Random CEL...
  75. Headlight & turn signal indicator connectors severed from tire blow out :(
  76. DRL Not Working After Bulb Swap
  77. water leak resolved
  78. Does anybody know where the knock sensor is on the 2.4?
  79. Boost Gremlin Dead!!
  80. Window Switch Light Fuse
  81. cost of sunroof repair
  82. Strange paint issue
  83. HHR front end noise.
  84. Intermittant P1174 - Fuel Trim Cylinder Balance
  85. service intervalls????
  86. Coolant use
  87. Codes C0561, P0171
  88. Keyless access
  89. New Problems Appear
  90. Engine Codes?
  91. Adjusting windshield washer spray?
  92. cold start no brakes
  93. Need some tire recommendations
  94. SES Light Code P0449
  95. Headlight problems
  96. #4 mis fire Help....
  97. It's finally over for me
  98. Alloy Wheels Peeling
  99. Right running board adjustment
  100. HHR Wind Noise Advice?
  101. NO REVERSE LIGHTS 2008 HHR Ls
  102. Check Engine & T/C lights ON
  103. I have 2 codes that came up with the Check Engine light.
  104. Temperamental Radio and Alarm Chimes
  105. Rear Brakes clicking noise
  106. Newbie
  107. Computer Reset
  108. Drivers Seat Creeking/Ticking Noise
  109. Positive 12 volt supply
  110. is it just me?!
  111. sway bar links vs. radio........
  112. Fuel Pump issues
  113. problems with hhr premier
  114. Engine Power Reduced
  115. 8th trip to service!
  116. New Noise
  117. Struts
  118. Step on brakes and get an odd noise
  119. Noise when starting the car....
  120. Service Tire Sensor Alarm
  121. Brakes and sounds
  122. Starting issues
  123. 2009 HHR SS Brakes
  124. I need some help......
  125. Back from the dead---advice please
  126. Front end shudder
  127. Broken Glass
  128. Front Wheel Bearings
  129. how to change coil boots
  130. To The Dealer!
  131. Boost issue...Map sensor hitting and my car got stuck
  132. My power steering woes...
  133. In for service again
  134. aero wing spoiler
  135. how to replace lower control arm
  136. Steel wheel covers rattle...
  137. Pissed!!! HHR Key Stuck - Shifter Micro Switch / GM denying responsibility
  138. Filler Cap Condensation
  139. rear door weather stripping
  140. Does anyone know… Blower Resistor?
  141. Check Engine Light on - P1682 code
  142. air coming only on defrost and floor
  143. Blinkers often don't go off automatically
  144. How can you jumpstart an HHR?
  145. dead batterys
  146. No Windshield defrost Air
  147. Should it be illuminated
  148. Reoccurring "Service Tire Pressure Monitor" message
  149. May or may not have shifting issues.....
  150. steering gear failure with less than 3500 miles
  151. Replacing the felt intake tube
  152. engine lt on
  153. Fuel Leak While Adding Gas
  154. Newbie HHR owner has some issues
  155. P2101 with K&N Air Filter
  156. Wrong Sway Bar Links
  157. Lost my Back Lighting
  158. More clutch problems..
  159. DIY rattle fix
  160. 2006 HHR Outside Mirror Switch Up Doesn't Work
  161. 2006 Stick Shift Key FOB Remote Entry Problem
  162. Sudden Acceleration in HHR?
  163. Another Dealer Trip
  164. Engine power reduced
  165. hhr back in the shop
  166. Front Passenger Door Not Opening
  167. Car back from the dealer....again.....
  168. power steering problem
  169. calliper bolt torque
  170. Got Some Things Fixed
  171. Singal/Blinker Issue
  172. TC Light Coming On
  173. Broken Exterior Handle
  174. Rattling Noises
  175. Greasy Headliner
  176. Factory radio creapy
  177. Climate control switch only works on high
  178. Steering Problem
  179. Funny rattle in lower dash/steering area?
  180. Serpentine Belt
  181. Door handle help please
  182. Loss of power while passing
  183. Paint issues on bottom of doors
  184. Hewbie
  185. '09 2.2 5Sp Wheel hop @ Hard accel
  186. Test procedure for cam position sensor?
  187. Key Fob Problems Cheap Fix
  188. Cabin Fan Blower for AC and Heater
  189. Engine light
  190. Mirror Whistle
  191. sunroof drain hole location
  192. 08 LS Automatic shifter "Grinding"
  193. HHR motor stops
  194. Miss fire codes
  195. Auto lights
  196. Whirring noise...bearing or tire or something else?
  197. no power to scanner
  198. Stabalizer links
  199. autopia for light wiring
  200. Front door speakers & turn signal chime out
  201. Help with A/C on 2008 LT
  202. Really need some help....
  203. Heated Passenger Seat Not Warm
  204. Tail light access panel loose
  205. Rear hatch rattle
  206. Squeaky Plastic Solution
  207. GM Recall/Anyone Know?
  208. my transmision feels funny at 51,000
  209. HELP! HHR started to whine on the highway.
  210. Seat belts
  211. Town Fair tire scratched up my rims.....
  212. Key won't come out of ignition
  213. Getting Flashed By Oncoming Vehicles
  214. knocking noise
  215. My HHR Won't Shift Out Of Park, Help!
  216. Dealer installed wheels...
  217. Eng light 2.4 2006
  218. Head Gasket Leaking Oil?
  219. Rear hatch noise
  220. Water on passenger side floor and Blower not working
  221. Suspension clunk.
  222. Headlight issue
  223. Question regarding remote start
  224. Fix to CEL and Reduced Eng Pwr
  225. Electric Door Locks
  226. Passenger door lock malfunction
  227. Need some Opinions
  228. Getting water in driver's floorboard
  229. Engine noise
  230. Normal operating temp
  231. No Heat
  232. Roof Rack parts
  233. Front End alignment??
  234. I'm having trouble with 3rd & 5th gears
  235. New pads/rotors-Low Pedal
  236. Something Remotely Bad Happened.
  237. Front Vibration
  238. Programming replacement key fobs
  239. FYI cracked crankcase
  240. Rear Wiper Sweep
  241. Side mirror failure....
  242. 2 strange issues
  243. Engine code 107
  244. Sticking Cargo Door
  245. traction control, hard shift, camshaft position sensor
  246. Engine Squeal '08 HHR SS
  247. Brake Pads Needed?
  248. Not Working - Cruise, Door Locks
  249. Front Headrest removal?
  250. National back order on SS front struts ?
