PDA
View Full Version : Problems/Service/Repairs
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. AC WORKS, Heater not working,
  2. P0087 = FRP too low
  3. Risk Repair or replace car? And how long can I keep driving?
  4. TPMS Issue
  5. traction light when cold
  6. Can I install back seats in a 2012 Chevy HHR PANEL
  7. !!! EXTREMELY URGENT!!! Did Amazon send me the wrong sway bar end links or what?
  8. P0326 p0014
  9. 2011 hhr LS front end kit???
  10. Head lamp issue
  11. To meany code need help
  12. Coolant Smell
  13. Abs and traction control light
  14. PO302 misfire headache
  15. ZZP flex pipe install
  16. Misfire codes
  17. No brake lights except for center high mount
  18. Question about diag scanner for HHR
  19. replacement radio - missing chimes
  20. Need a good bidirectional scanner
  21. Emissions Waiver or get the right CAT Converter?
  22. FOB only works eighteen inches from front of vehicle.
  23. Unknown Fluid leak
  24. No Codes/ No start/ Starter click/ New battery/ 2009 2lt
  25. Growling when engine braking, louder when turning
  26. I’m seeing a clear type fluid , problems?
  27. Electrical issue(s)
  28. when need to replace the seal Output Shaft Seal - GM
  29. Replacing motor mounts- what else to inspect?
  30. ABS/Traction Control Lights, no OBD2 scanner codes
  31. BCM Issues?
  32. Fuel Tank 20866941 - Vent line issue - looking for new replacement
  33. 2011 Chevy HHR Misfire
  34. 07 Chevy HHR 2.2l ecotech emissions system
  35. Service ESC
  36. Catalytic Converter
  37. Chev 2007 HHR: Coolent Leak Help
  38. Alarm sound coming from speakers
  39. Fairly new/good brakes, but car "intermittently" moves with brake pedal pressed?
  40. 2007 HHR check engine
  41. car won't start or crank after shift solenoid replacement
  42. 9/2024 transmission solenoid codes 2010 HHR HELP
  43. Help needed aligning driver side transmission mount
  44. Runs extremely rough & makes a loud noise after installing timing & balance chains.
  45. Lower Control Arms-rear bush chassis thread- tap length ?
  46. AC doesn't feel very cold, but no leaks detected?
  47. 2009 Getrag F23 - no reverse lights
  48. Hhr codes and questions
  49. Pop Noise when turning Steering Wheel (axel?)
  50. B1325.03 Device Power 1 Circuit Low Voltage
  51. 2008 fluctuating temp Gauge and stalling
  52. Any thoughts? Clutch issue?
  53. Anti theft / U0073
  54. PO302 Random misfire
  55. 2009 hhr center console wiring diagram
  56. Cheap catalytic converters? (Original performance)
  57. Car shuts off while running, Sometimes will not start back up!
  58. I'm not sure if my A/C compressor is engaging
  59. Electrical crap
  60. AC problem
  61. Loud noise from front of car when above 18 mph & gets louder as speed increases.
  62. Another blower motor issue
  63. Weird Issue
  64. oil pressure switch leakage
  65. Starting Issues - Anti Theft/TDM
  66. Noisy transmission
  67. Exhaust manifold replacement advice
  68. P0054 code
  69. Window problems in my 2009 LS
  70. Timing chain problem
  71. Another A/C thread
  72. Random plate gasket for intake manifold
  73. Another! good call from the old guard- start up rattle
  74. Fuel Rail
  75. Exhaust break
  76. Low Power Disaster
  77. AC quit
  78. side Mirror blowing fuses
  79. Replacing head gasket
  80. I’m lost again, many codes
  81. Pending repairs on my '06 LT: Radiator fan not running, warm A/C.
  82. No Throttle
  83. Wireing diagram, BCM
  84. Exhaust flex pipe installation
  85. Fuse/Relay
  86. Speakers
  87. 06 HHR LT 2.4 Engine power reduced engine no crank Fathers Day Fiasco
  88. Code P2270
  89. 2011 LT - Intermittent shudder/stutter in brakes -> ABS light came on
  90. Sudden shutdown while driving
  91. Cruise control and third brake light
  92. 2.0L engine swap
  93. P0171 Code
  94. Wheel Cylinder Torque Specs
  95. low voltage
  96. whose Cam Actuator Solenoid s are best?
  97. Sluggish starting, P0326 & p0336, & crazy gauges
  98. Rear Axle Brake Lines
  99. 2006 Chevy HHR
  100. No crank no start
  101. Thermostat issues, A/C malfunction
  102. 2011 HHR Steering-shifting issues
  103. Veh trailered, won't turn over now
  104. dorman key programmer
  105. 2006 HHR multiple issues
  106. A/C blower won't shut off car stalls
  107. P0420 Diagnostics
  108. Repeated thermostat failure
  109. bouncing gauges, again
  110. No power to anything with new battery
  111. Control arm issues
  112. Cranks ,no start . After changing cam solenoids
  113. Shift Solenoids done but NEW P0842 code
  114. Electrical issue, speedometer gauge bounces up and down, trouble shifting into gears
  115. TPMS right rear!!!
  116. wet floor board
  117. Time for a new engine?
  118. 2011 LT intermittent door chimes after key removal.
  119. Ball joints
  120. Timing chain issues
  121. Need BCM but cannot find one
  122. Need a Original GM remote keyless entry fob.
  123. Manual Shifter
  124. Charging problem
  125. Cv axle/transmission noise
  126. Cruise control downshift points
  127. Electrical issues.
  128. Debris on VVT Solenoids
  129. Driver door wont open to do the door handle repair
  130. Intermittent hazard lights when hitting bumps
  131. Odd transmission issue
  132. 2011 transmission slippage
  133. 2006 chevy hhr 2.4l power steering replacement cause violent shaking in wheel??
  134. Exhaust fell apart!
  135. Power Steering issues
  136. What could cause negative fuel trims at idle and when the car is stopped (0 MPH)?
  137. Winshield washer pump/ power mirrors
  138. P0172, p0053
  139. ABS wire cut Do I need a mechanic to clear code after fixing?
  140. Hmmmmm, slow fuel pressure drop with key "ON"?
  141. Sudden oil loss when put in gear
  142. A/c won't take freon
  143. No tail lights or license plate lights
  144. are these normal MAF and MAP sensor readings?
  145. 2011 LT A/C blowing hot air
  146. Oil leak
  147. 2011 HHR Climate Control Panel
  148. Ugh, always annoying when there's "multiple" OEM parts... which one is correct?
  149. Door Locks Will Not Lock
  150. Thank You to chevyhhr community
  151. Panel lights issue
  152. ESC issues
  153. Error code P0340 and P0341
  154. Problems solved by yall
  155. Po641
  156. Oil leak from oil pressure sensor?
  157. "Command air-fuel equivalence ratio"?? What does this mean?
  158. Oil leak collecting in fuel injector area.
  159. Code P0302
  160. I’m lost
  161. Recommended replacement motor and transmission mounts?
  162. The constant misfire
  163. Temperature blender actuator - strange symptoms
  164. rear wiper motor question
  165. HHR Starting issues
  166. Tpms sensors
  167. Oxygen sensor in 2006 2.4
  168. Ball joint replacement question.
  169. Right rear turn signal bulb keeps blowing
  170. Drain and fill question about the transmission (automatic)
  171. Handy Angi needs help
  172. Another A/C thread
  173. Check engine, P0300 code, Traction Control MIL
  174. Cel, code P300, p301, tc off
  175. 2006 hhr no 5v key resistor signal at ignition switch
  176. Starts and runs for 3 mins then dies
  177. No crank no start.
  178. Timing issue
  179. Sqeaking Sound on Startup.
  180. Shifter Bezel Removal on 2006 HHR
  181. driver door gremlin
  182. Hmmmmm, what are the "good" brands of wheel bearings nowadays in the year 2024?
  183. no ding
  184. No spark
  185. is it safe to spray throttle body cleaner near the "hinge" areas?
  186. more 2006 lt problems
  187. "Exhaust leak prior to catalysts"
  188. Radio Fuse Parasitic Draw...
  189. Need help with power steering problem HHR location: Netherlands
  190. Was told by the quick-lube place my alternator might be overcharging? Need thoughts
  191. Will ESC affect transmission from going into OD
  192. Quickie question about "how to properly crimp" for a wiring repair?
  193. 2007 LS: can someone explain these numbers from my alignment earlier today?
  194. 2006 LT engine troubles
  195. Six CD-Changer/Radio on the Fritz
  196. Underperforming alternator diagnosis
  197. Sounds Like Valve Tap
  198. Transmission not responding when shifting into gear
  199. CEL and P0011 code on 2011 LT
  200. 2006 chevy hhr no crank/ start
  201. Timing Chain Replacing
  202. Soft Brake Pedal
  203. Horn inop
  204. 2008 LS Overheating - Diagnosis help?
  205. Oil Pan Gasket Makers
  206. HHR LT w/2.4 Ecotec Starts but Doesn't Run
  207. 2009 HHR 2LT key Fob programming
  208. Water pump replacement
  209. cambio de motor
  210. Vibration
  211. '08 HHR LT no crank no start, fuel pump powers on
  212. Cranks and dies P1682 & P0689
  213. clear coating bubbles
  214. lost body part
  215. Water in the spare tire area
  216. Emissions test 2024
  217. 2006 HHR Door locks- All dead-dealer no help
  218. 2011 Fuel line question
  219. Drain problem. Water floods passenger side floor
  220. Kind Of Emergency
  221. Issue with esc message
  222. Solenoid issue?
  223. Sluggish cold start
  224. Electrical issues.
  225. Transmission Coolant Lines filled with Oil
  226. Swapped thermostat in the SS
  227. Strange Problem, Fuel Smell
  228. 2010 electrical issues
  229. Dead Transmission
  230. Wiper transmission linkage to motor removal
  231. Radiator Leak in cold
  232. Dash lights flickering ,no crank no start
  233. Won't start
  234. Keyless Entry System
  235. P0455 code, car stalled out after fill up
  236. First Time Post - Radio
  237. Temp gauge flatline no temp readout
  238. Minor moisture on floor and windows
  239. My 2007 HHR
  240. Timing chain question
  241. 2007 HHR - Can’t turn off headlights
  242. Lock with power door lock, immediately unlocks.(Driver only
  243. 06 2.2 coolant in spark plug hole
  244. Do I need to change my starter?
  245. Error Code U0121-00
  246. What did i do to my SS????
  247. 2010 hhr goes forward in all gears
  248. Service ESC Dashboard Alert Help Required!
  249. 2011 HHR 2.2L Coolant gauge issues
  250. Battery: Confriming It's Bad (Or Good) Request
