PDA
View Full Version : Problems/Service/Repairs
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. Dealer replaced steering motor
  2. Flasher work sometimes
  3. Fuel Line Bracket Studs?
  4. Fuel System Troubleshooting Help Wanted
  5. Blank engine temp …F
  6. Codes opel corsa e
  7. 2008 body control module
  8. Squirley off the line and clutch question
  9. Please Help
  10. Dreaded intermediate shaft?
  11. Poor handling
  12. Go to start and eps fuse keeps blowing
  13. no communication EBCM?
  14. Coolant filler cap very hard to turn
  15. 2008 HHR SS overheating
  16. No crank problem
  17. P0341 2007 Chevy HHR 2.2L
  18. Glitchy right turn signal
  19. Lumbar Motor Replacement
  20. Lift gate adjustment
  21. 2008 hhr passenger water leak
  22. Power mirrors not working
  23. New code in my 2009 money pit
  24. HELP! IPCW Tail light problem
  25. VATS delete Please
  26. Instrument cluster reboots intermittently
  27. Transmission sounds
  28. 08 HHR LT no communication with any module with my scanner
  29. Hhr high rpm then hard shift, no code thrown
  30. 2006 water pump replacement nightmare
  31. Please help
  32. Check charging system
  33. HHR will not start
  34. Power Mirrors Not Working
  35. 2006 HHR possible electrical issues.
  36. Hello all
  37. Front end clunking!
  38. In search of 2009 HHR SS power steering control module
  39. Automatic Lights convert to Daytime Running Lights
  40. 2006 No Power to HVAC Blower Motor Control Panel
  41. HVAC control panel
  42. TPM shows dashes on front tires
  43. Electrical problems? Or dead battery!
  44. Power steering still stiff
  45. Spindle nut
  46. P0172
  47. Reviving 2009 HHR LT 2.2 after sitting 3 yrs
  48. Air conditioner
  49. 2008 HHR Panel Tailgate Issues
  50. Blower motor not working.
  51. Air Conditioning Filter Drier
  52. P0341 and Misfire
  53. 2007 Hard Shifting from 1st gear
  54. Door lock stuck open
  55. 2.2 poor performance
  56. Code 0016 Camshaft Sensor
  57. LED Upgrade
  58. Overheating
  59. Brake master cylinder cover
  60. Washer Pump
  61. 2.2L engine no start, zero fuel pressure after sitting
  62. Dead battey
  63. ERROR CODES. HHR Running fine.
  64. TPM Switched
  65. Is it my timing chain
  66. Curious if my cluster was replaced before I bought it?
  67. Bushings and cage nuts
  68. intermittent no crank or start
  69. Typical Lifetime of Battery
  70. 07 Starts then stalls
  71. Locking Fuel Cap Fit HHR LS
  72. Crank position sensor
  73. Bought 2011 HHR Monday, code P0100, bad intake duct?
  74. 2007 2.4l Air Compressor ☠
  75. No sparks when connecting jumper cables
  76. Power Steering problems
  77. Front End Noises
  78. Intermittent battery warning light
  79. 5 speed gear shift problem
  80. Summit Racing Equipment. Is it a reliable supplier?
  81. Door pop
  82. Correct Axle seal part
  83. oil seal?
  84. Loss of power
  85. AC Stopped
  86. A/C System Knowledge
  87. Starting issue
  88. Service ESC and Power Steering
  89. 2009 HHR no start
  90. Hum
  91. 2011 HHR LS -- ABS and Traction light both on at same time
  92. 2009 HHR Absolutely no power!
  93. Metallic noise
  94. Pop up front when beginning to back up
  95. Catalytic convertors killed my car?
  96. Need advice
  97. HHR electrical issues TCM
  98. Fumes/carbon monoxide in cabin
  99. Guages and radio
  100. Key Ignition
  101. Battery Drain
  102. Retrieving Item Fallen in Defroster Vent
  103. AC problems 06 2.4
  104. A/C Vent Hoses
  105. Randomly won't shift out of park
  106. 06 HHR Temp gauge and AC compressor not working
  107. In a panic!
  108. Serpentine Belt / Check Engine Light
  109. Burned/bubbled front turn signal bulb, socket and lens
  110. Need Help car dead key stuck in on position.
  111. Manual transmission issue
  112. Ac compressor blew all 134A
  113. A/C Issues
  114. Old alternator and new alternator not charging, No battery light or codes
  115. proper way to install oil filter ?
  116. Brakes
  117. How many bolts
  118. Dropped the TB divider into intake, how screwed am I?
  119. erratic steering
  120. security lock SOS
  121. Intermittent Cruise Control Outage: Yet Another Post!
  122. P0014 Code 2011 HHR
  123. Tpms….
  124. More problems with my 07 Chevy Money pit
  125. Auto Lights
  126. Butyl Patch
  127. Infamous Vague Code P1174
  128. After Camshaft Position Actuator Solenoid replacement
  129. Part connected to 25803946
  130. 2011 HHR temp gauge problem
  131. engine rattle
  132. Missing washer
  133. Coolant temperture sensor keeps needing replaced.
  134. Intermittent strange behavior
  135. Help with a problem
  136. P0171, P0300, Traction Control
  137. Diag Code P0303
  138. hydraulic lifter question
  139. DRL not activating
  140. Rear doors won't power lock
  141. Power but no crank
  142. 2007 catalytic converters
  143. AC Freon Pressure
  144. Intermediate shaft bolt
  145. Help
  146. HHR in General, but looking at an SS.
  147. Thanks. My wife backed onto a curb she didn't see with passenger front tire
  148. missing
  149. 2006 hhr problems
  150. Shock Eyebolt length center to center
  151. I don't have the tool to remove the key lock nut
  152. Shifting issuses
  153. Gauges and Dashboard lights not working.
  154. P0480 Code.
  155. 2009 HHR Panel LS Parts Confusion
  156. Another day, another problem after replacing injectors
  157. Steering Air Bag
  158. Chimes
  159. Sunroof Problem
  160. Chevy HHR LT 09 Service ESC/Traction
  161. Hhr did start but engine stopped
  162. Programming new transponder Key
  163. Body damage
  164. 2010 w/ 2.2L chugging
  165. New to the herd
  166. A/C - What happens next..??
  167. Stabilizer bar end links replacement
  168. Evap Purge Valve Mount Oil Leak
  169. P0446
  170. Humming noise
  171. Cooling fan not turning off issue
  172. 2010 interior drivers handle won’t work
  173. The infamous front end vibration...
  174. EVAP problem
  175. 2006 HHR Sunroof issues
  176. Coolant temp sensor wiring
  177. 2009 HHR SS Stalling in traffic
  178. Blower motor power issues?
  179. gas cap
  180. Strange engine noise
  181. Rubbing sound from steering column, and other symptoms
  182. Wiring schematics and diagram for 2009 HHR LT
  183. Beyond frustrating
  184. Strange HHR problem
  185. Timing set
  186. Headlight connector wiring does not match
  187. Changed Cabin Filter - Now What's That Noise?
  188. Lamp wiring messed up...trying to diagnose
  189. Shifts in and out of gear
  190. Blower Fan Wiring
  191. Rattle Under Steering Wheel ONLY WHEN AT STOPS, HOLDING CAR BY BRAKING
  192. Reverse not working seems like car is in limp mode otherwise
  193. Harmonic Balancer
  194. How many miles did your alternator last?
  195. 12v power outlets not working
  196. Limp Mode, no trouble codes, traction, abs, and svc service notices
  197. Alternator choices
  198. Headlight Won't Work
  199. Help !!!!!
  200. 2009 HHR LS 2.2 crank no start
  201. Squirrel/ wiring problems
  202. 2007 LS Bad front suspension
  203. Airbags Did Not Deploy
  204. Timing chain tensioner
  205. Sounds like old VW Bug
  206. Rear Wiper Fluid not Working
  207. Interior liftgate removal
  208. Starting to look like a power draw
  209. windshield wipers
  210. Hhr
  211. Remote star not working
  212. on again off again electrical
  213. Metal shavings in oil
  214. doors randomly lock and unlock
  215. Can Fast blink from LED turn signals cause damage
  216. Several Codes 🙄 and Odometer Problem
  217. Interior Passenger Door Handle
  218. Car Locks and Unlocks while driving
  219. New alternator and battery. Still no charge
  220. 2008 HHR climate controls
  221. How To Replace BOTH FRONT Axles
  222. Intermittent Charging System Fault
  223. What bumpers are interchangeable with a 2007 HHR LT
  224. 2006 HHR California Smog Check Repairs
  225. P0128
  226. I badly need help
  227. Do you think this sounds right?
  228. Windshield Wipers Intermittently stop
  229. Can I or can I not program a remote for my 2006?
  230. Radio only partially working after alternator replacement......
  231. Clicking under waterfall. And relay behind BCM?
  232. Remote Unlock Turns On Headlights
  233. 2010 HHR Shift Solenoid Question
  234. P0010
  235. P0171, No AC, No engine fan, runs rough higher engine temps
  236. P0013 code
  237. Power Steering Turns Off While Driving
  238. ESC now shifter relay issue
  239. CV/Trans Axel question.
  240. Third brake light not working
  241. Mushy brake pedal
  242. Bi directional obd2 scanner
  243. No FOB’s with new to me 06 HHR
  244. Is it possible to reverse the VVT sprockets?
  245. Chevy Recommends New Engine
  246. Key fob replacement and functions
  247. Clutch master cylinder
  248. Key Fob Follies
  249. Everything's going crazy
  250. Horn Issue
