- New Brake Issues
- Manual SS tranny, no reverse!
- bumper fog light plugs
- what's on the radio?
- Ice in doorwell
- Odd squeak
- Thermostat or Water Pump?
- HHR service manuals ?
- miss fire codes
- Thermostat repair
- 2006 Stock Radio Operation
- Key removal
- Dead battery problem fixed!!!!!
- Drives like new
- Tire Pressure Sensor ?
- Help 06 HHR :blower fan stoped working on setting 1-3. Water leak inside
- sloshing noise in the morning
- coolant temperature readout question??
- HELP! Power Steering Replaced/Anyone Else Had Issues With Theirs??
- Hot smell in engine compartment
- PLEASE HELP. Fried computer after "jumping" the fuse box?
- Ignition Control Module Replacement
- My SS is in the shop again
- Low beam headlights won't come on
- fuses
- HHR left me stranded today! Has this happened to anyone?
- Remote Start
- Open Hatchback with dead battery?
- Noise when pressing on the brake pedal?
- Keyless entry
- Collapsed Lifter?
- Catalytic Converter/P0171
- 06 Amber Turn Signal Lenses Melted
- miss at 40mph
- Dead RKE
- transmission issue
- Rear Interior light bulb?
- Rear seat backs don't latch
- Redesigned rear liftgate?
- Am i wrong ?
- Remote start
- 08 steering
- Key Fob Broke
- compass is dark
- 2009 HHR LT Error Message ECR Traction.
- Radio Static
- Power loss & cel today
- Heater core replacement 07 HHR
- 2008 HHR LT owner
- Need third brake light access
- Heater problem
- Oil filter leaks down?
- Transmission problem, car cant drive
- Cloth seat issues
- Those Surveys actually work, maybe?
- Information from G.M. on traction control issues
- FYI on shifter knob
- Driver Inside Door Handle Broke
- HHR parasitic (phantom, mystery) electrical drain, dead battery
- Bad vibrations
- Heated Seat Switch Light Flashing
- I think I lost my Turbo
- Ready to replace stereo system, but affraid of BCM issues
- 1 Month Old and Dead Battery?
- Driving up on ramps w/o scraping
- lost all Instrument readings
- Trust the DIC for Oil Changes?
- I feel that I almost got scammed in a way...
- Steering Column
- Traction control probs on HHR unfixed?
- Cargo area carpet w/seats folded down
- a/c compressor
- new blower motor not working
- Issues with tranny rpm versus engine output
- Premature Unwanted Oxidation
- Rear door unlocking problem
- A number of repair questions from a new owner
- front seat back panels GRRRR!
- Code P0442
- Here is a good Video on brake issues
- Fan noise
- Problems with my Rear Defrost still!!
- 2009 LS Oil Leak at 8400 miles
- Keyless entry quit working?
- Electrical issues.... Console and tail lights.
- dome light removal
- SS Handling bad sinse return from dealer
- Error Code PO340
- HHR Headlamps...
- New owner, A/C vibration ?
- Lemon Law Help???
- Well it happened, brakes
- Sloshing noise
- Cylinder 3 misfires
- Clutch grinding?
- Squeaky noise on a 2009 HHR
- Anyone out there.......
- Re-setting Tire Sensors
- "TWANG!" Seat noise - advice please?
- Radio Buttons randomly not working.
- TPMS not reading.
- Automatic Transmission Problems
- Air Filter
- third brake light staying on after off and key removed
- Ignition locked and key won't remove!
- Is it a Lemon?
- P0010, What to replace?????
- Rear wiper parking inconsistently.
- Another error code P0010
- check engine , code , help ?
- check engine light= new cylinder head?
- Reading codes?
- Dic and door locks
- key stuck
- XM Radio Weirdness
- Brake lights
- 2009 Console/Waterfall disassembly diagram/blow-up?
- Jack points
- Steering Wheel slightly tilted...
- Service ESC and Traction warnings
- Dome Override
- Battery Vent Tube Broken
- Blower motor making noise
- HHR SS with a miss!?
- Camshaft Error thrown, but HHR has no camshaft..
- front end click
- Leather seats...grr
- HHR SS dash lighting issues
- Mirror LED & Bluetooth Stays On
- Radio problem - new to forum
- Condenser blown- still under warranty but not paying because it was a rock
- I think my water pump is gone....
- exhaust rattle
- Anyone else with engine revving between gears?
- Electrical Output
- good news hopefully
- Service Warning Messages on New HHR
- Discharged Battery. Recharged fully. No start After
- Fuel Pump Warning
- Clutch?
- Noise coming from front of car
- Cancel Interior Lighting?
- Temp gauge stops at 180
- HVAC fan speed control only works on high
- Stumble/Stutter 2.4l
- Windshield Wiper Problem
- Check engine light and........
- EBC Rotors and Pads. Any opinions?
- loud snap sound
- Noise in 2.4 above 2500 rpm
- Chrome cover over shifter A/T vehicles
- ? for those that have had the aux brake fix
- power mirrors
- Couple of problems after intake manifold installation
- I need help! Cooling fan is working non-stop...
- Center console
- Have you guys used NON dealers for repairs?
- Electric door lock chime sound.
- Bcm
- Water Pump Replacement 2.4???
- SVC Brake System Message
- Illumination issues
- Oil Change ?
- surge/hiss
- Brake fluid issue?
- Door lock not working.
- Dash power outlet not working.
- Weird Electrical Stuff
- Sunroof rattling in vent mode?
- Temp reading
- Potential Exhaust Leak?
- Water on floorboard
- Sun Roof Issue
- leak in passenger foot well
- Reduced Engine Power problem
- Steering Wheel Shimmy
- Radio buttons stay lit
- Water sloshing around under hood after rain.
- Blower Motor Change-out
- SS Boost limited to 5 psi, clutch slipping?
- Good Vibrations NOT
- Windshield washer pump dead.
- Ok, here is the deal for those with USB issues
- TPMS Sensor Stems
- Clutch Pedal
- Growling up front...
- Cruise Control Surging
- Compass not working
- Rock or Debris Damage to Radiator/Condenser
- Disc Brake Rotor Prices...
- sub and amp
- New Special Policy for Certain 2006 HHRs
- Question about the ESC light
- Gear lock out
- Leaking Front Struts
- Here's a doozy.
- Problem with Rear defroster grid- 1 line not working???
- No pwer steering after a dead battery jump?
- horn replacement problem
- I see a future Problem with the HHR Rear Hatch
- Seat Play Issue?
- How far can I drive????
- hard pipes
- I now officially HATE my USB port on the radio....
- Is this much tire air loss normal?
- Misfiring
- Stereo/Electrical Issue - Need Help!!!!
- Tire Pressure Problem
- A/C compressor probably shot
- Cracked Flex fitting on Downpipe...
- heated seat light
- Warranty issue or .... ?
- Check engine reset
- 98,000 miles , is everything falling apart?
- Mountain Dew spilled down in shifter now it takes a while to shift into drive
- Exhaust fumes in cabin
- OS wheel vibration driving me mad! help!
- Code P0010
- Cleaning a GMPP Intake Air Fitler????
- Trans Problem i think?
- USB issue
- Stalls with operation of Tilt Wheel
- Almost stalling?
- How do I shut off the alarm?
- Need your help for info! GM is saying now harness till OCT!
- WTF is up with getting parts.....
- Horrible noises!!
- low profile rims
- Speaker pop
- Aux brake pump and new rim fix turned it to atleast a week. My dealer sucks!!
- Key Fob Not Working
- A/C In Neutral
- Key will not turn but steering column will
- Road Rash
- Driver's door lock problem
- What is the Serial Data Line??
- Whining noise when a/c compressor is on
- Chevy emblem
- Manual trans carpet issue.
- Issues w/ dealer not the car
- D.o.a.
- Headlamps won't shut off...
- Real Problem
- key removal issue
- A/C won't cool
- Drivers power door lock question
- Multi-Point Inspection
- Backup light issue
- Seal Strip Driver door
- Grinding noise on startup ?
