- Help with CEL
- Clunking/scraping noise when braking
- P2135, related? Oil in ecm connector
- No crank no start
- Change in MPG
- timing chain removal and replace
- Tail Lights Out
- Sensor Diagnostic Module AKA SDM
- best place to get estimate after accident?
- right low beam problem
- Electrical Issue Brake Lights/Rear Wiper/Cruise/ plate light
- flashing engine light
- 06 LT New fobs will not program
- What's happening?
- New Bearings Trigger ABS and ESC lights
- A/C short cycles .. blows hot & cold
- Loose cigarette lighter socket
- Hhr 2008 in panama
- Service Traction, Check Engine, Traction Control
- 2008 hhr key fob
- Engine Or Transmission
- A/C issues
- Brakes and rotors
- remove trim plate holding window and mirror switches 2011
- ALARM and Horn does not sound after towed
- 08 HHR Windshield wipers only work on high
- AC still not working after thermostat change
- Everyone who's living without a sunroof wind deflector
- new car clunks
- Shift Solenoids and other codes
- Windows won't roll down!
- Replaced hub - now car won't move
- Ac problem
- Won't start
- Is steering column rattle a safety issue?
- Power mirror switch replace
- Water Leak - Rear Seat Back - Both Sides
- Many problems, timing chain
- Whining sound from drivetrain
- Possible issue with catc
- P0442 chevy hhr 2009 .... help please
- "Engine Power Reduced" car stops accelerating then engine won't start.
- Intermittent clicking
- Won't start
- A/C cycling between warm and cold air.
- Be careful!
- slight shutter
- Evap System Frustration
- temperature up
- service light
- Acceleration issue
- Running hot
- Engine swap
- sun visor - alternate gm parts compat
- BCM inop. HHR SS
- Chilton DIY
- Abs
- P0107 and Service Traction/ESC ESC Off??
- Transmission Carrier Bearing?
- Rear hubs
- dash & radio lights go dim in daylite
- Engine trouble codes
- Rough Idle on Hot Start, clears up
- Dorman FOB and Programmer
- 07 hhr not shifting out of 2nd
- Power door locks not working
- MPG and Struts - Answers Please
- Engine Temp Sensor
- Tire sensor issues
- BAD Antifreeze leak 2010 2.2
- a little hard to start and the smell of gas
- Hazard Switch
- Sunroof crapped out
- Camshaft position sensor problem, Code P0341
- Engine Limiting Power
- TCM trouble code help
- 06 HHR No Crank No Start
- Whine noise
- Had a bit of a crash and now....
- WHere is the RF module?
- P0300
- Hot fan relay and AC out
- Fuel Line repair Hhr 2007 LT
- Power Steering/Service Airbag Message
- Both headlamps / headlights completely dead
- Hewbie
- CD error
- Cooling Fan Not Working and Blown Fuse
- Seized motor/Motor swap
- Rear wiper switch kills the car!
- Timing Chain Life on HHR Ecotec
- I see how this fourm is
- Lazy shoulder harness belt
- Master Cylinder
- Wow this hhr loves me, p0420 cat eff low?
- Steering wheel stiff
- HHR cooling fan low temp cut off?
- 2009 HHR 2.2 intermittent miss at idle
- Steering Column Rattle
- Cabin (spare)Fuse box layout
- 2007 hhr broken valve lash adjuster
- I need help - W/W reservoir removal
- Center Brake Light stay on?
- Temp gauge flat lined..
- Light on the radio stay on
- 2006 chevy hhr evap and catalyst not ready
- Intermittent P0420 without other codes
- Squealing in gear while idling
- 2010 HHR overheating
- Cam Actuator Fail
- Fan not working.
- 2009 security light stays on
- Engine swap?
- 2011 Remote mirrors
- Battery died
- Broken Rear Spring
- Fuel injector question
- Problem O2 Sensors / Codes
- Help!! SS smoking!
- Hey guys new member here need help
- Rear suspension noise in cold weather
- 2007 key fob - original fobs
- While driving lost power
- 2006 Chevy HHR cranks but won't start
- Camshaft solenoid or timing chain?
- shudder at 60MPH and noticable clunk when releasing brake from complete stop
- Wippers go on all the time
- replacing multifunction switch(turn signal)
- Alarm
- 2008 HHR Klunking
- Fan not working
- P0420 and p0172
- Need to repair codes so I can pass inspection
- Waterpump replacement woes
- 2011 hhr
- 07 LT Key Fob problems
- Oil pressure issue driving me nuts
- No power.
- Headlamp bulb issue
- Coolant leak disappeared
- key fobs & tpms
- Explanation on how the charging system works
- Ecm
- door lock problems
- Clunking front suspension.
- Transmisson won't shift out of 1st gear...
- Door locks unlock randomly
- Hard Shifts, Clicking, Car Shaking, Speedometer Erratic & More!
- 2011 dash air vent louvers
- My HHR won't start after hit
- Replacing Lower Control Arms is EASY
- No power on my alternator
- Help! Airbag sensor going off after installing a seat.
- Different Suspension Noise
- Front end clunk returns
- No Power to right side fog light?
- dashboard lights not working
- Transmission Box
- Charged battery and now have a whole list of issues
- Fog light wires
- Lights are on but not cranking
- Gas smell
- Door Locks
- Steering wheel rocks to and fro
- Seat belt plastic button
- security mode? horn honks...key won't start now
- suspension damage help
- Brake lights
- Sway bar link part nos?
- No Power From Cigarette Lighter
- Still Having Gear Shift Knob Problems
- 2010 2.4l - p0010
- Steering binding
- Random Stalling Issue
- Knock Sensor Connector for an Oil Leak?
- rearview mirror map lights won't turn off
- crank no start
- P0365 Code - 2009 2.2 litre LT - My experiences
- No crank, no start, no communication
- Heater blows cold
- ABS code and service traction control
- Flickering headlights and all Cabin lights during idle
- Engine wiring
- Engine wiring harness
- HHR LE9 to LE5 swap?
- 2008 Chevy Impala headlight problem
- Fuel Line Replacement - floor pan mount advice.
- TC light & ABS
- 2011 HHR Power Locks
- Tachometer won't zero
- ABS and anti skid warning lights
- rear passenger side floor?
- Feels like I'm driving in the wrong gear.
- struggle starting in cold
- Computer failer ??
- Reduced pwr, engine disabled, service traction/esc. yowza.
- My HHR Is Very Sick
- Another passenger wet floor thread
- Am I missing an O2 sensor?
- So many issues
- ? Heater core leak
- Intermittent Remote Start Issue
- Headlight out again
- Need help on changing transmission fluid in a 2006 Chevy HHR Please and Thank you!
- Is Motor Mount Sealed?
- Front and rear suspension
- shift knob
- Sunroof drains freezing at the outlet this winter.
- Hard start when cold, no codes.HELP!!
- Rpm's bounce around at low speed
- Front Windshield Streaks/Leakage
- Battery light on/check airbag/power steering lights and car dies
- Engine will not crank
- Key stuck/won't start question
- Will not put start unless you put pedal to the floor
- Ground on headlight
- Deja vu: hood latch punctured condenser...
- Suddenly oil leak, no remote start, camshaft position actuator P0010, airbag light
- Timing Chain???
- Cylinder coil....
- Pulled Wires out of Headlamp socket
- 5 speed shifter problem
- EVAP cel
- Coolant disappearing/possible coolant leak
- Car cranks,but won't start unless...
- I like my HHR but... List of issues
- 2010 blower issues
- 2007 hhr throttle body & pedal sensor codes
- Tire Pressure Monitor issues
- Coolant tank
- Intermitten Power Steering issue
- Water on passenger floorboard
- static from speakers when i open the door and stalls
- High idle and P0507 after cleaning throttle
- Rough Idling and P0301 Otherwise runs great
- ESC / Check Engine Lights
- HELP. Front end thump
- Stuck oil filter cap
- red light
- Temp gauge shows well above normal
- Gas mileage dropped
- Brake judder again
- Engine shake/Rough idle while in gear
- TPMS Error
- Washer pump or switch
- I swear this isnt a joke....Fog horn noise. Egr or pcv?
- Can I just detach the sway bar?
- Gregg, the spoiled, temperamental HHR. A P0128 story.
- Steering position sensor calibration not learned
- Cam sensors
