PDA
View Full Version : Problems/Service/Repairs
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. Knocking noise when reaching 4p mph
  2. radio problems
  3. Driver side window not working
  4. 2006 hhr 2.2 getting fuel but no spark
  5. Headlights, OBDii port, front cigar lighter -> all a freaking problem!
  6. Straight drive handbrake
  7. Problem after replacing front hub
  8. When changing the thermostat gives the car a heart attack!
  9. Cooling Fan
  10. Heres a good one !!!
  11. Noise with a tiny vibration starts only when reaching 40+ miles per hour
  12. Multiple issues - 2011 HHR LT2 - 101k
  13. Front End Clunk (another post)
  14. Pull handle 2x to open door?
  15. Horn blasts on its own unexpectedly
  16. Brake Caliper Bracket Replacement
  17. Overheating
  18. Check Engine light
  19. Chevy HHR Clock Spring
  20. P0102 p0053 codes,cel and t/c light on
  21. Power steering
  22. Quick Question Regarding Wheel Studs
  23. 2009 HHR LT 2.4 ecoengine Rear View mirror wiring harness part number
  24. New Key and Fobs
  25. help! (cant find this exact problem thru search) rubbing noise
  26. Leaking water through hood release
  27. Puzzled
  28. Manual Trans Fluid
  29. Fog light install - no start condition
  30. acuater help
  31. Needing help
  32. Steering shaft, 2009 LT 2.2 litre
  33. Electrical - no a/c, no temp reading, but no errors
  34. 2011 HHR growling from Left front tranny
  35. car not moving when in drive
  36. Sunroof drain hose missing?
  37. 2006 HHR climate control panel ...
  38. Yakima Roof Rails Install Info Please
  39. 2006 2.2 Automatic P0340
  40. P0010 and P0013 codes - can you just clean the solenoids or do they have to be repla?
  41. jump starting late model vehicles (2007 and up)
  42. HELP!!! brakes mushy...
  43. Automatic Transmission Question
  44. Timing chain?
  45. Evap Canister Solenoid connector
  46. Engine electric fan keeps running when I cut off A/C
  47. Keyless entry problem
  48. 2007 hhr radio speakers
  49. What brand Catalytic converter should I get?
  50. Intermittent Screech from 2006 HHR
  51. Wheel bearing
  52. P0449, 2007 hhr ls
  53. tps sensors
  54. 2007 Chevy HHR LT dreaded shift stuck at park
  55. Motor Mount Question
  56. Occasionally stalling when stopping
  57. Water droplets from vents with blower on
  58. Traction control and service engine light on in my '09 . It's a manual 4.0. It
  59. Ac only blows cold while car is moving
  60. Starter issues
  61. Transmission - Lost Top Gear
  62. No blower
  63. Method of fixing damaged threads on rear shock lower mount
  64. Ball joints
  65. 2010 HHR LS engine surges
  66. Oil Leak
  67. More Evaporator drain problems
  68. LR Window
  69. Power Steering/Traction Control/multiple Warning Lights-Video Included
  70. Abs light
  71. ​​​​​​​Newbie adds a Woolly Worm idea & question!
  72. How long can i drive if I need my control arm looked at?
  73. Some lights don't work
  74. Take a look at my fuel pressure test?
  75. AC is it a TXV?
  76. problem with a/c drain leaking with heat on
  77. Close but not quite
  78. Stablizer link threads
  79. 06 hhr temp not reading but a/c works
  80. Rain leak Driver's side
  81. Headlight problem
  82. No brakes
  83. water pump replacement question
  84. Windshield trim molding rubber seal gasket fitment
  85. is this what the timing chain and top guide are suppose to look like ?
  86. Camshaft removal - VVT sprockets stuck
  87. P0014 after installing new Actuator
  88. AC Delco timing chain tensioner problem
  89. P0011 code-Running by the gurus
  90. Shaking in the steering wheel when braking, but only on highway
  91. ac does not work ang guages on instrument cluster
  92. Traction control issue
  93. Front end clunking on a 2007 chevy hhr
  94. Help! Help! Help!
  95. Timing Chain parts list check
  96. 14 miles per gallon,,, help ????
  97. A/C Charging issue
  98. Steering Angle Sensor?
  99. Changing AC default setting
  100. Need help please
  101. Having issues putting in gas, dealership is insane
  102. Wipers are acting goofy
  103. Clicking passenger side airbag
  104. 2006 engine swap with 2008 g6
  105. Gauges not working 2011
  106. I was running sluggish, but it went away on next start?
  107. Gauges going crazy - electrical problems continuing
  108. SS gets hot
  109. rear hatch won't open
  110. Gusty gag
  111. Need Help
  112. 06 HHR check charge system
  113. Battery going dead when radio is on
  114. 2007 HHR nothing but a problem.
  115. Crank sensor
  116. Looking for mechanic in the Chicago area
  117. Is this the cracked flex pipe hiss?
  118. P0172 Code- Help Please
  119. Rattle - timing chain?
  120. Water tragedy...
  121. Coolant Temps Bouncing all over
  122. Timing Chain is tight but Guide is chewed-UP P0016 P0017
  123. Need info on part orientation
  124. A/C Compressor Not Running
  125. Issues after engine replacement
  126. Fuel line body clips
  127. Knock Sensor Replacement
  128. No brake lights
  129. 2008 HHR 2.2L Suitable Engines.
  130. My A/C Wires have condinuity but no voltage what’s a fix for this????
  131. 2011 HHR LT issues
  132. HVAC control
  133. Chip in my tire, need replacing?
  134. Can't turn off my ignition.
  135. Tire pressure monitoring system error
  136. i have a crazy hhr first one out of 200 plus HELP
  137. coollant warning
  138. Panel rear door/liftgate issue
  139. Adding keyless entry to a 09 LT
  140. O2 sensor problem
  141. Lost communication with TCM/ ECM
  142. Cruise control
  143. Dashboard shorts out
  144. exhaust manifold leak
  145. Radio only works thru tweeters
  146. Cranks- no start -no spark
  147. Where do I begin? Too Many DTC’s
  148. Driver side Door Lock assembly
  149. Cranks, but no start
  150. 2008 Chevy HHR air/cooling issue
  151. 2011 Chevy HHR with car/lock symbol
  152. Maintenance schedule
  153. 2008 hhr cranks won't start
  154. Gas mileage
  155. 2007 hhr 1lt 2.4 a/t
  156. 006 HHR Radio issues
  157. Ac on dying out
  158. Faulty Speakers
  159. Engine power reduced code on my control panel??!
  160. HHR Rough Idle On Start
  161. No start
  162. popping noises after control arms installed
  163. Help! Need clarification on coil pack vs timing chain
  164. Question about air bags.
  165. Drive Cycle questions
  166. No coolant temp
  167. Front end squeak
  168. ignition cyl replaced, now no electrical...expert advise plz
  169. o6 clunk
  170. Time chain guide bolt plug
  171. 2006 hhr
  172. Valve cover installation help 06 2.4
  173. 2007 2.4 lt catalytic converter replacement
  174. Steering wheel doesn't center
  175. Lots of electrical issues
  176. A/C and Alternator issues
  177. How dire is replacing the O2 sensor? (please read)
  178. 2006 HHR Electrical Issues
  179. Engine Turnover and leaking fuel?
  180. 2008 chevy hhr wont start amd weird dinging.
  181. Press brake pedal, rear wipers turn on.
  182. Exhaust Stud
  183. Transmission won’t shift into 4th at all
  184. Mount up! We’re tracking shimmy shakes! An engine transmission mount problem
  185. Strange codes
  186. Car won’t start after replacing engine!!
  187. 2007 CHEVY HHR ls 2.2 wont shift past 40mph
  188. 2007 HHR car stalls when I apply the brakes, battery draining
  189. Pins/connectors needed for pcm?
  190. no crank/ignition switch voltage
  191. Front Struts Replacement
  192. Intense rocking and bouncing from side to side.
  193. 06 HHR 2.4L engine, lots of electrical issues?
  194. stalls in traffic
  195. HVAC Fan Switch Replacement
  196. I need a part
  197. 2007 hhr code issues
  198. 08' Evap Drain Has Something Completely Blocking It
  199. 2010 HHR Slow coolant leak
  200. Please help!! 2009 HHR
  201. Automatic Transmission
  202. Broken Bracket Wont Allow Window To Close Entirely
  203. Speedometer not working
  204. ESC, Service traction, and ABS
  205. Passlock warning light flashing
  206. electrical
  207. Brain twister
  208. whine w/ engine speed after timing/balance/etc service
  209. Main lights won't shut off
  210. Fault P0016 Problems
  211. Radiator cover holders, how loose?
  212. Steering
  213. Power Window Issues
  214. Hissing vacuum like noise from dash on accel
  215. Oil Pan Gasket
  216. needed torque specs for engine replacement
  217. draining battery
  218. 2007 HHR Won't Crank/Start & No Fuel Pump
  219. Suspected fuel leak
  220. Horn wiring
  221. Coolant gage flat lined again.
  222. Sticking /Locking Front Brakes.....?
  223. Driver door stuck
  224. Some interior lights not working
  225. Cooling fan fuse keeps blowing
  226. ABS code C0280
  227. Programming FOB
  228. Car is all over the road!
  229. Is my bcm bad in my 05 yukon
  230. Timing Component Questions (cam gear bolts? 90537451 vs 11588844?)
  231. Where is block coolant plug bolt?
  232. Timing Guide Bolts; ARP vs Dorman vs Mike Brandt vs Havuk Ind?
  233. 2006 LS Electrical Problems
  234. 2009 HHR clicking and not starting
  235. oil leak
  236. Kangaroo in Glove Box
  237. Rear Door Handles Stick?
  238. wheel alignment specs?
  239. 2007 hhr panel goes crazy
  240. Peeling Top Coat
  241. a/c blowing hot air
  242. Problem with 2007 HHR
  243. Timing Chain Guide
  244. how to test remote receiver in mirror
  245. Had bluetooth and now none
  246. service esc
  247. 08 hhr new time chain has slack
  248. Surging at Idle
  249. 2010 hhr. Gauges wacko.HELP
  250. Right rear power window will not go up
