- Remote Start / 2nd Start Cycle Not Working
- had my rotors turned today
- Rear Door won't open HHR Panel
- Seatbelt Thingy
- Anyone else having problems with HHR surging
- HHR Marketing Director/Running Board Issue
- Water on the Floor !!!!!!!
- Tail Gate Dents
- My hhr overheated today
- Car Stalls on Start
- Front end rattle issue FINALLY resolved
- Car is going crazy!!
- Temp guage flat and Coolant Temp "---"
- Dealer Recommendation in Central NJ?
- 4t45e aut trans pic from GM
- Heater Motor Resistor Question(s)
- help the newb... please! trans & remote start
- t/c
- The infamous "ENG PWR REDUCED"
- blower fan works, but no forced air from vents
- Rear Brakes Drums - Replace
- Windshield replacement costs? I getting quotes from $710 to $217, What up with that?
- Key fob
- Door sticker
- Battery died and took the power steering with it!
- Right front CV joint noise on deceleration ??
- Takes 4-5 times to start HHR
- P0304 CODE At witts end!
- Creaking/Squeaking/Rattling
- No Start = BIG Problem
- Removing the inside door panel
- SS Front stabilizer shaft links ? Bad at 15,000 miles?
- HVAC Overhaul question...
- Visors loose
- Right rear wheel locked up
- Front End Alignment
- Just got HHR, Key Won’t Turn, other concerns
- Engine Running Rich...Engine light on
- Recalls
- HHR head ache -new cd player car wont start.
- Check Engine Light and remote start doesn't work
- the LIST
- axles replaced
- Radio Problem
- broken garment hook
- How does the steering work
- Need help ASAP
- liftgate not unlocking
- I finally got mine
- 06 Died while driving, mechanic says fuel pump
- cruise control not working
- Brake Fluid Warning Message
- interior lights out
- Ignition Turning
- Door Rattle
- Noise when going from defrost to face/feet setting
- anyone changed a front wiper motor yet
- Service Engine Soon / Oxygen Sensor
- Greasable poly sway bar bushing ?
- clunk in the front end
- Performance seat issue
- Doors rubbing against body
- Cruise Control shift issues
- starting problem
- Brake Problem
- HHR Dash Peeling
- Tpms (no rke)
- TPMS (Tire Pressure Monitor System)
- Remote Start not working....
- Power window controls
- Door latch adjustment?
- Steering column clunk
- low boost/power anyone?
- Car not turning off when brake stepped on- remote start
- front doors don't open due to ice
- Frequent Headlight Failure
- Struts replaced now out of warranty, broken bolt
- Windshield Washer Reservoir woes.....
- 2007 HHR Fuel Level Sensor
- 2008 HHR 2.2L Heating concern
- advice
- service
- Extreme cold+short trip=no start
- DIC outside temperature
- Bad day today.. Car smelled and stalled on me.. It's at the doctors overnight
- Multiple issues
- Ignition Cylinder Lock?
- Wiring harness hanging out back
- Growl or a roar.....
- Aftermarket Disk brake Rotors??
- Fuel Pressure
- P0449 Code
- Injectors and Cylinder Head Problem
- What's going on?!
- Steering Column Issue? (06 2lt)
- 2008 HHR SS Quality Controll Problems
- Clunking noise in the front end of 06 HHR LT
- GM opens the flood gates on TSBs today!
- Keyfob battery low indicated in DIC
- Door Alignment
- belts
- Revisit - Oil changes and the DIC
- 2008 HHR Window Buttons
- Code POO17 on HHR SS
- Tracking oil leak
- Battery Charger Operating Temperature
- coolant recovery fill tank question
- trouble code
- Noise coming from front end when accelerating while in gear!!
- DIC/Radio Brightness
- Bent rim fix
- Paint Specks
- ABS & Trac control light on...but not always
- Adusting Door Alignment
- Fifth door sound
- Door Ding!!!
- Rear wheel bearing
- 2007 HHR Block Heater...
- Changing spark plugs?
- Weird Fan Problem
- Please Help Wet Floorboards
- Intermittent Front End Clunking
- Key Fob Issue
- help
- Fan ticking sound
- hatch almost rubs on bumper
- Outside Temp Display
- "Service Traction" & "Service Esc"
- HHR had a Doctor Appt today..
- Turn Signal Lever no longer cancels automatically
- floor vents suck
- First trip to dealership.....
- ignition key stuck
- K&n
- Radio goes Physco...
- Anyone??
- Tire pressure monitoring system
- New car comes with black grit and swirl
- Slammed on brakes, now Check Engine Light?
- Service airbag warning
- Total loss of gauges....
- Sorry paint job
- Grab Cup for HHR hatch?
- Rear brakes issue
- peez help me! keys wont come out and radio wires are cold
- Warranty climate?
- 08 Auto SS slipping in OD @60mph
- Remote stopped working
- Coolant - What is too high?
- Optima Battery...
- New 2008 HHR Owner... HVAC Motor Problems?
- OK, I give up.
- Cruise.remote Start And Door Locks
- Rear Hatch Struts
- One headight yellowing?
- 2008 SS - Weird Radio Noises on Startup
- Seat back-passenger side
- Have you guys heard of this one?
- chrome on handles bubbled
- some kind of problem
- ABS and T/C
- dead battery could not get key back
- Radio no sound
- Driveshaft Rem/Refit
- Driver Door Lock
- Radio/Door Chime/Turn Signal Click Glitch
- Servicing car on Monday - Questions
- Intermittent Wipers Not Working Properly- ? for ChevyMgr or anyone else
- Auto-dm mirror not dimming
- Fog Light Harness
- clunking noise when starting HHR.
- Help! Factory Tires for a 07 Lt2 ??
- 20 miles & Broken!!
- So Whats Next..............
- blinking dash light ?????
- wet carpet on passanger side
- Heat A/C blower replacment
- Lurch/Pulse/Jerking at stop light ?
- brakes
- Car died at redlight
- Wet Insulation
- Rear hatch won't latch
- Rear hatch scraping bumper pic
- Pics of rail dust...ugh!!
- Parking Brake Issue
- help
- Passagers Door won't open
- Alignment
- Tan interior
- Service Brake System Message
- Coolant drain valve?
- DR low beam headlight not working
- Problem with passenger door checklink
- Brake peddle "pops"
- Brake Problem
- Another strange noise from right rear (interior)
- sunroof question
- Ooopsie BIG TIME!
- tsb numbers for rotor shield and radiator shield
- What makes the loud noise from the right rear of the HHR?
- Anyone else have/had this issue
- Can dome light killl the battery?
- squeaky drums still after 21k miles
- Electrical Issues , 2008 Lt
- CEL Fuel Injector
- Electrical problem
- First Problem with My HHR
- Water Leak
- Remote Start car acts like the car a dead battery, but key starts the car fine
- Headliner Glue? GM recommended
- Service Bulletins
- We are at 21k miles what service do we need?
- oil filters
- Headlight issues
- XM/Onstar antenna
- some help please
- TPMS not working, funny engine noise (SS)
- Rattling hatch door?
- Cruise and info stop workin
- Suggestion for extended warranty
- Brake noise issue
- 2006 HHR Blower Motor AGAIN!
- Electrical whine
- Warranty Question for ChevyMgr
- Instrument Panel Lights and Radio lights work but
- Look what I found.
- Lights dimming when auto shifts gears
- '09 DRL or Auto Lights Disable?
- DIC problem
- Remote start option question
- 2006 HHR Blower Motor Removal?
- HHR Stopped Running on Interstate and won't accelerate now
- wet driver's side floor.....anyone???
- Wet floorboard again!!!!!!!!!!
- Electrical/Transmission/Dash/Power Steering Issues
- IPC Dead
- 2008 PANEL rear side doors Problem
- Stuck!
- Trans shifting hard
- gallons of water in my HHR
- Clock Spring
- HHR Recall
- Intermittent wiper works intermittently
- Need more HP
- HHR repair sites / Fog Lamps Help Requested
- Not sure what that sound is!
- Loss of power
- First problem is w/ Onstar System
- Check Engine Light Came on today
- 2 Questions!
