- New Member With Small Repair Issue
- Bouncing gauges and no start
- need help with p2122 code
- Another 2006 Not Starting
- Broke part of the connector for Solenoids.
- Low beam went out?
- CEL Fuel Pump Relay
- ABS & TC light on and off
- Traction control light is on
- 1995 Chevy silverado, trys dieng and clunk when turning left?
- Brake & Steering Shake - 34 mph - have read entire Internet
- outside temperature sensor stuck at -1 c
- lost power steering
- timing chain rattle again
- 2006 will not run
- P0113 code
- Like I was out of gas...
- 08 HHR Front clunk... different than the rest
- P0010 Intake Camshaft Position trouble code
- Consistent P060E & P2135
- Where is this high pitch coming from?
- No power- key stuck in ignition.
- 2011 HHR Hazard lights switch
- RDCLR fried???
- Rear seat fold down "pull-tab"
- Door Latch
- Engine cross reference
- Problem with my HHR
- Sunroof
- Key Fob Programming with Aftermarket Radio Installed
- P0700/p0974
- p0496 Error Code Changed Number of Parts
- power steering went out after jump start
- Weird sound when starting engine
- Emission code P0446, P0449
- Wont start 08 hhr
- Replaced Motor-NO POWER??
- Sand scratching windows
- antifreeze on oilfill cap
- Multiple Codes / "Phantom" Problem
- Engine Missing at times
- Metal tapping noise when turning or going slow over bumps
- TCM module and ECM
- Positive camber on passenger side
- Car Not Starting & Service Traction/Service Esc Errors After Replacing Stock Radio
- love my car, TONS of problems
- oddness after battery boost
- Front disc brake replacements
- 08 HHR SS won't start
- Shifter interloc switch?
- Glovebox handle broken
- Trying to Install Insulator & Bolt for Engine Cover
- Need to replace engine on a 2008 with a 2.2L 8th digit D
- Sway bar bushings & links
- Turn signal canceling
- Rusted Fuel lines
- P0014 code and "fix" NEED HELP!
- 2010 dome lights - cargo light not working
- 06 HHR LT won't start, cranks, but getting no fire at all ... Suggestions?
- 06 Chevy HHR wont start, electrical issue???
- Oil Filter O-Ring
- Wiper transmission question
- Center Brake Light, Cruise Control Problem
- Rear blinker won't work even with changed bulb
- Door issue
- powerside view mirrors
- HHR 2008 Won't start or crank...
- More Tire Pressure Monitor stuff
- Gas smell
- Blinking Led wiring
- hhr starter
- Is this the spot?
- Engine power reduced
- Misfire Problem
- cylinder 1 misfire
- problems with idle on remote start?
- noise in radio
- No auto locks, shifter not working properly, etc
- Steering Wheel Problem
- Front end noise in 2008 HHR LT 2.2l
- 2006 hhr overheating?
- Overheating Problems (Specially at night)
- remote door lock problem
- Hello from GA! With Some Electrical Issues Too!
- Save my baby Goldie!
- 2010 HHR LT/ gauges going crazy
- A/C Fresh Air / Recirculate Actuator
- akamike102 has hard start problem
- Windshield wiper linkage
- oldloadie
- Rear window not rolling up using rear door switch
- Drops out of Cruise Control
- RE: single HHR manual door lock
- P0172 code with high alcohol %
- Grounding Issue? - Radio goes black, Power Steering Quits
- Overcharging
- Cnicole1140 '09 HHR Issues
- Oil Leak?
- Lazy throttle in reverse
- Please help.... 2006 Chevy Hhr won't start!!!!
- DIC going haywire (ESC/Traction Control/reduced engine power)
- SOS! Heater/AC Blower not working!!
- Engine reduced power
- Noise in rear wheel after new brake job
- What does it Cost, Parts and Labor? Brakes
- Leaks from both rear lens letting water in wheel well
- Questions about a front brake job
- HHR getting warm
- help with dash removal please
- Multiple issues
- Interior Water Leak Passenger Side Lake
- Help/Rim needed in Ocean City Maryland area
- Can anyone help me? Front driver side blinker problem
- Interior Driver's Door Handle Fix....Had to fix the fix!
- Headlight Assembly Not Tightening In
- fuel gage error after replacing fuel pump
- Windshield washer fluid sensor
- Traction control came on when driving on dry roads, brake pulse
- engine idles down too low and dies
- 2006 HHR driving issue past 3100 rpm
- Some questions after a smashed radiator
- False info TPMS
- 2009 hhr hatch lock wont stay locked
- Bad battery causing airbag light and tire sensor light to come on?
- '07 with bad 2.2. What engines will work?
- po172 alcohol content to high
- '06 LT Overheating
- Brake upgrade for HHR SS
- Knock Knock. Who's there?
- Door won't open from inside
- cruise control and auto door locks don't work
- Overheating galore
- Doors Fail to AutoLock
- Looking For Pic and Info passengers door window switches 2009-2011
- current flow
- Wires to left under steering wheel
- Car takes off on second gear
- BCM-fuse panel
- Caliper piston dirt seal
- Zero boost
- How hard is it to change the camshaft position actuator?
- Fuel Door Skin Repair
- Power Steering & Wiper Issue
- 08 HHR Wont Start Battery is Good is Getting Gas
- Many CV and auto trans questions for 2009 LT2
- Flex pipe help
- 2007chevyhhr
- Third brake not working
- Park does not engage in the transmission when shifter is in park
- Traction Control Light on after Tire Rotation
- Rattle/Scrape/Knock from 2007 2.2L LT
- Back Tires Rubbing Wheel Wells Or Inner Fenders
- Fuel Leak Threads Merged....
- TPMS sensor install.
- 2007 Will not crank
- just did engine swap. plz help!
- Power steering on DIC , chugging all f a sudden
- New Engine
- TPMS DIC Light Disabled
- Alarm & TPMS Questions...
- R & R liftgate pressure switch
- 2009 HHR Key Programming Question
- steering wheel shake finally resolved
- Help overheating!??
- P2176 DTC and Reduced Engine Power
- Major electrical problems after ignition replaced
- Engine Swap ?
- Need PN/links to purchase 2.2 auto TPS pigtail harness
- Can shorted Radio Light be Replaced?
- Engine temp under load
- 2007 lt 2.4 no crank
- GM part # 25829960 Grille Insert Screen, Front - protects AC condenser
- Engine block differences
- replaced radatior fan, now it knocks
- radio flashing, no cruise, no power steering, now no start battery just replaced
- 2011 LS Engine Trouble/Issues with Mechanical Diagnosis
- Remote Internal Contact Repairs Question
- New fuel injector doesn't fit
- airbag and seat belt warning light.
- Steeringwheel cold start
- Tach Stopped Working..:(
- Check engine light
- Need Help Sunroof Doesn't Close Right
- Need help
- 2011 HHR won't start
- Trouble with DTC codes (long)
- Heater Core and overheating question
- Security system: is this a reset or a repair problem?
- Coolant recovery tank replacement
- Muffler Problem(Actually smoking excessively after an oil change)
- New Cat on the HHR
- Engine Performance
- Speakers replaced, now fob nor door key work
- Possible Strut Problem
- battery light on in 2010 chevy hhr
- CV Axle wobble
- driver side front tire noise
- Chain Tensioner
- 08 HHR Parking lights stay on
- Electical ground problems:transm., BCM, etc.
- Tc ABs light on popping and jerking
- Both Fobs Stopped Working
- replacement rim
- front end noise and vibration
- temp gauge/DIC not working
- New speedo now back doors won't work
- First thread, need help.
- How to fix loose, drooping visor?
- po172 error code
- Need help figuring out possible transmission problem
- 2006 chevy hhr #4 misfire
- Keyfob remote will lock but won't unlock
- 2006 HHR 2.2L code P0717 P0700
- 2008 HHR dors won't lock/unlock with fobs or switches
- Water floor board..I know,I know but please read
- air bag codes b0019 & b0020
- Transmission Question?
- 2006 HHR no crank, no start, no communication error
- 2006 CHEVY HHR LT 2.4 Shifter and shifting problems
- fob not working, could it be......
- Backing up & HHR Suddenly shut down & wont start
- Key FOB ?
- 2011 hhr trans module replacement
- oil below throttel body in the intake manifold
- Service traction, service "esc" error.
- Is chevy dealer only person who can program TPMS?
- Won't start
- coolant recovery tank compatibility
- Sticky door handles
- Problems with HHR P0013 & P0014
- How to Remove Rear Tailgate Chrome "Beauty Bar"
- shrader valve low side a/c 2011 hhr
- 2011 HHR Car is not starting
- Coolant DIC reads hot
- Intermittent Transmission problem
- Question about Key FOB and New Locks?
- Door locks and horn got crazy
- My ambient temp is reading 150 degrees!!
- BARO SENSOR - code p2229
- New KYB struts - What is the Bushing for?
- 2007 hhr new head
- Swap
- P0016 code
- How to Rebuild Fuel Injectors on 2.4 Lt Ecotec
- The Ambient air sensor
- Infamous P0010/0020 codes
- Oil leak
- 2.2L Won't Start
- 2.4LT won't start
- 07 hhr 2.2 motor lost compression please help
