PDA
View Full Version : Problems/Service/Repairs
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. Sunroof issues
  2. Checking Cam Timing
  3. Timing Chain and Cam Phasers
  4. Persistent Idle Issue - Help
  5. Steering column noise question...
  6. Limp home mode
  7. water leak
  8. Brake pads & squeaking question..
  9. New Member - Service Manual Question
  10. Crazy Automatic Door Locks
  11. AC issues HELP!!!
  12. T/C light
  13. 2008 Chevy HHR engine rev problem!!!
  14. High pressure service vale on a/c
  15. Mildewed carpet: clean or replace?
  16. 2008 - Unable to lock doors using the remote!
  17. Alarm wont stop going off
  18. P0010 & P0011 Codes
  19. Engine swap - '09-11 motor in '07?
  20. Won't start when hot.
  21. engine cooling fan running constantly
  22. cannot fix evap po449
  23. camshaft and crankshaft position secsor's
  24. Car overheats when A/C is running.
  25. Water leak
  26. Rough/Jumpy Idle at stoplights
  27. After having AAA jump Dead Battery...
  28. Haunted HHR
  29. Radio cycles on & off every second
  30. Cooling System Flush, 2.2L
  31. Problems replacing exhaust actuator solenoid
  32. Only third stop light works, side stop lights no more
  33. ac charge
  34. Blower motor relay socket
  35. interior light issue
  36. Ring singalong! The chimes
  37. 2006 Rear latch issues
  38. Security light and bouncing gauges
  39. Car won't start, has power..more inside
  40. A few problems the garage have problems with.
  41. Cooling fan
  42. aftermarket Catalytic converter
  43. Power steering does not work
  44. Karenann- code P0303
  45. P2533 & u0073
  46. clutch position sensor
  47. dead battery
  48. P0341 and P0340
  49. Charging System Woes
  50. my baby is sick a/c stopped, CEL
  51. Catalytic converter clogged?
  52. No injector pulse
  53. clicking/popping noise when braking and accelerating
  54. Driver side floor wet
  55. AC Water leak solution
  56. Coolant temp problem
  57. Transmission Hard Shift
  58. Help! Water leak
  59. Humming Noise
  60. P0171 issue
  61. P0641 code, how to test ECM?
  62. Solenoid not engaging after motor rebuild
  63. Sun roof will not open
  64. Rodents
  65. Air vents won't stay open
  66. Air Bag disassembly
  67. I have s 2006 LS HHR and i can't seem to get my power mirrors to operate. i had check
  68. 2006 Will not start * with video / sound *
  69. 2.2 engine the difference in years 2007 /2009
  70. PASS KEY lll+ issues
  71. Wobble and knocking in steering wheel
  72. No AC, temperature reading, and temp. gauge
  73. EPS issue and column rattle fixed
  74. Buying Part from Chevrolet or Autozone / Orielly's
  75. Window Regulator issues
  76. Risk Analysis Broken Rear Coils
  77. Possible TPS needs replaced again?!
  78. Possibly a crank position sensor?
  79. blower motor only works on high
  80. 2006 HHR malfunctions help please
  81. Engine light came on
  82. Hissing Sound All Of A Sudden??
  83. P0171 help.
  84. Front End Noise
  85. best 02
  86. Front End Noise Drivers side
  87. Drivers door window switch problems
  88. ESC warning
  89. Front left signal light won't blink on 2006 Chevy HHR
  90. Front side left inside lock cable
  91. Front side left inside lock cable
  92. Battery saver mode on/check charging system
  93. bad dash rattle
  94. 2007 hhr ls automatic trans complete failure
  95. Hard/abrupt shifting
  96. Power steering failure
  97. Strange Noise When I Reach 20 MPH Speeds
  98. 2009 HHR Bluetooth does not work
  99. Shut hatch with batteries out - can I use the posts up front?
  100. Car wont start but everything else works
  101. Stubborn SRS Codes and subsequent seat replacement
  102. Esc Active
  103. Thermostat/Water Pump Question
  104. Help with flex pipe and TPMS
  105. How Does the Rear Nozzle Come Out?
  106. few problems
  107. Humming noise when I reach 40 mph
  108. P1682 code. crank but no start
  109. What Next?
  110. I have problem with my driver's power seat toggles.
  111. 08 hhr rcdlr
  112. battery shorts out after charging
  113. Program Key / Engine Disable/ Recall QUESTION
  114. New Tensioner Release Tool
  115. unresponsive, electrical power to fuses
  116. CV shaft replacement questions
  117. exterior lights constantly needing replaced
  118. Overheated - what to look for?
  119. BackUpCamera instalation....
  120. battery
  121. electrical problem?
  122. RADIO volume acts like poor speaker connection
  123. Light for PNDL Shifter position on and off
  124. Service traction/service ESC lights on
  125. Power steering problems, but nothing showing on DIC
  126. 36+ CEL codes found after jump starting
  127. Manual Trans- randomly doesn't go into 1st-3rd-5th
  128. Low brake peddle if I drive in reverse
  129. Lift Gate Re & Re ?
  130. Rear passenger door won't open...
  131. p0011
  132. bluetooth sound quality
  133. 2006 HHR - RPM Needle Problems????
  134. Rattle in steering column
  135. Should Onstar green light on rear view mirror be on 24/7?
  136. Rear View Mirror Compass Not Working
  137. No power to HVAC controls, heated seat controls
  138. Power windows quit...
  139. hhr intermediate steering shaft warning
  140. Green oil on back of A/C compressor
  141. 2010 HHR Door ajar light on when all are closed
  142. HELP!! Chevy Malibu 2003 p0300
  143. Is the fuel pump bad when it .......
  144. No Crank No Clicking problem
  145. Brake lights and rear turn signals
  146. Rear Axle Beam Pivot Bushings...
  147. Door Actuators
  148. Suddenly Black Beauty Pulls to the left
  149. Steering Grind?
  150. New door handle repair?
  151. Fuel tank evaporator control valve
  152. Intermittent overheating. Where's the sensors?
  153. Tail lens glue
  154. Engine won't shut off after ignition turned off
  155. Dealership can't get a front axel?
  156. Am I overheating?
  157. Horn blows till 1:30 in the a.m.
  158. B3055 and CO196 codes on 2011 HHR
  159. Woolly worm diameter
  160. engine light
  161. door handle broken
  162. 2006 Engine compatible with a 2008
  163. DRL inop 2008 HHR
  164. 2007 hhr ls
  165. Passenger doors (left and right) stuck shut
  166. bad gas and car wont stay running
  167. gears
  168. How to Unlock 2007 HHR Hatch Back Door
  169. Hit a raccoon....
  170. Engine Swap
  171. Key fob not working at times.
  172. Headlight replacement
  173. Timing Chain change,
  174. Overheating & recent symptoms
  175. Crazy happenings in my HHR
  176. front left speaker volume incredibly low
  177. Engine Code Issues after Month of Owning
  178. intermittent issue with electral system - 2011
  179. Coolant leak
  180. No High beams
  181. A/C Temp Gauge STILL
  182. Loud chimes
  183. Leak on my tank
  184. CEL dilemma
  185. Engine Rattle/shake
  186. Just bought a Chevy HHR.......Engine Light
  187. busted rear view mirror map lights
  188. Another key stuck victim
  189. Engine codes
  190. sun roof leaking
  191. steering wheel lock?
  192. Turn signal flashes too fast
  193. 08 Auto Shifter Cover Plastic Strip
  194. Steering wheel controls...?
  195. TPMS problem
  196. Brakes not working
  197. hhr wont turn over ??
  198. Torque converter not locking up
  199. no reverse
  200. Remote start and door lock not working
  201. need help
  202. auto lights not turning off
  203. Passenger Low Side Beam Won't Work
  204. Better brakes?
  205. Help! ENGINE POWER REDUCED
  206. Replaced engine - Now car won't start
  207. A well priced mechanic
  208. 2010 hhr lt trouble code po302 and p0300
  209. Nicked Pistons from jumped timing chain
  210. A/C Issues
  211. major issues after air filter change
  212. Help - numerous CEL codes generated
  213. Water In Door
  214. New Member with question on floor heat
  215. Wiper Blades not Completing Track
  216. parking lamp fuse constantly blows
  217. Outside Temperature Sensor
  218. radio driver side channel out
  219. Electric Power Steering HELP!
  220. Flex Pipe
  221. clicking noise from left front suspension area.
  222. Good Evening
  223. transmission shifting hard from first to second
  224. Anti-theft triggered - no power
  225. tpms help
  226. shifting button
  227. frost inside windows
  228. Traction control light and rough shifting
  229. rear window replacement
  230. HVAC fan noise
  231. Temperature Indicator
  232. ABS, Traction Control
  233. Power Steering Motor Replacement
  234. Possible Steering Recall Notice
  235. Washer nozzle freezes
  236. Power steering problem 2007 Panel
  237. Steering wheel concern
  238. New Member with Problems & Questions
  239. Leaking intake mani???
  240. Where is the cars tow point?
  241. Auto shift button will not depress
  242. HELP!!!! Locked out of my HHR from inside and out!!
  243. Automatic headlights
  244. one headlight is a different color... help
  245. Timing Chain / Head Servicing
  246. Power Brake Issue
  247. Sunroof inoperative
  248. Driving / Fog Lights
  249. Air intake hose problem
  250. Car wont start
