PDA
View Full Version : Problems/Service/Repairs
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. Tire pressure sensors
  2. Console clicking when stepping on brake pedal
  3. 2008 HHR wont turn off
  4. 2007 chevy hhr ..crate motor replacment and seizure
  5. need help with power steering, C0475
  6. 2007 HHR acceleration issue
  7. Stuck odometer
  8. Part# for 10mm Stabilizer Bar Bracket bolt & nut
  9. Mystery issue with brakes
  10. RPD gauge wiring diagram
  11. 44 mph rough idling
  12. 2011 LT - Service ESC light odd behavior
  13. 2.2 LE8 VVT Sprockets
  14. Power seat
  15. Vehicle chirping
  16. Chevy HHR 2007 tach broke crank sensor
  17. Warning Lights
  18. Red Battery Light. 12v at battery, 14.4v under the hood.
  19. P0010 problem
  20. A/C Compressor Clutch
  21. 2010 2.4 rough idle when warmed up
  22. Headlights only work in auto mode
  23. New motor questions
  24. 2011 LT - Rear liftgate struts/supports
  25. Transmission stuck in neutral
  26. Valve cover gasket replacement
  27. P0300 Code - rough idle
  28. alternator for 2.2 l4 2006
  29. 2006 2.4L intermittent no crank
  30. A/C control knobs not activating
  31. Won't start
  32. Mysterious Case of the Maddening Mechanical Mysteries
  33. Check gas cap then later p0455
  34. Windshield Washer Reservoir
  35. 2006 2.2 5 speed, p201, p202, p203, p204
  36. Hesitates at 1500 rpm? Tps light?
  37. High Beams Not Working. At my wits end
  38. 2008 HHR Wet Passenger Floorboard - NOT RAIN!
  39. Cranks but won’t start
  40. Coolant leak drivers side
  41. Unplugged plug under my passenger seat?
  42. Check engine light misfire
  43. Airbag Code Reader
  44. P0171. Need help troubleshooting
  45. Rear left blinker not blinking
  46. Hhr pulls to right when driving
  47. 2009 hhr ls hesitates only at 1500rpm?
  48. Only one blower speed, the lowest.
  49. 2011 HHR clicks but wont start...Jump 12v to starter signal and it works.
  50. Alternator Charging
  51. P1174 and then some
  52. Which Sway Bar Links? FE3
  53. 2.4 swap for 2.2
  54. Alternator replaced now no cold air blowing from a/c
  55. Stalling
  56. I need help
  57. Radiator fan running a lot and other things???
  58. Radiator replacement 2008 HHR 2.4L automatic
  59. Tried everything
  60. Dash Warning Lights???
  61. Strange Starting Problem
  62. It's a Crazy World
  63. Stalling when decelerating with rpms jumping around
  64. Delete TPMS alarm
  65. BCM issues
  66. AC Control module Part Numbers?
  67. Blown head gasket
  68. Sunroof
  69. Fuel Filter Location
  70. a/C Losing coldness
  71. What's is this?
  72. Hvac
  73. Avoid Amazon front struts!
  74. HHR doesn't rev past 4000 rpm and won't go over 40mph
  75. Sway bar locknut
  76. Unstable communications
  77. Possible cooling system leak?
  78. 2010 Rain related water leak on passenger side floor
  79. Overheating After Multiple Repairs
  80. ac problems
  81. Rear Hatch wont lock
  82. 2008 cooling fan air direction?
  83. 2011 Alarm issues
  84. Rattle noise
  85. Engine is stumbling at highway speeds now
  86. Alternator died Battery died NO Lights etc when it happened
  87. swapping climate control modules
  88. Misfire on cylinders 2&3
  89. Exhaust pipe
  90. Now there's something something wrong with my keyless entry remote.
  91. Need to replace clutch
  92. replaced RCDLR in my 2008 with one from 2010
  93. 08 SS electrical problems
  94. Is there any way to bypass the passlock 3 plus theft deterrent?
  95. New knocking from front driver's side wheel when braking
  96. ABS module, hard shifting, gauges going crazy, alatm(?) dahs indicator on
  97. Rear Blinker Bulb Housing
  98. Vibration
  99. 2010 HHR Pulls to the left
  100. Door unlock and lock while driving, shifter in the transsmisiongoes crazy
  101. P0106 Code
  102. No crank, No power to starter solenoid, PCM is definitely trying though.
  103. Weird Oil Leak "help"
  104. Power steering
  105. OBD plug lost communication while programming
  106. Lost on this electrical path
  107. Batt. light on
  108. ABS and Traction Control MIL intermittent
  109. Cooling Fan and prob AC
  110. Sunroof won't slide back
  111. AC Heater Control Unit Switches (3)
  112. Manual crank to close tilted sunroof
  113. P0036 P0141 P0054 codes
  114. Temp Gauge Flatlining
  115. Misfire Mayhem
  116. Analog Fuel gauge not correct, all others working
  117. 07 Transmission swap
  118. Programming Transponder Keys after dead battery from flash flood
  119. P0300 code
  120. After Replacing Cat P0420 came back
  121. Door Poppers
  122. Coolant and oil loss
  123. Cooling Fan Not Running Again
  124. Radiator Filler Neck ⚠️ Warning ⚠️
  125. Slow fuel fill and missing fill neck flap
  126. “Missing” in action
  127. radio
  128. Struggling getting new exhaust manifold in.
  129. Tcm question
  130. New guy battling P0304
  131. Rear wheel sensor
  132. P0340
  133. transmission output shaft bearing
  134. Car wont turn over ?
  135. Driver front door will not open
  136. Need advice about the A/c
  137. Power gain using AC?
  138. Window issues
  139. blinky blinky left turn signal
  140. Transmission Fluid Port
  141. Tcm
  142. Intermittent Temp Gauge
  143. Had an accident with a hitch. Damaged ABS module.
  144. code P1035 ??? 2006-2.4-auto
  145. Problem disconnecting fuel line
  146. No tail lights on 06 HHR
  147. Turn signal relay fuse
  148. Evap p0442 issue
  149. Key FOB question
  150. Sync tire pressure system
  151. I have a kazoo under my hood
  152. Stalling issues
  153. 2009 2.2ls manual transmission doesn't shift right after replacing the clutch
  154. Both Lower control arm bolts broken
  155. Coolant Leak to start, car won't start
  156. Intermittent Power Window Issue
  157. HELP my 2006 HHR electronics are on the blink
  158. fuel pump replacement
  159. 07 rear wiring harness - passenger side
  160. Timing chain torque specs
  161. 2010 hhr
  162. Fixed persistant P030 P036 P102 P443 and P014
  163. 4T45E issues
  164. P0134 P0135 and intermittent P0300, no start, newly installed cat/O2
  165. Chevy HHR no power at all!
  166. 2009 HHR LS turn signal electric issue?
  167. A Really Strange One
  168. 2011 2.2 chugs at idle after warming up
  169. Pigtail, wiring, harness diagram/color codes
  170. Front Axle Question
  171. 3000rpm
  172. Timing chain
  173. 2010 HHR won't start after roll over
  174. Ignition won’t activate starter
  175. Help with codes
  176. Turn Signals quit cancelling?
  177. 144k my first trans delay/slow shift
  178. Car stuck in limp mode won't crank or start
  179. No chime when door is opened with key still in ignition, cylinder or switch? Both?
  180. Fuel pressure sensor
  181. Hit a huge rock in road and busted oil and trans fluid pans, car started to sputter..
  182. 2.2 vs. 2.4 exhaust manifold and pcv valve.
  183. Turn signal switch / drl issue
  184. Tc light hard shift + 6 codes
  185. 2008 with two EXH VVT gears
  186. 07 Won't crank
  187. 2006 HHR LT 2.2 Crank but No Start
  188. Battery cable
  189. cruise control won’t resume
  190. Traction control light coming on causing hard shifting
  191. Left headlight not working
  192. 06' 2.4 won't stay running
  193. HHR Hood Release Cable
  194. Where is (CMP) cam pos sensor
  195. Indicator lights not working
  196. Connector Under Driver’s Seat
  197. cranks but no start
  198. LS Manual transmission issue
  199. Sun roof wont slide back all the way
  200. Need help urgently please please please
  201. Weird transmission / maybe steering problem?
  202. Need electrical help
  203. Control arm stuff
  204. Does this sound like a rod knock?
  205. Weird crank no start
  206. P0121 - intermittent
  207. No power to the starter
  208. Front side marker lights flickering w/LED bulbs
  209. P0171 and P0420 code problems
  210. Inop autolock/unlock, manual downshift, TCC lockup, cruisecontrol, roughshifts
  211. Brake Pedal low
  212. Shifting problem
  213. 1st time poster. Electrical problem after terminals were crossed
  214. Belt flapping on startup
  215. fooling brake fluid warning
  216. 2007 chevy hhr power stearing fuse!
  217. Condensation in oil fill cap
  218. Radio and airbag issues
  219. Blower fan problems
  220. Several things
  221. 2009 rough start
  222. Chug a lugging along
  223. Driver door won't open from inside, handle OK
  224. Installing factory fog lights 2006 LS
  225. 2007 hhr no power to interior
  226. Low oil, no knock short drive
  227. Blinker problems
  228. bolt size for oil pan?
  229. Driver's seat heating pads part number and source
  230. 2011 Chevy HHR
  231. Oil Pan Gasket, what the?
  232. 2011 chevy hhr p0442
  233. Instrument Cluster
  234. Coolant Message says 187 degrees
  235. Idle and speedometer issues
  236. Clicking noise when adjusting climate control (video included)
  237. Scraping noise when braking
  238. Dorman Intermediate Steering Shaft
  239. Problems with miss
  240. 07 blower motor
  241. 2010 HHR idling problems
  242. New Battery -now issues
  243. Engine Revs at the touch of the pedal
  244. Need help badly here starter connections
  245. Tab on coolant pipe broken
  246. Where can I buy this hose or clip?
  247. Throttle Body Code?
  248. Camshaft position sensor location
  249. Expert Help Needed 2006 HHR 2.4L NA Throttle revs & ECM
  250. 2010 Chevy hhr
