- Dead battery no warning/cancelled smog check
- 2006 HHR. Rough idle, P0300, P106 Codes
- Won't start
- engine power reduced
- Water in oil problem
- Remote FOB
- HHR drain the gas tank useing the pump
- I have a 2006 Chevy HHR LT 2.4 with a
- weird electrical
- Dash check engine lite on
- ESC with P0302
- Right front tire clicking sound
- '09 won't shift to overdrive when cold??
- P0128 Engine cold too long code
- ac/ heater controls
- auto head lights stay on
- Electrical Mayhem
- Throttle body issue
- Gurgling Noise
- oil in coolant
- Data Link/diagnostic port - no power
- Tailgate does not want to open.....
- Hi Beams wont work!
- Passenger door latch
- In need of electrical wiring diagram for 2006 Chevy HHR
- Please help I have a no crank no start condition!!!
- Knocking in Engine... 07 LS
- No crank/start after dying
- New Owner 2010, Oil Leak?
- Check Engine light and no remote start
- cyl 3 misfire
- Headlight that will not turn on
- 2008 SS Electrical Issues????
- no power to left rear window
- will not start after gas fillup
- Brake pulsation, steering wheel vibration
- Changed camshaft sensors, now flashing CEL
- Code P0650
- Ignition Problems
- Failing to unlock.
- change a starter and solenoid
- New to forum with light problems
- Radiator fan running at high speed from ignition
- 2009 Chevy HHR shaking/jerking
- Unlock problem
- Another oil leak thread....
- timing
- P2135 code (help)
- 2006 radiator replacement picture
- sterio problem
- abs light
- reversed polarity, alternator not charging
- CEL - Mechanic said Gas Pedal
- Power steering error but still have power steering???
- 2007 hhr traction control problem ruining my life
- Service Air Bag Light
- Door chime keeps chiming
- Temp guage quit
- Another Cruise Controll issue ?
- Vibration at Idle - Not in Park
- Misfire 08 hhr 2.2 Ecotec
- windshield wiper linkage & door latch problems
- auto door locking
- '06 dying when driving
- Possible Steering Motor Going Out?
- Hello my new community
- DIC & cruise control
- P0171
- Power Steering
- fuel pressure regulator
- Automatic shifter handle moves hard
- Mepzor-Front corner buzzing.
- 2008 HHR Starting Issue
- Chevy HHR 2006 exhaust flex flange replacement
- Replacement key fobs will not activate tpms relearn
- Help, oil in coolant
- HHR stuck in Park
- new to web site/dead battery
- code po700tcm,mil requested
- 2011 P2135 Code
- Rear window
- remote rear door popper
- stiff steering
- Question about balancer chain tensioner.
- Trouble Code P0303 - Twice in 286 miles
- Spun tires then CEL came on with only error P0641
- Exhaust leak
- Rough idle
- 06Hhr Service traction control
- Engine Replacement problems
- '08 HHR. 2.2 engine- "Starting quirk" Question
- Transmission Control Module
- Seat Belt Jammed and Won't Extend
- Used engine vs head rebuild?
- CD player eject.
- Power steering hasnt failed...yet
- Cabin blower fan doesn't always work
- DRASTIC MPG drop
- Low Compression in ALL cylinders and P0300/0303 code
- new member, need help desperatly, headlamps out!!!
- Overheats
- Installing heated leather seats
- Head Light Problem
- Car sputters and hard to crank on a cold start.
- wobble on acceleration
- Headlight/HID problems
- Camshaft Position Sensor replaced, still problems!
- Check Engine Help: P0303
- HHR question - front suspension noise
- 2006 engine dies at the first stop sign.
- "Service ESC" message
- Security Module Issue
- Turn Lamp Keeps Blowing
- Grinding noise coming from front end
- For those that have had power steering fail
- dcp07hhr (No OBD II codes?)
- Power steering out (new column?)
- Need help timing a 2.2 who's crank has been turned without a chain on.
- Outside air temperature sensor & wiring
- Keys left in ignition or lights on chime not working
- 2010 HHR passenger headlight intermittent
- randy hhr (DRL lenses melted)
- New member, power steering question.
- Rusted Fuel Line
- 2006 Chevy HHR
- cruise control not working
- power steering go's out while driving
- Transmission issue? or what?
- Brake lights only work when ignition on
- erratic gauges when cold
- Door Lock Wiring
- Brake Light/Turn Signal
- "Check Charge System"
- heated seats 2006 2.2
- Whining noise when steering= bad PS Motor?
- Door Open Chimes but Doors are closed
- Engine (Stalls while driving)
- 2008 Hhr ss leakin rain water!! Help!!!
- Anybody else have this problem??
- code:P0304 misfire//help!
- interior light bulb replacements
- Power Steering/Rattle/Onstar
- Newb help with Remote Start
- Spark plug saga I
- 1 more question about AC growl and TSB
- HHR door lock problem
- Service Items During An Engine Swap
- 2008 HHR struts...
- Thermostat...again?
- planetary gear fried
- Slight pop when steering at slow speed
- po303 clunking front end when under 40mph
- Hi all.
- High Hz Electronic Noise From Radio
- 2.2L-Air Cleaner Box Bracket Broken
- rear turn signals not working
- Exhaust ticking noice problem
- the elusive tech 2
- Testing ABS wheel speed sensors
- Alternator Compatability
- Sunroof rattle?
- Wiring for lighter socket
- electronic communication problems
- Oil leaking
- WRECK!! Replacing the engine Cradle
- Clicking Sound in Front End
- New Noise
- P300 code yesterday, 420 code today.
- Common Problem?
- Power Mirror Problem
- yellowish white film on the oil fill cap and in the oil fill tube
- shaking front end when braking but not all the time
- Broken Driver Door Strut
- Need help! 2009 HHR!
- Timing Chain Tensioner
- Problem with Radio going dark.
- knock sensor?
- Residue after catalytic converter
- service esc/service traction/misfire cyc 4
- Surpentine tensioner kudo's
- Steering squeak
- Very Slow Acceleration when Cold
- traction control
- Airbag light
- Headlights
- Radio is changing inputs
- Key dance
- Inch of water on frt passenger floor
- Another Noise Problem - Need Help
- key fob resolder successful; 4x
- slight ticking noise
- P0606
- Replacing Cam Sensor on 06 HHR
- Poly bushings
- what are names of mounts in 2006 hhr
- Steering Column or Intermediate Steering Shaft?
- Need help! Air flow direction control
- Sunroof problem
- RPM sensor caused emission test fail....
- Warrenty questions
- jtriker
- Hhr alarm issue pleaee help
- Battery drain
- engine vibration
- Dredded p030x code
- Humming Noise
- key fob = lock set
- Does the TPMS sensors have replacable batteries???
- Windsheild Wiper fail.. need some serious help
- Key Does Not Open Door
- Cruise control went out again.
- Clunking noise?
- Door Damaged
- map lights won't turn off... grrr can't find answer
- Noisy fuel pump ... Warranty Criteria??
- Help with broken door lock
- DDM Tuning HIDs died at once!
- Code 0455
- Top or bottom Engine Replacement
- no turning over moter
- Not floor or defrost air flow
- Replacing Shift Assembly 09 HHR
- VV & O2 Censor
- Brake pedal makes rear wiper run
- 2006 hhr blower motor blockage?
- 08 HHR needs to flash
- New poster
- Blown head gasket-replaced...but timing chain just killed my motor.. Help
- Cel
- Power steering and other problems
- Oil in intake?
- problems still after replacing camshaft actuator solenoids
- Opening driver side door with both outside and inside handles not functioning.
- Tire pressure monitoring system - how do I reset it?
- Strangeness with Lights
- Over the counter scanners?
- Rear doors won't open from inside
- Radio lights going crazy
- More EPS fun...
- Steering, AC, other problems
- Rust on rear corner panel
- Hazard and fog lights have been switched!
- Hard takeoff now P0010 code.
- P0014 After Changing Oil 2006 HHR
- water leaks
- P0016 code after timing chain tensioner installed
- please help. car wont start after replacing shift assembly
- bum windshield replacement - is XYG glass part of PPG?
- maybe a motor mount?
