PDA
View Full Version : Problems/Service/Repairs
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. Transmission fluid change - Form-a-gasket sealant?
  2. Intermittent trouble code p1133
  3. CODE P0013, P258B newbie need help!!
  4. water collecting on floorboard of right back seat
  5. Overheating
  6. Oil
  7. ​​​​​​​High mount stop light won't turn off
  8. 09 leak on drive side floor
  9. Battery saver mode on- reduced engine speed- check charging system
  10. 09 HHR LT - power steering msg on dash
  11. 2011 HHR won't turn on, lock appears on dash
  12. 2009 HHR Power Steering Motor
  13. Front End Rebuild Itinerary List
  14. No crank no start
  15. console switches not working
  16. Chevy HHR Startup
  17. Where did my cruise control go?
  18. Torque converter malfunction?
  19. Paydirt! The power steering problem FINALLY SOLVED!
  20. Steering wheel position sensor
  21. Can of worms.
  22. Will changing the grade of gas cause a CEL
  23. Issue with Passkey III / Relearn fail
  24. 2010 HHR LT 2.2 has CEL codes : P0717, P0700, P0976 & P2764
  25. Fog Lights
  26. 2007 Chevy HHR LT Heat Blend Door Actuator
  27. Water pump
  28. Leaning Front Passenger Side
  29. Transmission
  30. Vent Air
  31. AC Draining onto passenger floor/carpet
  32. Starter punctured front pump seal on Transmission
  33. My Car Door wont unlock
  34. 09 HHR SS - Shudder
  35. Fuel Lines Drip... easy replacement?
  36. Rusty fuel lines
  37. Car won’t start
  38. Electrical Nightmare
  39. Service Code Reader/Fob Programmer
  40. rear right wheel seized
  41. How do I fix the rear door - drivers side on my HHR Panel.
  42. Valve cover bolt tightening sequence
  43. HHR died
  44. Oil Pump Issue after Timing Chain Kit replacement
  45. TCC Solenoid needs replaced
  46. Car shut off, went dark
  47. Power window motor
  48. Caliper pin replacement
  49. 08 HHR Door locks
  50. 2011 electrical gremlin
  51. Pesky Oil Leak 07 2.4
  52. Left lights on and battery went dead now I got it jumped no headlights??
  53. No overdrive PO751 & PO700
  54. Water Pump / Timing Chain
  55. Hole in gas tank
  56. Weird annoying issue
  57. Cold Air Intake - P0171?
  58. Alarm going off by itself with no one around it.
  59. P0107 code keeps coming back
  60. 2011 hhr won’t start
  61. Throttle body question
  62. Accelerator Pedal - electronic?
  63. Oil leak?
  64. P0010 and P0107 car slow to start...
  65. Front Knuckle Bolt Broke
  66. TC and ESC
  67. Lost
  68. 2008 Chevy HHR Tail lights & Side Yellow lights are staying on
  69. Still dinging
  70. Exhaust Diameter, 2.2L, 2006 LS
  71. Heater won't blow
  72. car is broken
  73. vent solenoid switch failure
  74. 2006 hhr p0036 & p0300
  75. Alignment after strut replacement?
  76. low RPM idle then dies
  77. Antifreeze Leak
  78. 2007 HHR Power Steering Problem
  79. Tile blue tooth tracker
  80. trouble codes
  81. Battery light and chime
  82. Car surges
  83. FOB needs long press
  84. Gauges going up and down
  85. Front end noise
  86. swap engine
  87. Remove valve cover
  88. Back of block
  89. Central locking has a mind of it's own
  90. Oil light is on after change
  91. Fuel line question
  92. coolant leak, steady stream
  93. 2011 water leak passenger side
  94. No power steering, taillights, windshield wipers
  95. Time for a new engine!
  96. Help car just quit
  97. transmission broken
  98. Sway bar stop problem
  99. Battery post that connects to external fuse box broken.
  100. Noise very much like a bad wheel bearing
  101. Brake shake stopped
  102. No power to fuse 19 at the bcm
  103. Repeated Noise Under Slow Braking
  104. No start after exhaust repair. Help ! Please
  105. fuel pump?
  106. No ABS, no dash light on
  107. Express down
  108. HHR SS pads and rotors don't fit
  109. TPMS Learning mode WITHOUT a FOB
  110. click in stgeering but no noise?!?
  111. Braking issue with potholes.
  112. Fuel Line
  113. Hyper blinking
  114. Wiring and or fuel pump problems need help
  115. ABS and traction control lights
  116. Tranny Issues
  117. spongy brake
  118. Repair advice.
  119. Engine replacement
  120. Chevy hh
  121. What's inside the actuator solenoid valve (for the Gearheads)
  122. No sound from radio
  123. no power to ecm/tcm
  124. Real Poser
  125. alignment nightmare
  126. Timing Chains
  127. Code 2119 - some questions
  128. HHR Morning Surges
  129. Replaced TCM now car wont shift out of first spedo not working and power steering lig
  130. Add ATF
  131. 09 HHR heater issue
  132. ABS light on!
  133. Headlight Wiring Harness replacement help 07HHR
  134. Hhr problems, not starting
  135. HHR is junk
  136. heater fan does not run
  137. Low Beam Bulb Blowing every 4-12 months
  138. "Phantom" battery drain
  139. No Crank No start
  140. P0752
  141. Limit Power steering?
  142. No FOB, but need to lock tail gate/trunk
  143. Pulsating Interior Climate Control Door
  144. Engine Swap
  145. Front end noise, not hub?
  146. No crank, no start, battery is new, starter tested fine...
  147. What is the charging voltage on a HHR?
  148. Duralast Brakepads and Rotors
  149. Intermittent/flickering radio display
  150. Transmission problem
  151. Spark Plug Replacement Schedul
  152. 2008 won't crank
  153. Codes: Autozone said prob cylinder head. Could it be evap purge?
  154. Engine issues
  155. 2006 ls 2.2 A/C
  156. Please someone help me, lots of codes
  157. Loud blinker sound.
  158. What caused this to happen?
  159. Front Sway Bar Bushings - Repair Shop/Person Recommendation
  160. I'm about to pull my hair out!!!!!!
  161. Headlight housing water moisture
  162. Transmission
  163. 2011 AC Blower motor replacement
  164. Rear thump thump
  165. Service ESC after tire rotation
  166. Head lamps
  167. It won’t stop dinging
  168. ABS TC code C0035-18
  169. No crank, no start after first start-up.
  170. Trans problem
  171. 1600$ at Chevy and still no fix need help
  172. 2009 HHR A/C sporadic
  173. timing guide
  174. Heat shield rattle
  175. cant figure where the coolant leak is
  176. vacuum leak
  177. So THAT'S what that whining is!
  178. Radio and power locks stopped working
  179. 2009 HHR Horrible vibrating from the front end
  180. Battery/Idiot light doesn't work?
  181. Replacement engine
  182. Short Throw Shifter for HHR SS F35 MU3 come with cables??
  183. 07 HHR hard start
  184. Steering issue
  185. Coolant temp (I'm asking a question asked a billion times)
  186. Electrical Gremlin?
  187. Jack stands
  188. BOOST problems
  189. Coolant leak Orings?
  190. p0302 and p0446 related?
  191. Timing chain whine after water pump replacement
  192. Possible front right suspension/strut problem
  193. Hole in oil pan
  194. Thermostat replacement
  195. P0014 CEL and TC Lights On
  196. Blue Tooth drops out after programming
  197. Oil & Coolant leak
  198. After fixing door handle, etc. no domes lights or map lights
  199. 2010 2.2 nat asperated
  200. Help!! Ac/heater not blowing any air!!
  201. Need airbag lock clips
  202. Fuel Tank Installation
  203. battery losing power overnight
  204. False dtc lights came on only code is1682
  205. Transmission?
  206. Check battery syst
  207. Need info on replacing 2006 liftgate switch
  208. Misfiring
  209. P2270
  210. Rodent nest in SS airbox
  211. HVAC Fan Switch Replacement
  212. New issue with P0420 07 LS 2.2
  213. Charging system - is this normal?
  214. My AC stopped working...HELP
  215. Esc off light
  216. 07 2.2 upper chain guard bolts
  217. tire sensor coming on and not showing
  218. Engine cranks but will not start
  219. Wipers arms?
  220. Misfire / traction control light???
  221. Power steering
  222. HHR putting and turns off at low speeds
  223. Door looks issue please help
  224. Check gas cap issue.
  225. Car wont start
  226. 2006 hhr EPS problems
  227. 06 HHR won't shift out of 1st PLEASE HELP
  228. Transmission
  229. 2008 HHR Overheating
  230. parasitic draw
  231. 2006 HHR no power after alternator change
  232. Chasing a misfire
  233. Strang AC issues Works in the afternoon but not in the morning
  234. 2010 HHR 2.2 Starter wire questions
  235. Buzzing sound center dash with a/c?
  236. ABS Code "C0292-1A"
  237. Passlock Light Flashes all the time
  238. AIr conditioning doesn't work when really hot
  239. Auto trans surging at low speeds
  240. Wheel bearings - howling sound got me
  241. Service Airbag warning
  242. charging system question
  243. Problems with the breaks on my HHR
  244. AC stops working and the temp gage stops working
  245. 2007 HHR Anti-Theft I'm locked out, please help
  246. Finding interior parts?
  247. 07 2.2 manual - issues w reduced engine power, otherissues
  248. Install metal inside door handle
  249. Pinkish fluid leaking bad!!
  250. I have a weird problem
