PDA
View Full Version : Problems/Service/Repairs
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. no windshield washers
  2. Window wiring schematic requests
  3. 2008 lt2 half panel ac/heat not working
  4. 2011 HHR transmission schematic
  5. 2006 hhr won't start or crank
  6. Engine Missing?
  7. Blower motor
  8. Speedometer spikes and stalls
  9. 2011 hhr
  10. Radiator fan inop
  11. How to reset Body Control Module?
  12. 2008 AC/Heater Not Blowing
  13. Key fob case...
  14. wet floor both sides
  15. P0300 Mystery
  16. P0013 exhaust camshaft bank 1 circuit malfunction
  17. Anti-theft light flickering constantly while driving
  18. Driver door
  19. 2010 HHR SS - Service ESC, Gauges Acting up, Hard Shifting
  20. Adding Remote start
  21. P0191 p2177
  22. Traction control
  23. Brake noise
  24. Steering Rack
  25. Headlight only working when remote clicked
  26. Please help P0172 system too rich
  27. Timing Chain Issue
  28. Help plz
  29. Lost key
  30. Low idle
  31. ground location for tcm
  32. 2010 door vs 2011 door
  33. Weatherstripping replacement??
  34. My HHR is marking hot but everything is normal but I do smell oil
  35. Vent canister connector
  36. Climate control blower switch operation
  37. Engine won't start, starter don't engage.
  38. Starter Problem! Turn Ignition, One Click, No Crank
  39. Some Sort of Electrical Issue (Need Help)
  40. difficult to get the emissions monitors to be complete
  41. 3 codes at once
  42. Tilted Sunroof stuck
  43. Bizarre Sunroof Control Issue
  44. Non abs wheel hub and bearing on hhr with abs
  45. Couple of issues, temp gauge/ac
  46. Brake noise
  47. Wet floor....and more
  48. Yet another fuel smell thread
  49. A/C High Side Schrader Valve
  50. Esc
  51. What to do
  52. Cooling system issues
  53. VCIM out?
  54. Help! I broke a bolt
  55. 2008 no crank no start
  56. 08 HHR SS scanner connection issues
  57. 2011 HHR - U0073 code only during hot/humid weather
  58. what is this june bug/cicada noise coming from my engine?
  59. --- f
  60. 07 HHR Sunroof Drain Tube Grommet
  61. new owner of 2006
  62. Intermittent power steering problem
  63. Trouble codes
  64. No crank problem
  65. All rear lights not working.
  66. Alarm Issue?
  67. How to keep rearview mirror lights from turning on?
  68. Changed Temp Sensor and Thermostat
  69. Oil change
  70. How to replace AC vents...
  71. Control module from Flagship 1, failed only after one day? Any ideas
  72. Sluggish acceleration from a stop
  73. HHR Locked Out Can’t unlock with key
  74. HELP with electrical issues
  75. Loss of acceleration, erratic speedometer, etc. Only code P0573-00
  76. Svc tire monitor
  77. Howl on acceleration..
  78. Front end wheel grinding and clunking over potholes
  79. 2006 hhr LT issues
  80. Poor Idle esp with AC
  81. Cooling system issues
  82. P0340 troubles
  83. A clunk ?
  84. can't shift to 1st or reverse 5 speed
  85. 2009 HHR. Crank but NO start
  86. 06 HHR Climate Control Lights not working
  87. Hard shifts on 2006 HHR
  88. Still can't get a smog check
  89. P0102 code
  90. 260K Miles, New transmission fluid?
  91. Cooling system issues
  92. What the ....?
  93. P0341 with stall from Idle
  94. Help with ecm/o2 wiring
  95. Steering column noise
  96. Not starting
  97. Alarm HHR
  98. intermittent hard shifting
  99. Brake noise
  100. Another Computer Code Issue
  101. HHR stalled then wont start back up.
  102. power steering shut off
  103. Front right turn signal not working
  104. Rpd cam phasers showing no data P0016 P0017
  105. Battery Draw when Engine Running
  106. What is the name of this hose behind the engine? (pictures included)
  107. Cannot open door
  108. Leaky door panel nightmare...
  109. Remote start not working
  110. Door handle woes
  111. Odd clutch pedal problem. Half power on 1st and 2nd
  112. HHR noise in front
  113. AC Blower Problems
  114. Weird problem service traction control
  115. Weird brake problem...
  116. Tire Noise...extreme!!
  117. HHR Cruise Control & Wipers
  118. Could this cause ?
  119. Power steering works fine but light stays on
  120. 08 Chevy HHR computer ruined by shop??
  121. Wont start after replacing transmission solenoids
  122. Brake Nightmare
  123. Traction Control Problem
  124. Lag isue ?
  125. Multiple codes on new to me HHR SS
  126. A/c blowing warm even after new thermostat
  127. AC Cold but not Blowing - Air Trickle When Driving
  128. 2006 HHR 2.2 question
  129. 2009 Chevy hhr
  130. FOB Rear Door Programming
  131. Window controls not working.
  132. Maybe Thermostat Issue?
  133. Trouble Codes
  134. Climate Control Vent Selector
  135. P0442 question
  136. Knock, Knock, Knock
  137. Power Steering
  138. Oil Leak Alternator Pulley? What?!
  139. Cranks, but will not start. Whole slew of repairs
  140. 2006 Chevy HHR 2.2 Crankshaft Position Sensor
  141. Finally happened at 340k miles, the power steering went out on my 2006 HHR
  142. P0234 Turbo overboosting then going limp
  143. Windshield Cowl Not Flush with Windshield, is this a problem?
  144. Frame Structural Damage
  145. Wipers ??
  146. Mystery coolant hose
  147. Some issues.
  148. Forge motorsport bypass valve orientation?
  149. What Is The Number For This Part?
  150. Fuel leak
  151. A Pair Of Problems
  152. Should I replace Clutch Master/Slave Cylinder
  153. another door lock problem
  154. p0172 error code
  155. Speaker ?
  156. Transmission fluids
  157. door lock problem
  158. Reduced engine power
  159. Electrical issues
  160. Ignition switch and codes
  161. Remote start stopped
  162. Power steering recall?
  163. No crank/no start
  164. No electrical power
  165. Recurring shifting, power steering & gauges problem.
  166. AC issues
  167. Speedometer not working, not shifting from first
  168. ABS Control Module for a 2011 HHR LT 2.4L
  169. 2009 hhr alternator problem
  170. Power Steering Light came on/Transmission?
  171. Instrument cluster
  172. Replace the transmission?
  173. Multiple CEL, car stalls consistently.
  174. Brake shoe removal & installation
  175. P0449 and p0455
  176. Relay Direction
  177. 2011 HHR has no power
  178. stumbling at idle....fuel issue?
  179. Cruise control not working code P0573
  180. Oil leaking into Coolant
  181. Window Switches Confusing
  182. Timing Chain ?
  183. Automatic Transmission Delay
  184. Clutch Feed Line
  185. HHR rejected by emissions station
  186. Timing chain should do's?
  187. 2008 hhr liftgate stuck closed
  188. Blower Motor does not run
  189. Changes following hub and axle replacement
  190. Checking battery voltage
  191. 2006 Sports Edition Pinstriping - NEED
  192. Rpms running to high
  193. Rear shoe looks good?
  194. Driver non-power seat position
  195. Smooth Shifting when Cold
  196. Key Fob Replacement
  197. Paint Job
  198. p1174 and p1516 codes
  199. Ran hot, then not, reduced power output....
  200. Low Voltage / Headlight Dim
  201. Transmission problems
  202. Valve time or cam
  203. heater /defrost AC issue
  204. 2011 Model year Rust
  205. This is a problem for me, rear defrost button?
  206. How does voltage sensor work on negative cable
  207. Ac
  208. code p0442
  209. Need help with finding the source of some trouble codes
  210. 2009 HHR - no shift out of 2nd gear
  211. Transmission Issues - Next Step?
  212. rear left turn signal not working
  213. Get Steering Wheel centered?
  214. Hi beams cut off
  215. Timing chain
  216. remote key for door lock MIA ?
  217. Lower control arms
  218. 2,000RPM whine, torque converter? Shifting pretty hard too.
  219. Oil Leak after Solenoid Replacement
  220. 02 sensor 2006 chevrolet hhr lt 2.2l upstream
  221. possible bad shift solenoid?
  222. Vvt solenoid pigtail
  223. rear bumper (?) rust
  224. 06 HHR LT WON'T START.. And hello to ALL
  225. Battery Light, Alternator Wont Charge.
  226. Emissions Test OBDII
  227. LED Headlight Orientation
  228. DTC P0506 powertrain idle control system RPM lower than expected
  229. Radio issue ?
  230. Excessive Fan Noise
  231. CEL P0010 Code Quick Question
  232. Headlight going in and out
  233. Transmission seal
  234. Door Lock Issues
  235. 2009 Chevy HHR Major Problems No Crank
  236. Captive nut loose on Subframe Bolt
  237. Ball joint replacement
  238. Car turns over but only backfires a little bit but won't start
  239. Cranks, fuel pump not running…
  240. More front end issues
  241. Starting Issue
  242. Alternator diode
  243. Map Lights
  244. Crankshaft seal question
  245. Traction control light always off
  246. Radio Connections
  247. Squishy brakes after running out of things to replace
  248. Need help with Code B3951-02
  249. AC blows weak or stops in Reverse
  250. Sunroof seal 2008 HHR Ss
