PDA
View Full Version : Problems/Service/Repairs
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. Random window and door problem
  2. Car is creaking like crazy, looking for things to check (have researched here already
  3. Cel po496
  4. Warning bell going crazy!
  5. Rear hatch wont open
  6. I think my 2.2 jumped time
  7. Knocking, ticking sound when accelerating at 4 rpm.
  8. 2011 HHR - AC stopped blowing cold air
  9. Not sure what the problem is????
  10. 2011 HHR Timing Chain and code P0300
  11. Noise?
  12. weird issue with Interior lights staying on
  13. key does not work
  14. Bow tie removal
  15. overeheating/fan runs after shutdown
  16. Transmission Durability
  17. AC compressor
  18. ABS warning light? It ain’t always the ABS sensor!
  19. Wheel bearing or Strut bearing
  20. rodent infestation in the spare tire well
  21. tailgate relay
  22. Car surging after replacement of Camshaft Position Actuator Solenoids
  23. A/C Blower stopped. Magically working again?
  24. Steering bind/Clunk HELP
  25. Car stalled at the start ...
  26. vibration
  27. 2008 hhr ac compressor
  28. Tilted sunroof won’t close - 2006 HHR
  29. Red Brake Light on Dash - Not Parking SW or Fluid Level
  30. Rearview mirror map light button issue
  31. door lock solenoid
  32. Gauges and TCM issues.
  33. U0100 code have to pass this info on
  34. Cranks without key
  35. Can't pull codes; no juice to outlet. Prob causes?
  36. Stupid question time
  37. 2009 HHR LS Cruise Control
  38. 2007 HHR overheating only some times
  39. Dash Vent
  40. auxillary plug
  41. Need some headgasket guidance from the HHR gurus
  42. Helping hand for fallen marine
  43. Running out $$ help
  44. Tinny Rattle.
  45. Low Fuel Pressure
  46. Engine light
  47. CV Axle Tripot GAP?????
  48. Broken Ignition Coil Hex Bolt
  49. Driver side door lock issue
  50. 2010 hhr power window issue
  51. Help with alignment question, tire wear
  52. Fender Bender
  53. hhr 2007 2.4L LT
  54. Speedometer problems
  55. AC stopped blowing cold air, and check engine light is now on
  56. Falling Visors
  57. Driver side door wont unlock
  58. Radiator fan not working 2006 hhr lt
  59. Stupid Question
  60. 2007 blower motor issue
  61. Remote Start Immediately Shuts down
  62. Sub shaft removal(CV axle
  63. Can I drive on a code that reads p0014 & p0013 camshaft solenoid that is going bad?
  64. Can’t get launch control to turn on
  65. Radio
  66. Here i go again
  67. Throttle body
  68. Temperature Gauge, and over heating issues
  69. 06 HHR Intermittent Power Reduced Mode
  70. ABS Light - C0045 code
  71. Need to know main ground locations
  72. Traction Control
  73. Running Light Not Working
  74. Pass Key III
  75. HHR 2007 code P0017 and C0045
  76. Dead Sunroof AND Hatch won't lock
  77. Tons of P codes... help!
  78. Shifting Issues
  79. Knocking noise
  80. Security system is locked after replacing the electric power steering unit.
  81. Camshaft VVT Solenoid Connector Retaining Clip
  82. Sporadic Gears Slipping
  83. Bad starter again or some other issue?
  84. Daytona Beach, FL
  85. Serpentine Belt Issues
  86. Cruise Control Will NOT Engage
  87. P0171
  88. Motor swaps
  89. Keyless Entry Receiver - Reprogram or Replace?
  90. Headlight ground wire
  91. Help please
  92. Defrost running
  93. HHR hard shift and air mass engine code after alternator change
  94. Looking For TSB 06-08-50-007
  95. Pos 2011 Chevy hhr lt
  96. Grinding noise after changing cv axle
  97. Noise
  98. Power Mirrors
  99. Turns No Start
  100. Svenubee Intermediate Steering Shaft warning
  101. Green LED light
  102. 2006 hhr lt drivers side door lock switch
  103. Need Sunroof Replacement. Question about frame
  104. Stuck in Limp Mode
  105. Radio Harness
  106. 2006 HHR No Start
  107. Slightly different TPMS issue
  108. Won't crank
  109. New tires and - NOW WHAT!!!!
  110. Where to get motor mounts?
  111. 2009 ambient air reading doesn't move?
  112. What’s the name of this piece?
  113. 2011 over heating.
  114. Sudden oil leak after valve job!
  115. Leaking seal or gasket near rear wheel
  116. Wheel Thumping While Driving?
  117. For people that change outer seal on the transmission
  118. Front end and steering wheel issues
  119. Battery went completly dead, now instrument cluster is not working
  120. Turn signal doesn’t engage when using left turn signal
  121. Backup Light Problem
  122. manny
  123. Tpms all 4
  124. 2010 HHR abs big problem.
  125. Driver door lockout
  126. Dashboard noise
  127. Engine power reduced
  128. 2010 heater problems
  129. Rear window stuck down
  130. Codes P0131, P0171, P0300 & P1133
  131. Atlantic City Depressed Way HHR SS Transmission Problem
  132. Ignition will not turn
  133. Bad Chain?
  134. 2006 HHR Sunroof problem
  135. missing at idle
  136. BCM issues
  137. trans cooler lines
  138. HHR still won't start even after replacing starter
  139. Steering issues
  140. I have a 2006 chevy hhr
  141. P0700 and p0742 code and hard shifting.
  142. Tech 2 question
  143. Power Saving Mode now won’t start
  144. Paint problem
  145. Front brakes wearing 2x faster on the passenger's side than on the driver's side
  146. Power Locks Snafu
  147. Service Code P0016: Besides the timing chain, what should I replace?
  148. Fobs don't work, no TPMS readings
  149. Tpms relearn tech 2
  150. HHR used - historical repairs
  151. Midas..the garbage touch !
  152. Service traction and abs light
  153. Trany flush
  154. bucking engine
  155. My HHR engine sounds crazy loud
  156. p0340, new ecu needed?
  157. Service ESC appears when its cold
  158. Auto transmission problem
  159. Front end shaking 2009 HHR
  160. Drivers window problem
  161. 2006 Oil Leak
  162. Repair or Junk
  163. Check Charging System / Auto lights not working
  164. Cooling problems/ a/c
  165. Noise from throttle body when trying to clear codes u0101 & p0449. No crank
  166. Wiper transmission
  167. spark testing
  168. 2010 HHR 2.2 bad oil leak possibly from timing tensioner?
  169. Ignition transponder and receiver question
  170. Temp gauge
  171. Plastic Cover and brackets on fuel lines
  172. Glitch in driver information readout
  173. New Here Just got a Panel
  174. rough cold start
  175. Need help with p0420
  176. high idle after TB cleaning
  177. 2006 HHR won't crank
  178. painting roof and removing or masking windshield
  179. Temp dial gets to red and no heat
  180. 2009 63k mi valve job!!!
  181. P0011 & p0014
  182. Watch what you do when replacing your fuse box
  183. Since
  184. A/C Problem
  185. Auto locks malfunction
  186. Can Dorman Programmer be used for non Dorman Key fobs?
  187. Another timing chain video
  188. CEL Lights and Instrument Panel Going Haywire
  189. Here we go again
  190. (a different kind of) "key stuck" issue
  191. P0455 - Evaporative Emission Control System Leak Detected Gross Leak
  192. More headlight fun!
  193. timing chain and balance shaft
  194. Engine Mount
  195. P0302 low compression 2011 / 120k
  196. Torque Converter Clutch Solenoid replacement
  197. code P0365
  198. Lost bolt
  199. Driver Side Door Handle Broke Off!
  200. Code p0016.
  201. Good Ole Power Steering Message Again
  202. Error codes
  203. Loss of Power, no crank
  204. Passenger Side Blend Door Actuator never answered
  205. Front End Alignment
  206. Replacing the fuel pump
  207. Timing chain motor trashed?
  208. CEL with P0014 Code
  209. Paint chip repair
  210. P0010, P0011 Code-Replace Solenoids, still have the same symptom
  211. Fuel Tank Pressure (FTP) Sensor Performance code p0451
  212. 09 ls panel oil leak
  213. RADIO - No Display
  214. Service Air Bag Message
  215. More electrical problems
  216. 5-speed manual balky shifter.
  217. 2009 HHR Overhead Console
  218. Click when i press brake
  219. Automatic Lock Issues
  220. trouble with codes
  221. idle issue
  222. 2007 hhr
  223. Power Steering failure
  224. key fob programmer - need it
  225. P0013 and more
  226. Tpm
  227. Weird things about your hhr
  228. headlamp issue/question
  229. Fog light wiring using passenger side empty slot
  230. Message Gate ajar
  231. no overdrive
  232. Alarm goes off sporadically
  233. P0304 Engine Code
  234. Parking Brake
  235. High voltage
  236. 2009 hhr 2.2. Manual trans. Heater blower failure. Switch? Blower?
  237. p0016.....car wont start
  238. Where do I start? Noisy, rough idle, poor performance, leaking oil
  239. Chevy hhr shut off and wont start!
  240. Flashing Dash Lights!!
  241. "floating" idle when warming up
  242. Mark your wires!
  243. Remote starter key fob
  244. Noise that sounds like a hub bearing
  245. Remote start- starts then shuts down in 2-3 seconds
  246. Ordered new door actuator, how can I keep the door shut in the mean time?
  247. 07 LS 2.2 no steering wheel lock, no crank
  248. wiper linkage/transmission
  249. Sensor receiving signal from remote locks/start?
  250. jumpstart ps
