- P1174
- Blown Strut
- Anybody Have These Same Problems?
- A/C problem with 2006 HHR
- Knocking noise in PS door over bumps
- blower motor dead
- Whitewall Tires?
- I think my hhr is a lemon
- Do I have a gripe with the Service Dept? Chevy Mngr?
- Will not crank!!!
- Frozen Window
- Seat doesn't stay put!
- DIC - Temp Gauge Gone?
- Sunroof and Headliner
- Hot to clear Adaptive Shift Logic w/o disconn battery?
- fob battery? wtf
- 2008 Paint Blotches
- Rear Wheel Alignment - Tech advice needed
- Stopped & in Park gear, pump brakes and engine almost dies, why?
- HHR SS Brakes
- rocker panels damage - design issue
- HELP! DIC out and fuel gauge reads empty
- stuck between shifts & klunks
- Paint peeling off wiper arm
- Service Question
- Dashboard Rattle
- Need Remote Start Help! Please
- new SS UBEC problem to ????
- Glove Box
- Couple of problems with the 06
- 2008 HHR SS Oil Question
- Headliner issues still
- Taillights
- Problem with playing bruned MP3 CD
- Remote Battery Question
- Recent stealer vist
- ABS/TC sensor problem
- Roof Rack side rail plastic push fastener HELP!!!
- Anyone else has some difficulty when shifting?
- Pioneer Stereo Stinks
- Clutch Sensor
- Steering Lock
- Warranty Work
- paint overspary on cluster pics
- Clicking noise above 35mph
- Loaner/Rental Tax
- shifter repair cost ???s
- Are TSB issues still honored if your HHR is out of warranty?
- A/C not working
- Buzzin sound from transsmion (new owner)
- Steering Column Lock
- Engine soundling like an airplane
- Ecotec Oil Flow routing through filter compartment
- No start when hot outside
- Nightmare at Chevy Dealer
- Weatherstripping around driver door wearing out
- How hot should front wheels get normal driving (brake heat)?
- Chelly wont start.... please help me find TSB to give to dealer!
- paint inperfections ?
- Windshield wiper rubbing on the hood when wiper is up.
- Fixed Windshield wipers go on when I unlock the car at times
- Purolator/Proline Ecotec oil filter: better anti-drainback o-ring than OE Delco (?)
- P.A.L. Problems
- Front end shudder
- Torque wrench: clicker or needle?
- oil analysis report
- Front noise solved
- transmission????????
- What next?
- 2006 fuel pump
- brand new hhr steering problem
- Suspension - Something Feels Loose
- Good dealer report, for a change of pace
- Extended Warranty
- Oil film on inside of drivers side window (Chevymgr i could use your help!)
- SS transmission/differential normally noisy?
- HHR paint and windows pitted after dealer performed service.
- Our first TSB for 2009 models
- New PI for a lot of GM vehicles
- "Engine Power Reduced" Hopefully Gone For Good
- Arm rest TSB bulletin
- Customer Satisfaction Recall for 2008 HHRs
- What codes can clear their self
- HHR newbie with headliner question, not what you'd expect.
- Dead Battery!
- Weird Poping Noise any Ideas?
- '08 dying at parking lot speeds
- watch your wheel studs
- Electrical problems tonight...
- PAL (personal audio link)
- Question on A/C growl/whine
- OW!My leg!
- hhr leak
- Parking brake problems!
- Paint chipping
- Removing rear window EGR Vent...easy way to do it?
- Key fob battery life?
- Air bag?
- Gurgling Noise Under Hood HHR SS Turbo
- What was that noise
- Help Please
- Speedometer not accurate?
- Lock n Key Gas Cap...
- Electronic Stability Control (ESC)
- Brake vibration resolved
- Too many lites
- Radio Button Help....
- HHR SS Door Problems?
- This car is driving me crazy
- Door Lock
- dirty windshield
- question on weatherstriping care
- Water on inside of windows?
- Adjusting Headlight/Door/Key Chime Volume
- First warranty visit (I hope)
- electrical woes
- Noise When Braking...?
- IPCW L.E.D.'s issues...
- breaks squeal
- Windshield wipers go on when I unlock the car at times
- My map lights won't turn off!
- oil change- now oil and t/C lights on, rough shift
- A/c
- TSB for stuck key problem
- Follow-Up on my "Engine Power Reduced" post
- I got a flat tire!!! But had a question??
- Uh-Oh--- red fluid on garage floor
- Arm rest adjustment?
- electric power steering go's out while driving
- Fuel Cap
- Battery keeps dying!
- Starting problems
- Windshield crack
- That Ol' Engine Power Reduced Gremlin...
- Service survey bribe
- Brakes vibration
- How long does it usually take to get parts in?
- Sunroof Goo
- Engine miss..then surge
- So pissed. Key stuck in "run" position
- Aggggg!!!
- power outlets..??
- Starting Problems
- coolant leak
- Subwoofer Problem
- Pioneer Premium 7 Speaker System ????
- What axle problem?
- Drivers door adjustment?
- Whistling mirror caps
- wish me luck...and a question
- Security lockdown...
- Gas gauge problem?
- Windshield Sandblasted
- Am I missing a screw here??
- Driver's Seat Dry rails
- TSB 06-08-51-002 (04/11/2006) Body - Paint/Body Damage On Rocker Panels
- Tires at 69000 Miles on my HHR 06
- Little rust spots?
- Eibach Spring Problem
- Visor airbag warning
- Wobbling at acceleration/vibration when breaking/Bad A/C
- plastic wear patches
- No power brakes on startup (cold)? SS
- Sandblasted Rear Panels
- Rock & Debris Damage to Radiator/Condenser
- HHR SS problems
- Dome light problem
- Donut Tire Size?
- Check Engine Light and other Service department scares
- Stupid suspension noise!!!!
- I Need some part numbers
- Anyone else have these issues?
- Question For Those Who Have Had The Shifter Assembly Replaced
- Car just dies while running!
- Radiator Drain plug
- First stealer visit
- Underhood fuses loose/popped out
- Harness problem!!!
- Advice wanted
- New brakes
- Whine noise that seems to be controlled by engine speed
- Latest oil change - shavings on the oil plug
- Cruise Control issue
- Taking lug nuts off
- Tire Pressure Valve Stems Wanted:
- 1st trip to the Idiot Dealership
- 2008hhrss
- Questions for Chevy parts/service mgrs
- Interior light questions for 2008 HHR
- Wind noise ...above my head
- 2006 HHR Sunroof Loose
- Fan control unit
- OK i have to ask???
- Tire pressure monitor problems
- Shifter and shift interlock - GM warranty
- Alignment/Suspension toast after collision
- Rear hatch makes a popping sound ?
- Whirring sound at startup?
- Grrrrr. Going to kick hubby's arse!
- Dropped Violet at the dealership this morning
- Etching of paint on rocker panel and rear door rock guard
- Water spots in rear bowtie
- Lighter or outlet? Is this guy full of shinola?
- Warranty almost expired & she goes to hell in a handcart!
- Re: Fuel door opening during car wash.
- First oil change
- Wet windows
- List of Diagnostic Trouble Codes for 2008-2010 HHR
- Metal Shavings in oil filter???
- HHR 4 speed auto trans dead in 2010 (good)
- A/C Problem
- HELP....I got issues
- 07 Fall Spec. Ed. Wheels Need part number
- Dead battery..now electrical problems
- PAL problem
- What Happened???
- Headlight Issue.
- Compass Issues?
- Where to buy Air Filter etc.?
- Possibly the rotors?
- Auto Shifter Button Stuck!
- Door Lock Issues
- HHR vs. Tundra
- car shakes when I brake
- Help Please
- Scary transmission problem - learn from my experience!
- In for some work
- door locks issue
- Ignition problem
- Bought used, lots of issues...
- Noise in radio from PAL
- Have you had rotor issues? POLL
- Torquing Lug Nuts
- Creaking Noise Passenger Side Dash
- Just a Few Issues!!!!
- Replaced side marker bulb
- Windows sticking
- warped rotors - AGAIN!!!
- Pop Locks
- Interior Lights
- Black soot on tailpipe
- Help!!
- Wind noise??
- Difficulty removing key from ignition switch
- Official TSB and Recall Thread
- hi all....stupid question
- headlight bulbs
- Possible Problem Connection
- Smell
- 600 Miles and back to Service
