PDA
View Full Version : Problems/Service/Repairs
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. no boost
  2. hard starting after filling gas
  3. Door lock problems
  4. ignition coil question
  5. CKP Relearn issues
  6. Embarrassed newbie locked out! Help!
  7. Instrument cluster problem
  8. Will an 04 2.2 ecotec from an Ion fit an 06 HHR
  9. 2011 HHR 2.4 ECM Removal
  10. Fob Unlock
  11. Exhaust Smell in Cabin
  12. Service traction control/ ABS LIGHT on
  13. Replaced fuse and rear headlamp now battery is dead!
  14. Only drives in reverse fix
  15. Blower quit today--- for a few miles then working again
  16. 2006 2.2 HHR Electrical Issue or possible Demonic Possesion
  17. Washer Pump Grommet
  18. Clutch Pedal Return Spring Issues
  19. Dashboard went crazy for a minute (2011 LT)
  20. Panel to half panel window issue
  21. Crashed my car and want to know how bad it is
  22. Car won't start
  23. rough idle/stalling
  24. P0010 and P0011 codes.
  25. Reflashing a BCM.
  26. Mirror switch wire
  27. Traction Control light
  28. headlight adjustment screw inoperative
  29. Seat belt sensor
  30. Engine suddenly overheating, no codes
  31. Broken latch
  32. Shake’n all over!
  33. Dash gages crazy, intermittent power steering/cold air
  34. Front end rattle.
  35. temp gauge sensor
  36. Rough Idle after road trip. where do i start?
  37. Help!!! Motor Mount Replacement Gone Wrong!!
  38. Help please!!! 11 Chevy hhr ls traction control hard shifting
  39. Price to repair control arms
  40. MAF not plugged in? Check engine light disabled?? What?!
  41. No crank after water found in trunk compartment
  42. Questions about Quickstruts
  43. Transmission Fluid Leak
  44. Severe coolant leak all of the sudden
  45. front seal or harmonic balancer pully SLEAVE?
  46. Strange behavior from drivers door lock
  47. want to put bluetooth in my 2011
  48. HELP! Everyone stumped. Unknown road noise.
  49. Thermostat?
  50. confusing no-start
  51. clunking heater
  52. Steering hanging up
  53. static speaker sound after start on car or turn signal left or right
  54. S/C kit installed in 2006 HHR LT engine won’t crank
  55. low brake fluid
  56. Fuel filter??
  57. Driver Door Sounds when opening
  58. Rear View Mirror Mount Stuck
  59. P0302
  60. Turn Signal Not cancelling
  61. Bilstien struts
  62. P0171 Problems
  63. MORE abs/traction problems
  64. Broken windshield from mirror mount
  65. Weird stuff after cleaning maf
  66. procedure to replace Radiatior HHR 2006 2.4 manual shift
  67. Radiator Replacement Troubles
  68. coolant temp rising when not moving and odd raddle on left side of the engine
  69. Dash Mirror Map lights switch
  70. Dome Light Reattachment
  71. Antilock brake question
  72. no power2006 HHR
  73. Odd Accleration/Throttle Pedal
  74. 2007 2.2 rough idle
  75. Bosch ecu
  76. Got rear-ended yesterday. Rear hatch door is slightly bent out of shape.
  77. Keyfob wont' open rear panel doors.
  78. Lifter noise??
  79. rough start, then runs fine. No codes
  80. Passenger side leak?
  81. HHR SS, 2009. BAD HEAD GASKET And?
  82. Valves Hit Pistons
  83. Electrical gremlins
  84. What killed your HHR and at what mileage?
  85. 2009 HHR SS 2.0 Turbo. no start after repair
  86. Ac compressor on same wiring as temp gauge?
  87. P0016 code. Sensor or something else?
  88. Evap vacuum hose
  89. sound on the passenger side front tire and driver side don't speed up
  90. That plastic coolant filler pipe!
  91. a/c heater control
  92. Transmission question
  93. Recommended Motor Oil - I Should Know This
  94. Changed front hubs, new wheel issue.
  95. need help/ information 08 hhr
  96. Steering wheel off center
  97. intermediate shaft grommet
  98. code p0700
  99. Not a problem.. yet
  100. Hard shift into 4th..
  101. Help please
  102. P0455 EVAP Gross Leak
  103. Car still pulls after alignment
  104. Remote Start relay?
  105. Exhaust manifold studs for 09 2.4?
  106. Does the radiator fan have high and low speed?
  107. Possibly fuel pressure problems
  108. Relay problem?
  109. Brake light on dash suddenly on
  110. Found my coolant leak
  111. Leaking oil at water pump access?
  112. Chevy hhr 2008 repair questions
  113. well changed my O2 sensors, AGAIN
  114. Key Fob works only when next to vehicle
  115. Ecm/tcm/bcm cover box part number
  116. Timing chain kit arriving. Need advice
  117. high beam disappeared
  118. Steering Rack Rebuild?
  119. Paint code
  120. OBD Codes P0575, P0700 & U0073 on 2006 2LT
  121. Best price on timing/balance shaft kits?
  122. 2010 HHR LT - C0050 RR Wheel Speed Sensor Circuit - How to...
  123. Those LCA bolts!!
  124. Shifting is what ????
  125. Front end noise
  126. Service Airbag + Traction Control/ESC
  127. Which actuator do I need to replace?
  128. Control arm bushings. Which side up?
  129. Car
  130. passenger side water hhr 2007
  131. Tailpipe knocked off center
  132. 2007 HHR Possible Alternator?
  133. i have a few questions and looking for feedback.
  134. Overheating!, need advice
  135. P0449 code, canister purge valve
  136. 2007 Chevy HHR LT - Chrome side Mirrors not Working
  137. electrical gremlin
  138. Upper Transmission mount
  139. A little levity
  140. Chevy HHR LS 2.2 starting really rough
  141. Could these all be tied to the BCM?
  142. Crank but no start!
  143. Vacuum hose dunce question
  144. Help w/Seat belt issues
  145. Not charging
  146. No crank no start
  147. Tailights
  148. New HHR owner, Tranny problem
  149. Intermittent Airbag Light
  150. blown fuse
  151. low/no speed steering noises
  152. Rear axle bushings shot :-(
  153. Service ESC Traction control ESC off
  154. I drove my hhr about 8-9 miles with the temperature sensor unplugged
  155. Desperate for help
  156. new battery makes it go crazy
  157. Help p0449
  158. 2006 HHR occasional clunk
  159. Security problem?
  160. 2010 HHR Ingition Lock: Key Sense ??? Remote Start issue
  161. Service ESC + Service Traction + lock icon appearing on dashboard
  162. Looking at buying an SS
  163. Light problems
  164. Water dripping on gas pedal
  165. Wind deflector repair help
  166. Hissing near brake pedal?
  167. HHR SS FAN will not run even after replacement of new assembly
  168. P Code Confusion
  169. Ignition / Blinker. Housing is lose.After Ign. Change
  170. Lower control arm
  171. Mechanic in LA/Hollywood
  172. 2011 battery light on
  173. 2009 panel no power windows
  174. HHR problems
  175. Headlights
  176. High idle
  177. flashing CEL wont crank or start obd2 reads fail?
  178. 2006 hhr basket case *need some help*
  179. Blower Motor was only on HI, now not at all
  180. Alternator tensioner
  181. Chevy 2011 HHR slow to start, smell of gas - New to cars
  182. Alot of issues: please help
  183. 2007 Chevy HHR LT - Steering Knuckle
  184. That annoying noise!!
  185. 2007 HHR key fob no longer work after dead battery
  186. Drivers side rear Door won't unlatch
  187. Hunting down "laggy" acceleration
  188. #4 misfire
  189. P0013 and P0014
  190. 2009 Panel LS Brake Master Cylinder O-Ring
  191. Oil leak
  192. Need heip
  193. Dealer Oil Chage, now AC doesn't work
  194. 2006 HHR Parking lights stay on.
  195. TC, ABS warnings
  196. Engine bay fuse panel rewire help please
  197. Odometer doesn’t move
  198. 2007 Chevy HHR LT - Security System
  199. 2007 Chevy HHR LT - Code Reader Won't Work
  200. How to remove "beauty bar" (rear hatch opener)
  201. Will not crank.
  202. Code p0128 need HELP!
  203. 2009 hhr sometimes stuck in 1st gear.
  204. All but 1 Speakers Not Working
  205. Backseat Passenger Window not working
  206. Power Steering hard to turn / not working
  207. Buzzing vibrating sound
  208. Driver's Door Won't Open
  209. Key fob problem may be figured out
  210. 08 HHR cold rad cap after driving
  211. Front end noise is baffling
  212. Engine problems
  213. Messed up on rear brake adjustment
  214. Newbie-Rough idle and window questions
  215. Fuel pump problems?
  216. Inner tie rod part numbers
  217. Outside door handle replacement, inside damage
  218. Ignition Coil Pack Mount Bolts
  219. Runs for 3 minutes then shuts down
  220. Not holding fuel pressure....
  221. What next?
  222. HELP! HHR SS stopped odometer and no check engine light at all
  223. audio speaker troubleshoot
  224. Lower Strut Mount Bolt/Nut
  225. Brakes
  226. Speedometer not working/ not calibrated
  227. Water Leak on Passenger Side When Raining
  228. flexuating idle while driving on my HHR
  229. Another no crank issue
  230. Temperature Gauge Not Working
  231. The Shakes
  232. Leaking AC compressor
  233. Timing chain
  234. Intake Manifold
  235. cannot adjust the clock
  236. Driver side sun visor
  237. Starts with rough idle then revs up
  238. LCA bolt/bushing issue
  239. test don't guess ECM 2008 HHR2.2
  240. Slow air leak from valve stem
  241. Will an older 2.2 ecotec fit in my 2007 hhr
  242. rough
  243. 2008 hhr rough idle when ac is on causing p0303 code?
  244. Possibly a blown motor?? Help!
  245. Need electrical help
  246. Intermediate steering shaft boot
  247. Rough Idle
  248. Drive cycle
  249. P0496
  250. Throttle Body Cleaning (The Good, The Bad, & The Ugly)
