PDA
View Full Version : Problems/Service/Repairs
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35
  1. 2009 2.2 temp question
  2. 2.2L + Dual Exhaust = low back pressure?
  3. power window rocker/leveler light?
  4. Check Engine light on - no codes
  5. Help please! Electrical Gremlins Invade Elvis...
  6. Seasonal fuel blends
  7. Remote start problem
  8. REPAIR LIST!! lets see whats broken!!
  9. Water Leak/Butyl Patch problem - worst case scenario
  10. Temp gauge on dash
  11. My Gauge Cluster Went Banannas
  12. front end shimmy @60 MPH
  13. Another hard shiftin HHr
  14. 2009 2.4 2LT Traction Control Problems
  15. Do you have this problem: Key Won't Unlock Door
  16. Engine blew on my 08 2LT-
  17. O2 Sensor
  18. Door lock stems not always going fully up/down
  19. cheap stock hubs...
  20. Speedo back lighting
  21. clutch master cylinder bleeding
  22. Running Boards
  23. I need serious help with my HHR
  24. 2.4 eng light
  25. noise in drivetrain
  26. Remote Control Not Working....
  27. Brake rotors
  28. Finally got fed up, End links are off!
  29. SS died on freeway
  30. Fuse Box getting replace!!!
  31. Auxillary booster pump
  32. Strange noise when I´m driving & Turn to the Right side.
  33. Gas station pump keeps stopping.
  34. Wants to Grind Gears Going from 2nd to 3rd- 5 speed
  35. What tempeture does the HHR SS run at "coolent"
  36. Dex-Cool "Puddles"?
  37. HHR Power Windows Inop
  38. rear bumper
  39. Not Again :(
  40. Ac only on passenger side
  41. Tire pressure gauge
  42. need part# for wheel well liner
  43. Hard to Start 2008
  44. Open rear window vibrations & noise
  45. Noise Under dash-Brake Pedal?
  46. Loose auto shifter knob.
  47. Has anybody fixed this?!?!?
  48. 2006 Any one solve this problem? Power Steering/Tansmission guages blinking
  49. Extending my warranty
  50. Changing Cam sensors T/C engine light on
  51. RPD Data Not Available
  52. 2006 HHR starting problem
  53. Stuck Ignition Key
  54. Blinking climate control lights
  55. driver side bulb gone
  56. HHR Starter problem...
  57. Howling noise
  58. Exhaust Flex Tube Crack Question
  59. radio has gone crazy
  60. flooded drivers floor
  61. Rear Axle damage...can this be true!!!
  62. 2006 A/C Problem
  63. Service Airbag Light/alarm
  64. Random Traction control light and transmission slamming.
  65. Powered side mirror selector lever popped out!
  66. 2006 1LT A/C switch pressure
  67. how can i tell
  68. engine surging problem
  69. High beam problem
  70. Passenger Airbag light
  71. Alarm Question
  72. Another tire pressure monitor problem...
  73. Radio display for CD's "Songs or Artist"
  74. Rocker Panel Paint Issue- Side Skirts OK or must use Running Boards?
  75. Car won't start!
  76. License Bulbs Acting Irratic!?!?
  77. HHR Cooling Fan
  78. New to forum...
  79. Emergency Help!!!!
  80. Paint problem
  81. Leak oil after engine fix from dealer
  82. Help-what have i done?
  83. 2007 hhr trans kicking hard
  84. Exhaust problem - now what do I do?
  85. 2007 HHR Front Passenger Window Scratches
  86. po171 code insight
  87. No cruise
  88. road noise: car or firehawks?
  89. Impala, not HHR compass reset
  90. here's another solman/hyperv6 invite
  91. Intermittent Cruise Control and Clutch Problems
  92. Car stalls when I turn on a/c
  93. Battery light and chime
  94. Bad front Bearings ?
  95. Radiator Problem
  96. Strange tones while driving
  97. Traction Light comes on.
  98. ESC Problems
  99. Oil Pan Issue
  100. Chevy-logo on rear door
  101. Intermittent Problem on 06 HHR
  102. Radio not working
  103. turn signal issues
  104. code P0011 on 2006 HHR
  105. No Steering wheel lock.
  106. Speaker problem
  107. Panel Door Poppers
  108. No power and key in stuck switch
  109. replacing lower control arm
  110. how to remove running boards
  111. Plastic covers for entry remote
  112. blower motor/ stalls
  113. Front hubs went bad???
  114. Engine light
  115. too many problems car going to the dealer monday
  116. P0299 Code and Waste Gate Adjustment
  117. Darn Door
  118. Well's well that ends well I guess
  119. Scuffed my brand-new HHR
  120. Fuel/Air Induction Service
  121. A/C problem
  122. Suddenly engine noise got louder
  123. Possible Transmission issue?
  124. door wont open
  125. Squealing noise from front brake pad?
  126. Engine stutter
  127. Smooth shifts with manual transmission
  128. Panel Door question.
  129. Rear wiper issue
  130. P0011 Troubleshoot.
  131. Power Steering Error Code
  132. Brake Pedal to Floor!!!! Cause & solution a mystery!
  133. Hewbie
  134. Key will not release
  135. Two steering column related problems in seven months
  136. daytime running lights stuck on
  137. change the belt
  138. Front end click on full turn
  139. Error Code P0135
  140. Special tool?
  141. High mount brake lamp replacement
  142. Clunk noise in Steering
  143. Power windows dont work,, help
  144. "engine power limited" on the dic?
  145. Seating problem
  146. Check charging system??
  147. Is there a way to get the car out of park?
  148. 06 lt jerking
  149. Putting auto shifter back together
  150. weird heated seat issue
  151. Control arm bushings
  152. A quick question
  153. Remote Start Issues
  154. Air Filter change
  155. dimmer switch ?
  156. now I really hate GM
  157. Water leak
  158. Air Condition varies
  159. UGH! Code U2137/Our HHR!!
  160. just looked under my hood
  161. Door pannel
  162. sluggish?
  163. HELP! Car Won't Start/Security Light Stays On
  164. Turn signals not deactivating?
  165. Moog Sway End Link problems
  166. Air Conditioner Stink - Fix Found - Simple
  167. esc not active
  168. 2010 LS...800 miles...vibration & rumble
  169. blower motor replacement kit part number?
  170. Erratic Gauge and Warning Light Readings
  171. Broken glass
  172. Soot at tailpipe
  173. 2007 AC Issues...
  174. Headlight cracks
  175. Serious engine vibration during hard acceleration.
  176. Struts and shocks
  177. Scored Rotors at less than 10K
  178. A solved problem and a possible hint for other owners.
  179. Driverside front and back have water!
  180. More Sunroof and Short Shifter Issues
  181. speakers going on/off
  182. Knocking noise when accelerating/slowing down
  183. Brake Pads - Question on Wear
  184. Heat gauge and AC not working all of a sudden
  185. Problems
  186. Driver's side speakers stopped working
  187. AM/FM magically stopped working.
  188. 2008 rusting
  189. sun roof deflector removed?
  190. 08 HHR Ignition Stuck in Run Position
  191. Funny Service Mishaps
  192. Warped Rotors
  193. Aleart tones got quite
  194. Jumpy boost gauge and car surging?
  195. Does the warranty cover cosmetic problems?
  196. service engine light
  197. SS E-Brake quit working completely
  198. Replacing exterior door handles
  199. translation of DTC
  200. Weird issues with 2009 HHR
  201. Buzzing vibration... passenger side
  202. A/C Fan Not Blowing Hard From All Vents
  203. Bad cat/flex...dealer wont cover
  204. INOP Horn Issue, Dealer Story
  205. CV joint or half shaft
  206. Remote start not working
  207. Brake solution?
  208. Steering wheel in-out play?
  209. gas mileage gone
  210. Fan Blower Motor problem & another solution.....
  211. External Temp not working all the time!
  212. Transmission not shifting
  213. Dash lights dimmer switch
  214. New to the site having AC trouble
  215. Clunking issue: Solved!
  216. Squeaking sound from rear
  217. manuel transmission shifter knob
  218. Power steering inop after Jump Start
  219. Loud Engine on Start up? (2.0 model)
  220. Weird sound front left front wheel
  221. help with misfire on Cylinder #4
  222. Driver seat uncomfortable
  223. Had a Boost problem and fixed it.
  224. Question for ChevyMgr
  225. Squeak from rear area of car-interior
  226. A/C recirculating button issue.
  227. 2008 HHR SS mystery horn problems. Help!
  228. Need help quick!
  229. wiper issue
  230. Horn honks when I use the key
  231. Rear shoulder belts are wet.
  232. Inside door handle
  233. Replacement Battery for HHR
  234. Am I Being Too Picky?
  235. Passenger airbag light
  236. Firewall sound insulation installation
  237. How much oil
  238. Steering column noise.
  239. Boost Issue - non stage 1
  240. Weird battery issue
  241. List Of Common Recurring HHR Problems
  242. Leaky windsheild
  243. ignition switch replacement
  244. RPM's dropped at red light???
  245. Sticking lock on drivers door...
  246. Seat frame cracks bulletin
  247. limp mode
  248. HHR Won't Start!!!! Please Help!
  249. Seat Belt Rattle at B Pillar Anchor Bolt
  250. Key won't come out of ignition at times
