- ESC Light
- Clutch Pedal on Floor--fixed
- Did some maintenance today
- remote start not working
- Power window switch
- Blown trailer lights fuse
- Fuel pressure spec
- balancing SS tires
- Misfire Code
- Radio Auto-Adjust Volume high speed issue
- XM adaptor?
- P1174
- Remote starter no longer works. Horn beeps 3 times instead
- Need antenna for onstar
- Recurring misfires/pos. valve guides loose
- Intermittent temp gauge failure
- Constant Pull to the left
- remote start
- Ignition Key
- Hello, and thanks for all the past help, and I have a Neg. Camber Issue...
- ABS Monitor has died
- rust on bottom of door
- Air Conditioner makes whirring noise when on
- Alternator
- Front End Noise
- Ac vents
- Outside thermometer temperature
- Programming key fob
- self deployment of airbags
- I am sure it has been asked a 1000 times,
- 2010 HHR Shifter stuck in park
- HHR SS engine light on and power loss
- Dashboard vents, no air flow through the two center vents
- Front end has Clunking noise-help
- prndl bulb replacement
- Lost all power while driving
- Door Handle Broken
- Error code P0016
- Fixing ALL the issues / problems!!!
- TSB help bad valve guides
- Rear Spring Insulator?
- Minor Jolting at Stop
- Rough Running
- Black Smoke
- Lift Gate won't open, amoung other things
- Rear washer spray pattern
- Randomly loosing power when accelerating - solved
- Odd water leak issues
- Shift knob M/T
- Warranty
- Need help!!
- New Transmission on '06 HHR LS
- Tempature Switch Replacement
- My service airbag light comes on
- Temperature issue.
- Exhaust leak
- Electronic Problem
- Engine light
- Timing chain failure
- program remote and key
- hhrrws
- rotate tires get error message
- Temp Sensor
- How do you fix Mirror Lamp light bulbs?
- 15,000 + sensors.....YIKES!
- Dash rattle/squeak
- Safelite - broken windshield now missing part
- End links and ABS bracket
- Rough start and idle issue
- Water pump replacement
- Clicking
- Trying to get remote start working
- Get"check cas cap" code
- What's going on here?...
- Radio only working on one speaker
- Oil leak
- What going on?
- New guy with a 2.2 problem
- No radio sound, no turn signal sound or OnStar sounds, any guidance?
- Coolant leak?
- 2.4 problematic
- I need HELP fast
- Weird temps...
- Wipers, Timing chain
- Noise in dash
- Thumping noise when on rough roads
- Ticking in engine
- Suddenly sounds like a lawnmower
- Brake & Cruise Switch Adjustments
- DRL going wonky
- Horn button emblem
- Turn Signal Chimes Gone
- All instruments in cluster dead
- Door Lock Mechanism flaw design 2008
- Strange problems
- Problem starting
- Had a CEL pop on this morning on the way to work.
- service air bag message and airbag icon
- Gauges go crazy
- Rubbing Sound When Turning
- Headlight assembly
- F.O.B. Battery?
- Tail gate door release w/no battery
- Seat,arm rest adustment
- Power mirror switch
- No temp indication or a/c
- Injector replacement question
- 2008 hhr
- peeling paint
- Temp Gauge
- No Cold Overdrive
- Esc
- 2006 HHR won't start
- Some Backlighting Out
- Help led glow
- Power mirrors don't work
- P0449 code CEL on
- Need to adjust rear hatch latch oer striker
- CV Replacement
- Engine Power Reduced
- loss of power sterring
- Cruise Control Switch
- Diagnostics Port Help
- Door problems
- ambient light sensor
- Cleaned K&N air filter, code P0113, shifter click
- Butyl Patch
- Knock under passenger side dash
- Trunk door opens when my hhr is locked.
- 2007 hhr
- My 2010 1LT now drives like new..
- Flex joint on downpipe
- Loose control arm bushing
- How to fix ESC
- 100,000 mile question
- Repair Cost Question
- Location of the ambient engine temperature sensor.... Help!
- Keyless entry won't work after I had it tuned.
- 2008 Won't Start
- Hewbie
- Front Bumper Inner Bracket Broke. Need replacement part name/#
- Throttle stuck--OH MY!
- Running board pads coming up
- Radio not working at all/Missing Key fob
- Ignition & displays dead
- Alarm problem
- IPCW fogging
- Rear window switches for rolling down don't work easily
- Heater Fan
- Battery issues
- Brake adjusters
- Hello Fellow HHR's
- Hose replacement
- Odd Speedometer/fuel gauge problem
- HHR won't start: no codes, has fuel, has spark - please help!
- Low battery blowing fuse?
- Steering Column Noise
- dim dash lights
- Wet back seat
- 07 HHR Passenger Door Latch Actuator Problem?
- Check engine light, code reader has #1 cylinder missfire
- HHR ss won't start and won't release key
- Cam Chain Jumped Time
- Back of Front Passenger Seat
- 2007 hhr won't start
- Removing lift gate handle
- Head Lights repair
- New to posting here-joined Jan. 21, 2013
- Seeking MANUAL owners asap! 7x code P0172 - GM no help
- HHR Freezing up :(
- New blower resistor dead in less than 3 weeks
- OBD II vehicle monitoring and diagnosis
- Reduced Engine and engine light
- No brights
- Changing Cluster
- Problem with 2007 keyless auto start
- Extended Crank and Engine Code p0171
- P0234 having trouble problem solving
- How do i program a new key fob from another hhr
- Front wheel bearing woes
- No sound from left speaker
- Exhaust
- Check Engine light leads to new engine!
- Airbag
- Door locks crazy
- Stabilizer Bar Rattle
- Tackling some repairs this weekend!
- Key Fob Junk
- LOUD POP as I left stop sign, then just revved
- Top dash storage door is stuck
- Whine with engine off
- Burning oil
- 2011 HHR panel 5 speed, key will not turn OFF !
- Help...locks and more 06 hhr lt
- Howling/Grinding/Clunk/Crunch/Squeak/Squeal Noise thread
- Blower motor
- Ongoing Front End "clunk"
- T/C ongoing issue.....
- Ball joint question
- 2008 2.4 Chevrolet HHR LT Power Steering HELP!!!
- Squeaking steering wheel/lighter fuse
- P0302 and rough idle/cel light
- First post...Tranny ? and RPM's
- Combination of issues
- Torque converter clutch solenoid
- Lighter/power plug
- Radio with steering wheel controls issue
- Ignition switch problem?
- 2007 ls Code p0449
- 5 Speed HHR SS shifter problem
- Headlight problem
- Lost all Electrics
- Lighter fuse
- Rough idle at fill up
- Low Brake Fluid
- Power door lock problems
- Choppy idle and raw fuel
- Ticking sound
- Abs/ ESC /Traction control
- 2009 hhr rear brakes
- Electrical problems
- 2006 HHR Engine "Runs" After Turning Off
- eng power reduced
- New Problem.
- P0010 code on 2010 Hhr LT - help!
- Crank postitoning sensor
- 06 hhr wont crank
- Valve cover gasket leaking...
- Oil Leak
- Racing Disc Hub Caps & The Car Wash
- led tail bulbs
- 2009 2.4l O2 sensor
- Heater blower resistor
- Dead zone when ac on
- 2010 Trans Issue
- Unintended acceleration...OMG
- So I got in an Accident... Now Time to Repair..
- Theft-deterrent light
- Where does this go?
- Car stalled while driving
- Help changing front tranny mount
- Steering wheel shimmy when touching the brake pedal going downhill.
- Was in an accident. Does this look Fixable?
- Camshaft pos actuator
- '07 HHR Panel LT1 2.4 water pump replacement
- Anyone have their struts go prematurely?
- Front end clunky noise
- Evap Solenoid new solenoid power connector different HELP!
- Traction Control
- No-start, backfire, CEL
