PDA
View Full Version : Problems/Service/Repairs
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. P0449 Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
  2. Power window stuck open
  3. Bulletin pic4677f
  4. car won't crank over
  5. Kit has surging problem
  6. Engine power reduced?
  7. CV boots
  8. T/C light on
  9. electronic problems
  10. Yet Another FOB problem/question
  11. code p0010
  12. Camshaft and crankshaft Position Actuator Solenoid correct parts
  13. Greetings from a hoping to be happy HHR owner...
  14. Keyless Entry Remote switching signals
  15. Info on electrical to A/C & Heater Dash Controls?
  16. cracked head or blown head gasket
  17. CEL light and P0014 Code
  18. Tramsmission hard shifting
  19. 2006 HHR Climate control Worked One day and Nothing the Next Day Wondering
  20. TPM not working
  21. Fan inside 2008 just stopped working.
  22. lost key and fob
  23. Door will not unlock
  24. HELP!! Heater & A/C
  25. pcm power tain contol module
  26. RUNNING BOARD SWAP Between SS and LT
  27. Service ESC & key stuck in ignition
  28. HHR Low Idle/Turn of while driving.
  29. Clunk in front end 2009 HHR
  30. Airbag light 2009 HHR
  31. windshield fluid pump
  32. front end noise
  33. heater problem
  34. Frequent clunk items
  35. Engine per reduced, code p0121, p2135
  36. Headlight Problem
  37. Key Fob Programming
  38. HHR 06 P0302 code
  39. 186,000 miles and its dead
  40. Front Wheel Noise
  41. Need help P0303
  42. interior bulb issue
  43. ABS and Traction Control Lights
  44. HHR Battery Too Weak for Winter
  45. no crank, no start 08 HHR
  46. Engine block heater electrical plug
  47. 07 Transmission TCM Interchange
  48. Making a growling/airplane noise
  49. Hewbie
  50. power steering doesn't return to center
  51. Check engine light
  52. Traction Control and Security light came on.
  53. Front Windshield wiper wiring diagram
  54. Being ripped-off by dealership?
  55. hhr with inter code 2135
  56. Codes and Problems
  57. 2009 HHR LS 2.2 5sp cold start issue
  58. Ambient temp sensor, yes again!
  59. phantom CEL
  60. Weird problem
  61. Power Lock Fuse 26 "Blows"
  62. Hub and possible axle fix
  63. Key FOB Issue
  64. Surging Issues
  65. P0480
  66. Throttle Position Sensor
  67. Radio stopped working
  68. Alarm not working after body shop disconnected battery
  69. Transmission won't go into forward gear
  70. sound in the front end when cold
  71. Temperature
  72. Car will not unlock at all with fobs or keys
  73. 06 HHR LT throwing P0420 and P0138 codes
  74. water leaking from exhaust
  75. Check Engine Light When Cold Outside
  76. Seat Back
  77. Problems from Rear end collision
  78. Transmission cooler lines
  79. HHR RR Speed Sensor
  80. Early 2006 HHR 2.4 oil cooler relocated
  81. 2006 HHR still overheating
  82. T/C Light & Hard Shifting
  83. transmission soleniod A off
  84. HHR engine codes P0013 & P0014
  85. AIR Valve for Exhaust Manifold ?
  86. Engine Power Reduced / Power Steering / Low Fuel / Service Airbag Message
  87. hard to believe..
  88. Alternator charging output
  89. Fan runs after engine off with COLD engine
  90. front wheel bearings
  91. getting emails about alternator
  92. cylinder 1 misfire. low compression
  93. Block Heater Question...
  94. First Check Engine Light and I'm Stumped.
  95. No crank 06 HHR 2.2
  96. Need help
  97. quarter panel removal???-_-
  98. fender bracket id
  99. 2006 rear door
  100. Hhr idle mystery
  101. OH NO!!! someone's blow-out...
  102. Wheel speed sensors not letting the transmission shift??
  103. Blown head lamp fuse after seat install
  104. Computer Inside HHR not Working
  105. Bcm
  106. Excessive Halfshaft Play on 2006
  107. Head Gasket Inquiries
  108. 2006 hhr LS need help
  109. Fog Lamp
  110. 06 HHR Driver door stuck shut
  111. When was the Shifter Issue Resolved
  112. No Power at All / Key Stuck in Ignition
  113. "Engine Power Reduced" P0601
  114. Another Head Light Problem, Bulb Is Okay
  115. 2008 HHR Dashboard Lights up like a Christmas Tree
  116. 2006 HHR overheating issues
  117. HHR Rev Problem (I Think)
  118. Sticking valve
  119. 2007 Chevy HHR LS Engine Oil Switch Leak, Dirty Air Filters, Left Rear Tail Light Out
  120. Head light problem
  121. SDM Fuse location 2009 HHR LT
  122. New key fob!
  123. 2010 LT rear hatch release malfunction
  124. Blower motor malfunction and leakage onto floor mats
  125. slow go
  126. No Fuel
  127. Parasitic Battery Drain n 2010
  128. 2006 HHR Timing Belt
  129. Should I replace the VVT solenoids
  130. Head Replcement help needed
  131. stabilizer bar length ??
  132. rotors & bushings
  133. P0171b code appeared after rear end collision
  134. relay noises after start.
  135. Door jamb pin switch
  136. HELP! HHR wont start.
  137. Car stops
  138. extra glove box sticks
  139. ETS Enhanced Traction System
  140. serpentine belt LOUD squeal
  141. hhr power brake vacuum line freezes ?
  142. p0013 and p0014
  143. Radioproblems
  144. Needing Assistance (DTC P0016)
  145. replaced timing chain tensioner, no start now :(
  146. Annoying rattle from engine ...
  147. Please help! Possible fuel pump problem
  148. Tolerating Noise
  149. new clunk
  150. Front End Rattle
  151. Dealership
  152. Traction Control & Engine light
  153. Piston Ring Replacement
  154. camshaft position sensor
  155. Able to remove key but car won't turn off...ignition or electrical?
  156. Backup Lights
  157. timing chain guide broke
  158. HHR with a stuttering miss and yellow snot in intake
  159. dash lites
  160. Low Brake Pedal after Hub assembly change.
  161. Oil Leak
  162. Poor gas milage
  163. what I should have done about P0420
  164. Variable Valve Timing Solenoid Stuck
  165. rough idle and engine light on
  166. Orphined Fuel rail connector.
  167. water leak
  168. P0172 and high ethanol reported
  169. Lifter tapping sound
  170. Surging after timing chain replaced
  171. P0011 CEL
  172. engine surge after tune
  173. Intermittent vibration 50-55 MPH
  174. oil flow
  175. Emissions Light and Hard Shifting
  176. Wierd Battery Power Condition
  177. Front End Rattle
  178. Headlight Troubles
  179. MAF sensor question
  180. transmission wont shift into drive from second gear
  181. exhaust manifold replacement
  182. check engine light
  183. New member with a liftgate problem...
  184. Can't get right
  185. Remote Start works then kills engine
  186. Seatbelt Warning chime not working
  187. 06 hhr p0300 & p0449
  188. Chevy HHR Engine issues.
  189. Help!
  190. P1174
  191. Side Air Bags on 2007 HHR
  192. Red battery light
  193. 07 2.4 Crankshaft Seal
  194. Repairing broken door panel pin brackets
  195. Interior replacement parts
  196. Jump started wrong radio dead
  197. weird buzzing noise
  198. 2010 HHR Oil Idiot Light, engine dies
  199. Fuel gauge / range indicator issue
  200. RIP Great Pumpkin Off to the salvage yard she goes...
  201. Burning oil, engine noise
  202. water in ecu
  203. Replaced wheel hubs, still have loud noise above 35 mph
  204. hhr 2.2 p0016
  205. 2009 HHr
  206. 2006 believe I spun a bearning...
  207. Drove through water, now having issues
  208. murply416
  209. Dome light will not work
  210. 2007 Chevy HHR Won't Start
  211. "New" 2007 HHR LT2... new problems.
  212. Sunroof deflector
  213. Help! Bypass gasket
  214. Battery Draining Over Time?
  215. Catalytic Converter EPA Federal Performance Warranty
  216. Fuel pump
  217. AC Fan on 2011 wont blow.....
  218. Timing Chain Repair
  219. Broken Antenna Cable
  220. A/C Delete
  221. Budster-Power Steering Issue
  222. Temp gauge flat lined changed Therm already
  223. crankshaft sensor wiring
  224. Fuel economy sucks, advice needed
  225. Trouble replacing drum brakes
  226. I need help. p0442
  227. a/c clutch hub is missing...
  228. HHR a/c quit working and temp gauge doesn't work
  229. 2011 HHR Lots of Issues
  230. Blower Motor Fuse Location?
  231. windows down but not up
  232. Power Steering loss.
  233. Recall didn't fix ignition problem?
  234. 2011 lt electrical problems
  235. Improved Gas Mileage
  236. grinding,crunching noise when backing up
  237. SS wobbling problem.
  238. Popping noise from front end 2006 HHR
  239. Starter problem after ignition recall repair
  240. B0090 rollover sensor
  241. 20'09 1LT front passenger seat belt reatractor
  242. Serious shaking after brake change
  243. Clicking Ignition
  244. Driving through high water - sputter
  245. crazy car
  246. We really want to love this car but...
  247. Need just a little help with a possible gas tank leak
  248. which relay do I check
  249. Sputtering, idiot lighs coming on, speedo bounching
  250. What is up with the temp readings?
