PDA
View Full Version : Problems/Service/Repairs
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35
  1. New road noise issue
  2. Car shuts off after pothole
  3. Windshield wiper spray
  4. Loud tranny noise after shifting into D
  5. Interior door handles
  6. Elusive Radio Reception Problem
  7. Coolant replacement.
  8. HELP!! MAJOR MPG/oil life issue, only had car 2 mo.!
  9. Panel aux. mirror problems
  10. RADIO / STEERING WHEEL CONTROL's NOT WORKING
  11. Need help with my dome light
  12. Code P0016 Help Needed
  13. engine removal?
  14. Driver's door won't latch
  15. Clutch Pedal Spring
  16. Wheel Bearing failure?
  17. lost communications
  18. Drivers Side Mat Question
  19. Reset TC , ?
  20. cruise control
  21. Well that was a new sound
  22. Rusty Front Crossmember
  23. Cam angle sensor
  24. My HHR is growling, & not the good kind!
  25. Exhaust Leak
  26. Headlight repair
  27. Why not buy a code reader?
  28. Check Engine Light due to Oil Change?
  29. Panel, front door pops when the rear is open
  30. Strut top nut is stuck
  31. Violation function of the automatic transmission or something like that
  32. headlight/electrical issue?
  33. 2006 HHR radio does not work
  34. No start due to faulty ground?
  35. backup lites don't work on my 2006 HHR with manual trans
  36. Cruise control question
  37. Wheel hub assembly axle nut torque spec
  38. Passenger air bag light keeps alarming
  39. Rear marker lights out
  40. 2006 HHR 2.2 has a miss at idle
  41. Steering wheel wouldn't turn .. Service esc
  42. Speedo quit
  43. 2009 HHR 2.2 - Poor Fuel Economy
  44. First real problem with my SS
  45. random shaking
  46. HAD a rattle..
  47. Condensation on inside of windshield
  48. 2010 SS...Noise (fan?) in front end after engine's turned off.
  49. Brake pedal slowly goes to floor on start up
  50. front brake noises
  51. Height Issue/Lowering the seat.
  52. Starting issue plus weird smell
  53. Liftgate Strut Problem (not the usual)
  54. What can too much oil do.
  55. 2006 Chevy HHR 2LT Gear Shift Light
  56. Front headlight...bulb replaced or fuse issue?
  57. Auto won't start!! Help!!
  58. No Hot Air
  59. water leak
  60. My hhr electric power steering is too sensitive !!!
  61. Clutch Spring
  62. Warranty rant....is this covered?
  63. BAD misfiring, NO POWER -- PLEASE HELP
  64. Dash gauge plastic color
  65. Power steering, check engine, traction control, no speedo, remote start not working,o
  66. NO Cruise control, remote start or autolock...all quit at once
  67. Emissions 2011 2LT - "Monitors Not Ready"??
  68. Brakes
  69. Problems getting care out of Park - Brake issue?
  70. Throwing Code P0128??
  71. Noise / rattle at start up
  72. Electrical / speedometer / tach warning lights
  73. Check Engine Light On
  74. Oiled doors
  75. 2007 HHR 2.2 ECM Manual Transmission
  76. knocking at high speeds
  77. sunroof exploded
  78. bad fobs
  79. Keyless entry not working
  80. Rattle in Steering Column?
  81. Tail lights
  82. Front Suspension Problems
  83. Part# for steering shaft?
  84. Weird transmission problem - jerking while at temperature
  85. HHR 2006: Unlocking driver's side door with key sets off alarm
  86. Sunroof Closed and then reopend today should I be worried?
  87. Leaking washer fluid fix
  88. Blower not blowing warm air...HELP!
  89. check engine light
  90. check engine light
  91. Car is COMPLETELY dead
  92. Car does nothing...
  93. Leaky Left Front Sunroof Drain
  94. Problems with IPCW Tail Lights
  95. steering wheel noise...........
  96. Traction control light and check engine light on
  97. Electrical System Went Berserk!
  98. p2138
  99. Dead battery problems
  100. new for me 2006 HHR LT 2.4
  101. excessive engine vibrations in warmup phase
  102. SS Trans
  103. Car ran hotter than normal today.
  104. back window just blew out
  105. shifter stuck/sticks
  106. Traction & Stability Control Warnings On
  107. Odd rpm transmission issue?
  108. Code PO303
  109. HELP! Vapor lock/Air in fuel line??
  110. Can anyone tell me what this is?
  111. Getting ready to trade this stupid POS car in...
  112. Finally had my first prob - GM came through
  113. Why do the door panels rust?
  114. No dome or map lights
  115. Reprogram Alarm
  116. Temp gauge and a/c stoped working
  117. Radio dead stick?
  118. Vibration - 40 to 60 mph
  119. blower driving me nuts
  120. Just Under The Wire
  121. Engine Temperature Sensor
  122. Radio
  123. Canadian powertrain warranty question
  124. Typical Wheel Shake and Questions on Tires
  125. Slipping 1st-2nd gear
  126. slosh...??
  127. Keys in the ingnition alarm
  128. Noise
  129. 2.4 no power 2k~3k
  130. Stuck key
  131. rough manual shift
  132. Broken motor mount
  133. SEL and P0010 code
  134. Howling/grinding noise
  135. Radio/Chimes/Remote start issues
  136. my 11 LS is t totle lost cause
  137. 09 2.2 Engine Vibrating at Idle
  138. intermittent PO300
  139. Cooling Fan Assembly.. UGGH!!!!!
  140. Dead Battery?
  141. Nag alarm went silent
  142. Radio Problems
  143. Liftgate Will Not Open
  144. the AC fan clicking
  145. Steering feels loose
  146. Temperature Display Hung
  147. Front Passenger Door Lock
  148. Rear Window Switch Lights
  149. Door lock actuator
  150. Power Seat Groan
  151. Driver's seat creaking/headliner rattles
  152. startup noise
  153. Please Help With Name of Hose in Air System
  154. ss missfiring
  155. Wheel shake
  156. ABS and ESC PROBLEM
  157. Cruise control not working
  158. door locks
  159. Rear hatch won't open
  160. leaking pipe of radiator
  161. Thermostat Temp Issue -- Need Help
  162. Remote key buttons
  163. My Turn to Deal With Flex Pipe - Warranty ?
  164. Fan noise (vent/AC, not engine)
  165. Coolant Smell
  166. moonroof squeaks when opening
  167. noise is drivng me crazy
  168. tempature gauge
  169. Strange Problem! no power at all.
  170. variable acceleration>drive by wire problem?
  171. Pop On Cold Start
  172. Random start issue
  173. HHr air bag problems
  174. This is strange - start issue
  175. Busted strut?
  176. Mpg! Wtf?
  177. Front wheel bearings
  178. Which sensor is this?
  179. Engine Noise During Acceleration
  180. First issue!
  181. Electrical issues... Help!
  182. Headlights Reminder
  183. Heated seat problem
  184. Vin # blocked
  185. 07 Temp. guage flatline
  186. Ready to Give Up
  187. Cylinder Head replacement
  188. replaced wheel bearing...DIDNT HELP THE HUMMMM!
  189. Turn signal problem
  190. My Ignition Lock Cylinder battle
  191. '08 that's DOA
  192. erroneous compass reading
  193. Fuel door popper
  194. 917danno
  195. Odd sound in the rear
  196. front wheel hub replacement
  197. P0011 code is back and thats the good news
  198. new Blower Motor Resistor getting hot
  199. Key stuck on
  200. Rear Bowtie
  201. Horn
  202. Misfire problem
  203. OBD light
  204. Overheated Cooling Fan not kicking on
  205. Steering Wheel Emblem Bubbly
  206. Sway bars
  207. help
  208. Air Bag issues
  209. Power steering overheating
  210. rattling noise from cabin air filter?
  211. Topping off radiator; overflow bottle markings?
  212. AC issues! Help appreciated!
  213. Seat belt issue
  214. Anyone have
  215. Hard to start
  216. Clunk/Creak when stopping
  217. disable key fob to rear door popper signal?
  218. AC Quit Working Today
  219. Jerky Transmission
  220. rear brake clicking noise
  221. Driver's Door Seal; have to re-shut after twisties
  222. Cracked wheels HHR SS
  223. Key Fob 2008 HHR SS
  224. A/C Compressor Whines Loudly When Accelerating
  225. Radio won't power on
  226. LF TPM out of phase with the rest of the car
  227. Key jammed and couldn't shut it off!
  228. Hard to start
  229. Service Air Bag
  230. Radio Problem
  231. Extended Warranty
  232. 2006 HHR Cooling Fan Won't Run
  233. Radio Sound Cuts in and Out
  234. Digital temperature display
  235. Fuel gauge issue
  236. Hot weather and Tire pressure sensors
  237. Power windows not working - 2006 HHR LS
  238. Great... Power Steering Out at 13,000 Miles?
  239. stupid question front lower grill+ remote start
  240. Oil leaking from somewhere....
  241. Strange Humming noise at highway speeds
  242. intermittent air conditioning
  243. Forum newbie needs help with 2 items - please!!!
  244. Outside Temp is "stuck" at 77
  245. steering cut out
  246. ECS issue
  247. Fr Hub replacement
  248. Key Fob Problem
  249. 2007 HHR Front Clunk
  250. Warped Rotors?
