- im just not fit to have working HIDs!
- Ghost Locks
- Panel HHR Mid Compartment
- catalytic converter
- Passenger Window Fell Down ???
- Service ESC - TSB?
- Spark Plug Cover
- No radio stations in '06 HHR
- Headlight sensitivity?
- Front End Noises
- Hard shifts, t/c indicator
- T/C problem
- Battery issues
- Rattling under the hood
- power steering, traction control, car dies in D
- Bouncy Speed?
- Power Steering
- Engine Power Reduced - follow up question
- Front end noise update......
- Brake problem 2006 hhr
- blowing ignition modules
- Dash light and Gauges not working
- 06 2.2 code 128
- blown out back window
- my door FELL OFF!
- Rim lip bent
- ghost headlights
- my heater quit,Please help
- Tiny dents
- Heater Problem
- Code P0010 Camshaft Actuator
- Reduced Power
- Where did my coolant go?
- Chevy mgr TSB?
- steering column issues
- Traction Control Light/Service ESC on DIC
- Cracked windshield
- What is wrong with my hids!!!!!!!!!!
- car would not start :( please help with advice or suggesstions
- What finally fixed your P2135 code?
- Service With A Smile
- rear wiper sagging
- 2010 with 28k miles got PO496 evap. code today
- stall
- transmission fluid level
- Engine light on
- Another CEL, and car didn't want to start today
- weather stripping
- Quick Key Remote Question
- radio problem
- alarm
- Big P0449 problem!!! Help Please
- 2.2 LS Whining Noise When Cold
- Another remote question....
- engine cover
- Oil Cooler
- 06 will not turn over
- Snow+tires=vibration?
- How to remove center panel ??
- Caught in a bit of a boost conundrum, need opinions.
- fuel gauge - died.
- hhr dies at stop signs
- Brake Problems
- Wiper Blade Arm Malfunction
- How to programming Remote ?
- Couple Questions about Parts and Problems
- Trouble with remote start
- code po171
- clear coat peeling on wheels
- Drivers side door lock problems??
- My HHR rides like a crappy ole truck!
- Clutch question.
- Stabilizer Bushings 07 HHR
- Traction??
- Threw a code this morning....
- Seat Belt Button
- Valve Job How To?
- Thermostat issue
- Another 'Engine Power Reduced' Thread...
- Seat Belt Retractor
- CEL with P1174
- Door locks
- possible thermostat or temp sensor issue
- Flat Spotted Tires?
- Transmission -Locks
- check eng lite code p0332
- broken interior door latch (driver's door)
- Strange radio issue
- question about window switches
- Radio reception
- 3 Things not working
- Headlights acting weird
- blower issue
- CV Axle
- My 75000 Mile Service Report
- Bad brakes
- Won't accelerate
- limited slip
- Tick at idle?
- No cruise, hard shifts
- Catalytic Convertor
- Yet another stereo replacement issue.
- How to Diagnose Strut/Sway Bar Issues
- No Tempature Reading
- blind spot
- Power Steering Intermittent Failures
- Car pulls left on accel
- Stuck in park???
- Check engine light, "Engine power reduced" and "Engine disabled"
- Folding rear seats
- Visor Flop
- Code P0606
- SS Brembo Brake Noise
- Trouble with my DIC
- Threw some new codes today
- Wife hit curb- now something's bent
- GM SS HHR Buy back
- Keyfobs
- Im Curious
- Heater Resistor??
- Side Steps
- Replacement speedo
- Can't figure out what's wrong.
- Battery
- Sun Visor keeps falling down
- Mounts turbo and wires
- Codes P0011 and C0561
- P1174
- Changed Rims/Tires for Winter and now have a Service Tire Pressure Sensor Warning
- air flow sensor?
- Not again!
- Wiper weirdness
- Blower Problems
- Some one has experienced this Before?
- torque converter
- Are wheel hubs/bearings covered under powertrain warranty?
- Remote start problem
- Remote starter
- alternator swap/rebuild
- My computer and radio are in french plz help
- Loud Pop when I turn on radio.
- Dash lights dim
- 06 hhr no rear running lights
- Traction Control light
- engine miss no. 1
- Knock sensor
- Wont shift into second fourth and reverse
- noise while driving
- A/C stopped working any ideas!!!
- water leak fixed????
- How to replace wheel bearing assembly on front
- Need to remove Steering Wheel
- key fob contact repair
- Noise from front of HHRSS
- Looking for the next step
- doorlocks
- Steering wheel controls Screwed?
- Recall Alert: 2006-08 Chevy HHR
- Mass Air Flow wiring diagram 2009 ss
- Vibration at 50mph
- Chevy 2006 HHR Radio
- warranty parts??
- Transmission Noise
- 06 HHR Wheel Hub Replacement Torque
- Loud humming noise.
- Armrest problems? Good ol' GM
- Mold/Mildew smell from AC
- A/C Compressor blew up
- Dash removal?
- Rear drums stuck
- inflatable restraint front passenger presense system sensor connector
- Transmission whine when cold
- Warranty voided by blue antenna.
- HHR not turning over
- This could happen to you
- Cruise control won't engage & won't manually downshift into "I"...
- 2008 HHR water on floor solved!
- Again... Now a doubt about tranny mounts.
- Security System Problems?
- Engine Power Reduced Light on
- HHR won't start with Jump
- Wheel bearing? noise at 83,000 miles
- Catalytic converter code on at 83,000 miles
- chirping sound from a/c blower
- Ignition Key Stuck, Engine Running
- Fuel Gauge Issues
- Possessed?
- Front Bumper Corner lights
- Air Outlet Swivel Damper Broke
- CEL and TC warning lights came on
- Fog light question
- An Update On My Issues!!
- Jump started my car and it's running rough
- Dome Light and Radio Issues!
- how do you aim headlights
- I need detailed info for brakes and...
- 06' HHR suddenly quit recognizing the code in my key's chip??
- wheel bearing 60,000 miles ?
- Driver seat heater indicator blinking
- Dealer Mistake - Synthetic to Regular
- MTX Shift Knob removal Help
- more water on drivers side
- blue plastic ring holding parking brake line
- Intermittant Start(Haunted HHR)
- Misfire on Cylinder #3
- Driver's side strut leaking
- No start..!!
- Poor Radio Reception
- Would it be called surging?
- HHR Haunted??
- 2007 HHR "Clicking" sound when shifting...
- Is it possible to fix this?
- 2 yrs 2 mos = Battery Dead
- Blower motor switch
- Bad Paint
- Dead Battery Question
- Temperature running hot
- Any problem with anti-freeze in oil?
- After a week in the shop...
- P0442
- door handle broken
- gurgle
- Thermostat
- Windshield Wiper Problems
- Turn signal stalks working rarely
- The cluster that is known as the Jeff Gordon Chevrolet service department...
- Vibration driving over 45 mph when I make a right turn... & Frustration
- CHECK Engine Light. Coolant Temp...
- Tire Sensor problems
- Hatch door does not stay up
- Front End Clunking
- Some smoke from tailpipe at WOT
- No lemon here!!
- Hooligan Chief
- Key FOB repair, where is it?
- P0420 DTC code?
- where to find shifter. m5 '07 hhr
- Inside door handle busted-again
- This car is a POS!!!!
- fan blower
- temp sensor problems.
- ABS T/C light on when backing up
- A/C Compressor wont shut off
- stuck key issue and replace shifter
- 2010 HHR LT2 With oil leak !!!!
- Electrical problem
- Service ESC on the DIC
- t/c and cel light problems
- Strange Noise
- Waterleak in floorboard
