PDA
View Full Version : Problems/Service/Repairs
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35
  1. HHR SS code P2196, Rough Idle, surging.
  2. Lousy gas mileage
  3. broken plastic sides on intercooler
  4. Ignition Control Module - 2006 HHR LT
  5. Rear tire rubbing/Uneven wear
  6. starter "run-on"
  7. A/C stops blowing cold air
  8. Power door locks
  9. P0019 Code
  10. Cruise/info button replacement
  11. Drivers door window
  12. high pitch sound from wheels
  13. Heater Blend Door Broken
  14. Both rear doors very hard to open
  15. Whining noise coming from rear wheel well
  16. engine lite on
  17. No cruise Control or Torque converter lock up
  18. rhondasb1
  19. Remote start inop on 2006 - auto trans
  20. Air Dam Noise
  21. Misfire at idle, fixed now new problem
  22. lower control arms
  23. Power lock issue
  24. HHR SS Turbo cooling problems
  25. Car Shakes/rough idle, CEL will not go off!
  26. Repeated drivers warped rotor not drum related
  27. menu button on steering wheel
  28. Flex pipe repair failed
  29. Key Fob Issue
  30. Stalling, rough idle FIX
  31. Spindle/ Axle Nut
  32. 2010 Seat-Armrest 15935273
  33. hey just joined
  34. cannot shift out of park & car will not start
  35. HHR SS Smoke at Idle hfter new Downpipe
  36. Front Bumper Cover
  37. TPMS sucks!
  38. 06 door problem. Yes have searched, please help.
  39. RPD will not come on
  40. Dim Passenger Headlamp
  41. 2011 HHR Turns on Won't start...?!?!?!
  42. a/c issue...
  43. Houdini oil...
  44. intake sensor codes (map & maf)
  45. 2011 Windows
  46. 2006 HHR leaking on front passenger floor
  47. Any easy mod for interior light controls?
  48. water in the floor board passenger side
  49. Contaminated cam solenoids
  50. New O2 Sensor Installed.......
  51. Constant door problems - any MI HHR specialists?
  52. RPM dial scare
  53. interior lights
  54. Water leak - Drivers side near hood release
  55. 1 Rear seat wet...soaking
  56. Wheel bearing mileage
  57. Looking for electrical connectors in engine bay
  58. Hello Please Help!
  59. Brakes or Transmission Locked Up
  60. Strut/Stabilizer sheared off
  61. GM Parts Direct vs the Dealer for my cat
  62. offset for rims 2006 LS
  63. LR Window Won't Go Up
  64. DRL switch
  65. Unique problem
  66. gauges and warning lites going cazy
  67. ABS kicking in when it shouldn't
  68. Posting for a new member with a "Dingy Towing" issue..
  69. Driver Information Center Blacked Out
  70. Catalytic converter questions
  71. 2006 HHR Problem but no engine light
  72. Coolant sloshing noise in dash
  73. 2008 HHR Evaporator Drain?
  74. LEDs as plate bulbs
  75. TPMS loses info and then regains
  76. Shifter Assembly
  77. Key stucked/Microswitch works
  78. 2007 HHR AC Issue
  79. Traction control
  80. Steering question
  81. 2011 HHR won't start
  82. Common Engine Components Location
  83. Radio and Rotors
  84. Rh rear turn signal wont work
  85. Radio problem
  86. ugh - trans fluid drip
  87. Sway bar link nut won't come off.
  88. How to pull 2.2 motor? (originally titled: wifes car)
  89. Help with connecting DRL module
  90. Hello from New Mexico/Having trouble with my SS.
  91. Help! With brake/boost problem
  92. Ignition question
  93. Odd Air conditioning problem
  94. 2008 Crank and no start
  95. Failing Electrical system
  96. Repair codes and costs
  97. How do I replace defective yaw rate/lateral accelerometer?
  98. obd 2 dead
  99. Starting Problems with 2008 HHR (2.2)
  100. Jaws.. chewing up light fixture
  101. installing aftermarket radio
  102. module issues
  103. Passenger Side Blend Door Actuator
  104. Do I have to replace the air bag
  105. 2009 HHR 2.4 thermostat/waterpump repair
  106. Rear hatch will not lock after replacing the actuator.
  107. Front end noise and vibration
  108. Sounds like exhaust leak but...
  109. P0856 Traction Control
  110. fan control switch
  111. Starting problems
  112. 07 hhr hvac stays on/blower not working
  113. Air Intake Auto-on??
  114. Power windows
  115. Service?
  116. rear tail lights
  117. HHR Power Windows No Go
  118. Uneven Brake pad wear 2006 LS
  119. Power mirrors
  120. Car is Shaking and I need some advice....
  121. Switches
  122. Eng light/ Throwing (P0107) code solution.
  123. Power Door Locks Problems
  124. Bumper scratches
  125. Odd Starting Issue after a "Check Charge System" warning.
  126. Rock Auto Flex Pipe Review?
  127. weird "slurping" sound?
  128. Heater Core Hoses
  129. Warranty Question
  130. Hydraulic Line
  131. Help!
  132. Suggestions on what to check for a bit of intermittent rough running
  133. Unable to turn off my HHR!
  134. Help me please!
  135. Problem after spark plug change....
  136. temperature sensor
  137. Check Engine Light - Code P1127
  138. po340 and jerky motion
  139. smoke from oil fill tube
  140. Won't start after rinsing eng compartment.
  141. New and Need Help
  142. IPCW L.E.D. Taillights - Backup Lights Not Working
  143. Repairing a paint run
  144. key left on drained drained the batt, so i jumped from the trunk
  145. Pressure switch for AC
  146. Noise in LH front
  147. Won't Start After Reinstalling Fuse Box
  148. Clutch/accelerator/neutral safety/cruise control issues
  149. 2006 HHR > block heater
  150. Torque converter?
  151. Have you heard about the ECM warranty?
  152. Engine Shot
  153. blower motor resistor
  154. Removing drivers power window control panel from door?
  155. And now, headlight circuit is messed up..
  156. Cracked block resolution, 6 months later...
  157. Cranks at least 15 or more times then starts
  158. Traction Control Light on Hard Shifting
  159. Spindle?
  160. engine knock???
  161. Door Shutting Issue
  162. Leaking Rain Water Inside
  163. Cabin Temperature Controls
  164. Code C0300
  165. Is my A/C turning on without my knowing?
  166. Intermediate steering link
  167. Stability control applying the brakes randomly!!
  168. New head gasket still eating water
  169. Ac motor killing me!
  170. P0171 low pressure
  171. Front Seat Plastic Shroud
  172. approximate cost drums/rotors
  173. P0302 check engine traction control light on
  174. HHR low beam
  175. tire sensor trouble
  176. coolant recovery tank leaks
  177. Steering and Front Suspension Noise Concerns - Clunk, Thump, Rattle, Knocking, Pop, S
  178. Battery dead, now door won't unlock?
  179. It smells in here!
  180. front end rattle
  181. 2007 Power Steering failure
  182. car wont start
  183. Left rear blinker not working
  184. Minor shimmy Front drivers side 2007
  185. Key Fob water damage
  186. esc p0302
  187. replacing shift solenoids
  188. Hewbie
  189. Hard to shift
  190. Bad TCM? BCM?
  191. Battery Drain-Parasitic draw
  192. bumper clips/tabs repair?
  193. Need a little help..
  194. Flex pipe warranty
  195. Service Traction & Service ESC alerts
  196. Is there any part or actuator to fix AC Recirculation Air Door?
  197. heating ac controls
  198. CEL and P0011 HEELLPP!!!!!
  199. auto shifter assembly removal
  200. Switched fuse other than #21?
  201. possible ignition switch going bad ?
  202. Engine power reduced/Engine disabled....I've had it!
  203. passagners door lock
  204. A few issues
  205. keyless program
  206. Front Passenger Exterior Door Handle - Deer Hit Wife
  207. Service traction and service ecs message
  208. Latest in a Long String of Noises. Video Link of Sound Included
  209. Adjusting drum brakes
  210. Blower motor not getting power 2007
  211. Knocking, clicking under engine
  212. power steering noise
  213. A/C sometimes work...
  214. Power Steering Problem
  215. Ignition stuck in run position, had to pull fuel pump fuse...
  216. HID high beam problem
  217. Hard starting after an ultrasonic injectors cleaning
  218. Drive cycle
  219. Upgrade lamps to LED's
  220. Three questions: adhesive/emblem/vent thingy
  221. It seems I really do need an engine
  222. Temp Reading
  223. Ticking sound ...
  224. 2 problems with my wifes '09 HHR
  225. So Whats this part called?
  226. "POWER STEERING" Assist, Fails & Returns!
  227. New and Need Help - Speakers
  228. 2007 HHR Heater blower problem
  229. 2009 chevy hhr windshield wiper motor/transmission arm replacement
  230. Rear Brake Problems
  231. HHR radiator
  232. At my wits end with these brakes!
  233. KYB struts
  234. Pinging noise 2.4 auto
  235. 2.2 LT oil in spark plug well
  236. joeymollo
  237. Why do I keep getting a PO13 Check Engine Light?? Help!!
  238. P0171 traction control hard shifts.
  239. Bulb Change
  240. I replaced my timing chain tensioner on my 08
  241. 2006 HHR with Traction Control light on
  242. 2009 winshield wiper linkage
  243. Joeymollo-? On Battery
  244. Rear shocks/springs
  245. Wipers making squealing noise
  246. Traction control light
  247. CV joints or brakes issue !?
  248. Doors locks act up and trans slips
  249. AC draining in passenger floor board 07
  250. Fire!
