PDA
View Full Version : Maintenance and Upkeep
Pages : 1 2 3 4 [5] 6
  1. Is there a known problem with TPMS and aftermarket tires?
  2. Broken ABS Sensor Ring On Drivers Front
  3. Oil filter
  4. Thingamabobs.....
  5. energy suspensions sway bar bushings
  6. Spark Plugs
  7. cleaning headlight lenses
  8. MOOG Link-Quick Question
  9. Radiator Drain
  10. Left front door and roof speaker not working
  11. Oil resetting question.
  12. Best Available Scan Tool for < $200 ??
  13. plastic cover on rear doors
  14. 2008 hhr 2.2
  15. drilled/slotted rotors..??
  16. 2006 2.2 HHR....belt or chain..??
  17. Those Pesky Push Pin Christmas Tree Fasteners
  18. disconnect the battery.
  19. TPMS relearn tool or air out on a 2011
  20. AC Delco oil filter varies in configuration?
  21. Evaporator Drain?
  22. Mobil 1 oil type
  23. Spark plug gap
  24. replacing sway bar links
  25. Car show tips
  26. Headlight issue
  27. Haze on paint
  28. ? on oil change time...
  29. recharging air conditioner
  30. Oil spec changed for all gm 2011's
  31. new wipers
  32. Low key fob battery
  33. transmission dip stick is lost.... I think
  34. Race Ramps
  35. HHR Shop Manual
  36. Pin Striping
  37. Black Rubber Window Moulding
  38. Dipstick Oil Level
  39. Fuel Injection Service
  40. Serpentine belt replace
  41. Cleaning and Waxing
  42. Sunroof Lubrication.
  43. I normaly use everything Meguiar's on my cars !
  44. Jack Lifting Positions
  45. 31000 miles dealer service
  46. 50k/5year Maintenance
  47. OEM Plugs or Aftermarket?
  48. Spark plug gap 2006 2.2l
  49. Grease fittings?
  50. How to replace headlight bulbs on 2007 HHR?
  51. Weird Wax Thing
  52. Seat Back
  53. dealer oil change
  54. Small O ring in Oil Filter
  55. Time for better brakes...
  56. Cleaning Engine Bay
  57. Type of Spark Plug
  58. OEM oil on 2011
  59. Passenger side wiper too long?
  60. Change oil soon reset
  61. Drivers side mirror install...how?
  62. Offset socket to torque struts
  63. HAND Wax or Power tools?
  64. Bleeding/flushing brake lines
  65. Battery Replacement
  66. Walker Exhaust flex pipe/catalytic converter installation
  67. HHR Handle Replacement Kit
  68. Just how reliable are battery tests?
  69. Oil filters - Who makes the best?
  70. oil change questions
  71. Spark Plugs
  72. Radiator Drain Plug Bolt
  73. fuel pump?
  74. 32mm socket?
  75. Light pattern screwed up
  76. Cooling system maintenance
  77. Oil Changes - Where do you get yours?
  78. Informational update
  79. Maintenance logs?
  80. Cleaning the hhr scuff guards
  81. Brakes??
  82. Spark Plugs
  83. Fuel Pump Longevity
  84. ? on LNF spark plugs.
  85. D.i.c. / oil life minder...
  86. Surprised at Tire Rack
  87. Replacement passenger side mirror (lens only)
  88. Rust on Drivers Door
  89. Tune-Up Parts
  90. Extendend Warrenty
  91. HHR float charge
  92. left front fender turn signal bulb
  93. Replacing belt on 06 HHr
  94. Purolator Double Action Air Filter Sale
  95. 60k Extended warranty About to expire: what could need fixed?
  96. Auto Trans Dip stick
  97. Protecting the rear bumper from scratches
  98. New Wix Oil Filter
  99. elecrtical connectors
  100. time to change my oil?
  101. Bought new brakes
  102. Oil filters
  103. maintaining the "wood"
  104. Gm parts
  105. Loose Wheels x 2
  106. Intake Removal
  107. Clutch replacement ??
  108. oil filter wrench??
  109. Two-Stage Foam Filter Update
  110. Coolant drain/flush/refill
  111. What weight Mobil 1 to use?
  112. headlights
  113. Right blinker is suddenly on crack....
  114. Thermostat replacement?
  115. Best Location to Tie in Battery Maintainer
  116. Cooling system hose replacement
  117. Battery replacement
  118. KYB or Monroe Shocks/Struts?
  119. stupid question
  120. Ramping Up? - Rhino Ramps by Blitz
  121. Sound from hell
  122. Windshield wipers
  123. 5W20 oil?
  124. Best damn hand cleaner
  125. AC Delco Injectors
  126. Dumb question about oil filter
  127. Push Fastener Removal Tool That Really Works
  128. headlight
  129. 2010 HHR 2.2L Flex WHAT OIL
  130. ? on socket for oil filter cap.
  131. So you want to know what oil to use
  132. This can't be right
  133. Miles between transmission fluid change?
  134. Type of Oil(s) to be used..
  135. does the rear wiper blade have it's own resvoir ?
  136. Miles on an Oil Change
  137. Storing in a Heated Garage
  138. best plugs
  139. '07 HHR tune up...
  140. The quickest polish ever
  141. Make sure you have the tools you Need...
  142. Plug Change
  143. Replacing Headlight Bulbs
  144. any info on changing the air filter
  145. Frt Marker Bulb Replacement
  146. dirty in 60 seconds flat!!!
  147. Wiper Refills
  148. Engine oil bolt hard to get off!
  149. Cabin Filter's HHR SS
  150. Rubys first oil change. Easy as silk
  151. Cleaning Engine??
  152. How to replace rear wiper blade
  153. Replacing the Serpentine Belt
  154. Drum replacement?
  155. HHRPalmettoguy
  156. Brake Rotors
  157. Spark Plug Change
  158. Ignition probems
  159. Transmission fluid/filter change HELP!
  160. antifreeze
  161. Required Engine Oil for 2011 GM Vehicles
  162. fluid evacuators
  163. Need info for gmpp filter
  164. New Forum Section: Maintenance and Upkeep
  165. Oil Filter Cap
  166. GM air intake
  167. Engine Life
  168. first HHR oil change
  169. steam cleaning seats?
  170. How often do you change your oil?
  171. Cabin Air Filter
  172. Is PF457G oil filter correct?
  173. What is better Wix Oil filter or A/C Delco?
  174. One for Chevy Mgr. Oil filter #s.
  175. How Much For A Cabin Air Filter
  176. Oil filter dissection - VERY interesting
  177. Basic Tune Up!!
  178. General question about servicing the vehicle..
  179. Spark plugs...easy to change for someone who knows nothing about cars?
  180. Air Filter
  181. Regular HHR maintenance?
  182. What is checked in the 27 point free inspection?
  183. air filter
  184. Clogged air filter and mileage
  185. Quick Clay Bar Question
  186. Checking and/or changing transmission fluid
  187. What to use for cleaning suade inserts?
  188. Rear Wiper replacement?
  189. 100k
  190. 50,000 mile maint.
  191. Royal Purple Email
  192. Fumoto valve?
  193. Oil change %
  194. Options for Front Wiper Blade Replacement
  195. Do you change oil according to the oil life monitor?
  196. Spark Plug Replacement
  197. Winter Washing
  198. 1st Service
  199. GMPP air filter (K&N compatible number)
  200. Synthetic Oil
  201. 5-speed manual maintenance
  202. rear wiper blade?
  203. Using DexCool
  204. Need Advice - Painted PinStripes Care
  205. 15,000 Mile Checkup. Needed or Not?
  206. wiper blade problem
  207. Black HHR SS Wax or no wax tips
  208. 20W 50W oil in HHr
  209. Castrol Edge
  210. How to replace the air filter?
  211. Oil filter Question
  212. Deal on Oil at Advance Auto
  213. K & N Air Filter
  214. Cleaning Seats and Removing Spots?
  215. Oil
  216. Spark Plugs
  217. For those who B$$$H about the HHR battery
  218. cabin air filter INTAKE
  219. Synthetic oil, which brand?
  220. Castrol Edge 15,000 mi filter?
  221. spark plug change
  222. Cabin Air Filter
  223. Removing Wax Residue from Grille
  224. Do you wash your car if you know it will rain soon?
  225. claybar question
  226. How to access power window switches
  227. leather cleaning
  228. how to clean suede
  229. Wax?
  230. Flushing Brake System
  231. Spark plug wires demise
  232. can a K&N Filter void warranty?
  233. Key Fobs and Remote Starts...
  234. Spark plugs
  235. Advice on accessing lower hose clamps
  236. K&N Oil filter?
  237. Cleaning the interior
  238. how to remove my front bumper marker lights
  239. Changing a light bulb
  240. Change Map Light Bulbs
  241. Free Oil Change FTW!
  242. How do i change head light bulbs? and what size are they?
  243. Replacing fog light bulbs?
  244. Rain-x wiper blades
  245. Switching to synthetic oil.
  246. I Need Help
  247. Help
  248. Washing Seatcovers
  249. need help , oil
  250. Chassis Lube?
