View Full Version : Maintenance and Upkeep
- Evap system code P0449
- no power when hot outside with A/C on
- Headlights not lasting more then 1 year?
- A/C question
- Sorry Flex Pipe
- Tie Rod Ends - Prothane Boots
- Brand of Rotors
- Spark Plug Virgin
- Just another oil filter thread well almost
- how fast the oil live gauge depletes?
- Water Leak
- Rear brakes
- Article on excessive Oil Consumption
- Steering wheel rubbing noise
- downstream O2 sensor
- Long range maintenance.
- Fluid check intervals
- Thermostat replace
- 08 HHR SS Fuses
- HHR LT OEM Brake Capiper Bracket Model # ???
- 100k and still kicking!
- sec on dash info.
- Couple things found & need help with
- AC Delco Oil Filter
- Anyone running Pulstar plugs???
- Monroe strut & coil spring assembly
- Drivers window
- Which Key FOB do I need???
- Replacing '06 HHR Key dongle
- Intake valve cleaning
- Fan motor runs sometimes??
- How to properly wash your car exterior for finish and protection
- hood open lite
- outsidedoormirrorsremotecontrolswitch
- Coolant
- Direct in line fuel injection
- Wrong LED interior bulbs
- 194 bulb replacement
- automatic cooling line seals
- Looking for part numbers
- Wires to the fuse block under the hood
- Battery jump starter v2.0
- Preventive maintenance/proactive replacement
- Bolt size on lower control arm?
- thermostat ??
- coolant level in recovery tank (pic)
- Radiator hoses, 1st design or 2nd design? 2006 HHR 2.4
- Front wiper arm removal tool?
- Battery jump starter for HHR
- Blinker problem, need advice
- Paintless dent repair
- cooling system flush
- how do you torque a 2007 2.2L automatic transmission?
- unlock doors
- what to replace while having head work done?
- ESC Service Question. Need help!
- My key fob issues fixed
- Anyone using an OPTIMA Battery
- software
- Hummmmmmmmmmm.......
- rubber liner
- when do you replace your tires?
- Seeking advice for replacing front and rear brakes
- The FAIL-SAFE Thermostat
- Videos of the engine from the factory
- Brake Job
- Headlight Adjustment...
- Rear Stone Guard part # (the plastic ones)
- Not sure if this goes here, please move it if need be
- In need of this specific hose (connects to from throttle body to MAF sensor)
- Bumper Retainer Clips
- Cabin air filter
- Gas mileage drop after air filter install
- 100,000 mile maintenance
- Piston height in bore
- Brake Pedal Rubber Cover Pad 22729032
- A little help for the "lazy people"
- Transmission Fluid change after 160,000 miles?
- Windshield washer pump grommet leak fix
- Do not trust your service manual for spark plug replacement
- 2.2 interchange
- Codes p0010 & p0011???? 2010 Chevy hhr
- rusty door seams
- Cam gears
- Tune Up - 2010 Chevy HHR LS
- Checking timing
- Wheel Stud Replacement
- Warning beeper not working
- Spark Plug Replacement
- Mainenance - Dealership or Mechanic?
- how do I change oil indication on information panel?
- Another fix for Loose Plastic Rear Panel Fastners
- Has anyone purchased this product & does it work?
- sway bar link replacement and alignment issue
- Cleaner for the seats
- What is your battery life
- 100,000 Mile Service suggestions
- Need some links for missing interior parts
- Repair Manual
- Does the type of washer fluid matter?
- starter clicks before engaging- 3 times-
- auto part stores that lend tools in CA.
- Dexos spec
- Hewbie
- Hewbie
- Replacement Master Cylinder Cap
- changing oil filter question
- P0010 Cam Sensor Need Help
- Loose Bolts I Found When Doing the Struts
- Waterpump replacement
- Window Switches
- Reusing cylinder head bolts.
- Brake fluid reservoir
- HHR Spark Plug Replacement
- First Oil Change
- Windshield Wiper Lengths
- Did Some Maintenance on the HHR.......
- Motor mounts stock ls
- coolant temperature
- Mobil One oil question
- Pitted/oxidized alloy wheels
- Wiper linkage bushing
- 2007 HHR LT CEL Weirdness
- Oil Filter Country of Manufacture
- Po301 misfire comes and goes
- Plugs after 115K
- Thermostat
- How to keep your dic_ from going crazy!
- O2 sensor question
- Rough starting
- Rubber Hood Adjuster
- Battery
- Headlight Polishing
- To get or not to get......
- P0014 (pending); it's a tractor again!
- Clutch
- why 4 snow tires¬ 2 for front wheel drive
- Right headlight
- Input Speed Sensor Location
- Best struts
- Passenger side, rear thud
- 5w20 in my 2006 2.4, problem?
- opinions at 115,000km (71,000m)
- interpreting compression results?
- 80k tune up?
- Is it safe to switch to full synthetic with high mileage?
- Hub replacement w/ impact wrench
- How hard to change trans fluid?
- Snapped the TC Cable
- Timing chain guides
- Tire rotation
- inside door panel insert
- Interesting find
- Article "Ignore that check engine light at your own peril"
- Good luck with the taillight bulbs.
- Swap out auto dimming mirror?
- instrument cluster has gone wacky
- Wheel bearing replaced today
- T/C Light and Engine light
- spark plug
- Rear Hatch Gas Lift Supports
- Dealer Service vs Independant
- Dr. Color Chip on Victory Red
- Checking Oil Level on 5 Speed Manual Transmission
- Dealer said at 30,000 clean fuel system?
- Oil eater?
- Steering intermediate shaft to short!
- Heads Up Cruise control Stopped Working?
- advice'help Changing Antifreeze??
- Radiator complete drain and refill.
- Sunroof won't close all the way, no vertical movement
- Normal operating temp. for 2008 2LT with 2.4L
- Changing spark plugs--what interval
- Thermostat and temp sensor replacement
- Newbie Question
- HHR smells of gas at times
- Coolant temp flatline. What next?
- THUMPING NOISE suspension
- Poor Mileage after tune-up
- What suspension package do I have?
- Replacing radiator core support
- Motor mounts
- Timing Chain Replacement??
- Chain or Belt?
- Best way to touch up bumper....
- Heating and air conditioner
- odor coming from blower
- Rubber glovebox grommets
- 115K on a 2008 2.4l Tune up?
- Checking trans fluid
- Rear Brake Question after drum and shoe replacement
- OBD2 bluetooth/wifi - $8-$20 - any one use one?
- front end noise
- 2010 hhr
- CV Axle - How do you know its bad?
- Panel retainer part number
- Replacement shocks or struts 10 Chevrolet hhr LS
- just picked up 2006 HHR
- Hell Freezes–I'm using a 5W30 oil
- Brake Pad Replacement $$$
- '09 SS reading code P013E
- Timing Chain Tensioner
- Extended Warranty Coverage
- Brake Fluid
- intermittant cruise control failure to engage
- Parts and Grades: HHR Adventure
- When to change oil?
- Metric or SAE
- Change Coolant?
- Pressure Bleeder
- Which Napa Sway Bar Links?
- Panel, removal of commercial service goodies
- Can I change from non-synthetic oil to synthetic
- Door sound
- extended warranty soon to expire
- Dropping the headliner: coat hook?
- Fuel line
- Door adjustment is a good thing!
- Mixed Green Coolant with Dexcool
- Hub and Bearing Question (rotor shield and spacer)
- Dumb question perhaps?
- Sensor remarks
- Very Interesting
- Transmission fluid?
- sometimes, you just have to listen to others
- A new maintenance item that I will be inspecting
- replacing thermostat
- maintance on low milage hhr
- Bosch ICON Front Replacement Blades Any Good?
- Is there a parking brake cable adjustment at console?
- Motor Swap, help/tips/dos n donts
- coolant reservoir
- ESC light
- HHR keyless entry problem
- throttle body cleaning
- OEM Wiper Blade Refills
- cylinder number
- Sunroof wind deflector
- Tired of changing Thermostat
- How many miles did (or have) your stock hub bearings last(ed)?
- front rotor and BRAKE pad bolts
- New member hub/brake questions
- Hi, I'm new to the forum (...and have a problem)
- Front Hub Replacement 2009 LS
- Replacing Headlights...
- 06 HHR spark Plugs
- Dave East (Clay Barred My HHR)
- Rip-offs at quick oil change places
- Brakes?
- Gas Mileage
