View Full Version : Maintenance and Upkeep
- Manual Rear Brake Adjustment Info ....
- Lake Chevy and My HHR
- Transmission hesitant at stops, fluid change?
- Tracing Battery Drain
- Serpentine belt part number
- Struts
- vehicle service history.
- Oil filter cap removal
- Fluid life expectancy
- water pump timing chain replacement
- Serpentine Belt
- Question on Coolant/Thermostat Replacement
- MAINTENANCE 50,000 miles
- My personal system of checking out a Used HHR purchase.
- New Detailing polish: Reflect
- Update for High Temp Muffler Coating
- Maintenance and pitfalls advice for a new owner
- Want to swap my catalytic converter
- brake cleaner as degreaser?
- Re-aim headlights
- Break-in oil?
- Timing Belt on 06 HHR
- successful repair of CEL P0010 &P0011 ?
- Do I just need a new bulb?
- Just hit 50,000 miles. What to do?
- How many amps is the blower supposed to be?
- Autolite Spark Plugs
- Thoughts on spark plug torque
- Spark plug thread chaser
- Synthetic Oil
- Some Very Handy Maintenance Helpers.....
- oil filter question
- Newbie question/Oil change
- Serpentine belt ..
- For those that have replaced the cat/downpipe
- ceramic front brake pads
- New Struts: Brake Judder, Camber, Height
- outside door trim dull
- Fine scratches
- Lousey front rotors
- tube drain from sunroof
- Clutch time
- TPS sensor
- For guys that did transmission fluid change
- spark plugs and oil changes
- Interesting Evap Cannister Info
- How to replace Turbo Boost Sensor ...
- Oil Filter Cap
- Suspension Torque Specs?
- Right front power window switch
- 2011 Air Filter
- Upholstry cleaner
- Bushing Replacement Headache
- Weight of oil ??
- Did an oil and transmission fluid change....easy
- "Severe" Service Schedule / Long Commute
- lower control arm bushing
- Several Questions
- mobil 1
- dash lights too dim
- temp spare question
- Jump start question
- How many quarts for a 2010 LT flexfuel? And is my engine 2.2 or 2.4l?
- Front Brake Pads & Rotors & New Front Tires
- torx bit size for air filter in 2007 hhr
- transmission lines
- Where to Find Repalcement Console Flood Light
- Is it Worth the extra?
- transmission fluid
- Wiper Blade Recommendations ?
- Antifreeze and radiator hoses
- To drain entire cooling system?
- HHR tire pressur sensor question
- Cleaning products that will repel dirt?
- Where did my light bulb go?
- 2 Weeks on Mobil 1 oil
- Exhaust gasket
- Colored Wax....Remove those door handle marks, made my own
- Oil Changed on 2011 HHR
- Alignment ?
- Oil change today
- GM certified preowned 2 year free oil change?'s
- HHR paint
- Collapsed Oil Filter
- What floor mats?
- Broken moonroof part, no, not the wind screen.
- header cleaning
- Trans flush completed
- 2011 running board needed right side
- Good day for detailing
- P0301 code
- Shocks
- 07 2.4 plug gap?
- Door Link (or Limiter) Replacement
- Adjusting headlights
- Transmission Fluid change following post on here
- 2011 2.4 2lt air filter
- 2007 HHR WaterPump
- Reduced Engine Power
- Odd noise while driving
- Wiper blade
- Under the hood question
- Air box gromments! GRRR!
- Not so perfect
- New battery
- 2007 2.2 high idle.
- Seafoam, Oil change, and Spark plug change today
- Air filter Question
- INNOVA 3150 Anyone got one? OR?
- 2009 HHR, 75k miles, recommended maintenance?
- Door Limiter?
- Replacing O2 sensors
- Weird Tire Ware
- High Mileage oil vs regular.
- New Style Rear Drum Brakes?
- Cosmetic repairs.
- Heater blower fan
- oil change length
- Wheel alignment
- Can you rate your Outdoor Car Cover?
- labour costs
- Transmission Service
- Help! "Power Steering" warning
- Passenger assist handle(s)
- another oil thread
- Question on Synthetic Oil Brands
- Looking for good Dealer or mechanic in Golden Horseshoe
- Overhaul/Maintenance intervals
- transmission
- Check Engine Light = Bad Battery Cell?
- Dex cool or reg coolant
- location of Air Pressure Sensors in tires?
- Auto on lights
- license plate bulbs
- Serpentine belt replacement
- ambient air temp sensor..2006 hhr lt
- Do U have to use Synthetic Oil in HHR
- Fuel filter..??
- Is 2008 HHR 2LT OBDII or CAN?
- Atf
- Coolant flush
- 2.2 Spark Plug change?
- keyless remote
- My feelings on the Wheel bearing Failure issue.
- 2006 Driver Side sun visor flops down!!
- Door handle lubricate?
- Rear window trim at top of door leaves a strek on glass.
- For those that don't know this little noise tip.
- Oil
- What's Your Choice of Motor Oils
- Oil on headliner
- Fuel addtives
- Testing ...Testing... High Temp Coating
- opening a sunroof without power
- glue like residue on sunroof glass.....
- Panel interior
- Cleaning your cloth seats
- Clean under your roof rack rails!
- Key Fob Batt Low
- sparkplugs?
- Cleaning "behind" the headlight lenses
- Transmission service??
- fabric cleaning
- Haynes HHR Manual Now Available!!!
- Transmission fluid change is easy
- Transmission?
- 50,000 service maintenance
- Caliper Slide Pins
- tires
- Trailer lights
- Oil extractor
- Missing rubber grommet.
- looking for good scanner obdII with abs diag also
- Does any one have aCarMD
- Bosch 6716 Platinum Plugs
- '10 2.2L plug change
- Brake fluid/Clutch fluid flush??
- another oil change question
- Strut Change
- 1st set of brakes at 97k!
- Replacement Light Bulbs
- 5000 Mile Checkup
- Waterwetter?
- Brakes at 34K
- Front right tire wearing out on the outside
- 2006 sparkplugs
- Dumb Coolant Question
- Preferred Brand of Oil
- Car wax
- Monroe Quickstruts
- Changed the plugs & air filter early
- Help..Flunky Floor Mats
- Headlight change tip
- Fuel filter
- Best spark plugs (SS) and gap replacement
- Should I switch to Full Synthetic
- Hawks or Brembos?
- great record keeping program for computer or droid
- Wash Your Car when Looks Like This
- Recommended Maintenance
- Armor All new wax you have to see this video
- Battery Neutral
- Checking Coolant Level
- Car wash recommendations?
- I replaced my coolant. Did I make it correctly?
- Spark Plug GAPPING
- hhr ss through a delta sonic car wash?
- change oil soon message
- When should I do what maintenance?
- Old school fool or cheap china parts Just sharing.
- Service Manual
- Water spots on sunroof
- Radiator coolant change?
- Runny Black stuff
- Changing head light bulb
- g- oil the green oil?
- Spark Plugs uh oh
- Door Opening Creak
- Erratic outside temperature indication
- Change rear wiper
- seafoam? anyone done it?
- New Oil?
- zerk fittings on ball joints
- Brakes
- Show manual on DVD
- Cruise Control
- Seldom Used 2.2L and Tranny FLush?
- My 07'
- 5-Year Olds - Any Problems
- Internal Transmission Filter
- Oil Pan Heater.
- Fog light retention
- hhr panel
- Replacing front turn signal bulb?
- Tires/ Wheel alignment/ ???????
- Recommended Oil Filter for SS
- Hub Bearing question
- Typical Coolant Temps at stops/idle?
- Seat cleaning
- Battery
- Is it time to change my battery?
- What Should Drained Coolant Look Like?
- Dayco Serpentine belt Change veryt tight on a 2.4L?
- what is the story with the rear windshield wiper arm plastic cover
- SS - First oil change.
- Oil change Question
- DIC Coolant Read
- Bulb Replacement Numbers
- On Dex-Cool and Thermostats
- front bearing hub
