View Full Version : Maintenance and Upkeep
- Rear Door Protective Stickers
- Battery Brand Opinions/Experience
- Blend door knocking
- Wiper blades 2008 HHR SS
- AutoLift 3000 - any one use
- Diagnose help
- CV joint as an alternative to a CV Axle
- Hub: w/ABS to car without ABS.
- oil change won't fix it i told him LOL ,,,,
- Driving without intake hose
- Coolant Flush - Splash Shield and Drain Valve (petc0ck)
- Brake Fluid warning
- Air filter cross over
- How to restore headlights
- Check engine light
- Sway bar bushings
- Map lights not working
- Chrome Cleaner
- '06 hhr leaking rear washer fluid internally; d/c'd drain tubing flooding floorboards
- Remove engine air filter cover
- 150,000 miles on the HHR
- Snow and ice tires
- Oil Change to Synthetic or Semi Synthetic?
- Different axle seals on left than right
- Engine Light - P0014 and P0017
- 9 year old air filter?
- strut mount bearing size?
- What the Funk??? Try an Ozone Generator
- 2.2 check engine light
- 2010 Chevy HHR LS Trouble lights
- heater fan motor
- Front end rattle finally fixed!
- Rocker panel
- Tune up ?
- 2.4 Timing Chain
- key entry sounds alarm
- Crank Pulley Torque Question 2.2L VVT
- ATF
- Rear center brake light 08 SS
- Body control module
- Tie rod toe ajustment
- Brake shoes
- Remote Start and duplicate key
- Driver side window 2011 HHR
- 2008 2.4L Oil Filler Tube Part Number
- Ac leak
- Yes, yes you can
- Tpms issue
- Timing chain
- Creaking
- Charcoal Canister Seal
- panel dashboard door button
- balance shaft chain
- hood grommet/bumper
- ac compressor clutch
- Brakes and abs question
- Lower control arm question
- Dead Battery? Rear Lift Release Lever - DENIED
- HHR Transmission question
- Oil video/Something to think about
- How to jump start an HHR?
- Seat occupancy sensor/mat
- Emergency flasher clip
- -50F RV antifreeze
- Sunroof wind filter
- headlight bulb alignment
- Steering wheel coil clockspring
- Windshield washer tubing
- Video on testing your coolant
- Where to find GM15847494?
- 09 ls panel timing chain tensioner
- Oil Change question.
- front end rattle when hitting bumps
- That annoying, Clunk
- 2006 Chevy HHR Radiator fan
- 06 oil cooler leaking 85k miles
- Interior buzz/rattle fix: seat belts
- Rear shock absorbers
- changing fuel injectors
- Mobil1 on Sale
- oil leak
- rear brake adjustment
- dorman FOB
- coolant pipe O-ring repair
- I'm not sure if this is a sparkplug issue or something else
- Another 'what is this harness to' question
- Driver Sid Front Seat Belt Buckle Replace
- parking brake adjustment for rear brakes?
- Tired dooor locks
- 2009 hhr
- Front End Bearing Replacement
- Sticky Stuff
- HHR Questions
- control arm brand and part number
- Help...My HHR pulls to the right, middle, And left...
- KPH Speedo
- Confirmation for O2 Sensor Part Number
- turn signal switch replacement
- Transmission Fluid Change Parts?
- Removing rear door
- Oil filter cap seal
- brake question yet again
- About to Start Driving c Again - Tune Up on my 2008 HHR
- P0301 continues to popup
- A1 Auto
- Cooling fan commands?
- Question on air filters
- engine temperature change
- Valvoline synthetic ATF fluid
- Charge a/c
- Buying an HHR question on miles
- Timing chain
- Sway bar links
- Where's my oil going?
- Getting my transmission fluid changed for the first time at 67,500 miles
- cleared codes
- WIX oil filter, anyone ?
- How long until I should expect my AC to need a recharge or repair?
- Brake Bleed Issue
- motor mounts
- 2008 HHR LS Cooling issues
- Searching for
- newbies butyl patch fix
- Kudos to Palm Chevrolet in Ocala
- motor mounts
- drivers inside door panel replacement
- ac vents not putting out much air
- front wheel hubs
- LED taillight bulbs
- Try this at home
- faded taillights
- Never before seen coolant leak?
- brake question
- oil change
- What's this?
- Cooling Fan Switch
- Got a P0442 code, and I think it's the hole you put the gas nozzle into
- Windshield Washer Fluid Pump
- Fuel line leaks
- Sway Bar Bushings..Should I attempt myself?
- CHECKLIST for purchasing a used HHR
- More cooling issues
- Need help finding a short.
- Turn signals flash rapidly when engine is on
- I need a part number for...
- Sluggish Cold Starting For ~5-10 Secs. - Runs Fine After That
- Emblem Replacement
- Correct Windshield Wipers Position
- Thoughts on why timing chains fail/wear
- Shifting Problems After Coolant Change
- Question re: Maintaining this forum
- Brake pedal pad
- Oil weight
- Battery
- coolant temp gauge
- What's with the Rock Auto Site ????
- Radio parts
- TSB for Sunroof Wind Delector
- Innova 3150
- Alternator question
- Guys, I cant believe the.....
- 2nd cabin air filter & acorn noises?
- Driver's sight tail light working, but not blinking
- Sunroof..... Possessed?
- Dex Cool explained
- Cleaning product to use on SS seats
- Outside Air Temperature
- Correct Part #for Steering Rack assembly
- Jounce bumper
- new fix for an old problem-brake judder
- Installing Door Lock Actuator
- Don't think it's just a stone chip!
- Manual access to rear lift by release lever?
- 2011 hhr 2.2l coolant flush
- Car wax recommendation Florida
- Best glass cleaner?
- any recommendations for car wax?
- Oh Gregg, P0301
- MMO cleanup
- Who makes your radiator fan
- Torque spec for transmission bolts.
- Oil usage
- Greggs first pampering
- Coolant temp
- Bought a new air filter, 2.2 vs 2.4 fit the same?
- 2008 Chevy HHR
- 2008 2.2 o2 sensor codes
- Maf sensor cleaning
- How long can engine coolant/antifreeze last?
- oil leak???
- Friendly experience with ATP AT-205 Reseal
- PSA on 41-103 AC Delco Spark Plugs Rebate!
- STP vs Lucas fuel
- Keyless entry question
- 2007 2.2 motor question
- Replacing control arms - Bolt stuck!
- Regarding the cowl trim, butyl patch or ?.
- Passenger side bulb out, but high beam works
- Airbox/aircleaner
- High Mileage Oil Filters... do your home work first!
- Clutch pedal pad
- Thoughts on installing new fuel pump
- New fuel pump different
- Fuel Tank Removal
- Brake Pedal Travel
- Ticking sound coming from engine during idle
- Timing mark- intake or power stroke at TDC?
- Radiator Fan Assembly Replacement.
- Transmission (Automatic) Fluid/filter change questions
- suspension woes..
- Gas Lines
- Replacing Control Arms - anything else to go after???
- Problems with dealerships and HHR upkeep
- Dexos oil harder and harder to find
- rock guard panels
- Coolant change concerns
- Battery Tender
- P0128 code, coolant temp up when idle
- Temp gauge not going up in car reads --- Engine light is on
- First post and question
- P0010 Code...
- After timing chain replacement,an oil pump question.
- Mysterious ticking noise
- Ball joint bolt replacement 2006 HHR 2LT. What size?
- Time to operating temp (180 on dic)
- Front brake question
- inner fender removal
- Oil Leak?
- How does my 260,000km engine look
- Door Handles
- Tools we seem to need for diagnostics
- timing Chain 2.2 Ecotech
- Rubber Hoses - All
- replacing wheel stud...does hub need to come off too?
- Rotors non ss
- Rough idle at start up
- driveline maintenance
- Dripping issue
- Tires, California
- cooling fan
- strange issues after battery change, HELP!
- Cleaning up Worn Parts
- Greasing end links
- Cutting bolts off and removing adhesive residue; What do you use?
- Repair flex pipe or replace cat?
- ANOTHER sway bar link thread
- Hhr
- 2009 HHR AC question and Problem
- Part number for '09 Driver seat mounting bolts?
