PDA
View Full Version : SS Specific Service Issues/Repairs
Pages : 1 2 3 [4]
  1. Questions about spring and sway bar upgrades
  2. overheating
  3. What is the Front rotor size for a non Brembo Rotor?
  4. Another squeak found and in the process of correction!!!
  5. Magnetic oil drain plug?
  6. any one want to see a 5 speed in pieces.
  7. Lowering an SS
  8. Boosting
  9. heating problems
  10. Cracked turbo??
  11. blown turbo??
  12. New Intercooler
  13. Bad external temp/gas gauges
  14. SS Clutch
  15. SS 5 speed clutch fluid??
  16. Airflow straightener for MAF
  17. It's true LSD for auto
  18. 2010 limited slip question
  19. Synthetic Oil
  20. limited slip
  21. The SS making a clunk noise at WOT
  22. The SS was shaking this morning!
  23. Boost gauge has to warm up?
  24. Brakes, tires, and other replacements @ 67,000 miles
  25. Intermittant boost problem.
  26. Brembo upgrade
  27. Heater issues?
  28. Automatic Launch Control???
  29. Rear sway bar only?
  30. Anyone have the fuel regulator/accumulator leaking?
  31. 2010 SS lagging down at full throttle start
  32. 2008 SS Clutch Covered Under Warranty???
  33. HHR-SS sway bar bushings
  34. Gauge mounting options???
  35. Boost Issues
  36. RPD Light Issue
  37. Notice: This is going to sound Dumb... Auto to manual swap?
  38. Overboosting way past normal.
  39. any one with lsd
  40. 2009 SS just died - please help!
  41. HHR SS Lug Nuts
  42. HHR SS wheels vs. Brake dust.
  43. WTF with my Turbo
  44. Map sensor location ?
  45. The Boy "killed" The Battery
  46. P2196
  47. '09 SS oil leak
  48. Got a question about tire size???
  49. SS Exhausts - Magnaflow and stock art
  50. GM questionares for service problems
  51. a rush of water
  52. SS In the Shop
  53. New struts/shocks
  54. SS Auto, Boost When Shifting
  55. Normal Temp range
  56. Launching issues
  57. Do u know the weight of the SS rim?
  58. Valve tap already????
  59. Anyone Have This SS Issue?
  60. New engine break-in?
  61. Idle Wild
  62. Axel Back Exhaust System?
  63. weird problem with 08 HHR SS Auto
  64. Time for my first oil change
  65. Still noisey
  66. Arguement With My Dealer Over Gearbox Oil Change
  67. service manual for 09 hhr ss
  68. Doing the Job Chevy won't. Wire Job Step 1 MAP
  69. When the engine light comes on...
  70. P0101 on stock intake
  71. Mobil 1 oil cap ?
  72. BLOWN Turbo???
  73. My front sway bar bushings are shot
  74. Clutch Questions
  75. 5 speed 2010 SS Problem
  76. Hhr/ss cv axles
  77. Just Did the Front Brakes.....Must Praise the SS
  78. upgrade issue
  79. My SS fixed itself, engine rattle is gone now
  80. Brake booster/Stage 1 upgrade
  81. B&M Shiftplus
  82. Excessive valvetrain noise
  83. "Plunk" sound abour 5 sec. after ignition off
  84. Blow-by catch can
  85. Dejon Powerhouse Wastegate Spring
  86. Oil cap
  87. Is there a swith to disable the passenger side air bag?
  88. Performance Display Bright/Dim
  89. Wire soldering question
  90. HHR SS 08 and 09 brake loss upon startup
  91. Anyone with the Performance Display have this happen.....
  92. Shimming the IC forward
  93. Modern Performance Downpipe?
  94. Bov
  95. curb damage, it was destiny
  96. brakes gone
  97. engine hesitation?!
  98. Hhr ss turbo
  99. SS 5 Spd Sounds
  100. power steering FAILURE!!!
  101. Mobil 1 question
  102. Avg. MPG
  103. antifreeze all over
  104. possible fix for those with the service esc...
  105. turbo flutter and brake-fix program issues: resolved
  106. Getting a new Turbo
  107. p0099 code - chevy manager help!
  108. Overheating ?
  109. More boost loss....back to the dealer...again!!!
  110. P0236 Code Help
  111. set new code today...P0234????
  112. Air bag short
  113. Is anyone else lookin' for tranny mounts?
  114. Battery current sensor
  115. Brake Hardware
  116. I need a clutch, any suggestions
  117. "Service ESC" message
  118. Shift problem
  119. Code P0089
  120. boost issue again
  121. Front Sway Bar Link replacement
  122. Fuel Question
  123. brembo brakes?
  124. turbo issues help please
  125. Long story short,,, I NEED to find a SS cat converter!!!
  126. How do you remove the air box on an SS?
  127. IC piping/ warranty
  128. Lug RPM?
  129. Whats up with Stage 1
  130. Brembo brake issue
  131. Factory Fog Lights
  132. Replaced Ignition Cylinder Today
  133. Brake pad replacements
  134. Engine Code
  135. Muffler delete
  136. Grill
  137. EBC - Which pads to use?
  138. Does this ever happen to you guys in launch mode?
  139. Is the clutch covered under the 3yr/36k?
  140. Brembos and Sky wheels?
  141. Offset for SS
  142. Air Box
  143. Oil Leak by high pressure fuel pump.. READ ME!!
  144. Silly gas cap error
  145. Low Boost / Wastegate actuator solenoid problems
  146. Wow...the SS Manual Tranny Doesn't Like the Cold
  147. Oil filter and prices
  148. What size rims do I need?
  149. Hard Starts - 12k SS
  150. Manual Tranny Oil???
  151. Turbo DTC set....need advice....
  152. Air Bag Needs Service?
  153. 09 SS 2.0 crank seal gone
  154. Brembo Setup on 08
  155. Replacement Air Filter for the SS
  156. Clunky 5spd
  157. Front Shock or strut?
  158. ss on the tow truck
  159. CEL P0299 Turbocharger Underboost?????
  160. New Recall for SS...sort of....
  161. Transmission and clutch sure make strange noises
  162. Goldline Springs Installed!! Detailed Pics!!
  163. cylinder 1 misfire detected
  164. Manual Shift Light
  165. Auto tranny strong enough for stage 1?
  166. Surging when driving normal
  167. CEL on way to work today, OnStar says code P2261
  168. 2.0L Issues speak up
  169. Have to take SS in no heat and temp skyrocketed Also brake fix
  170. Coolant missing
  171. For the guys who have changed their oil in the SS....
  172. Coolant Recovery tank looks empty!!!
  173. 2008 HHR SS Brake issue/buy back
  174. No cruise, No ESC, Service ESC
  175. where to replace clamps on ic pipes???
  176. New SS TSB
  177. SS Rear Sway Bar....
  178. Revs up by itself between shifts?
  179. HHR-SS -Service - Changing Oil Filter
  180. Why so high final drive ratio?
