- 204,000= p0016
- RPM does not reduce when shifting
- Cold start noice
- Help me I'm melting! Front turn light lenses.
- Boost Problems
- Engine reduced
- P2261 code
- Timing Chain Jumped Tooth
- boost surges
- Severe oil use at times / no turbo boost at times
- Boost gauge going backwards.
- Front hub/bearing tolerances
- 2.0 Timing Chain Problem at 61,000 Miles?
- Turbo install
- Bad Turbo?
- Auto trans and tune
- knock sensor
- SS ball joints
- boost gauge stopped working
- HHR SS How many cats?
- Replaced the HPFP and now I have a no start condition.
- Bank 1 O2 sensor 2 fault
- Turbo only work when fuel lite is on
- SS Lower ball joint replacement
- Automatic ss axles
- CEL, P0010, thinking it's a fluke.
- Forge bpv
- Charge Air Pipe Leak = GMTU Low Boost?
- Transmission to engine...bolts how many
- P Codes popping up
- Moog Control Arm Bushing 6698
- P0089 and P0304 plus no start condition
- 09 SS Overheated - What now?
- Keyless reciever inop.
- Front Sway Bar Bushings?
- Rear O2 sensor not ready
- Hhr ss stage 1 turbo erratic
- Drive Shafts
- AC/Heater
- HHR SS CODE p0100and p0113
- No rpm in neutral
- intake cleaning media blast setup video
- P2188 code
- Another P0303
- Problem after zzp intercooler system install.
- Time for another cooling fan and/or module
- Misfire on 3. Head tear down video hhr ecotech turbo
- SS Overheating
- 2009 Chevrolet HHR SS Struts Question
- SS Oil Filler Cap Deconstructed (PICS)
- Brembo Caliper Mount Torque
- Air filter box question
- 25 psi bog
- Lower Tmap sensor and Autowerks pipe
- Gaps in Hood and Tailgate - Fix?
- Boost issues
- Boost misfire
- Brakes and TPMS
- P0013
- wastegate question
- Transmission going
- 2010 HHR SS block questions
- Help!!! SS runs rough blown turbo?!?
- Broken shift cable
- Turbo Failed Exhaust Manifold Cracked
- HHR SS Fan Control Module
- Kent Moore EN 48266 - injector seal tool info
- Chevy HHR won't start. Code p0336 + Additional Codes
- throttle body replaced and now bad ECM??
- Turbo Heat Shield removal
- SS has no steering position sensor
- p0221 yet again!!
- Warrany for Sun Roof Repair
- Windows won't work.....
- Low GMTU Boost
- Please help boost issue
- Turbo Coolant Bypass Location?
- New Continental Extreme Contact DWs being put on tomorrow
- looking for cv shafts for SS automatic
- Clueless Dealership
- Should I buy this turbo upgrade or not?
- Check Engine Light
- Eng Pwr Reduced/Engine Power Reduced
- ZZP down pipe o2 sensor location issue
- WTF is going on? I can't get My SS tuned...
- white smoke on decel
- loss of brakes
- blown head gasket
- what company makes the turbo?
- "Newbie" with SS Questions
- Vibration in motor WAWAWAWAWA !
- Nothing wrong with my car....
- Need help, Please!
- 09 hhr ss starter problems
- 2010 SS: P0299 and more...
- 2008 HHR ss turbo upgrade
- can only get 10lbs of boost.
- low boost
- 2008 HHR SS power lag
- codes p0221 and po121
- Coolant temp shot up
- 08 hhr ss mass air flow issues
- 2010 HHR SS P0101questions
- where to get wastegate solenoid?
- Compression test
- HHR SS Performance Flash
- Over boost code solution questions !!!
- P0234 code
- 80K miles and engine blew
- Bad Turbo? :(
- Help oil in coolant.
- auto trans oil fill
- HHR SS Power Steering Motor??
- limited slip
- Special tool for holding the cam sprockets??
- Too Much Boost?!
- Error Codes :(
- clean t-body
- Oil Change
- Compressor surge in first gear
- Gauge Panel 2010 HHR SS
- Brake pedal has too much free travel or way too soft.
- 08 SS whirling sound but no start
- SS GM Factory Turbo Upgrade For Sale ???
- speed sensor ring
- suspension woes
- Rough idle when AC is switched on
- Direct injection and intake port coking...we are not alone
- Random surge with Trifector tune
- ss manual rear flywheel cover?
- Various Stalling issues
- 2008 SS has had problems, but I still love it
- Prospective SS Owner
- Rear Shocks
- Power and gas mileage loss
- MAF and MAP
- Clutch Pedal Spring Kit
- esc active
- color code????
- bad steering knuckles
- Coolant Lost
- up to 82% off HHR auto parts, Rock Auto
- Service ESC
- Help! after clutch install fans not working no comm with ecm.
- Dash lamps
- Oh no...Turbo & Ticking
- Wilwood Brakes
- Crazy steves intercooler install
- Water intrusion Cylinder 1
- Rough idle, hesitation, 0304
- 2008 Chevy HHR SS Engine Cover
- New Turbo Owner
- Front sway bar bushings
- AIRBAG lite
- Vibration at idle with AC on
- zzp s256 install into automatic
- Strange 5 speed leak
- Timing Chain Replacement
- Frozen Gas?
- P0133 problem
- "Boost lag" = MAF?
- Belt replacement on 2008 2.0L SS
- Anyone know the screw size on the intake?
- HHR ss gearproblems
- Tuning
- oil leak
- New Owner Questions
- Boost power A/T = M/T?
- DV noise when shifting
- 2008 HHR SS auto trans clunk
- Possible bad 2.0 engine
- Only 2 clips for the SS air box?
- recall = a whole lot more
- Replacing my Brembo calipers....
- loss of boost
- SS Air Box Mounting Questions
- boost
- Cooling fan issues
- Manual shifter, nearly frozen
- Steering pull left while braking and right during acceleration??
- HHR SS Control Arm
- Low Boost - No codes
- Cam Solenoid Issue
- HVAC System
- HHR SS blacks out?
- check engine lite
- HHR SS internal coolant leak
- Aftermarket SS CV Boot?
- in shop P2261
- Code P2187 on '09 SS auto
- P013A - I got initiated!
- clutch replacement, my story. what to know
- Rough Idle
- Fuel pressure problem
- Low Fuel Pressure
- 5 Speed Manual Clutch Life
- HHR SS strut assembly
- Reverse gear grinding on 5 speed
- Over heat T-stat change Water pump change 08 SS (Auto)
- Car won't shift out of Park, Key won't come out of ignition
- HHR SS Rear lower bump stop mount removal
- Lnf?
- Timing chain broken at 87k
- loaded question for SS owners
- Ign Recall for ALL HHR"S
- ss power down
- SS Low RPM Misfire
- Help, Clutch info needed..
- Upper Strut Mount Replace
- forge bpv question(s)
- Squeaky front struts
- No Boost
- Dome light replacement?
- low boost...
- Brake price & brand / tires plus vs dealer
- Best O2 Sensor for LNFs (Search turned up NOTHING!)
- Hard to get into gear hhr ss
- Question about fixing turbo upgrade problems. Please help!
- Change oil soon? I just did!
- Brake pad life expectancy?
- Code P0087 diagnosing the problem
- Mounted ss rotors without changing caliper!
- clutch replacement repair manual
- CEL Two Codes P0455 & P0497
- 2008 SS rear brakes
- OEM rear shocks
- just bought an 08 SS what issues should I watch out for?
- SS Exhaust Reccomendations
- Unexplained rattle, possible Turbo issue?
- Need SS brake recommendations.
- Back windows won't go up
- Squealing brakes
- Engine stalls & dies when AC is turned on
- Looks like I'm getting ready to pull the tranny
- Rattle noise
- Anyone run into intermittant P0302 Miss Cylinder 2?
- Hello and call for help
- Intermittent overheating
- Strange drive train rattle at 2600rpm
- FE5 vs FCS struts
- does this fuel line part really need to be changed out when taking the intake off?
- fe5 lower a arm, best price
- need help with a code p0010 cam sensor bank 1 and p0011
- Looking for a how to on changing the PCV valve on a HHR SS
- help needed with my continuing limp mode issue
- Clutch Spring Return broken..(HELP)
- Pending CEL P2187 Code
- Anyone know what these two wires are for
