View Full Version : General HHR
- 2007: Can cigarette port 12v be tapped to add 2nd port?
- 3rd, Brake Light LED ?
- Charging issues
- A/C blend door or Control or or Temp control knob
- Blown Head Gasket Between Cylinders
- Trans stopped pulling
- Dash Bezel
- 3rd Brake Light
- If in doubt......
- Coolant temp.
- ESC question
- Had a really cool experience yesterday
- Fuel Gage drama
- Increasing engine cooling fan speed? Improving idle A/C performance
- engine swap 2.4 to 2.2
- The Orange Section of the Instrument Fuse Panel
- 2009 Fog light help
- Roof Rack Template?
- Replace 4 parts together-would my HHR start
- Zombie Team.
- New Wheel Bearings
- Air conditioner
- 2007 Chevrolet HHR LT Replaced Odometer Reset
- Steering Wheel Peel :(
- Oil Life reset
- Build sheet link
- BONEZ is back in the house
- RockAuto Discount
- Parking brake lever: non-SS vs SS models
- Spark Plugs on Sale - Amazon - $18.16 per set after rebate
- Digital Temp gauge
- For a model that died 11years ago I still see HHR's everywhere.
- Cheap Amazon keyfobs
- Replacement Wheel Covers
- Removing 5sp knob and shift boot
- My "New" used Chevy HHR
- Driver Side Door Locked Out
- CARiD Article: When it’s time to get rid of your old car?
- Whatever happened to that Star Trek Galileo Shuttle raft HHR?
- Hhr ls
- Leaky wheels
- Paint code 2006 orange
- Mulch
- Shift handle.
- 90,000 miles
- Map Lights
- Revamp your exhaust flow with CGS Exhaust System + Spring Deal
- Turn signals
- Mileage
- Red Paint
- Driving Without Gauge Cluster?
- New Member - Map Light Bulbs
- Does anybody know where this front bumper kit came from?
- Leaking fuel line just ahead of gas tank. Is this common on HHRs?
- Roof Nest Roof Top Tent
- Insurance Cost
- Why 17 inches wheel good for LT not LS?
- Electrifying! GM E-Crate motor
- What is it?
- Oil Change
- Tailgate won't open
- Fuse Electrical Problem
- Anybody ever try these LED Headlight bulbs?
- Roll tide hhr
- Battery vent tube size
- Restore your vehicle's top operation with iD Select Parts & Get a Discount!
- 48 Chevy Suburban with HHR dash, interesting size comparison
- Hard shift
- Antenna…
- Tpms…?
- Remote start
- Interior door handle
- Price check isle 6
- Backup Light Switch
- 08 exhaust
- Tires and Battery
- Cool Swap Meet Find
- 06 to 07 Body Swap?
- Right Headlight Dim?
- Dash lights intermitent
- California HHR question...smog...selling
- 07 HHR no crank sometimes
- HHR SS Ball joint news
- Radio not working...
- Help with P0171
- 08 Panel numbers
- Improve your vision with Bosch Wiper Blade + Promo
- Scan tool for crank relearn and more
- Leak From Rear Hatch
- VCIM Programming
- 09 and Newer auto shifter for early cars
- New York CARB compliant catalytic converter
- HHR deer collision compatable body parts?
- 2006 HHR non starter
- CEL* P0010, P0011, P0013, P0014, P0300, P2135 reduced engine power & service ECS
- Doing flood mode clear
- cooling fan runs always
- remote start sensor location
- Programmer for key fob
- Removing condensation
- Happy New Year
- Old member, new ride
- Tranny fluid leak
- Complete your Holiday Shopping with CARiD E-Gift Cards
- Steering Wheel Radio Switch
- HHR SS Panel
- Dash camera.
- What type of headlight bulbs are good?
- 2006 HHR loose wire internal fuse box
- Wanting to find shocks for my 2007 HHR
- CARiD 2021 Gift Guide + Holiday Video
- Exhaust options? (Wife hates current set up)
- Chasing a noise...
- storage compartment behind the back seats
- Transmission check plug?
- Monitor the road ahead with Geko Dashcams + Holiday Promo
- Having some odd issues
- Radio Antenna
- Someone please help me!
- P0446 CEL Code
- Weather Stripping
- Fuel line for 06 2.4
- Installation under hood light
- if the hood fits?
- Infamous Lund Visor - Hens Teeth
- Air Lift suspension
- Catalyst/EVAP not ready for over 3,000 miles, want to get remote start to work
- 08 hhr 2.4 p0315 error
- Front wheel hub…
- Part #? or part source?
- 2021 SEMA Show After Movie - The Best Moments
- steering column replacement tips needed
- Wheel Spacer Recomendations
- Emergency Flashers….
- replace Upstream Oxigen sensor
- Best non-ss hhr's?
- Rear Door Lock Won't Unlock
- Protect the inside of your HHR with new Rixxu Floor Mats + CARiD Video
- Transmission fluid
- Strong fuel with full tank.
- Suggestion…
- Rough idle
- Vapor Canister Connections
- "KlackKlack" sound when opening front doors
- Before & After
- Req: Android App to read ABS/Airbag codes with wifi dongle?
- Question on location of camshaft actuator solenoid valves
- Dual battery + AGM
- Help locked my key in my car
- 2008 Overheating/But Not Overheating?
- Lost and Broken
- Black Headlights
- Control arm fastener torque
- TPMS programmer
- engine diag fault class HPTuner question
- Differences between LS and LT
- Plywood in the cargo area
- Razzi Side Skirts HELP!
- Are All Tailgates Interchangeable?
- 2008 HHR SS Cooling issue and temperature
- Old Blue
- Price check on Aisle 6, 2008 HHR LS panel van
- 2009 SS Panel Van (almost)
- 06 2.4 HHR runs warm but only on highway
- Aftermarket Fog Lamps
- Oldblue tests the CarWash Cannon
- roof rack
- shifting and revving
- Large bolt in front end
- Driver side splash shield
- Replacing Stop light bulbs every 3 months or less.
- Want to understand VVT?
- OBDII output
- Manual Shifter
- 2.2L tips?
- Is the 2.2 a weak engine?
- abs/traction control light fuse
- Rearview mirror upgrade
- Can't see my dash in daylight.
- 2LT to SS body conversion
- Steering wheel turns when braking
- Hood latch assembly
- Brakelights
- Suggestions…
- Need advice on engine replacement from older to newer hhr
- Onstar Capabilities with 08
- What's wrong with me?
- New FOB
- Proper Lug Nuts?
- Replacing 2007 automatic shift knob
- Hhr ss fuel line
- Windshield Washer Reservoir Grommet
- dies with rear wiper button
- Great deal? Hmmm, probably a scam
- 2.4 swap
- Windshield washer seal
- Ecotech 4
- All-New 63 Series AirCharger Cold Air Intake by K&N at CARiD
- Keep your interior looking great with CalTrend Seat Covers + Summer Sale
- PARASITIC BATTERY DRAW, difficult to start
- P060?
- Towing a 1200 lb camper with the HHR...?
- 2010 hhr leaking of the back windshield washer fluid
- newbie to the beautiful HHR world
- Rock auto discount
- Alternator wiring diagram
- Does anyone know this HHR?
- Hood and grill
- Bought a 2011 HHR Only 1 Key Fob
- Shipping an HHR to Canada
- temperature gauge on dash
- Sun visors
- Rear shelf rubber grommet
- Body parts
- Counter balance sprocket tool
- Mileage question...
- Floor shifter wont come out of Park 2009 HHR LT
- What is it?
- Paintless dent repair
- oil leak
- Speaker wiring polarity
- Throttle
- Roadmaster base plate
- Fobs/ keyless entry...
- Question.....deliberate no start
- Keep your wheels looking like new with Alloygators + Video Review
- Front axle nut torque
- First HHR
- A replacement for OldBlue (the car, not our admin)
- Key Fob
- A DO They ?
- Replacing rear wiper arm
- Provide the ultimate protection for your interior with CalTrend Seat Covers + Promo
- convert HHR to a pickup
- Oil Leak
- Spare tire drain hole fix
- Hen's Tooth aka ....Exterior Sunvisor
- Service Traction Light
- 2010 HHR has fuel leak
- Give your rims superior protection with AlloyGators + New Sale
- Do you let your hhr warm up?
- Slip/sliding away
- A Facebook HHR Fan Club
- Dimmer control interior lighting
- Sunroof windscreen
- Paint and Adhesive ... Don't sniff either y'all 😊
- Towing my HHR
- Reduced Power warning and blower fan
- Ignition timing
- Drive safer with Rixxu Soft Pet Barrier + New Promotion
