PDA
View Full Version : General HHR
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. Need Hope to figure out what kind of harness I need
  2. Think we got bamboozled.
  3. Replacing oil pressure switch but concerned about starter...
  4. Transmission acting funny .
  5. Tire pressure sensors and key fobs not working.
  6. this shht happens too
  7. Back to HHR SS!
  8. Something scraping underneath
  9. Looking to buy an hhr panel WITH NO REAR WINDOW
  10. Headlight compatability
  11. Tie rods replacement
  12. new shifter cable need HHR 2006 manual
  13. Rear windshield wiper
  14. Alarm system.. sort of...
  15. Fog light switch
  16. Advice on purchase.
  17. 2009 HHR needs cylinder head replacement
  18. Possible self-alignment?
  19. Sun visor clips
  20. Had the rear shocks changed about 5 months ago.
  21. Don't leave a dexcool container in your car if its cold :(
  22. Whats the deal with Traction and Power ?
  23. Buying another HHR?
  24. 1158125
  25. Question regarding traction on snow
  26. Piston ring replacement
  27. Dealing with condensation / moisture inside the car
  28. The Minister of Sinister is coming back !!!
  29. HHR 'Panel' Emblem
  30. risk of buying a 2008 SS due to porous block?
  31. Fuel line insulation question
  32. Cooling issues
  33. Surprise, Surprise!
  34. Remove wiper arms, 08
  35. Hhr power window problem
  36. 2007 HHR 2.4L died
  37. Drivers side mirror
  38. Front end questions
  39. New member with a/c problems 2009 2.4L
  40. Brake line question...
  41. New struts and rear shocks?
  42. Done did it again- another panel!
  43. HHR 2006 tranmission fluid fill plug, need to unescrew
  44. Adding factory remote start, 2009-2011
  45. 07 Panel engine options.
  46. OEM roof rail cross bars
  47. reverse gear won't engage(dont move in reverse always in foward)
  48. ???plastic tail light access planels
  49. p0014 code
  50. 2011 hhr lt
  51. rear hatch
  52. Front end frustration
  53. Wheel Speed Sensor
  54. Good ground spot under dash?
  55. Can I fit a 6ft. Aluminum ladder in the back?
  56. 2010 HHR SS Turbo OR supercharger?
  57. New dashcam, wiring question!
  58. Steering wheel alignment; i-shaft snapped
  59. 2008 LS engine ID code?
  60. 2008 hhr
  61. Opinions about HHR usage
  62. Side rail install?? Should i?
  63. Ignition switch wiring diagram/pinout/color code.
  64. Cell phone holder
  65. Parts or Junkyard?
  66. TCM problem?
  67. Slight Wobble after hitting small bumps or potholes.
  68. Seeking the flush mount roof spoiler
  69. Replace Serpentine belt
  70. Opinions on Years
  71. replace door blend AC actuator
  72. That time of the year again....
  73. looking for dome light
  74. Misfires and stalling
  75. need replace the FUEL line
  76. A/C Drain
  77. Esc
  78. Cooling Fan and Fuel Pump never turn off - 2009 HHR
  79. Coolant temp….
  80. Water pump
  81. engine harness
  82. Dash Cluster
  83. Driver window won't go down
  84. Orange turn indicator light on drivers side is on all the time
  85. 2006 HHR Wipers only work on high
  86. New cooling fan has metal clips? Do I leave them alone?
  87. Steering
  88. Air intake for 2011 2.4 ltr
  89. 2008 Chevy HHR SS - check engine code P0101
  90. Admin Please
  91. Balance Shaft Sprocket Removal
  92. HHR Gauge cluster issues
  93. Loss of acceleration, won't start
  94. HHR Head Light replacement
  95. looking for spray painting WA913L Sunburst Orange Metallic
  96. Engine identification , 2.2 vs 2.4?
  97. 2010 Cobalt SS BCM3 fuse blows
  98. Door Ajar Indicator
  99. How would you install a wall in passenger hhr
  100. Part Needed: Front Bumper Valance (Deflector)
  101. Mysterious Device
  102. Won’t turn over
  103. Custom HHR truck
  104. Class 3 trailer hitch receiver?
  105. HHR Replacement
  106. Mods?
  107. 08 HHR 2.2l won't start
  108. 2010 HHR roof rack
  109. Rocker panel
  110. Deal
  111. intake cam shaft senor
  112. Big cooling system brought my operating temps 25*C lower than stock
  113. need wiring help
  114. 06 gray interior paint code
  115. Is it possible to install a turbocharger from the HHR SS model to the LS one?
  116. Car stereo
  117. enter into cooling mode
  118. woohoo! HHR number five!
  119. Drivers seat foam
  120. 710 still good
  121. Getting engine code P0010 and service traction
  122. New owner
  123. water in passenger side
  124. Losing oil
  125. Thermostat housing removal
  126. Sudden drop in mpg
  127. American Classic Whitewalls
  128. Got HHR problem
  129. 2009 HHR cup holder compatibility?
  130. Thermostat housing question
  131. Spare tire area Q
  132. Need advice
  133. Passenger Inside Door Handle
  134. Car won't move
  135. Headlight problems
  136. Vent actuator, but which 1
  137. Service Manuals on Ebay
  138. 2006 hhr CRAZY
  139. SeatBelt Dilemma
  140. Rear hatch struts
  141. push button start
  142. Engines and Towing
  143. ? Tie rods
  144. Has anyone swapped lead acid for an AGM battery?
  145. Chevy HHR AC Condensor Replacement
  146. 2008 hard shift code P0752
  147. can't find my old post??
  148. Knock sensor
  149. Butyl patch
  150. Help...
  151. Hhr code po756
  152. Stop lights
  153. 08-10 fuel pump removal
  154. Brake upgrade
  155. VERY hard brake pedal while running
  156. Doors
  157. Rear disk brakes
  158. Found previous Facebook post for my car
  159. Odd trans issue
  160. Headlight bulbs?
  161. Get window to work
  162. rpm increase in neutral gear(manual shift)
  163. Service Manual
  164. HHR will not warm up
  165. Click click click
  166. Heater issues
  167. 2011 chevy hhr.
  168. Control arm
  169. Front Axle nut size
  170. 08 HHR cranks but does not start
  171. Engine stuttering
  172. So cold...
  173. P0172 & P0561 after 30 second idle
  174. 2007 HHR Transmission issues
  175. Knocking? from engine bay
  176. Window Cleaning
  177. Looking to ground Digital antenna
  178. 5-spd manual guys: How many miles on your original clutch?
  179. Heated seats mod ?
  180. Headlights not working after stereo and sub install
  181. Need a name for my 2007
  182. Radiator Cap hard to come off and put on???
  183. HHR Newbie, Common questions
  184. Steering wheel rattle
  185. HHR Inside door handle in metal?
  186. Flooded HHR
  187. Indicator lights
  188. needed a laugh..
  189. 06 HHR Engine Noise - Anyone know what this is?
  190. Ground for trailer wiring
  191. Interior Light
  192. Poor FM reception with engine running.
  193. 07 Auto Lock not working
  194. 2008 HHR Special Edition Suspension
  195. first gear don't engage first time, but the second to the first yes
  196. Foolish to give up Honda for HHR?
  197. Which hhr ss to get?
  198. Rear hatch
  199. P1516 & p2101 2007 hhr lt
  200. Gas key
  201. Hhr help
  202. Trys to start when I hook up battery...
  203. Rim Question
  204. up date
  205. Thoughts on HHR 'Value'
  206. Sunroof issues
  207. WTB HHR door
  208. 2009 Chevrolet HHR LT 57,400 1 owner regularly maintained.
  209. Dimming
  210. replace normal bulb for Halogen
  211. rear bumper cover 2009 HHR SS
  212. Battery on 2008
  213. Power steering motor?
  214. WTB - AC Heater Climate Control Unit Switch w Heated Seat
  215. Where to get a crank pulley key?
  216. LCA Bolt
  217. P062f
  218. This years local car show, juat a few pics
  219. fog light button Illumination
  220. Hitch adapter and riser?
  221. lobotomy
  222. Brake booster/master cylinder
  223. Getting back in the saddle
  224. heating on the high only work
  225. Damaged remote control & tire pressure module
  226. Chinese parts Spammer
  227. Rcdlr 2006-2008
  228. Should I clean this sludge or leave ot alone
  229. GM trailer hitch
  230. Time for a smoke test - P0171 issue
  231. Broken guide bolt
  232. Bobby Bode Racing
  233. code P0449 HHR 2006 Evaporative Emission Control System
  234. Fog lights…?
  235. No reverse lights
  236. Revving at 40 mph and rough idle
  237. Rear Sway Bar
  238. Best time to refuel
  239. Outside temp
  240. Stupid Move -COUNTER CLOCKWISE Harmonic balancer blues.
  241. A panel I saw today
  242. Radio confusion
  243. Clutch go down, don't engage and liking on reservoir brake
  244. AC Compressor
  245. Dome light random on/stuck on 09 HHR LT
  246. Replacing Rear Shoulder Belt
  247. 2022 Van Nationals
  248. Restoration of window switch trim to brand new look
  249. Door on 2006 LT Stuck Closed
  250. 2006 HHR LT 2.2L - Manual - Cat Converter ?
