PDA
View Full Version : General HHR
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. Mirror mod for visibility?
  2. New 2006 HHR LT Owner - Part # request
  3. Oxygen Sensor Codes P0138 and P2270
  4. Copart SS Panel
  5. Armrest goes down too far
  6. Replaced Headlights and car does not start - 2010 HHT LT
  7. custom steering
  8. Battery Replacement
  9. Disc brakes
  10. parts advice
  11. power mirror issue
  12. Hhr ss overheating
  13. 55 hhr taillight
  14. Cam phasers
  15. Automatic or manual
  16. Hhr ls1
  17. Couldn’t ignore this panel
  18. Missing Milage
  19. Intermediate Steering Shaft issue
  20. ABS & Service Traction Lights On
  21. trailer hitch ?
  22. Rear hatch opening
  23. Black Friday Weekend Starts now! Up to 18% off! And Free Shipping!
  24. Air Bag Service Light - Intermittent
  25. TPMS learn mode without RKE
  26. HHR electrical issue- no power steering, no speedo, no gas gauge
  27. Free shipping over $199.00!
  28. Everyone saves! Forum discount!
  29. was gifted a HHR
  30. Hit in the rear
  31. Headlight replacement
  32. No fire
  33. Have the dreaded P0121 code.
  34. Fuel
  35. Remote with garage opener
  36. Funny thing about battery voltage
  37. Oil stick tube O ring
  38. Tpms
  39. Stiff Steering
  40. Braking
  41. Adding Sirius/XM and Bluetooth and retain factory look?
  42. what is it ? 09 HHR panel
  43. Replacement fobs and keys?
  44. engine swap
  45. Stick on vents..yes or no???
  46. Replacing Battery
  47. I found my HHR SS replacement
  48. Is it my battery ?
  49. Same ideas
  50. HHR v. Mercury
  51. Black chrome ?
  52. Are code P0010, Service ESC and TRaction related?
  53. Instrument Cluster
  54. Another One Joins the Fleet
  55. That's not a good design
  56. And now we have 2
  57. 2007 2.2 5 speed to 2009 2.4 flex fuel swap
  58. 2006 HHR LS stolen!!!
  59. Traded In My Chevy HHR
  60. Anyone live near adelanto california or janesville wisconsin?????
  61. GmPartsDirect.com aka Flow Chevrolet buyer beware
  62. General questions regarding forum
  63. Front passenger side splash guards
  64. power mirror switch stays on
  65. Air bag system after an accident.
  66. which t-stat?
  67. AGM battery for HHR LT
  68. newer doors on older model
  69. Panels
  70. Cut my wires!!!!
  71. Time to start with these upgrades
  72. rough idle and check engine light stays on
  73. Look. What got!
  74. found loose fitting and hose in battery compartment
  75. Full Moon Wheel Covers
  76. What's the HHR like in winter
  77. Sure is a low hanging nose on this critter
  78. Rims
  79. Remote start?
  80. Hhr liftgate removal
  81. Ash tray. Anyone got creative?
  82. Goodby HHR
  83. *# My HHR Check engine light will not go off. SYSTEM TOO RICH****HELP**,
  84. Seat Cleaning
  85. 2007 HHR LT 2.4 engine
  86. Coolant and thermostat change questions
  87. Chevy dealership experience with my HHR. Tried to sell me non-needed stuff.
  88. Headlight Adjustment
  89. turning off daylight headlights
  90. Front end noise
  91. Vin vs build tag
  92. No crank...Fixed! Leaking oil pressure switch, no way!
  93. Question about used hhr
  94. A big thank you
  95. Headlight problem
  96. it is a sad day
  97. HHR golf cart
  98. Success Enabling Remote Start On Former Rental
  99. Remote Start isn't working
  100. ‘55 Chevy tail lights
  101. 2010 hhr remote
  102. Water pump
  103. Noise clunk wobble
  104. Lights going off randomly
  105. Hhr purple wiring harness near battery identification?
  106. 2007 HHR - which REAR brake shoes fit ?
  107. No start ESC off and SERVICE TRACTION warning after battery disconnected for 30 mins
  108. 2006 chevy hhr, front end whining noise constant front right
  109. Lots of new parts, with some old issues...
  110. Weird Butyl Patch Problem, Part doesn't work
  111. A anyone know ?
  112. Scoop
  113. Problems
  114. Tire pressure on hot days?
  115. 1/2 Panel
  116. Factory roof rack rails
  117. What do you think?
  118. 1947 HHR Panel
  119. Time to part with my 2009 SS
  120. Latest VIN decoding?
  121. Transmission fluid check plug
  122. Interior trim material
  123. Key fob question
  124. Best place for Wheel bearing assemblies ?
  125. motor interchange
  126. Plug
  127. what would you replace your HHR with?
  128. Passenger CV axle problems
  129. Help! New battery but wont start.
  130. Road trip
  131. HHR Capital
  132. Interior Trim Color Codes
  133. Rack crossbars
  134. Cargo Area Partition/Organizers
  135. front brake pads and rotors
  136. SS fan relay location.
  137. Control arm LS panel 09
  138. Please help
  139. Seat swap, air bag light
  140. Cargo Net Question
  141. Any body shop guys on here ?
  142. Mirror?
  143. Windows and radio control panel buttons
  144. Power outlet spins in place?
  145. Battery vent tube
  146. Rear shock question
  147. 2007 Engine Verification
  148. Intact camshaft
  149. Front struts?
  150. Heated rear view mirrors
  151. Firing order 2009 hhr ss 2.0
  152. Need Help ASAP! Rain is coming and sunroof won't shut!
  153. Found a 07 hhr premier
  154. towing
  155. I’m looking for an SS
  156. Look what I just got...
  157. Sun visor
  158. Proper hitch ball mount?
  159. Some advice on areas to check when buying a used HHR
  160. Po171
  161. Random wire
  162. Key fob
  163. which tpms?
  164. Interior Visors Loose
  165. Interior trim color
  166. 2.2L Power Upgrade Year
  167. Unfortunately...
  168. Ruthenium spark plugs
  169. Headlights... option codes
  170. I have a 2010 HHR Lt I need some ideas for interior color please
  171. HHR seat covers
  172. Hhr
  173. Here's My Fleet
  174. Performance Exhaust
  175. accelerates too much
  176. HHR's becoming popular as Taxi's
  177. Why the Pop Up ?
  178. Power passenger seat w/lumbar
  179. Rain leak Passenger side under glove box
  180. Feels like wheel is wobbling
  181. HHR Explodes
  182. 2009 HHR SS Panel on Ebay
  183. No crank no start problem
  184. Intermittent headlight issues
  185. Did anyone see this?
  186. finally did the conversion [wheels/rims]
  187. Electrical Problem?
  188. ACDelco vs Delphi ignition coils
  189. Insulation on the fuel and vapor line
  190. No HHR at Mecum in Phoenix
  191. Brake fluid indicator on unit
  192. Panel Door Interior Netting for Window area
  193. chevy bowtie
  194. Screaming noise from left tweeter
  195. Running Temp
  196. How dare they .......... ;)
  197. Press for bushings
  198. Considering a 2006 LT purchase.
  199. What is an acceptable amount of play in the lower control arm?
  200. Should I buy it? 2008 SS 68k miles
  201. Get rid of bad A/C smell
  202. Late model automatic shifter w/leather boot
  203. 2008 hhr eng pwr reduced
  204. Changing language 2006 HHR
  205. Opinions please...black or chrome roof rails?
  206. Bicycle rack
  207. Backup Lights
  208. Will not crank
  209. 2009 HHR 1LT-should I buy it?
  210. Can I change coolant?
  211. Aftermarket TPMS
  212. Which Headlight bulb do most people use?
  213. Changing battery
  214. DIC warning
  215. SS Font Brakes on the LT and LS spare tire issue..
  216. filter sale info
  217. Lateral wobbling under load
  218. Oil pressure Ecotec video
  219. CHMSL Information
  220. Best way to route/wire for rear Uber/Lyft light?
  221. Keyfob question - not about reprogramming
  222. 3rd Brake light out
  223. Fuse or Circuit Breaker
  224. Traction control override
  225. About to reach that point.... fix or kill
  226. Remote start not working in really cold temps
  227. Pulsating brakes, need advice
  228. Here it is..
  229. Pictures of custom Panels
  230. HHR Panel production numbers?
  231. Dash Compartment Screws
  232. Front crank seal and harmonic balance advice.
  233. Fear of Rabbit Hole
  234. R.i.p. 07 hhr lt
  235. power loss while driving
  236. Classic/Collector Car Insurance
  237. Vanity Mirrors - Lighted
  238. Fuse block - 10 Amp accessory Plug??
  239. Body rot locations
  240. Cartoons
  241. 2007 LT 2.4 vin P fuel question
  242. Engine Stand
  243. What is half throttle?
  244. Shared Saab 9-3
  245. HHR Blower/Vent Switch Issues
  246. Happy New Years!!!
  247. Gas tank leaking at rollover valve
  248. Passenger Side Front Fender Splash Shield Help
  249. Rims
  250. How to replace door lock and ignition cylinder.
