PDA
View Full Version : General HHR
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. true or false
  2. what color red for 08
  3. "TEMP er-Mental" Temperature guage. 07 HHR LT owner of 7 years.
  4. Beetles and HHRs
  5. fog light install help info needed
  6. HHR SS Halfpanel For sale in NC
  7. had trouble free use for 10 years and 80k, now no start
  8. Looking at Buying an HHR
  9. Basic Oil Facts.
  10. 2010 Rear View Mirror
  11. Gone in a Blue Flash
  12. Doors won't unlock when put in park
  13. Tech 2 questions
  14. 2007 HHR gas leaking when tank is full?
  15. Location of VVT Oil Filter Screen (P0012 code)
  16. Heli coil
  17. Man w/a Panel
  18. How to remove fuel injector
  19. Passenger Airbag and Seat Belt Light Gremlin
  20. Changing Trans Fluid
  21. After only 12 years,...
  22. Change TPMS's
  23. More dents for DentedHHR!!!!! (video inside)
  24. Chevy HHR running hot???
  25. 4x4 Roof Basket On My HHR.....NO WAY......
  26. Wife Wants to Keep Our HHR.....Forever
  27. Dash cluster--- is the dash cluster controlled by a computer module
  28. Outer window seal WTB or fix?
  29. Lug Wrench
  30. Driving Lights
  31. Rear Cargo cover hhr
  32. Changing Seats
  33. Merry Christmas Y'all
  34. Awesome WORKOUT!
  35. Engine Code PO420
  36. Looking for a HVAC wiring diagram 2008 HHR
  37. Getting removed bumpers from cargo area to where they belong
  38. Transmission Mount Needs replaced
  39. MPG Improvement Device Validation
  40. 8 years ago today, we brought home this little HHR
  41. New to HHR - discovered 2 things
  42. Driving in I gear and using cruise control? Is it bad or not?
  43. Shock Absorbers in Europe?
  44. Oil Catch Can Install November 2017
  45. 2006 hhr wont start, but cranks
  46. Helping
  47. Installing used factory seat belts and back seat in 2010 panel
  48. Low Voltage Cutoff Switch to Prevent Battery Drain
  49. P0171: System too Lean (Bank 1)
  50. No RPM when running but have when starting
  51. My 2010 HHR 2.2L LS Overheating Just Now - Please help!
  52. Should I Buy This
  53. Changes to the Search function
  54. Engine compatibility
  55. Fluid Film corrosion inhibitor prep and application
  56. Black Friday Weekend! Whos Ready!
  57. Air Dam
  58. Anybody had the opportunity to drive a new Chevy BOLT
  59. HHR Headlight Problem - HELP!!!
  60. Locked out while running
  61. 2006 HHR 2.2 to 2.4 swap
  62. Door handle DORMAN #80369
  63. window switch replace
  64. Headlight Bulbs
  65. Car radio problem.
  66. Spark plugs will not loosen
  67. TC light
  68. Turn signal Bulb
  69. Mass air flow sensor problem
  70. 2010 HHR front end vibration
  71. Code P0128
  72. How many of you out there do this?
  73. Emissions Control Label Location
  74. Temp guage remains inactive.....
  75. I don't know whether to be sad or amused
  76. This forum is awesome - buying an SS
  77. allmost a ss good bad & redneek
  78. sun visor
  79. RKE programming
  80. rear view mirror swap/ radio
  81. HHR 2.4 LT after 5000 km, good
  82. Dare to be different
  83. 2008 HHR engine replaement question
  84. Will a 9'6" Surfboard Fit Inside An HHR?
  85. Date code on battery
  86. Hi Guys ... Just Picked up Number 10 from Missouri
  87. Need help with Intermediate Steering shaft
  88. Catching Up.... Whats up?
  89. Upgraded intermediate steering shaft?
  90. cool hhr for sale on c/l
  91. 2008 hhr
  92. 2007 HHR electrical gremlins
  93. 07 Chevy Hhr LT Repair Question
  94. P0016
  95. installed rear seats in my 08 panel
  96. Eibach Springs
  97. HHR LS Swap Rat Rod
  98. Coil over rear shock?
  99. wrong ecm stop shifts ?
  100. Bowtie Emblems
  101. Aftermarket car alarm install......???
  102. Need help with question about rear seatbelt
  103. images/pics showing parts breakdown
  104. Dex-cool vs 50/50 coolant vs Super Coolant
  105. Random HHRs spotted... by Google!
  106. New roof rack installed.....
  107. Headlight Bulbs
  108. Will this combo of wheels and tires fit?
  109. new hhr
  110. Hazard lights stay on!
  111. Where can I get "Panel" emblem?
  112. 2011 hhr dash indicator lights
  113. Maximum Cargo Length
  114. New Member and New 2008 HHR Owner
  115. radio controls
  116. stock steel rims on a ss ?
  117. wife in wreck
  118. HHR 2.2L LT Overheating issue - Please help??
  119. Coffee cup holder
  120. 2007 LT turn signals not working
  121. Checking in
  122. black box with WX sign on roof
  123. Fuses falling out
  124. How to post pictures
  125. panel doors swap
  126. Anybody install a NON HHR OEM roof rack on thier HHR
  127. hhr panel remote
  128. Bushing K200361 replacement
  129. recommended brands for rear shocks
  130. Hey s/s reunion?
  131. Glove box repair
  132. tire monitor
  133. How should I go about putting an hour meter in my 2008 HHR?
  134. My HHR is from ?
  135. Metallic rattle drivers door
  136. Front end noise
  137. shows
  138. In Dash Navigation/Bluetooth Unit
  139. Meet Gregg
  140. Stickshift
  141. Does anyone know what part could be leaking from this pic?
  142. Thread that's stuck on page 1. Or conspiracy.
  143. can a 6 disc cd player can fit in a my Lt?
  144. Hhr diecast
  145. Hanyes hhr repair manual
  146. windshield washer tank
  147. OBD II port
  148. And now, the end is near....
  149. Turn Signal
  150. Adding a subwoofer
  151. Happy 4th of July
  152. 2008 Chevy HHR 2.2 won't start
  153. 2010 HHR no cruise control
  154. 2011 HHR power windows not working
  155. Fascia Clips
  156. Sub mounting depth
  157. Gregg before the storm
  158. Airbag module
  159. HHR FUEL FILTER replacement
  160. Would you buy a 2007 2.4 w/158K on it? I need help!
  161. Engine misfire on 2011
  162. OEM sway bar bushing bracket part number?
  163. A Bit of Damage... Deal killer?
  164. Sled dilemma
  165. Compatible 2.2L engines for '07 HHR LT
  166. Sirius/XM Radio
  167. Fuses
  168. Airbag
  169. No Cooling Fan or A/C
  170. HHR Crossrails (GM part) for roof rack
  171. Farewell, Dear HHR Friends!
  172. HHR Grill(s)
  173. Key fob code?
  174. How long will my 2008 last?
  175. First Year of Door Window Switches
  176. Pick a part scrapyards in Southern Ontario?
  177. Need a new engine for the chevy HHR 2008
  178. complete suspension package
  179. Best free CAN diagnostic software?
  180. Chicago Area Black Panel
  181. Parted ways with my HHR
  182. Invaders From the planet V8.
  183. Start up warning lights on dash
  184. new thread
  185. A couple of pics of my HHR and his cousin
  186. Need help with 2 engine codes
  187. Stereo problems
  188. Driver side cylinder lock
  189. #3 Has Arrived
  190. Shopping at Wally World
  191. air conditioner blows 40deg
  192. Lighted Bowtie ?
  193. Retainer pin in front wheel housing
  194. Oil pump question
  195. 2017 Tire Recommendation
  196. Front seat dimensions for HHR
  197. 2008 California Concepts LS Panel
  198. Replacement tires
  199. drivers door seal
  200. Last day with LITTLE GRAY
  201. Another V8 HHR
  202. 2008 chevy cobalt sunroof leak
  203. What's This?
  204. Trailer Hitch Wiring
  205. Keyless entry how do you program them, ive got a new remote and an old to 2006 hhr
  206. Adding another 2LT Possibly?
  207. Fog light differences
  208. Door Question
  209. Automatic Shift Knob
  210. 5 speed rpm shift knob
  211. HHR Rust Out Question
  212. How to remove manual shifter knob on SS?
  213. Factory Undercoat
  214. about to turn 200k...keep & maintain or sell & move on
  215. Control arm bushings
  216. Powered by ECOtec.
  217. Door check
  218. my new toy to go with my HHR
  219. Door Handles...
  220. Dorman 13736 (Keyless Entry Reprogrammer)
  221. Thank you!
  222. what is it worth ?
  223. Windshield Rock chips
  224. The Car of Choice for High Speed Chases
  225. Back on the Road Again
  226. Front seat belt bolt size
  227. HHR Fog Lamps
  228. New NY State Window Tint Law
  229. Looking For GM Performance Badge
  230. Basic equipment on 2009 HHR LT2
  231. Front Sunroof Drains
  232. My 2006 HHR
  233. roof rack
  234. What's the value of 2010 HHR
  235. Rear wiper washer
  236. sway bar end links
  237. 2010 hhr windshield washer
  238. A few questions in no particular order....
  239. Suspension
  240. DesignerDave
  241. Oh oh...!!!
  242. Steering Wheel And Shift Knob Rewrap
  243. Need some advice on HHR purchase
  244. Switching SS Drivetrain to a Panel
  245. AGM battery selection
  246. You got to love Fiber Optics
  247. price?
  248. fan fuse
  249. does my 2011 hhr have a computer telematrics on board
  250. Burnt rubber smell
