PDA
View Full Version : General HHR
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40
  1. Lower seats
  2. power mirrors not working.
  3. Key Fob Malady
  4. Take the style of your HHR to the new level with RT Wheels
  5. P0301 - Cylinder 1 misfire 2011 HHR 2.2 Ecotech
  6. sun roof adjustment
  7. Remote start
  8. Great Winter Sale from MaxLiner - Up To 15% OFF!
  9. On General Principle
  10. intermittent instrument cluster
  11. Brake Bleed Sequence
  12. Just bought 06 hhr LS. Came with some problems
  13. ESC Active after getting gas ?
  14. Pick-up truck conversion
  15. Keep your HHR clean in winter season with Coverking Custom Frostshield
  16. 2006 Chevy HHR wiper motor nut
  17. Most capable freebie scan tools.
  18. Oil Loss ?
  19. 2007 Brake light blinked, car shutdown dead
  20. Exhaust solonoid problems
  21. Rattling noise while idling?
  22. Sunroof Vent question
  23. Any one know this HHR ?
  24. Rattle
  25. Marker bulbs
  26. Remote
  27. Coolant reservoir retainer bolt
  28. Difference between years
  29. SS Space saver spare
  30. HHR and Motorcycle
  31. Swapping out engine.
  32. Misfire, no codes. Please help!
  33. 2011 Chevy HHR defrost.
  34. Help
  35. Best place to tap an ignition wire?
  36. Battery
  37. Gas can compromised water got in tank . Crank no start help !!!
  38. New Rixxu Seat Covers Promotion at CARiD!
  39. Front Brakes Locking on 2007 LS
  40. Dedicated turn signals
  41. HHR SS axles
  42. Black Friday Weekend! Whos Ready!
  43. Black Friday Savings 2020 at CARiD
  44. Adding Side Airbags
  45. Thinking of buying a 2009 wagon
  46. A Bite in the Arse
  47. Can you get 100% of coolant out of system when draining
  48. My SS now has a brother
  49. Front door difference??
  50. Battery "Lobotomy"
  51. reading lamp p# 15237187
  52. Shift indicator light
  53. LEDs
  54. What is the rear end knocking noise that ALL my HHR’s have had ?
  55. Fuel leak?
  56. Sun Roof
  57. Time for Upgrades
  58. The whole HHR feels like a giant vibrator!!
  59. Chevy hhr network
  60. Throttle body question
  61. 2007 HHR Whining and Sticking In steering
  62. Tires ???
  63. Misfire questions
  64. Battery Charger/Starter
  65. 2.2 to 2.4 from 2006 to 2007
  66. p0016, could it be vvt actuator?
  67. Fog Light Switch for 2006 HHR LT
  68. Question!
  69. Installing New PCM
  70. New CARiD Video Commercial is On!
  71. MaxLiner Sale at CARiD - Get 15% OFF
  72. SS Bumper Cover Fascia
  73. Once upon a time on HHR street...
  74. Constant 12v source?
  75. HHR Panel Wheels
  76. Why HHR?
  77. Battery Drains
  78. Windows and mirror not working (click)
  79. Capture all the angles of the road with Thinkware Dash Cam + New Sale
  80. Want to take a loan for a new car
  81. check engine light stays on after repair
  82. Timing Chain Guide Bolt
  83. SS Half Shaft
  84. Brake goof
  85. Derecho Storm
  86. Alternator bolts torque specs
  87. Farewell Maybe.....
  88. Lift Gate Struts
  89. Heat shield broken?
  90. Brake Questions....
  91. Cruise control confusion
  92. Power window problem
  93. Rear shocks
  94. How many ?
  95. Front brake Caliper pins
  96. Chevy hhr
  97. Fuse box issue?
  98. LCA differences
  99. front sway bar
  100. Customizing
  101. rear hatch cylinders part#
  102. Blowing Fuse ?
  103. 2008 hhr lt ac
  104. Oil extraction
  105. should I buy a 2009 LT 2.2 or a 2007 Corolla?
  106. Hiatus...
  107. New to me 2011 HHR 2LT 2.4 Need some help
  108. Wiring under front seats?
  109. Remote Key reprogram
  110. Aftermarket Steering Wheel
  111. Another hhr ecotec with missinhg / broken timing guides
  112. rusty fuel lines investigation
  113. Change clock time
  114. which coolant temp sensor to use?
  115. HHR Dilema Fix or Not
  116. GMPartsDirect Military Discount
  117. Bumper Prep Work for Body Shop
  118. Finding Dorman part numbers
  119. NHTSA investigating Cobalt/HHR for fuel leaks
  120. Driver side sun visor replacement?
  121. Front Hub Replacement Recomendations
  122. LCA bushings
  123. Cargo Nets ?
  124. Rear Seat belt Interchangabilty from year to year?
  125. Engine is bucking?
  126. About time!!!
  127. Cd player
  128. K&N intake box.
  129. Griot's Garage Synthetic Clay
  130. AC compressor burnt out?
  131. Buzzing noise
  132. Very Squeaky Noise in the back area of my panel ?
  133. What is this door trim part called ? (See picture)
  134. 2007 Premiere Edition: Local sighting
  135. Air conditioning question 2009 2.4
  136. 2010 LT Cargo Area Water Leak
  137. 5 sp HHR
  138. Hello again everybody! May be back with another HHR
  139. Funny Ad from CARiD - When You Really, Really Love Your Car
  140. Struck gold
  141. Weird Exhaust Sound
  142. Anyone come up with easy makeshift substitute for Air Cleaner box Grommets?
  143. Mirror lights.
  144. better antenna reception
  145. My HHR Family
  146. Happy Memorial Day Weekend
  147. Interior Part Name?
  148. Front end surgery
  149. HHR Down :O
  150. to have or not to have
  151. Wooly Worm
  152. Dash mounted rear view mirror?
  153. Trailer wiring
  154. Arm rest
  155. header install caused leak?
  156. Saving Time - Get Up To 14% Discount on Rixxu Car Covers!
  157. problem with key fob
  158. Front bench seat
  159. Strange question
  160. exahust/muffler
  161. ?'s
  162. Problem with HHR
  163. Hazards are not working
  164. back seat swap
  165. air bag didn't deploy
  166. Annoying rattle
  167. Seats fron 08 SS to 09 LS
  168. Service ESC ?
  169. Linkage, and no crank
  170. E85
  171. Cutting the front axle.
  172. Futon
  173. Decoder not working?
  174. Fuel Grades
  175. 2008 HHR door latch
  176. What is this?
  177. Complete Exhaust systems?
  178. Warranty Tracker
  179. Replacement fuse/relay box cover?
  180. Newb
  181. A Little Gunk in Oil
  182. Dark Switches
  183. key fob
  184. Need help identifying plastic cover
  185. Big Mystery Part
  186. Evap canister vent solenoid question
  187. Help pending codes
  188. Who would buy it? or your best reasonable offer...
  189. 2011 light knocking noise
  190. Battery
  191. Facebook HHR Groups
  192. Give your HHR a showroom look with Rixxu Detail Products + New Video
  193. over 60 mph shake
  194. Clean Leather Seats Easily with Rixxu Leather Care Products + Video
  195. SS auto repair/upgrade options?
  196. HHR ss parts ???????
  197. HHR damaged in an accident, I’m fixing it !
  198. Alarm horn not honking when doors locked with fob
  199. Emblems - Painting / Filling Red
  200. Hhr
  201. Thank you all for 5+ years of advice, help, and most of all support ♥
  202. Mitchell Service Info
  203. Headlights On/Off switch not working. Help!
  204. Hub removal tool
  205. 2011 Chevy HHR
  206. Security light on instrument panel confusion
  207. My SD Memory Card Fell Down Windshield Vent
  208. chevy hhr EVAP
  209. LED Headlights & LED SS Fog - Nice improvement
  210. Torque app question
  211. Adhesive Rock Chip Deflector Strips
  212. Check Engine Light - Code P0128 - Will it pass Emissions?
  213. Electrical
  214. Rubber Mat Rescue
  215. Blue dot lights and bowtie stickers
  216. 09 HHR SS build tag... anything stand out
  217. SS Wheels - were there any options?
  218. 09 SS clarification questions
  219. 2006 chevy hhr decided not to start today
  220. 2010 SS, no center arm rests
  221. Seat Arm Rests - Not on SS Shift Model and on LT Shift??
  222. TPMS learn mode
  223. Dedicated "Build" Section
  224. My third HHR and this one is amazing!
  225. 2005 chevy equinox
  226. NEWBIE - Need advice
  227. Lets see your hhr "TOONS"
  228. Exhaust manifold bolts.
  229. I had to replace my beloved 2010 TEAL BLUE HHR!
  230. Chevy HHR Motor EVAP and Motor Catalyst not ready
  231. Key fob won't lock/unlock 2006 hhr- tried 4 different batteries in fob
  232. Is my charging system working properly?
  233. 2006 LT - Turn Signal not cancelling both directions
  234. Issue with door locks
  235. 2006 LT - Junkyard Bonanza
  236. Heated seat issues.
  237. Motor Mounts, Tranny Mounts
  238. Happy 10th birthday to my SS
  239. Good exhast set up?
  240. 2006 LT Rearview Mirror Options
  241. Inside Door Handle Breaks
  242. 2006 HHR LT - Additional AC Delco Remote FOB wanted
  243. hatch door won't lock
  244. Aftermarket Headlights
  245. Wire harness the same for all cars.
  246. Roof rack template
  247. HHR LS convert some things to LT
  248. 2006 Part # Clarification
  249. Hhr ss exhaust with magnaflow
  250. Racking up the costs
