View Full Version : General HHR
- Six months - and a couple of questions....
- Safety belt on obd
- Advice I guess?
- Happy holidays
- Integrated Alarm - will it work without a key fob?
- This is interesting
- 9 years ago, today!
- Any way to lower top speed?
- Can't start. Changed the battery - some clicking and whistle - what could be?
- Thinking About HHR panel for my business
- New 2008 HHR 2LT owner! Hello!
- ACC Ignition Key Position Problem
- DTC self clearing?
- new to me HHR Panel
- weird observation
- "Smoothie Rims"
- HHR Woody
- Front strut top hat
- Ftfm
- Headliner & Clothes Hanger
- Brake up grades!
- A perfect Travel Mate.....
- front suspension groaning when cold.
- Door Poppers - any adjustment ? HHR Panel
- Need help. Want to buy HHR
- Door lock malfunction
- Panel rear seat/package tray
- Removing the small wire from the starter
- Hhr sos
- Stainless steel exhaust system?
- Adding a voltage gauge
- Chevy cobalt cat back exhaust system
- Been awhile since my last visit here
- Losing oil through exhaust
- ODB II Scanner - Windows SW vs Handheld
- Transmission in l
- '06 LT 2.4L 5-Speed M/T!
- Need LCA help
- Paint color?
- tire size needed
- Bizarre 😳
- Service Airbag warning light
- Battery ground
- Belair kits for HHR?
- Deer Hit, Ouch!
- Steering issue again
- It Finally happened
- Headlight restoration
- Spotted in a Movie, guess or post one
- Engine Swap 2007 HHR
- First time HHR owner.
- Turn signal bulb
- Slick 50 reviews for HHR?
- RockAuto
- How do I change out the ecm ?
- 2008 HHR - bit of gas fume
- Strange incident
- Radio part number
- Best lift points for floor jack?
- 2006 won't start after cleaning throttle body
- everything
- Fuel / Gas Line versus Vapor Line - Inside vs Outside
- Key chimes
- Service traction, abs, Tc, cel wtf lol
- HHR SS speedo Cluster in a LT. Plug and play?
- SS spotted
- AZ Class Action
- 2.4 engine year transfer info
- The fastest hhr
- cargo dome lights
- Low Mileage Thread....
- Factory stripes
- how much for a starter for chevy hhr
- Golden Teal Metallic
- does transmission control module replacement need programming?
- dead battery
- bumper bracket install?
- need two sided tape
- home made pet**** socket
- ABS light
- Retain reverse lockout with new shift knob?
- Wires
- power seat adjustment
- Keys
- rear bumper cover
- install ss side skirts and rear wing
- lowering springs install info / help
- I broke the Main power lug off the engine fuse box
- Engine light still on after replacing camshaft and crankshaft sensor
- HHR won't start. Please help.
- HHR spotted . Hope you are ok
- CarFax and a word to the wise
- HHR rear fenders
- Dually HHR truck
- Power Steering Observation
- Weird A/C thing today, anyone else ?
- looking for rubber seal part number
- Rocker panel clips, left blinker
- Lug Nuts
- Why use Dexcool?
- Moving to a new state! Have to tow the HHR, any tips?
- radios
- 2010 HHR gear shift button stuck in park
- Check engine light
- lkq score
- Problems with her can anyone help
- Weird HHR AC Issue
- Headlight not working?
- HHR for sale
- IM Monitor Readiness?
- and now Gas leak
- Custom HHR
- Custom air intakes
- Happy birthday america!
- Temp. Gauge and A/C
- Added a ground
- Map/Navigation info for Phones
- door panel fix ?
- Chrome pen
- factory amp
- door lock pins
- Bad rear wiper switch (08).
- running boards
- It now has a name
- factory radio
- Slight ticking noise
- Camping with the HHR
- inside pictures
- Canuck Motorsports...Great guys!
- new accessory
- fog lamps
- Automatic locks and tranny problems
- Dash covers
- No start Can Bus YouTube
- Rear window, ventable?
- remove headliner
- Washing the car
- Lowering springs and polyurethane sway bar bushings: groan and moan
- custom mirrors
- Towing and mileage
- passenger seat
- My new (to me) 2007 HHR 1LT
- 2.2 or 2.4L and a few other questions.
- Daytime running lights.
- My 2018 June Calendar
- One light on at a time
- 2008 LT Panel needs a new engine at only 65k miles?
- more t-stat stuff
- Wrecked... But will be repaired :-)
- 2010 hhr
- HHR conversion into a camper
- After 40+ Years...
- Kentucky Cars
- 2008 HHR SS Option codes
- Drive-in Theater Car Show
- 2010 Chevy HHR Stereo or Speakers issues
- Fuel lines
- timing noise
- Battery light stuck on
- rear power window switch
- Seat Repair Help
- Just a thought
- Chevy HHR 2006, Key Cannot Be Removed, Stuck On
- Storage suggestions
- Working modification to increase cargo carrying capacity
- Only got 11 years on the original battery 2007 HHR
- Oil Filler tube leaks on 06
- Retrofitting larger capacity battery in HHR
- Fantastic Car
- AC Compressor Time
- What is the little round light for above the rearview mirror
- 2008 hhr ss
- finally got another
- Color question
- Looking to buy an HHR
- 0-60 time on a 2010 2.2L automatic?
- Canadian 2008 LT Panel 2.4L
- Tire Sensor Battery?
- Odometer Not advancing
- Cobalt radio swap?
- Moving HHR with no battery
- Looking to purchase 2010 HHR LT
- code p0017
- I bought another one!
- Seeking advice for replacing lower control arm
- Towing
- 06 HHR Crank No Run
- Rear Bumper Replacement
- Rock Auto discount
- Can I leave an AC adapter plugged in 24/7 as long as it's not charging anything?
- Pealing chrome on auto shifter
- Loose sunroof
- O2 (oxygen) sensors
- Red stripe down the side of my 2010 Chevy HHR LT
- 2007 hhr down for over 6 months
- Things to check after purchasing a used HHR
- HHR OEM wheel needed
- Upset (but I understand)
- 2011 remote start
- 2006 HHR Automatic problem
- Key Fob Programing for 2011 HHR
- Waterbased Paint Code
- Why it's hard to find the correct HHR parts.
- Why I like ChevyHHR.net
- 07 HHR with 2.4 swap questions
- Chevy rim upgrade?
- Sunroof after wind reflector removal
- First time service on Throttle Body/MAF Sensor
- 2009 LS - Keyless Entry???
- This might be following me home in about a month
- heater not turning on in my 2008 HHR
- Shake and Shimmy, cv axle or more
- Question about code p0315.
- Radio issues
- Removal of Rewiper
- fitting large items in back
- Axe body spray and a cig ligher vs HHR Panel
- Goof of the Month Article
- Power Steering Failure and Air Bag followed by no power.
- New Stereo, HHR has OnStar.
- Panel Rear Door Programing
- Thinking about going two tone on the hhr
- Vertical Doors
- Any value in original radio....
- RPMS go up and down while breaking.
- 2009 LS Panel TPMS problem
- Anyone use Quick Jack?
- What exhaust???
- We made the RockAuto forum of the Month!!
- reattaching door dust shields.
- bowties
- No Crank No Start Problem
- State With The Most HHRs?
- Traction control light; hard shift
- Big Props to CarMax
- Center cap
- RPMs in 5th gear
- Stopping by to say hi and a question for those who have been around
- GOODBYE CHEVYHHR.net
- Joey Martin Race Cars HHR
- Rarest HHR Future Collectable?
- Clunking hhr
- Seeking advice for timing chain tensioner replacement
- Stereo Woes
- I got my HHR back!
- Need some exhaust help
- dash lights are crazy
- Features of the HHR you may not have known
- Interesting Find
- Need orig fabric for pass & driver seats
