PDA
View Full Version : HHR SS
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14
  1. Help for my HHR SS 2010
  2. Need a new Clutch
  3. Clutch Replacement
  4. rough idle and running-my solution
  5. Time for a new car!
  6. Upgrade from 1LT to an SS !
  7. What is the right Timing Chain/Balance shaft, Water pump kit to get??
  8. How is the SS?
  9. 2nd question for SS owner's with Black and Grey interiors
  10. Question for SS owners
  11. What is best rotors for the ss
  12. Original HHR SS floor mat
  13. Who has the fastest automatic?
  14. Sway bar links
  15. Zfr performance turbo delivered!!
  16. Added a GM performance badge...
  17. Looking for aftermarket oil pressure send switch for SS
  18. Changing MAF sensor.
  19. Clutch upgrade?
  20. Back on board !
  21. Hot RodPower Tour 2015
  22. Timing chain tensioner
  23. Finally "got around to it"
  24. Installing SS Instrument Cluster In A LT
  25. 08 HHR SS - Project Overboard
  26. Lsd rpo
  27. 08 HHr ss feling a skip at 40 or so goon at high speeds
  28. Need a tune
  29. Where to start
  30. To sell or not to sell
  31. HHR SS Parts for Sale...
  32. Colors on hhr ss
  33. Big turbo and cams on an automatic
  34. old timer with a 09 ss
  35. PErformance chip
  36. Ok ..... on my Early 2.4 2LT GM installed
  37. injectors
  38. Discount Tire width limit
  39. stock airbox
  40. Heat Exchanger/Oil coolers on 2010 HHR SS Turbo's
  41. Horn options
  42. Just got backed into
  43. SS lower lip on eBay
  44. Muffler delete 2009 SS panel
  45. Fakers
  46. What size driving lights fit SS bumper?
  47. Rhetorical Q
  48. How to id Limited Slip with a bare transaxle
  49. New ECM Needed, Have Questions...
  50. Ss
  51. auto hhr ss dyno
  52. Map pocket (behind front drivers seat)
  53. Cincinnati
  54. Understanding laptop for Trifecta tune
  55. Getting new motor and turbo
  56. ss
  57. 08 ss.....issues after road trip
  58. ss 2010
  59. Wanting a little more sound
  60. It'SS Been Fun FolkSS...
  61. Test Drove my first SS, my observations
  62. SS Springs/Struts over Regular Ones
  63. New Shoe Options?
  64. I think I have found the HHR SS of my dreams...
  65. Thinking of Buying, what are the known issues?
  66. Panel SS production #
  67. Powell Racing YYZ V.5 Lowering Springs - Install/Review
  68. Check engine light incident - thoughts?
  69. It Was Bound to Happen
  70. front bumper change please help
  71. SS spoiler extension
  72. Lowering Spring options (Where to buy)
  73. HHR SS Auto: Transcooler
  74. Trade my 09 LT for 09 SS?
  75. Potential HHR SS Owner
  76. Intercooler
  77. Cancelling extended service contract
  78. Add LSD to hhr ss that did not have
  79. General performance
  80. Have a small issue with IC piping
  81. My new 09 SS
  82. Suggestions for a Big Turbo Build.
  83. Trifecta dealer in NY
  84. 2010 Chevy HHR SS (Bone Stock)
  85. gm chip
  86. 2008 hhr ss thoughts
  87. Headers
  88. Vacuum tank fail
  89. Bilstein struts & shocks
  90. New Shoes
  91. SS Side Skirt
  92. Can the Ecotec LTG (Gen 3) motor be used to replace the LNF (Gen 2) motor in my 08 SS
  93. Am I a Fool for Thinking of Purchasing...
  94. hhr ss 4t45e
  95. Heat issue
  96. losing air presure
  97. SS template sprayed on intercooler.
  98. Brake lines
  99. Belt slipping?
  100. silicone couplers for new bigger intercooler
  101. found a great Tuner
  102. Big Hiss
  103. Short shifter
  104. no lift shift
  105. The SS is hurt!! Please, lend me your ears...
  106. Need 2.0L Engine for my HHR SS
  107. Zzperformance catless downpipe
  108. Considering buying an SS. What to look for, what to avoid, etc?
  109. Purchased an 08 SS ... No boost gauge?
  110. Adding amp and subwoofer to my SS, help.
  111. Considering an HHR 5 spd.
  112. Problem after ignition switch recall
  113. turbo xs exhaust on hhr
  114. Question about GMTU w/ automatic trans
  115. Researching the SS
  116. Registry
  117. Turbo or not? :/
  118. Finally complete!
  119. Auto guys, Trans temp??
  120. Need info on buying a 2010 SS
  121. SS rear brake pad replacement
  122. Hhr ss production numbers
  123. Newbie
  124. weird request
  125. hhr ss front splitter
  126. OBD2/Torque HP estimate & 80mph+ Boost
  127. Looking for replacement RPD
  128. Picked up my 09 HHR SS Manual Today!!
  129. Gm rpo
  130. Rattle/clatter....valves?
  131. Good tire options from y'all down south?
  132. Question about boost
  133. Best SS Picture Thread
  134. Just a simple question
  135. HP Tuners
  136. TTR or Powell Sway Bar???
  137. ZZP tune= :)
  138. GM Transmission fluid
  139. What octane do y'all run
  140. Potential SSer questions
  141. E47 tune
  142. need to find a turbocharger
  143. Removing HHR SS Rear Spoiler
  144. high pitch whine on acceleration
  145. had to let the SS go
  146. Accessing the Subwoofer and AMP
  147. Oh Hai!
  148. 2008 HHR SS Limp Mode After Hitting Dirt Curb
  149. Cooling Fan Assembly Different in SS
  150. Motor Noise
  151. First oil change in "new to me" SS
  152. Wiring harness 2009 SS
  153. XM Installed?
  154. ZFR Turbo?
  155. Boost Gauge Question
  156. mechanic in Denver?
  157. Air Intake issues
  158. Towing with an SS
  159. SS emblem
  160. help
  161. VIN Request - GMS1 - 2008, Auto, Vacuum Pump
  162. Goodbye HHR SS... Hello Blue SKY
  163. The HHR SS finally finish!! Matte blue baby!!
  164. GF Performance chip...
  165. Brought in for service, wrong sensor on intercooler pipe?
  166. Diamond in the ROUGH?!
  167. Hi, new HHR SS owner...
  168. Intermittent Misfire under load
  169. New to the HHR SS, slight overheating issue
  170. Differential fluid, Manual trans?
  171. normal boost VAC/press
  172. Best fit tune for 09 auto
  173. Best Place To Get Parts For HHR SS
  174. Adding RPD
  175. Brakes in the morning
  176. Help Performance Display
  177. Finally got an SS
  178. Front Struts?
  179. gas pedal question
  180. larger fuel pump and injectors?
  181. Building a Stealth exhaust system for a HHR SS
  182. UPDATE: I've changed my 'light-weight' rotor selection
  183. Finally get to play with the SS
  184. Anybody running a 3bar Map sensor?
  185. Basics of How a Tune Works on a HHR SS
  186. Review of different tune options, on the dyno, & at the track…
  187. In Need of Summer Tires
  188. Making Performance Progress On My Buggy
  189. tire recommendations
  190. Adding Trailer Hitch to SS WITHOUT Trimming Bumper
  191. 2010 SS clutch replacement?
  192. GMTU only getting 17psi...
  193. A plan, a goal, a dream...realized.
  194. Miss my hhrss
  195. Gutted 2nd Cat
  196. Experience with K&N after GMTU?
  197. My Editorial: Our HHR SS...Keeping Up In Today's World
  198. 2008, 2009, 2010 HHR SS's
  199. What to look for on a higher mileage SS
  200. Thinking of purchasing a HHR SS..
  201. door rubs fender
  202. Treadstone cold air
  203. Cam for 09 ss hhr
  204. 6 years ago
  205. F35 Transmission
  206. Cost of a complete brake job on HHR SS with brembos
  207. Cooper Tires for Chevy HHR SS
  208. Lower intercooler piping repair
  209. SS wheel stud diameter?
  210. Best available tuner option?
  211. Megan muffler or stock muffler?
  212. Where to get SS tuned in Southern California
  213. Proud New Owner of HHR SS - With Facts and Questions
  214. GMTU Boost fluctuations
  215. BF Goodrich
  216. Brand New LNF's
  217. german hhr ss
  218. Looking to be an hhr ss owner-have questions
  219. Upgrades
  220. New SS Owner with some questions
  221. Tire Pressure Monitoring System
  222. Auto tranny guys..what fluid do you use?
  223. What gains did you see from upgrading your intercooler?
  224. First performance mods...
  225. Trying to find an SS...
  226. Anyone looking for SS in the southwest?
  227. HHR SS without a sun roof?
  228. ZZP HHR SS dual gauge A pillar
  229. Ext Warr ques from proud new owner of 2009
  230. Joining the family :)
  231. Pioneer stock head unit
  232. Going to sell my '08 SS sadly... Have a few questions though!
  233. Difference with Calif SS performance?
  234. LNF Lower ChargePipe from ZZP Concern
  235. Getting a little discouraged...
  236. optima battery
  237. Turbo Upgrade Install Dealer recommendation DC/Balt area?
  238. ZZPerformance Reflash
  239. Why is it signifigant to the 0-60 and 1/4 times to have a rear sway bar upgrad?
  240. Speedo cluster lens
  241. 2009 hhr windshield wiper problem
  242. Dragon Pics
  243. Do you ever regret driving your HHR in the winter with the salt and all
  244. Dyno sheet
  245. Drilled and Slotted rotors
  246. Saying Hello
  247. No Flash Logger on our cars?
  248. Warranty work with Trifecta Stealth Tune
  249. How to install BOV?
  250. Brembo Upgrade
