PDA
View Full Version : HHR SS
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14
  1. Hhr temperature question
  2. My Red Panel SS on Ebay!
  3. Under boost!!!! WTF!!!!
  4. knock sensor help please
  5. Caliper question
  6. Cooling Fan Running After Turning Car Off?
  7. Check Engine Light 2010 HHR SS
  8. Check List for HHR SS
  9. Center cap
  10. New member, just got a panel SS
  11. Wheel well insulation
  12. Charge system light
  13. New to this forum, Question
  14. Lower Control Arms
  15. Front rotor and brake question
  16. LDK Build 2.0
  17. Boost gauge still available from Gm
  18. Backup stock tune?
  19. HHRs in the One Lap Of America race
  20. Front splitter
  21. Finally got it 09 quarter panel ss!!
  22. Boneyard SS in Tulsa
  23. SS front struts/springs
  24. SS Turbo pistons
  25. FQ7 4.05 final drive transaxle
  26. Advice from you current owners I'm looking at a specific vehicle and have some questi
  27. Service Air Bag
  28. Does anyone have production figures for the SS by exterior color
  29. What's your highway gas mileage ?
  30. Decode VIN Help
  31. Dashcontrol obdii display in dic
  32. SS interior question
  33. 09 Front end noise over bumps
  34. Pennzoil Euro L hard to find
  35. Whats the differance between SS and LT radiators?
  36. Hhr ss catback differences
  37. New Wizard Cooling radiator install
  38. HHR-SS show
  39. Honing Cylinder Liners
  40. Are SS transmissions different?
  41. fuel line leaks
  42. SS Auto
  43. Valve Lapping
  44. shift sensor
  45. SS cooling fan question?
  46. Turbo Rebuild
  47. 6-speed auto trans
  48. Low tire air
  49. Looking for some advice
  50. Great Pic from the past-09HHR Panel SS
  51. HHR SS at Nurburgring: 11 years ago
  52. Opinions on TWM 5 sp BShifter
  53. My 2011 Panel SS Clone in finished!
  54. P0017-p0090-p0341-p0128
  55. License plate mount
  56. ZZP downpipe first mod?
  57. Towing
  58. Hiya! New member here
  59. Boost help
  60. Fuel injectors
  61. 2009 Owners manual in 2008 HHR-SS
  62. Should I buy an SS with a bad turbo?
  63. Highest mileage HHR SS
  64. 7163 turbo and auto trans ?
  65. Suspension is Toast!
  66. Looking at buying 09SS
  67. Ss auto transmission mounts torque specs.
  68. SS Pre Start Fuel Pressure Observation
  69. Performance Discussion
  70. My '08 HHR SS just turned....
  71. 2007 hhr ls brake issues
  72. Thoughts on Dura Last Brake Pads?
  73. Reduced eng performance
  74. Traction bars
  75. I just scored this 2008 SS HHR!
  76. lost ground wire need need help finding a home
  77. SS for sale, Bullhead City, AZ
  78. How many aqua metallic 2009 hhr ss turbos made?
  79. HHR SS mods
  80. 09 SS Turbo out
  81. Trans Mount Preferences/Advice - ZZP? TTR?
  82. SS Motor Question
  83. Well got it home tonight 09 ss panel
  84. HHR SS Fuel Pressure
  85. timing chain kit
  86. HHR Fuel pressure
  87. Reprogramming 2008 FOB
  88. Clutch suggestions ?
  89. ss dash gauge
  90. Need the A-Pillar
  91. HHR SS Sway Bar
  92. RPD Usefulness?
  93. HHR SS Sparkplug Witchcraft....LOL
  94. Exact HP and TQ number for the Auto SS?
  95. Coolant temp and Heater usage relation
  96. Skirts or Moulding?
  97. Have you ever seen this color
  98. Low oil pressure??!!
  99. A piece missing?!
  100. Personalized Plate
  101. testing back in 2002 that was the ground-work for our 2.0 turbo LNF
  102. Lower charge pipe replacement.
  103. This is the only oil that you should use in your HHR SS !!!
  104. Soldered in MAP sensor, but still have intermittent boost issues
  105. GM 15938134 SS Auto CV Half Shaft
  106. intermittent random misfires
  107. Adding LSD to non-LSD car
  108. Fluttering noise under boost
  109. Dealer Flash
  110. New to Turbo
  111. 2009 hhr
  112. Need help...Again
  113. Thoughts on this hhr ss?
  114. Lower T-Map wiring issue
  115. hhr ss lowering kit ?
  116. Too much oil in the engine on accident
  117. SS Engine took a dump
  118. 2010 HHR SS Turbo hates humidity?
  119. Waste gate dump
  120. HHR 2010 Engine Fan won't shut off
  121. New member, long time GM owner
  122. Break-in oil
  123. Expansion tank hose
  124. EBay Radiator?
  125. Hhr ss cams
  126. Black halo/Angel eye headlights and led taillights
  127. How to get the air out of the cooling system
  128. Help! Chevy HHR SS needs an engine
  129. New 2009 HHR SS Owner
  130. HHR SS Half Panel
  131. New owner here...
  132. New YouTube Channel for my SS Build
  133. Phoenix Shops
  134. Looking at buying an 09 HHR SS
  135. zfr6758 on auto
  136. Boost lag?
  137. 2017 value of HHR SS panel vans
  138. 1/4 mile seems way too slow
  139. Fastest van on the track!
  140. Newbie needs help
  141. Fuel in oil (a lot) with new LDK motor
  142. Hhr ss axle nut?
  143. Hi all... I'm back! Back in the SS game...
  144. f35 mu3 transmission
  145. Just about ready to pull the trigger on an HP Tuner...
  146. Getting rid of my Trifecta tune?
  147. HHR SS missing hesitate when using tune
  148. Where do you put your phone?!?!?
  149. Brembo Brake Pad Options
  150. Hhr ss for a 16 year old girl
  151. P0016 Code issues
  152. 2008 hhr ss not making boost
  153. New Owner, Couple of Questions
  154. SS struggles to start and then runs for 4 secs then dies. Help!!!
  155. Factory subwoofer
  156. 08 HHR ss help!!
  157. Remote start, grind, clunk...car doesn't start
  158. Losing coolant, but temp stays normal
  159. Another completed LDK swap
  160. red color
  161. Turbo upgrade
  162. HHR SS injector size
  163. RPM Motorsports in AZ
  164. Made a Cold Start video
  165. Need some help buying the right (K04)Turbo rebuild kit!
  166. SS won't run
  167. flywheel
  168. Boost issues
  169. HHR SS sudden overheating
  170. Trifecta adjustable launch control setting question...
  171. clutch kit
  172. trifecta from one 2010 SS to a another 2010SS
  173. Front and rear engine mount torque specs
  174. Pillar boost gauge
  175. Wastegate rod
  176. Wastegate
  177. touch up paint
  178. 15938134 is off national back order, axle for SS auto
  179. Control arm rebuild?
  180. long time no post
  181. HHR SS AA5
  182. Boost Issues and ignition off Boost reading
  183. 2010 ss full suspension upgrade?
  184. HPT Where do I start?
  185. Factory Plug from harness to module
  186. HHR SS overheating
  187. Newbie needs help 2.0 turbo exhaust
  188. Traction Control Warning
  189. Best exhaust upgrades for your buck ?
  190. HHR SS finally lowered!
  191. Seized LNF to completed LDK
  192. HHR SS 17" wheels
  193. Odd Sounds while boost is above 10 psi
  194. NO Boost
  195. Brembo Brakes
  196. Newbie With Turbos/Timing Chain and Upgraded Cams
  197. HHR SS in Gm EFI magazine
  198. 3 Things in 2 weeks :(
  199. Getting my ss back tomorrow
  200. HHR SS turbo replacement how to?
  201. FE5 Control Arms Part #
  202. Looking at picking up an HHR/SS
  203. How fast will your SS go?
  204. In-channel sun/rain/wind guard shade deflector window visors 2006-2011 chevy hhr
  205. Timing chain jump story (long)
  206. Nose piece
  207. Clutch Replacement
  208. Friday Not a fun day! Head Gasket failure.
  209. Moving On
  210. Temperature
  211. A couple more "newbie" questions for the SS owners...
  212. Ttr rear sway bar
  213. RPD Accuracy?
  214. Disappointing dyno post modifications; comments?
  215. Prewired ss for factory subwoofer ???
  216. Towing HHR with manual tranny
  217. Bought wrecked red ss 2008 anyone from here
  218. MAP Sensor Upgrade
  219. How do you manually turn with an automatic?
  220. Additives safe for E10 type fuel
  221. LDK build
  222. In need of clutch
  223. Question about Engine sound.
  224. Resale Value of 2009 SS 5 speed
  225. Best tuner ???
  226. P2188 and General Question
  227. 09 SS AA5 sp5 100K all options worth today
  228. CAI and Tune
  229. Question about seats, what are these?
  230. Am I Missing Something ???
  231. 09 ss blown engine swapped motors now a few small issues
  232. Electrical issue
  233. Rim blades
  234. OBD2 Performance Chip Tuning Box, Good ...Bad?
  235. Set this code: P0221
  236. Values for '08 HHR SS
  237. Hhr ss 2010
  238. Traction needed...
  239. HHR SS and pot holes and other road imperfections, is this normal?
  240. Bow Tie
  241. create more hp for auto ss
  242. 2008 HHR SS, Seat Covers
  243. Turbo trouble
  244. Is This Time for real?? and does anyone know who this is!!!
  245. Anyone put a lot of miles on their SS? With Trifecta tune?
  246. 2008 HHR SS transmission upgrades
  247. Just traded my LS for an SS. Couple things wrong with it!!!
  248. Drag Radials
  249. Gotta sell the Gray Ghost! :-(
  250. Silver HHR SS half panel in tampa
